root/radiance/ray/src/px/x11raster.c
Diff to previous 2.13 , to selected 2.3
Changes since 2.12: +55 -38 lines
Diff to previous 2.12 , to selected 2.3
Diff to previous 2.11 , to selected 2.3
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.3
Changes since 2.9: +7 -12 lines
Diff to previous 2.9 , to selected 2.3
Wed Nov 23 14:24:32 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.8: +7 -8 lines
fixed unnecessary color table allocation
Mon Jul 19 15:18:10 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.7: +2 -0 lines
fixes for DEC Alpha running OSF (sizeof long == 8)
Mon Oct 12 14:52:19 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.6: +7 -6 lines
changed from ciq to clrtab routines
Thu May 28 09:39:22 1992 UTC (32 years ago) by greg
Changes since 2.5: +9 -6 lines
further refinements for grayscale and odd devices
Wed May 27 14:28:54 1992 UTC (32 years ago) by greg
Changes since 2.4: +36 -38 lines
fixes for different display types
Tue May 19 14:22:50 1992 UTC (32 years ago) by greg
Changes since 2.3: +8 -5 lines
Did I fix 24-bit color this time?  Who knows.
Tue May 19 13:10:07 1992 UTC (32 years ago) by greg
Changes since 2.2: +5 -2 lines
fixed 24-bit byte ordering with hack for bitmaps
Thu May 14 08:58:23 1992 UTC (32 years, 1 month ago) by greg
fixed byte-ordering on some 24-bit displays?
Tue Nov 12 16:04:59 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.3
Tue Oct 29 16:21:37 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.3: +6 -1 lines
Diff to previous 1.3 , to selected 2.3
put in a hack for 32-bit DirectColor servers
Fri Mar 2 12:22:42 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +61 -18 lines
Diff to previous 1.2 , to selected 2.3
final bug fixes, working version of x11image
Thu Mar 1 18:13:34 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.1: +33 -1 lines
Diff to previous 1.1 , to selected 2.3
Various bug fixes
Thu Mar 1 13:18:23 1990 UTC (34 years, 3 months ago) by greg
Diff to selected 2.3
