root/Development/ray/src/px/x11raster.h
Revision: 2.5
Committed: Fri May 20 02:06:39 2011 UTC (14 years, 7 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, HEAD
# User Rev Content
1 greg 2.5 /* RCSid: $Id: x11raster.h,v 2.4 2004/03/28 20:33:14 schorsch Exp $ */
2 greg 1.1 /*
3     * x11raster.h - header file for X routines using images.
4     *
5     * 3/1/90
6     */
7 schorsch 2.3 #ifndef _RAD_X11RASTER_H_
8     #define _RAD_X11RASTER_H_
9
10     #ifdef __cplusplus
11     extern "C" {
12     #endif
13
14 greg 1.1
15     typedef struct {
16     Display *disp; /* the display */
17     int screen; /* the screen */
18     Visual *visual; /* pointer to visual used */
19     XImage *image; /* the X image */
20     GC gc; /* private graphics context */
21     int ncolors; /* number of colors */
22     XColor *cdefs; /* color definitions */
23     short *pmap; /* inverse pixel mapping */
24     unsigned long *pixels; /* allocated table entries */
25     Colormap cmap; /* installed color map */
26     Pixmap pm; /* storage on server side */
27     } XRASTER;
28
29 schorsch 2.4 extern Colormap newcmap(Display *disp, int scrn, Visual *vis);
30 greg 2.5 extern int init_rcolors(XRASTER *xr, uby8 cmap[][3]);
31 schorsch 2.4 extern unsigned long * map_rcolors(XRASTER *xr, Window w);
32     extern Pixmap make_rpixmap(XRASTER *xr, Window w);
33     extern XRASTER * make_raster( Display *disp, XVisualInfo *vis,
34     int npixbits, char *data, int width, int height, int bm_pad);
35     extern void patch_raster(Drawable d, int xsrc, int ysrc,
36     int xdst, int ydst, int width, int height, register XRASTER *xr);
37     extern void unmap_rcolors(XRASTER *xr);
38     extern void free_rpixmap(XRASTER *xr);
39     extern void free_raster(XRASTER *xr);
40 greg 1.1
41 greg 1.2 #define put_raster(d,xdst,ydst,xr) patch_raster(d,0,0,xdst,ydst, \
42 greg 1.1 (xr)->image->width,(xr)->image->height,xr)
43 schorsch 2.3
44     #ifdef __cplusplus
45     }
46     #endif
47     #endif /* _RAD_X11RASTER_H_ */
48
