1 |
/* Copyright (c) 1990 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* x11image.c - driver for X-windows |
9 |
10 |
* 3/1/90 |
11 |
12 |
13 |
14 |
* Modified for X11 |
15 |
16 |
* January 1990 |
17 |
18 |
* Anat Grynberg and Greg Ward |
19 |
20 |
21 |
22 |
#include "standard.h" |
23 |
24 |
#include <X11/Xlib.h> |
25 |
#include <X11/cursorfont.h> |
26 |
#include <X11/Xutil.h> |
27 |
28 |
#include "color.h" |
29 |
#include "view.h" |
30 |
#include "pic.h" |
31 |
#include "x11raster.h" |
32 |
#include "random.h" |
33 |
34 |
#define FONTNAME "8x13" /* text font we'll use */ |
35 |
36 |
#define CTRL(c) ('c'-'@') |
37 |
38 |
#define BORWIDTH 5 /* border width */ |
39 |
40 |
#define ourscreen DefaultScreen(thedisplay) |
41 |
#define ourblack BlackPixel(thedisplay,ourscreen) |
42 |
#define ourwhite WhitePixel(thedisplay,ourscreen) |
43 |
#define ourroot RootWindow(thedisplay,ourscreen) |
44 |
#define ourgc DefaultGC(thedisplay,ourscreen) |
45 |
46 |
#define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras) |
47 |
48 |
double gamcor = 2.2; /* gamma correction */ |
49 |
50 |
int dither = 1; /* dither colors? */ |
51 |
int fast = 0; /* keep picture in Pixmap? */ |
52 |
53 |
Window wind = 0; /* our output window */ |
54 |
Font fontid; /* our font */ |
55 |
56 |
int maxcolors = 0; /* maximum colors */ |
57 |
int greyscale = 0; /* in grey */ |
58 |
59 |
int scale = 0; /* scalefactor; power of two */ |
60 |
61 |
int xoff = 0; /* x image offset */ |
62 |
int yoff = 0; /* y image offset */ |
63 |
64 |
VIEW ourview = STDVIEW; /* image view parameters */ |
65 |
int gotview = 0; /* got parameters from file */ |
66 |
67 |
COLR *scanline; /* scan line buffer */ |
68 |
69 |
int xmax, ymax; /* picture resolution */ |
70 |
int width, height; /* window size */ |
71 |
char *fname = NULL; /* input file name */ |
72 |
FILE *fin = stdin; /* input file */ |
73 |
long *scanpos = NULL; /* scan line positions in file */ |
74 |
int cury = 0; /* current scan location */ |
75 |
76 |
double exposure = 1.0; /* exposure compensation used */ |
77 |
78 |
XRASTER *ourras; /* our stored image */ |
79 |
unsigned char *ourdata; /* our image data */ |
80 |
81 |
struct { |
82 |
int xmin, ymin, xsiz, ysiz; |
83 |
} box = {0, 0, 0, 0}; /* current box */ |
84 |
85 |
char *geometry = NULL; /* geometry specification */ |
86 |
87 |
char *progname; |
88 |
89 |
char errmsg[128]; |
90 |
91 |
extern long ftell(); |
92 |
93 |
extern char *malloc(), *calloc(); |
94 |
95 |
extern double atof(), pow(), log(); |
96 |
97 |
Display *thedisplay; |
98 |
99 |
main(argc, argv) |
100 |
int argc; |
101 |
char *argv[]; |
102 |
103 |
int headline(); |
104 |
int i; |
105 |
106 |
progname = argv[0]; |
107 |
108 |
for (i = 1; i < argc; i++) |
109 |
if (argv[i][0] == '-') |
110 |
switch (argv[i][1]) { |
111 |
case 'c': |
112 |
maxcolors = atoi(argv[++i]); |
113 |
break; |
114 |
case 'b': |
115 |
greyscale = !greyscale; |
116 |
break; |
117 |
case 'm': |
118 |
maxcolors = 2; |
119 |
break; |
120 |
case 'd': |
121 |
dither = !dither; |
122 |
break; |
123 |
case 'f': |
124 |
fast = !fast; |
125 |
break; |
126 |
case 'e': |
127 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
128 |
goto userr; |
129 |
scale = atoi(argv[++i]); |
130 |
break; |
131 |
case 'g': |
132 |
if (!strcmp(argv[i], "-geometry")) |
133 |
geometry = argv[++i]; |
134 |
else |
135 |
gamcor = atof(argv[++i]); |
136 |
break; |
137 |
default: |
138 |
goto userr; |
139 |
140 |
else if (argv[i][0] == '=') |
141 |
geometry = argv[i]; |
142 |
else |
143 |
break; |
144 |
145 |
if (i == argc-1) { |
146 |
fname = argv[i]; |
147 |
fin = fopen(fname, "r"); |
148 |
if (fin == NULL) { |
149 |
sprintf(errmsg, "can't open file \"%s\"", fname); |
150 |
quiterr(errmsg); |
151 |
152 |
} else if (i != argc) |
153 |
goto userr; |
154 |
/* get header */ |
155 |
getheader(fin, headline); |
156 |
/* get picture dimensions */ |
157 |
if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) |
158 |
quiterr("bad picture size"); |
159 |
/* set view parameters */ |
160 |
if (gotview && setview(&ourview) != NULL) |
161 |
gotview = 0; |
162 |
if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL) |
163 |
quiterr("out of memory"); |
164 |
165 |
init(); /* get file and open window */ |
166 |
167 |
for ( ; ; ) |
168 |
getevent(); /* main loop */ |
169 |
userr: |
170 |
fprintf(stderr, |
171 |
"Usage: %s [-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n", |
172 |
progname); |
173 |
quit(1); |
174 |
175 |
176 |
177 |
headline(s) /* get relevant info from header */ |
178 |
char *s; |
179 |
180 |
static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL}; |
181 |
register char **an; |
182 |
183 |
if (isexpos(s)) |
184 |
exposure *= exposval(s); |
185 |
else |
186 |
for (an = altname; *an != NULL; an++) |
187 |
if (!strncmp(*an, s, strlen(*an))) { |
188 |
if (sscanview(&ourview, s+strlen(*an)) > 0) |
189 |
gotview++; |
190 |
return; |
191 |
192 |
193 |
194 |
195 |
init() /* get data and open window */ |
196 |
197 |
XSizeHints oursizhints; |
198 |
register int i; |
199 |
200 |
if (fname != NULL) { |
201 |
scanpos = (long *)malloc(ymax*sizeof(long)); |
202 |
if (scanpos == NULL) |
203 |
goto memerr; |
204 |
for (i = 0; i < ymax; i++) |
205 |
scanpos[i] = -1; |
206 |
207 |
if ((thedisplay = XOpenDisplay(NULL)) == NULL) |
208 |
quiterr("can't open display; DISPLAY variable set?"); |
209 |
wind = XCreateSimpleWindow(thedisplay, |
210 |
ourroot, 0, 0, xmax, ymax, BORWIDTH, ourblack, ourwhite); |
211 |
if (wind == 0) |
212 |
quiterr("can't create window"); |
213 |
if (maxcolors == 0) { /* get number of available colors */ |
214 |
i = DisplayPlanes(thedisplay,ourscreen); |
215 |
maxcolors = i > 8 ? 256 : 1<<i; |
216 |
if (maxcolors > 4) maxcolors -= 2; |
217 |
218 |
fontid = XLoadFont(thedisplay, FONTNAME); |
219 |
if (fontid == 0) |
220 |
quiterr("can't get font"); |
221 |
XSetFont(thedisplay, ourgc, fontid); |
222 |
XStoreName(thedisplay, wind, fname == NULL ? progname : fname); |
223 |
XDefineCursor(thedisplay, wind, XCreateFontCursor(thedisplay, |
224 |
XC_diamond_cross)); |
225 |
if (geometry != NULL) { |
226 |
bzero((char *)&oursizhints, sizeof(oursizhints)); |
227 |
i = XParseGeometry(geometry, &oursizhints.x, &oursizhints.y, |
228 |
&oursizhints.width, &oursizhints.height); |
229 |
if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue)) |
230 |
oursizhints.flags |= USSize; |
231 |
else { |
232 |
oursizhints.width = xmax; |
233 |
oursizhints.height = ymax; |
234 |
oursizhints.flags |= PSize; |
235 |
236 |
if ((i&(XValue|YValue)) == (XValue|YValue)) { |
237 |
oursizhints.flags |= USPosition; |
238 |
if (i & XNegative) |
239 |
oursizhints.x += DisplayWidth(thedisplay, |
240 |
ourscreen)-1-oursizhints.width-2*BORWIDTH; |
241 |
if (i & YNegative) |
242 |
oursizhints.y += DisplayHeight(thedisplay, |
243 |
ourscreen)-1-oursizhints.height-2*BORWIDTH; |
244 |
245 |
XSetNormalHints(thedisplay, wind, &oursizhints); |
246 |
247 |
/* store image */ |
248 |
getras(); |
249 |
XSelectInput(thedisplay, wind, ButtonPressMask|ButtonReleaseMask |
250 |
|ButtonMotionMask|StructureNotifyMask |
251 |
|KeyPressMask|ExposureMask); |
252 |
XMapWindow(thedisplay, wind); |
253 |
return; |
254 |
memerr: |
255 |
256 |
} /* end of init */ |
257 |
258 |
259 |
quiterr(err) /* print message and exit */ |
260 |
char *err; |
261 |
262 |
if (err != NULL) { |
263 |
fprintf(stderr, "%s: %s\n", progname, err); |
264 |
exit(1); |
265 |
266 |
exit(0); |
267 |
268 |
269 |
270 |
eputs(s) |
271 |
char *s; |
272 |
273 |
fputs(s, stderr); |
274 |
275 |
276 |
277 |
quit(code) |
278 |
int code; |
279 |
280 |
exit(code); |
281 |
282 |
283 |
284 |
getras() /* get raster file */ |
285 |
286 |
colormap ourmap; |
287 |
XVisualInfo vinfo; |
288 |
289 |
if (maxcolors <= 2) { /* monochrome */ |
290 |
ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8)); |
291 |
if (ourdata == NULL) |
292 |
goto fail; |
293 |
ourras = make_raster(thedisplay, ourscreen, 1, ourdata, |
294 |
xmax, ymax, 8); |
295 |
if (ourras == NULL) |
296 |
goto fail; |
297 |
getmono(); |
298 |
} else if (XMatchVisualInfo(thedisplay,ourscreen,24,TrueColor,&vinfo)) { |
299 |
ourdata = (unsigned char *)malloc(xmax*ymax*3); |
300 |
301 |
goto fail; |
302 |
ourras = make_raster(thedisplay, ourscreen, 24, ourdata, |
303 |
xmax, ymax, 8); |
304 |
305 |
goto fail; |
306 |
getfull(); |
307 |
} else { |
308 |
ourdata = (unsigned char *)malloc(xmax*ymax); |
309 |
310 |
goto fail; |
311 |
ourras = make_raster(thedisplay, ourscreen, 8, ourdata, |
312 |
xmax, ymax, 8); |
313 |
314 |
goto fail; |
315 |
if (greyscale) |
316 |
biq(dither,maxcolors,1,ourmap); |
317 |
else |
318 |
ciq(dither,maxcolors,1,ourmap); |
319 |
if (init_rcolors(ourras, ourmap[0], ourmap[1], ourmap[2]) == 0) |
320 |
goto fail; |
321 |
322 |
return; |
323 |
fail: |
324 |
quit("could not create raster image"); |
325 |
326 |
327 |
328 |
getevent() /* process the next event */ |
329 |
330 |
union { |
331 |
XEvent u; |
332 |
XConfigureEvent c; |
333 |
XExposeEvent e; |
334 |
XButtonPressedEvent b; |
335 |
XKeyPressedEvent k; |
336 |
} e; |
337 |
338 |
XNextEvent(thedisplay, &e.u); |
339 |
switch (e.u.type) { |
340 |
case KeyPress: |
341 |
docom(&e.k); |
342 |
break; |
343 |
case ConfigureNotify: |
344 |
width = e.c.width; |
345 |
height = e.c.height; |
346 |
break; |
347 |
case MapNotify: |
348 |
map_rcolors(ourras, wind); |
349 |
if (fast) |
350 |
make_rpixmap(ourras); |
351 |
break; |
352 |
case UnmapNotify: |
353 |
unmap_rcolors(ourras); |
354 |
break; |
355 |
case Expose: |
356 |
redraw(e.e.x, e.e.y, e.e.width, e.e.height); |
357 |
break; |
358 |
case ButtonPress: |
359 |
if (e.b.state & (ShiftMask|ControlMask)) |
360 |
moveimage(&e.b); |
361 |
else |
362 |
getbox(&e.b); |
363 |
break; |
364 |
365 |
366 |
367 |
368 |
docom(ekey) /* execute command */ |
369 |
XKeyPressedEvent *ekey; |
370 |
371 |
char buf[80]; |
372 |
COLOR cval; |
373 |
XColor cvx; |
374 |
int com, n; |
375 |
double comp; |
376 |
FVECT rorg, rdir; |
377 |
378 |
n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL); |
379 |
if (n == 0) |
380 |
return(0); |
381 |
com = buf[0]; |
382 |
switch (com) { /* interpret command */ |
383 |
case 'q': |
384 |
case CTRL(D): /* quit */ |
385 |
quit(0); |
386 |
case '\n': |
387 |
case '\r': |
388 |
case 'l': |
389 |
case 'c': /* value */ |
390 |
if (avgbox(cval) == -1) |
391 |
return(-1); |
392 |
switch (com) { |
393 |
case '\n': |
394 |
case '\r': /* radiance */ |
395 |
sprintf(buf, "%.3f", intens(cval)/exposure); |
396 |
break; |
397 |
case 'l': /* luminance */ |
398 |
sprintf(buf, "%.0fn", bright(cval)*683.0/exposure); |
399 |
break; |
400 |
case 'c': /* color */ |
401 |
comp = pow(2.0, (double)scale); |
402 |
sprintf(buf, "(%.2f,%.2f,%.2f)", |
403 |
colval(cval,RED)*comp, |
404 |
colval(cval,GRN)*comp, |
405 |
colval(cval,BLU)*comp); |
406 |
break; |
407 |
408 |
XDrawImageString(thedisplay, wind, ourgc, |
409 |
box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); |
410 |
return(0); |
411 |
case 'i': /* identify (contour) */ |
412 |
if (ourras->pixels == NULL) |
413 |
return(-1); |
414 |
n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)]; |
415 |
n = ourras->pmap[n]; |
416 |
cvx.pixel = ourras->cdefs[n].pixel; |
417 |
cvx.red = random() & 65535; |
418 |
cvx.green = random() & 65535; |
419 |
cvx.blue = random() & 65535; |
420 |
cvx.flags = DoRed|DoGreen|DoBlue; |
421 |
XStoreColor(thedisplay, ourras->cmap, &cvx); |
422 |
return(0); |
423 |
case 'p': /* position */ |
424 |
sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff); |
425 |
XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y, |
426 |
427 |
return(0); |
428 |
case 't': /* trace */ |
429 |
if (!gotview) { |
430 |
XBell(thedisplay, 0); |
431 |
return(-1); |
432 |
433 |
viewray(rorg, rdir, &ourview, |
434 |
(ekey->x-xoff+.5)/xmax, |
435 |
(ymax-1-ekey->y+yoff+.5)/ymax); |
436 |
printf("%e %e %e ", rorg[0], rorg[1], rorg[2]); |
437 |
printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]); |
438 |
fflush(stdout); |
439 |
return(0); |
440 |
case '=': /* adjust exposure */ |
441 |
442 |
return(-1); |
443 |
n = log(.5/bright(cval))/.69315 - scale; /* truncate */ |
444 |
if (n == 0) |
445 |
return(0); |
446 |
scale_rcolors(ourras, pow(2.0, (double)n)); |
447 |
scale += n; |
448 |
sprintf(buf, "%+d", scale); |
449 |
450 |
451 |
XFlush(thedisplay); |
452 |
free(ourdata); |
453 |
free_raster(ourras); |
454 |
getras(); |
455 |
/* fall through */ |
456 |
case CTRL(R): /* redraw */ |
457 |
case CTRL(L): |
458 |
459 |
XClearWindow(thedisplay, wind); |
460 |
461 |
if (fast) |
462 |
463 |
redraw(0, 0, width, height); |
464 |
return(0); |
465 |
case ' ': /* clear */ |
466 |
redraw(box.xmin, box.ymin, box.xsiz, box.ysiz); |
467 |
return(0); |
468 |
default: |
469 |
470 |
return(-1); |
471 |
472 |
473 |
474 |
475 |
moveimage(ebut) /* shift the image */ |
476 |
XButtonPressedEvent *ebut; |
477 |
478 |
union { |
479 |
XEvent u; |
480 |
XButtonReleasedEvent b; |
481 |
XPointerMovedEvent m; |
482 |
} e; |
483 |
int nxo, nyo; |
484 |
485 |
XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e.u); |
486 |
while (e.u.type == MotionNotify) { |
487 |
nxo = xoff + e.m.x - ebut->x; |
488 |
nyo = yoff + e.m.y - ebut->y; |
489 |
revbox(nxo, nyo, nxo+xmax, nyo+ymax); |
490 |
XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e.u); |
491 |
492 |
493 |
xoff += e.b.x - ebut->x; |
494 |
yoff += e.b.y - ebut->y; |
495 |
496 |
497 |
498 |
499 |
500 |
getbox(ebut) /* get new box */ |
501 |
502 |
503 |
union { |
504 |
XEvent u; |
505 |
506 |
507 |
} e; |
508 |
509 |
510 |
511 |
revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y); |
512 |
513 |
revbox(ebut->x, ebut->y, box.xmin, box.ymin); |
514 |
515 |
box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x); |
516 |
box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y); |
517 |
if (box.xmin > ebut->x) { |
518 |
box.xsiz = box.xmin - ebut->x + 1; |
519 |
box.xmin = ebut->x; |
520 |
} else { |
521 |
box.xsiz = ebut->x - box.xmin + 1; |
522 |
523 |
if (box.ymin > ebut->y) { |
524 |
box.ysiz = box.ymin - ebut->y + 1; |
525 |
box.ymin = ebut->y; |
526 |
} else { |
527 |
box.ysiz = ebut->y - box.ymin + 1; |
528 |
529 |
530 |
531 |
532 |
revbox(x0, y0, x1, y1) /* draw box with reversed lines */ |
533 |
int x0, y0, x1, y1; |
534 |
535 |
static GC mygc = 0; |
536 |
537 |
if (mygc == 0) { |
538 |
mygc = XCreateGC(thedisplay, wind, 0, 0); |
539 |
XSetFunction(thedisplay, mygc, GXinvert); |
540 |
541 |
XDrawLine(thedisplay, wind, mygc, x0, y0, x1, y0); |
542 |
XDrawLine(thedisplay, wind, mygc, x0, y1, x1, y1); |
543 |
XDrawLine(thedisplay, wind, mygc, x0, y0, x0, y1); |
544 |
XDrawLine(thedisplay, wind, mygc, x1, y0, x1, y1); |
545 |
} /* end of revbox */ |
546 |
547 |
548 |
avgbox(clr) /* average color over current box */ |
549 |
COLOR clr; |
550 |
551 |
int left, right, top, bottom; |
552 |
int y; |
553 |
double d; |
554 |
COLOR ctmp; |
555 |
register int x; |
556 |
557 |
setcolor(clr, 0.0, 0.0, 0.0); |
558 |
left = box.xmin - xoff; |
559 |
right = left + box.xsiz; |
560 |
if (left < 0) |
561 |
left = 0; |
562 |
if (right > xmax) |
563 |
right = xmax; |
564 |
if (left >= right) |
565 |
return(-1); |
566 |
top = box.ymin - yoff; |
567 |
bottom = top + box.ysiz; |
568 |
if (top < 0) |
569 |
top = 0; |
570 |
if (bottom > ymax) |
571 |
bottom = ymax; |
572 |
if (top >= bottom) |
573 |
return(-1); |
574 |
for (y = top; y < bottom; y++) { |
575 |
if (getscan(y) == -1) |
576 |
return(-1); |
577 |
for (x = left; x < right; x++) { |
578 |
colr_color(ctmp, scanline[x]); |
579 |
addcolor(clr, ctmp); |
580 |
581 |
582 |
d = 1.0/((right-left)*(bottom-top)); |
583 |
scalecolor(clr, d); |
584 |
return(0); |
585 |
586 |
587 |
588 |
getmono() /* get monochrome data */ |
589 |
590 |
register unsigned char *dp; |
591 |
register int x, err; |
592 |
int y; |
593 |
rgbpixel *inline; |
594 |
short *cerr; |
595 |
596 |
if ((inline = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL |
597 |
|| (cerr = (short *)calloc(xmax,sizeof(short))) == NULL) |
598 |
quit("out of memory in getmono"); |
599 |
dp = ourdata - 1; |
600 |
for (y = 0; y < ymax; y++) { |
601 |
picreadline3(y, inline); |
602 |
err = 0; |
603 |
for (x = 0; x < xmax; x++) { |
604 |
if (!(x&7)) |
605 |
*++dp = 0; |
606 |
err += rgb_bright(&inline[x]) + cerr[x]; |
607 |
if (err > 127) |
608 |
err -= 255; |
609 |
else |
610 |
*dp |= 1<<(7-(x&07)); |
611 |
cerr[x] = err >>= 1; |
612 |
613 |
614 |
free((char *)inline); |
615 |
free((char *)cerr); |
616 |
617 |
618 |
619 |
getfull() /* get full (24-bit) data */ |
620 |
621 |
int y; |
622 |
623 |
for (y = 0; y < ymax; y++) |
624 |
picreadline3(y, (rgbpixel *)(ourdata+y*xmax*3)); |
625 |
626 |
627 |
628 |
scale_rcolors(xr, sf) /* scale color map */ |
629 |
register XRASTER *xr; |
630 |
double sf; |
631 |
632 |
register int i; |
633 |
long maxv; |
634 |
635 |
if (xr->pixels == NULL) |
636 |
return; |
637 |
638 |
sf = pow(sf, 1.0/gamcor); |
639 |
maxv = 65535/sf; |
640 |
641 |
for (i = xr->ncolors; i--; ) { |
642 |
xr->cdefs[i].red = xr->cdefs[i].red > maxv ? |
643 |
65535 : |
644 |
xr->cdefs[i].red * sf; |
645 |
xr->cdefs[i].green = xr->cdefs[i].green > maxv ? |
646 |
65535 : |
647 |
xr->cdefs[i].green * sf; |
648 |
xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ? |
649 |
65535 : |
650 |
xr->cdefs[i].blue * sf; |
651 |
652 |
XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors); |
653 |
654 |
655 |
656 |
getscan(y) |
657 |
int y; |
658 |
659 |
if (y != cury) { |
660 |
if (scanpos == NULL || scanpos[y] == -1) |
661 |
return(-1); |
662 |
if (fseek(fin, scanpos[y], 0) == -1) |
663 |
quit("fseek error"); |
664 |
cury = y; |
665 |
} else if (scanpos != NULL) |
666 |
scanpos[y] = ftell(fin); |
667 |
668 |
if (freadcolrs(scanline, xmax, fin) < 0) |
669 |
quiterr("read error"); |
670 |
671 |
cury++; |
672 |
return(0); |
673 |
674 |
675 |
676 |
picreadline3(y, l3) /* read in 3-byte scanline */ |
677 |
int y; |
678 |
register rgbpixel *l3; |
679 |
680 |
register int i; |
681 |
/* read scanline */ |
682 |
if (getscan(y) < 0) |
683 |
quiterr("cannot seek for picreadline"); |
684 |
/* convert scanline */ |
685 |
normcolrs(scanline, xmax, scale); |
686 |
for (i = 0; i < xmax; i++) { |
687 |
l3[i].r = scanline[i][RED]; |
688 |
l3[i].g = scanline[i][GRN]; |
689 |
l3[i].b = scanline[i][BLU]; |
690 |
691 |
692 |
693 |
694 |
picwriteline(y, l) /* add 8-bit scanline to image */ |
695 |
int y; |
696 |
pixel *l; |
697 |
698 |
bcopy((char *)l, (char *)ourdata+y*xmax, xmax); |
699 |
700 |
701 |
702 |
picreadcm(map) /* do gamma correction */ |
703 |
colormap map; |
704 |
705 |
extern double pow(); |
706 |
register int i, val; |
707 |
708 |
for (i = 0; i < 256; i++) { |
709 |
val = pow(i/256.0, 1.0/gamcor) * 256.0; |
710 |
map[0][i] = map[1][i] = map[2][i] = val; |
711 |
712 |
713 |
714 |
715 |
picwritecm(map) /* handled elsewhere */ |
716 |
colormap map; |
717 |
718 |
#ifdef DEBUG |
719 |
register int i; |
720 |
721 |
for (i = 0; i < 256; i++) |
722 |
printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]); |
723 |
#endif |
724 |
