| 1 |
/* RCSid: $Id: x11raster.h,v 2.3 2003/07/14 22:24:00 schorsch Exp $ */ |
| 2 |
| 3 |
 * x11raster.h - header file for X routines using images. |
| 4 |
| 5 |
 *      3/1/90 |
| 6 |
| 7 |
#ifndef _RAD_X11RASTER_H_ |
| 8 |
#define _RAD_X11RASTER_H_ |
| 9 |
| 10 |
#ifdef __cplusplus |
| 11 |
extern "C" { |
| 12 |
#endif |
| 13 |
| 14 |
| 15 |
typedef struct { |
| 16 |
        Display *disp;                          /* the display */ |
| 17 |
        int     screen;                         /* the screen */ |
| 18 |
        Visual  *visual;                        /* pointer to visual used */ |
| 19 |
        XImage  *image;                         /* the X image */ |
| 20 |
        GC      gc;                             /* private graphics context */ |
| 21 |
        int     ncolors;                        /* number of colors */ |
| 22 |
        XColor  *cdefs;                         /* color definitions */ |
| 23 |
        short   *pmap;                          /* inverse pixel mapping */ |
| 24 |
        unsigned long   *pixels;                /* allocated table entries */ |
| 25 |
        Colormap        cmap;                   /* installed color map */ |
| 26 |
        Pixmap  pm;                             /* storage on server side */ |
| 27 |
}       XRASTER; |
| 28 |
| 29 |
extern Colormap newcmap(Display *disp, int      scrn, Visual    *vis); |
| 30 |
extern int init_rcolors(XRASTER *xr, BYTE       cmap[][3]); |
| 31 |
extern unsigned long * map_rcolors(XRASTER      *xr, Window     w); |
| 32 |
extern Pixmap make_rpixmap(XRASTER      *xr, Window     w); |
| 33 |
extern XRASTER * make_raster( Display   *disp, XVisualInfo      *vis, |
| 34 |
        int     npixbits, char  *data, int      width, int height, int  bm_pad); |
| 35 |
extern void patch_raster(Drawable       d, int  xsrc, int       ysrc, |
| 36 |
        int     xdst, int       ydst, int       width, int      height, register XRASTER        *xr); |
| 37 |
extern void unmap_rcolors(XRASTER *xr); |
| 38 |
extern void free_rpixmap(XRASTER *xr); |
| 39 |
extern void free_raster(XRASTER *xr); |
| 40 |
| 41 |
#define put_raster(d,xdst,ydst,xr) patch_raster(d,0,0,xdst,ydst, \ |
| 42 |
                                (xr)->image->width,(xr)->image->height,xr) |
| 43 |
| 44 |
| 45 |
| 46 |
#endif |
| 47 |
#endif /* _RAD_X11RASTER_H_ */ |
| 48 |
