| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* x11image.c - driver for X-windows
| 9 |
| 10 |
* 3/1/90
| 11 |
| 12 |
| 13 |
| 14 |
* Modified for X11
| 15 |
| 16 |
* January 1990
| 17 |
| 18 |
* Anat Grynberg and Greg Ward
| 19 |
| 20 |
| 21 |
| 22 |
#include "standard.h"
| 23 |
| 24 |
#include <X11/Xlib.h>
| 25 |
#include <X11/cursorfont.h>
| 26 |
#include <X11/Xutil.h>
| 27 |
| 28 |
#include "color.h"
| 29 |
#include "view.h"
| 30 |
#include "pic.h"
| 31 |
#include "x11raster.h"
| 32 |
#include "random.h"
| 33 |
| 34 |
#define FONTNAME "8x13" /* text font we'll use */
| 35 |
| 36 |
#define CTRL(c) ('c'-'@')
| 37 |
| 38 |
#define BORWIDTH 5 /* border width */
| 39 |
| 40 |
#define ourscreen DefaultScreen(thedisplay)
| 41 |
#define ourblack BlackPixel(thedisplay,ourscreen)
| 42 |
#define ourwhite WhitePixel(thedisplay,ourscreen)
| 43 |
#define ourroot RootWindow(thedisplay,ourscreen)
| 44 |
#define ourgc DefaultGC(thedisplay,ourscreen)
| 45 |
| 46 |
#define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1)
| 47 |
| 48 |
#define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
| 49 |
| 50 |
double gamcor = 2.2; /* gamma correction */
| 51 |
| 52 |
int dither = 1; /* dither colors? */
| 53 |
int fast = 0; /* keep picture in Pixmap? */
| 54 |
| 55 |
Window wind = 0; /* our output window */
| 56 |
Font fontid; /* our font */
| 57 |
| 58 |
int maxcolors = 0; /* maximum colors */
| 59 |
int greyscale = 0; /* in grey */
| 60 |
| 61 |
int scale = 0; /* scalefactor; power of two */
| 62 |
| 63 |
int xoff = 0; /* x image offset */
| 64 |
int yoff = 0; /* y image offset */
| 65 |
| 66 |
VIEW ourview = STDVIEW; /* image view parameters */
| 67 |
int gotview = 0; /* got parameters from file */
| 68 |
| 69 |
COLR *scanline; /* scan line buffer */
| 70 |
| 71 |
int xmax, ymax; /* picture resolution */
| 72 |
int width, height; /* window size */
| 73 |
char *fname = NULL; /* input file name */
| 74 |
FILE *fin = stdin; /* input file */
| 75 |
long *scanpos = NULL; /* scan line positions in file */
| 76 |
int cury = 0; /* current scan location */
| 77 |
| 78 |
double exposure = 1.0; /* exposure compensation used */
| 79 |
| 80 |
GC revgc; /* graphics context with GXinvert */
| 81 |
| 82 |
XRASTER *ourras; /* our stored image */
| 83 |
unsigned char *ourdata; /* our image data */
| 84 |
| 85 |
struct {
| 86 |
int xmin, ymin, xsiz, ysiz;
| 87 |
} box = {0, 0, 0, 0}; /* current box */
| 88 |
| 89 |
char *geometry = NULL; /* geometry specification */
| 90 |
| 91 |
char *progname;
| 92 |
| 93 |
char errmsg[128];
| 94 |
| 95 |
extern long ftell();
| 96 |
| 97 |
extern char *malloc(), *calloc();
| 98 |
| 99 |
extern double atof(), pow(), log();
| 100 |
| 101 |
Display *thedisplay;
| 102 |
| 103 |
main(argc, argv)
| 104 |
int argc;
| 105 |
char *argv[];
| 106 |
| 107 |
int headline();
| 108 |
int i;
| 109 |
| 110 |
progname = argv[0];
| 111 |
| 112 |
for (i = 1; i < argc; i++)
| 113 |
if (argv[i][0] == '-')
| 114 |
switch (argv[i][1]) {
| 115 |
case 'c':
| 116 |
maxcolors = atoi(argv[++i]);
| 117 |
break;
| 118 |
case 'b':
| 119 |
greyscale = !greyscale;
| 120 |
break;
| 121 |
case 'm':
| 122 |
maxcolors = 2;
| 123 |
break;
| 124 |
case 'd':
| 125 |
dither = !dither;
| 126 |
break;
| 127 |
case 'f':
| 128 |
fast = !fast;
| 129 |
break;
| 130 |
case 'e':
| 131 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
| 132 |
goto userr;
| 133 |
scale = atoi(argv[++i]);
| 134 |
break;
| 135 |
case 'g':
| 136 |
if (!strcmp(argv[i], "-geometry"))
| 137 |
geometry = argv[++i];
| 138 |
else
| 139 |
gamcor = atof(argv[++i]);
| 140 |
break;
| 141 |
default:
| 142 |
goto userr;
| 143 |
| 144 |
else if (argv[i][0] == '=')
| 145 |
geometry = argv[i];
| 146 |
else
| 147 |
break;
| 148 |
| 149 |
if (i == argc-1) {
| 150 |
fname = argv[i];
| 151 |
fin = fopen(fname, "r");
| 152 |
if (fin == NULL) {
| 153 |
sprintf(errmsg, "can't open file \"%s\"", fname);
| 154 |
quiterr(errmsg);
| 155 |
| 156 |
} else if (i != argc)
| 157 |
goto userr;
| 158 |
/* get header */
| 159 |
getheader(fin, headline);
| 160 |
/* get picture dimensions */
| 161 |
if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR))
| 162 |
quiterr("bad picture size");
| 163 |
/* set view parameters */
| 164 |
if (gotview && setview(&ourview) != NULL)
| 165 |
gotview = 0;
| 166 |
if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
| 167 |
quiterr("out of memory");
| 168 |
| 169 |
init(); /* get file and open window */
| 170 |
| 171 |
for ( ; ; )
| 172 |
getevent(); /* main loop */
| 173 |
userr:
| 174 |
fprintf(stderr,
| 175 |
"Usage: %s [-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n",
| 176 |
progname);
| 177 |
quit(1);
| 178 |
| 179 |
| 180 |
| 181 |
headline(s) /* get relevant info from header */
| 182 |
char *s;
| 183 |
| 184 |
static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL};
| 185 |
register char **an;
| 186 |
| 187 |
if (isexpos(s))
| 188 |
exposure *= exposval(s);
| 189 |
else
| 190 |
for (an = altname; *an != NULL; an++)
| 191 |
if (!strncmp(*an, s, strlen(*an))) {
| 192 |
if (sscanview(&ourview, s+strlen(*an)) > 0)
| 193 |
gotview++;
| 194 |
return;
| 195 |
| 196 |
| 197 |
| 198 |
| 199 |
init() /* get data and open window */
| 200 |
| 201 |
XSetWindowAttributes ourwinattr;
| 202 |
XSizeHints oursizhints;
| 203 |
register int i;
| 204 |
| 205 |
if (fname != NULL) {
| 206 |
scanpos = (long *)malloc(ymax*sizeof(long));
| 207 |
if (scanpos == NULL)
| 208 |
goto memerr;
| 209 |
for (i = 0; i < ymax; i++)
| 210 |
scanpos[i] = -1;
| 211 |
| 212 |
if ((thedisplay = XOpenDisplay(NULL)) == NULL)
| 213 |
quiterr("can't open display; DISPLAY variable set?");
| 214 |
if (maxcolors == 0) { /* get number of available colors */
| 215 |
i = DisplayPlanes(thedisplay,ourscreen);
| 216 |
maxcolors = i > 8 ? 256 : 1<<i;
| 217 |
if (maxcolors > 4) maxcolors -= 2;
| 218 |
| 219 |
/* store image */
| 220 |
getras();
| 221 |
/* open window */
| 222 |
ourwinattr.border_pixel = ourblack;
| 223 |
ourwinattr.background_pixel = ourwhite;
| 224 |
wind = XCreateWindow(thedisplay, ourroot, 0, 0, xmax, ymax, BORWIDTH,
| 225 |
0, InputOutput, ourras->visual,
| 226 |
CWBackPixel|CWBorderPixel, &ourwinattr);
| 227 |
if (wind == 0)
| 228 |
quiterr("can't create window");
| 229 |
width = xmax;
| 230 |
height = ymax;
| 231 |
fontid = XLoadFont(thedisplay, FONTNAME);
| 232 |
if (fontid == 0)
| 233 |
quiterr("can't get font");
| 234 |
XSetFont(thedisplay, ourgc, fontid);
| 235 |
revgc = XCreateGC(thedisplay, wind, 0, 0);
| 236 |
XSetFunction(thedisplay, revgc, GXinvert);
| 237 |
XStoreName(thedisplay, wind, fname == NULL ? progname : fname);
| 238 |
XDefineCursor(thedisplay, wind, XCreateFontCursor(thedisplay,
| 239 |
XC_diamond_cross));
| 240 |
if (geometry != NULL) {
| 241 |
bzero((char *)&oursizhints, sizeof(oursizhints));
| 242 |
i = XParseGeometry(geometry, &oursizhints.x, &oursizhints.y,
| 243 |
(unsigned *)&oursizhints.width,
| 244 |
(unsigned *)&oursizhints.height);
| 245 |
if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
| 246 |
oursizhints.flags |= USSize;
| 247 |
else {
| 248 |
oursizhints.width = xmax;
| 249 |
oursizhints.height = ymax;
| 250 |
oursizhints.flags |= PSize;
| 251 |
| 252 |
if ((i&(XValue|YValue)) == (XValue|YValue)) {
| 253 |
oursizhints.flags |= USPosition;
| 254 |
if (i & XNegative)
| 255 |
oursizhints.x += DisplayWidth(thedisplay,
| 256 |
ourscreen)-1-oursizhints.width-2*BORWIDTH;
| 257 |
if (i & YNegative)
| 258 |
oursizhints.y += DisplayHeight(thedisplay,
| 259 |
ourscreen)-1-oursizhints.height-2*BORWIDTH;
| 260 |
| 261 |
XSetNormalHints(thedisplay, wind, &oursizhints);
| 262 |
| 263 |
XSelectInput(thedisplay, wind, ButtonPressMask|ButtonReleaseMask
| 264 |
|ButtonMotionMask|StructureNotifyMask
| 265 |
|KeyPressMask|ExposureMask);
| 266 |
XMapWindow(thedisplay, wind);
| 267 |
return;
| 268 |
memerr:
| 269 |
| 270 |
} /* end of init */
| 271 |
| 272 |
| 273 |
quiterr(err) /* print message and exit */
| 274 |
char *err;
| 275 |
| 276 |
if (err != NULL) {
| 277 |
fprintf(stderr, "%s: %s\n", progname, err);
| 278 |
exit(1);
| 279 |
| 280 |
exit(0);
| 281 |
| 282 |
| 283 |
| 284 |
eputs(s)
| 285 |
char *s;
| 286 |
| 287 |
fputs(s, stderr);
| 288 |
| 289 |
| 290 |
| 291 |
quit(code)
| 292 |
int code;
| 293 |
| 294 |
exit(code);
| 295 |
| 296 |
| 297 |
| 298 |
getras() /* get raster file */
| 299 |
| 300 |
colormap ourmap;
| 301 |
XVisualInfo vinfo;
| 302 |
| 303 |
if (maxcolors <= 2) { /* monochrome */
| 304 |
ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
| 305 |
if (ourdata == NULL)
| 306 |
goto fail;
| 307 |
ourras = make_raster(thedisplay, ourscreen, 1, ourdata,
| 308 |
xmax, ymax, 8);
| 309 |
if (ourras == NULL)
| 310 |
goto fail;
| 311 |
getmono();
| 312 |
} else if (XMatchVisualInfo(thedisplay,ourscreen,24,TrueColor,&vinfo)
| 313 |
/* kludge for DirectColor */
| 314 |
|| XMatchVisualInfo(thedisplay,ourscreen,24,DirectColor,&vinfo)) {
| 315 |
ourdata = (unsigned char *)malloc(xmax*ymax*3);
| 316 |
| 317 |
goto fail;
| 318 |
ourras = make_raster(thedisplay, ourscreen, 24, ourdata,
| 319 |
xmax, ymax, 8);
| 320 |
if (ourras == NULL)
| 321 |
goto fail;
| 322 |
getfull();
| 323 |
} else {
| 324 |
ourdata = (unsigned char *)malloc(xmax*ymax);
| 325 |
| 326 |
goto fail;
| 327 |
ourras = make_raster(thedisplay, ourscreen, 8, ourdata,
| 328 |
xmax, ymax, 8);
| 329 |
if (ourras == NULL)
| 330 |
goto fail;
| 331 |
if (greyscale)
| 332 |
biq(dither,maxcolors,1,ourmap);
| 333 |
else
| 334 |
ciq(dither,maxcolors,1,ourmap);
| 335 |
if (init_rcolors(ourras, ourmap[0], ourmap[1], ourmap[2]) == 0)
| 336 |
goto fail;
| 337 |
| 338 |
return;
| 339 |
fail:
| 340 |
quiterr("could not create raster image");
| 341 |
| 342 |
| 343 |
| 344 |
getevent() /* process the next event */
| 345 |
| 346 |
union {
| 347 |
XEvent u;
| 348 |
XConfigureEvent c;
| 349 |
XExposeEvent e;
| 350 |
XButtonPressedEvent b;
| 351 |
XKeyPressedEvent k;
| 352 |
} e;
| 353 |
| 354 |
XNextEvent(thedisplay, &e.u);
| 355 |
switch (e.u.type) {
| 356 |
case KeyPress:
| 357 |
docom(&e.k);
| 358 |
break;
| 359 |
case ConfigureNotify:
| 360 |
width = e.c.width;
| 361 |
height = e.c.height;
| 362 |
break;
| 363 |
case MapNotify:
| 364 |
map_rcolors(ourras, wind);
| 365 |
if (fast)
| 366 |
make_rpixmap(ourras);
| 367 |
break;
| 368 |
case UnmapNotify:
| 369 |
unmap_rcolors(ourras);
| 370 |
break;
| 371 |
case Expose:
| 372 |
redraw(e.e.x, e.e.y, e.e.width, e.e.height);
| 373 |
break;
| 374 |
case ButtonPress:
| 375 |
if (e.b.state & (ShiftMask|ControlMask))
| 376 |
moveimage(&e.b);
| 377 |
else
| 378 |
getbox(&e.b);
| 379 |
break;
| 380 |
| 381 |
| 382 |
| 383 |
| 384 |
docom(ekey) /* execute command */
| 385 |
XKeyPressedEvent *ekey;
| 386 |
| 387 |
char buf[80];
| 388 |
COLOR cval;
| 389 |
XColor cvx;
| 390 |
int com, n;
| 391 |
double comp;
| 392 |
FVECT rorg, rdir;
| 393 |
| 394 |
n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
| 395 |
if (n == 0)
| 396 |
return(0);
| 397 |
com = buf[0];
| 398 |
switch (com) { /* interpret command */
| 399 |
case 'q':
| 400 |
case CTRL(D): /* quit */
| 401 |
quit(0);
| 402 |
case '\n':
| 403 |
case '\r':
| 404 |
case 'l':
| 405 |
case 'c': /* value */
| 406 |
if (avgbox(cval) == -1)
| 407 |
return(-1);
| 408 |
switch (com) {
| 409 |
case '\n':
| 410 |
case '\r': /* radiance */
| 411 |
sprintf(buf, "%.3f", intens(cval)/exposure);
| 412 |
break;
| 413 |
case 'l': /* luminance */
| 414 |
sprintf(buf, "%.0fn", luminance(cval)/exposure);
| 415 |
break;
| 416 |
case 'c': /* color */
| 417 |
comp = pow(2.0, (double)scale);
| 418 |
sprintf(buf, "(%.2f,%.2f,%.2f)",
| 419 |
colval(cval,RED)*comp,
| 420 |
colval(cval,GRN)*comp,
| 421 |
colval(cval,BLU)*comp);
| 422 |
break;
| 423 |
| 424 |
XDrawImageString(thedisplay, wind, ourgc,
| 425 |
box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
| 426 |
return(0);
| 427 |
case 'i': /* identify (contour) */
| 428 |
if (ourras->pixels == NULL)
| 429 |
return(-1);
| 430 |
n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
| 431 |
n = ourras->pmap[n];
| 432 |
cvx.pixel = ourras->cdefs[n].pixel;
| 433 |
cvx.red = random() & 65535;
| 434 |
cvx.green = random() & 65535;
| 435 |
cvx.blue = random() & 65535;
| 436 |
cvx.flags = DoRed|DoGreen|DoBlue;
| 437 |
XStoreColor(thedisplay, ourras->cmap, &cvx);
| 438 |
return(0);
| 439 |
case 'p': /* position */
| 440 |
sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff);
| 441 |
XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
| 442 |
buf, strlen(buf));
| 443 |
return(0);
| 444 |
case 't': /* trace */
| 445 |
if (!gotview) {
| 446 |
XBell(thedisplay, 0);
| 447 |
return(-1);
| 448 |
| 449 |
if (viewray(rorg, rdir, &ourview,
| 450 |
(ekey->x-xoff+.5)/xmax,
| 451 |
(ymax-1-ekey->y+yoff+.5)/ymax) < 0)
| 452 |
return(-1);
| 453 |
printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
| 454 |
printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
| 455 |
fflush(stdout);
| 456 |
return(0);
| 457 |
case '=': /* adjust exposure */
| 458 |
| 459 |
return(-1);
| 460 |
n = log(.5/bright(cval))/.69315 - scale; /* truncate */
| 461 |
if (n == 0)
| 462 |
return(0);
| 463 |
scale_rcolors(ourras, pow(2.0, (double)n));
| 464 |
scale += n;
| 465 |
sprintf(buf, "%+d", scale);
| 466 |
| 467 |
| 468 |
XFlush(thedisplay);
| 469 |
free(ourdata);
| 470 |
free_raster(ourras);
| 471 |
getras();
| 472 |
/* fall through */
| 473 |
case CTRL(R): /* redraw */
| 474 |
case CTRL(L):
| 475 |
| 476 |
XClearWindow(thedisplay, wind);
| 477 |
| 478 |
if (fast)
| 479 |
| 480 |
redraw(0, 0, width, height);
| 481 |
return(0);
| 482 |
case ' ': /* clear */
| 483 |
redraw(box.xmin, box.ymin, box.xsiz, box.ysiz);
| 484 |
return(0);
| 485 |
default:
| 486 |
| 487 |
return(-1);
| 488 |
| 489 |
| 490 |
| 491 |
| 492 |
moveimage(ebut) /* shift the image */
| 493 |
XButtonPressedEvent *ebut;
| 494 |
| 495 |
union {
| 496 |
XEvent u;
| 497 |
XButtonReleasedEvent b;
| 498 |
XPointerMovedEvent m;
| 499 |
} e;
| 500 |
int mxo, myo;
| 501 |
| 502 |
XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e.u);
| 503 |
while (e.u.type == MotionNotify) {
| 504 |
mxo = e.m.x;
| 505 |
myo = e.m.y;
| 506 |
revline(ebut->x, ebut->y, mxo, myo);
| 507 |
revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
| 508 |
xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
| 509 |
XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e.u);
| 510 |
| 511 |
| 512 |
| 513 |
| 514 |
xoff += e.b.x - ebut->x;
| 515 |
yoff += e.b.y - ebut->y;
| 516 |
| 517 |
| 518 |
| 519 |
| 520 |
| 521 |
getbox(ebut) /* get new box */
| 522 |
| 523 |
| 524 |
union {
| 525 |
XEvent u;
| 526 |
| 527 |
| 528 |
} e;
| 529 |
| 530 |
| 531 |
| 532 |
revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y);
| 533 |
| 534 |
revbox(ebut->x, ebut->y, box.xmin, box.ymin);
| 535 |
| 536 |
box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x);
| 537 |
box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y);
| 538 |
if (box.xmin > ebut->x) {
| 539 |
box.xsiz = box.xmin - ebut->x + 1;
| 540 |
box.xmin = ebut->x;
| 541 |
} else {
| 542 |
box.xsiz = ebut->x - box.xmin + 1;
| 543 |
| 544 |
if (box.ymin > ebut->y) {
| 545 |
box.ysiz = box.ymin - ebut->y + 1;
| 546 |
box.ymin = ebut->y;
| 547 |
} else {
| 548 |
box.ysiz = ebut->y - box.ymin + 1;
| 549 |
| 550 |
| 551 |
| 552 |
| 553 |
revbox(x0, y0, x1, y1) /* draw box with reversed lines */
| 554 |
int x0, y0, x1, y1;
| 555 |
| 556 |
revline(x0, y0, x1, y0);
| 557 |
revline(x0, y1, x1, y1);
| 558 |
revline(x0, y0, x0, y1);
| 559 |
revline(x1, y0, x1, y1);
| 560 |
| 561 |
| 562 |
| 563 |
avgbox(clr) /* average color over current box */
| 564 |
COLOR clr;
| 565 |
| 566 |
int left, right, top, bottom;
| 567 |
int y;
| 568 |
double d;
| 569 |
COLOR ctmp;
| 570 |
register int x;
| 571 |
| 572 |
setcolor(clr, 0.0, 0.0, 0.0);
| 573 |
left = box.xmin - xoff;
| 574 |
right = left + box.xsiz;
| 575 |
if (left < 0)
| 576 |
left = 0;
| 577 |
if (right > xmax)
| 578 |
right = xmax;
| 579 |
if (left >= right)
| 580 |
return(-1);
| 581 |
top = box.ymin - yoff;
| 582 |
bottom = top + box.ysiz;
| 583 |
if (top < 0)
| 584 |
top = 0;
| 585 |
if (bottom > ymax)
| 586 |
bottom = ymax;
| 587 |
if (top >= bottom)
| 588 |
return(-1);
| 589 |
for (y = top; y < bottom; y++) {
| 590 |
if (getscan(y) == -1)
| 591 |
return(-1);
| 592 |
for (x = left; x < right; x++) {
| 593 |
colr_color(ctmp, scanline[x]);
| 594 |
addcolor(clr, ctmp);
| 595 |
| 596 |
| 597 |
d = 1.0/((right-left)*(bottom-top));
| 598 |
scalecolor(clr, d);
| 599 |
return(0);
| 600 |
| 601 |
| 602 |
| 603 |
getmono() /* get monochrome data */
| 604 |
| 605 |
register unsigned char *dp;
| 606 |
register int x, err;
| 607 |
int y;
| 608 |
short *cerr;
| 609 |
| 610 |
if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
| 611 |
quiterr("out of memory in getmono");
| 612 |
dp = ourdata - 1;
| 613 |
for (y = 0; y < ymax; y++) {
| 614 |
if (getscan(y) < 0)
| 615 |
quiterr("seek error in getmono");
| 616 |
normcolrs(scanline, xmax, scale);
| 617 |
err = 0;
| 618 |
for (x = 0; x < xmax; x++) {
| 619 |
if (!(x&7))
| 620 |
*++dp = 0;
| 621 |
err += normbright(scanline[x]) + cerr[x];
| 622 |
if (err > 127)
| 623 |
err -= 255;
| 624 |
else
| 625 |
*dp |= 1<<(7-(x&07));
| 626 |
cerr[x] = err >>= 1;
| 627 |
| 628 |
| 629 |
free((char *)cerr);
| 630 |
| 631 |
| 632 |
| 633 |
getfull() /* get full (24-bit) data */
| 634 |
| 635 |
int y;
| 636 |
| 637 |
register int x;
| 638 |
/* set gamma correction */
| 639 |
setcolrgam(gamcor);
| 640 |
/* read and convert file */
| 641 |
dp = ourdata;
| 642 |
| 643 |
if (getscan(y) < 0)
| 644 |
quiterr("seek error in getfull");
| 645 |
if (scale)
| 646 |
shiftcolrs(scanline, xmax, scale);
| 647 |
colrs_gambs(scanline, xmax);
| 648 |
| 649 |
*dp++ = scanline[x][RED];
| 650 |
*dp++ = scanline[x][GRN];
| 651 |
*dp++ = scanline[x][BLU];
| 652 |
| 653 |
| 654 |
| 655 |
| 656 |
| 657 |
scale_rcolors(xr, sf) /* scale color map */
| 658 |
register XRASTER *xr;
| 659 |
double sf;
| 660 |
| 661 |
register int i;
| 662 |
long maxv;
| 663 |
| 664 |
if (xr->pixels == NULL)
| 665 |
return;
| 666 |
| 667 |
sf = pow(sf, 1.0/gamcor);
| 668 |
maxv = 65535/sf;
| 669 |
| 670 |
for (i = xr->ncolors; i--; ) {
| 671 |
xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
| 672 |
65535 :
| 673 |
xr->cdefs[i].red * sf;
| 674 |
xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
| 675 |
65535 :
| 676 |
xr->cdefs[i].green * sf;
| 677 |
xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
| 678 |
65535 :
| 679 |
xr->cdefs[i].blue * sf;
| 680 |
| 681 |
XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
| 682 |
| 683 |
| 684 |
| 685 |
getscan(y)
| 686 |
int y;
| 687 |
| 688 |
if (y != cury) {
| 689 |
if (scanpos == NULL || scanpos[y] == -1)
| 690 |
return(-1);
| 691 |
if (fseek(fin, scanpos[y], 0) == -1)
| 692 |
quiterr("fseek error");
| 693 |
cury = y;
| 694 |
} else if (scanpos != NULL)
| 695 |
scanpos[y] = ftell(fin);
| 696 |
| 697 |
if (freadcolrs(scanline, xmax, fin) < 0)
| 698 |
quiterr("read error");
| 699 |
| 700 |
cury++;
| 701 |
return(0);
| 702 |
| 703 |
| 704 |
| 705 |
picreadline3(y, l3) /* read in 3-byte scanline */
| 706 |
int y;
| 707 |
register rgbpixel *l3;
| 708 |
| 709 |
register int i;
| 710 |
/* read scanline */
| 711 |
if (getscan(y) < 0)
| 712 |
quiterr("cannot seek for picreadline");
| 713 |
/* convert scanline */
| 714 |
| 715 |
for (i = 0; i < xmax; i++) {
| 716 |
l3[i].r = scanline[i][RED];
| 717 |
l3[i].g = scanline[i][GRN];
| 718 |
l3[i].b = scanline[i][BLU];
| 719 |
| 720 |
| 721 |
| 722 |
| 723 |
picwriteline(y, l) /* add 8-bit scanline to image */
| 724 |
int y;
| 725 |
pixel *l;
| 726 |
| 727 |
bcopy((char *)l, (char *)ourdata+y*xmax, xmax);
| 728 |
| 729 |
| 730 |
| 731 |
picreadcm(map) /* do gamma correction */
| 732 |
colormap map;
| 733 |
| 734 |
extern double pow();
| 735 |
register int i, val;
| 736 |
| 737 |
for (i = 0; i < 256; i++) {
| 738 |
val = pow((i+0.5)/256.0, 1.0/gamcor) * 256.0;
| 739 |
map[0][i] = map[1][i] = map[2][i] = val;
| 740 |
| 741 |
| 742 |
| 743 |
| 744 |
picwritecm(map) /* handled elsewhere */
| 745 |
colormap map;
| 746 |
| 747 |
#ifdef DEBUG
| 748 |
register int i;
| 749 |
| 750 |
| 751 |
printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]);
| 752 |
#endif
| 753 |
