| 1 |
/* RCSid: $Id: x11raster.h,v 2.3 2003/07/14 22:24:00 schorsch Exp $ */
| 2 |
| 3 |
* x11raster.h - header file for X routines using images.
| 4 |
| 5 |
* 3/1/90
| 6 |
| 7 |
#ifndef _RAD_X11RASTER_H_
| 8 |
#define _RAD_X11RASTER_H_
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
| 14 |
| 15 |
typedef struct {
| 16 |
Display *disp; /* the display */
| 17 |
int screen; /* the screen */
| 18 |
Visual *visual; /* pointer to visual used */
| 19 |
XImage *image; /* the X image */
| 20 |
GC gc; /* private graphics context */
| 21 |
int ncolors; /* number of colors */
| 22 |
XColor *cdefs; /* color definitions */
| 23 |
short *pmap; /* inverse pixel mapping */
| 24 |
unsigned long *pixels; /* allocated table entries */
| 25 |
Colormap cmap; /* installed color map */
| 26 |
Pixmap pm; /* storage on server side */
| 27 |
} XRASTER;
| 28 |
| 29 |
extern Colormap newcmap(Display *disp, int scrn, Visual *vis);
| 30 |
extern int init_rcolors(XRASTER *xr, BYTE cmap[][3]);
| 31 |
extern unsigned long * map_rcolors(XRASTER *xr, Window w);
| 32 |
extern Pixmap make_rpixmap(XRASTER *xr, Window w);
| 33 |
extern XRASTER * make_raster( Display *disp, XVisualInfo *vis,
| 34 |
int npixbits, char *data, int width, int height, int bm_pad);
| 35 |
extern void patch_raster(Drawable d, int xsrc, int ysrc,
| 36 |
int xdst, int ydst, int width, int height, register XRASTER *xr);
| 37 |
extern void unmap_rcolors(XRASTER *xr);
| 38 |
extern void free_rpixmap(XRASTER *xr);
| 39 |
extern void free_raster(XRASTER *xr);
| 40 |
| 41 |
#define put_raster(d,xdst,ydst,xr) patch_raster(d,0,0,xdst,ydst, \
| 42 |
(xr)->image->width,(xr)->image->height,xr)
| 43 |
| 44 |
#ifdef __cplusplus
| 45 |
| 46 |
#endif
| 47 |
#endif /* _RAD_X11RASTER_H_ */
| 48 |
