root/radiance/ray/src/px/x11image.c
Sat Jun 7 05:09:46 2025 UTC (2 weeks, 1 day ago) by greg
Changes since 2.80: +2 -4 lines
Diff to previous 2.80 , to selected 2.42
Tue Jun 3 21:31:51 2025 UTC (2 weeks, 4 days ago) by greg
Changes since 2.79: +2 -4 lines
Diff to previous 2.79 , to selected 2.42
Mon Apr 28 01:37:07 2025 UTC (7 weeks, 6 days ago) by greg
Changes since 2.78: +37 -35 lines
Diff to previous 2.78 , to selected 2.42
fix(ximage): Fixed bug in area averaging introduced with colr_color() inlining
Thu Nov 21 17:15:54 2024 UTC (6 months, 4 weeks ago) by greg
Diff to previous 2.77 , to selected 2.42
refactor: Removed unused client data parametr from tmSetSpace() call
Tue Sep 10 20:24:42 2024 UTC (9 months, 1 week ago) by greg
Changes since 2.76: +9 -5 lines
Diff to previous 2.76 , to selected 2.42
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Thu Aug 2 18:33:48 2018 UTC (6 years, 10 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Diff to previous 2.75 , to selected 2.42
Tue Aug 16 18:09:53 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.74: +2 -2 lines
Diff to previous 2.74 , to selected 2.42
Minor fixes
Fri May 20 02:06:39 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.73: +7 -7 lines
Diff to previous 2.73 , to selected 2.42
Mon Nov 10 19:08:19 2008 UTC (16 years, 7 months ago) by greg
Diff to previous 2.72 , to selected 2.42
Mon May 29 17:31:25 2006 UTC (19 years ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.71: +8 -8 lines
Diff to previous 2.71 , to selected 2.42
Sun Jul 24 19:53:08 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.70: +6 -6 lines
Diff to previous 2.70 , to selected 2.42
Fri Jan 7 22:05:30 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 2.69 , to selected 2.42
Added client data pointer to tmSetSpace() call
Fri Jan 7 20:33:02 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.68: +24 -17 lines
Diff to previous 2.68 , to selected 2.42
Tue Sep 28 17:54:18 2004 UTC (20 years, 8 months ago) by greg
Changes since 2.67: +1 -1 lines
Diff to previous 2.67 , to selected 2.42
Sat Apr 10 03:02:20 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.66: +1 -1 lines
Diff to previous 2.66 , to selected 2.42
Changed include <wait.h> to <sys/wait.h> for Unix compatibility
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.65: +132 -63 lines
Diff to previous 2.65 , to selected 2.42
Fri Jan 2 12:47:01 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.64: +7 -4 lines
Diff to previous 2.64 , to selected 2.42
Sun Jul 27 22:12:03 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.63: +5 -5 lines
Diff to previous 2.63 , to selected 2.42
Mon Jul 21 22:30:19 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.62: +1 -1 lines
Diff to previous 2.62 , to selected 2.42
Mon Jul 7 17:21:51 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.61: +3 -3 lines
Diff to previous 2.61 , to selected 2.42
Mon Jun 30 14:59:12 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.60: +2 -1 lines
Diff to previous 2.60 , to selected 2.42
Thu Jun 26 00:58:10 2003 UTC (22 years ago) by schorsch
Diff to previous 2.59 , to selected 2.42
Fri Jun 20 00:25:50 2003 UTC (22 years ago) by greg
Changes since 2.58: +14 -14 lines
Diff to previous 2.58 , to selected 2.42
Sun Jun 8 12:03:10 2003 UTC (22 years ago) by schorsch
Changes since 2.57: +1 -1 lines
Diff to previous 2.57 , to selected 2.42
Mon Mar 10 17:26:26 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.56: +1 -2 lines
Diff to previous 2.56 , to selected 2.42
Compile fixes for Linux
Sat Feb 22 02:07:28 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.55: +32 -38 lines
Diff to previous 2.55 , to selected 2.42
Tue Jul 20 14:07:38 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.54: +52 -10 lines
Diff to previous 2.54 , to selected 2.42
added support for 15-bit TrueColor visual for Linux
Wed Jun 16 08:15:17 1999 UTC (26 years ago) by gwlarson
Changes since 2.53: +2 -1 lines
Diff to previous 2.53 , to selected 2.42
moved initialization of fin to main() for Linux
Tue Oct 27 09:08:28 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 2.52: +2 -0 lines
Diff to previous 2.52 , to selected 2.42
Mon Aug 17 18:00:11 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 2.51: +1 -4 lines
Diff to previous 2.51 , to selected 2.42
removed "color.h" include from tonemap.h
Mon Feb 9 14:37:09 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 2.50: +5 -1 lines
Diff to previous 2.50 , to selected 2.42
added check for reading from stdin in 'h' and 'a' commands
Thu Jul 31 21:00:57 1997 UTC (27 years, 10 months ago) by gregl
Changes since 2.49: +70 -37 lines
Diff to previous 2.49 , to selected 2.42
changed behavior of 'a' and 'h' commands to emphasize selection
Thu Apr 24 17:29:53 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.48: +26 -24 lines
Diff to previous 2.48 , to selected 2.42
fixed histogram reuse
Tue Apr 22 10:01:43 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.47: +8 -20 lines
Diff to previous 2.47 , to selected 2.42
avoided repeat computation of static histogram
Mon Apr 21 13:10:12 1997 UTC (28 years, 2 months ago) by greg
Diff to previous 2.46 , to selected 2.42
changed -e option to only check first letter
Wed Apr 16 20:28:47 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.45: +13 -0 lines
Diff to previous 2.45 , to selected 2.42
added 'a' and 'h' commands for autoexposure and human exposure
Tue Apr 15 18:33:31 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.44: +2 -0 lines
Diff to previous 2.44 , to selected 2.42
put in NOPROTO definition for non-ANSI compilers
Tue Apr 15 16:53:58 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.43: +143 -38 lines
Diff to previous 2.43 , to selected 2.42
added tone mapping functions (-e auto and -e human options)
Mon Jan 27 15:07:03 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.42: +36 -5 lines
Diff to previous 2.42
added -t option and continuous mouse tracking with right button
Revision 2.42 - (view) (download) (annotate) - [selected]
Wed Dec 13 09:52:38 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.41: +46 -17 lines
Diff to previous 2.41
added -o option to control output of 't' command
Wed Jan 25 10:53:02 1995 UTC (30 years, 5 months ago) by greg
Changes since 2.40: +7 -3 lines
Diff to previous 2.40 , to selected 2.42
added -s option for sequential viewing
Wed Nov 23 14:24:34 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.39: +8 -4 lines
Diff to previous 2.39 , to selected 2.42
fixed unnecessary color table allocation
Mon Nov 21 09:18:48 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.38: +4 -5 lines
Diff to previous 2.38 , to selected 2.42
made child notify parent only after window is mapped
Tue Sep 20 15:48:15 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.37: +1 -1 lines
Diff to previous 2.37 , to selected 2.42
changed GAMMA environment variable to DISPLAY_GAMMA
Fri Jun 10 12:51:21 1994 UTC (31 years ago) by greg
Changes since 2.36: +3 -2 lines
Diff to previous 2.36 , to selected 2.42
Tue Dec 14 20:43:42 1993 UTC (31 years, 6 months ago) by greg
Changes since 2.35: +3 -4 lines
Diff to previous 2.35 , to selected 2.42
added explicit call to XCloseDisplay()
Mon Nov 22 11:33:18 1993 UTC (31 years, 7 months ago) by greg
Changes since 2.34: +18 -12 lines
Diff to previous 2.34 , to selected 2.42
added check for radiance.gamma resource from server
Mon Nov 15 10:55:33 1993 UTC (31 years, 7 months ago) by greg
Changes since 2.33: +10 -3 lines
Diff to previous 2.33 , to selected 2.42
fixed bug when '@' or '=' command used on zero pixel
Thu Nov 4 12:04:55 1993 UTC (31 years, 7 months ago) by greg
Changes since 2.32: +2 -4 lines
Diff to previous 2.32 , to selected 2.42
simplified error message
Thu Oct 28 11:39:59 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.31: +15 -8 lines
Diff to previous 2.31 , to selected 2.42
fixed problem where parent would stall after child aborted
Thu Oct 28 10:00:58 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.30: +10 -4 lines
Diff to previous 2.30 , to selected 2.42
minor improvement in quiterr()
Wed Oct 27 16:57:28 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.29: +17 -6 lines
Diff to previous 2.29 , to selected 2.42
removed fatal error on unfinished picture files
Wed Oct 27 13:03:18 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.28: +36 -9 lines
Diff to previous 2.28 , to selected 2.42
added forking for multiple pictures
Mon Jul 19 15:18:05 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.27: +11 -4 lines
Diff to previous 2.27 , to selected 2.42
fixes for DEC Alpha running OSF (sizeof long == 8)
Fri Jun 18 10:22:26 1993 UTC (32 years ago) by greg
Changes since 2.26: +8 -0 lines
Diff to previous 2.26 , to selected 2.42
added 'f' and 'F' commands to turn on and off fast redraw
Wed May 5 10:27:58 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.25 , to selected 2.42
corrected factor in '@' calculation
Thu Apr 29 12:17:45 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.24: +6 -1 lines
Diff to previous 2.24 , to selected 2.42
added @ command to adjust for observer's vision
Tue Mar 30 14:39:29 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.23: +104 -91 lines
Diff to previous 2.23 , to selected 2.42
fixes by Philip Thomson in init()
Tue Mar 2 11:10:15 1993 UTC (32 years, 3 months ago) by greg
Diff to previous 2.22 , to selected 2.42
changed background and border pixel values
Tue Mar 2 10:54:08 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.21: +25 -13 lines
Diff to previous 2.21 , to selected 2.42
made middle button double as 't' key
Fri Feb 19 10:46:16 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 2.42
minor cosmetic changes
Fri Feb 12 18:03:08 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.19: +24 -23 lines
Diff to previous 2.19 , to selected 2.42
fixed -geometry option handling for twm and like window managers
Thu Feb 4 21:00:32 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.18: +7 -0 lines
Diff to previous 2.18 , to selected 2.42
added '0' command to reset image origin
Wed Nov 11 17:34:08 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.17: +6 -4 lines
Diff to previous 2.17 , to selected 2.42
fixed bug in greyscale conversion
Thu Oct 22 20:50:40 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.16: +4 -7 lines
Diff to previous 2.16 , to selected 2.42
minor optimization in add2icon()
Thu Oct 22 17:51:05 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.15: +11 -5 lines
Diff to previous 2.15 , to selected 2.42
moved add2icon() call before colrs_gambs()
Tue Oct 13 16:43:39 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.14: +4 -7 lines
Diff to previous 2.14 , to selected 2.42
minor bug fix in avgbox()
Mon Oct 12 16:24:02 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.13: +2 -17 lines
Diff to previous 2.13 , to selected 2.42
minor fixups
Mon Oct 12 12:59:22 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.12: +50 -71 lines
Diff to previous 2.12 , to selected 2.42
converted to color quantization routines in clrtab.c
Tue Sep 15 12:15:48 1992 UTC (32 years, 9 months ago) by greg
Diff to previous 2.11 , to selected 2.42
fixed bunged call to make_rpixmap()
Fri Aug 21 13:49:30 1992 UTC (32 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.42
made getscan() slightly more efficient
Wed Jun 24 09:17:39 1992 UTC (33 years ago) by greg
Changes since 2.9: +4 -0 lines
Diff to previous 2.9 , to selected 2.42
Sat May 30 09:33:01 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.8: +8 -3 lines
Diff to previous 2.8 , to selected 2.42
small improvement in white&black color assignments
Fri May 29 14:21:12 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.7: +13 -4 lines
Diff to previous 2.7 , to selected 2.42
fixed text color on 24-bit displays
Thu May 28 09:43:09 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.6: +63 -23 lines
Diff to previous 2.6 , to selected 2.42
further refinements for grayscale and odd devices
Wed May 27 14:28:50 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.5: +147 -34 lines
Diff to previous 2.5 , to selected 2.42
fixes for different display types
Tue May 19 14:22:46 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 2.42
Did I fix 24-bit color this time?  Who knows.
Tue Apr 28 09:40:32 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.3: +2 -9 lines
Diff to previous 2.3 , to selected 2.42
changed calls to get view parameters from files
Mon Dec 23 23:20:09 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 2.2 , to selected 2.42
fixed CTRL(c) for ANSII preprocessors
Thu Dec 19 14:52:27 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 2.42
Tue Nov 12 16:04:23 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.26: +0 -0 lines
Diff to previous 1.26 , to selected 2.42
Mon Nov 11 14:01:17 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.25: +12 -6 lines
Diff to previous 1.25 , to selected 2.42
Mon Aug 26 10:15:01 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.24: +9 -1 lines
Diff to previous 1.24 , to selected 2.42
added check for duplicate box measurement
Thu May 23 12:00:38 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.23: +4 -0 lines
Diff to previous 1.23 , to selected 2.42
fixed bug in add2icon() for large aspect images
Mon May 6 13:14:17 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.22: +8 -3 lines
Diff to previous 1.22 , to selected 2.42
improved dithering slightly
Fri May 3 13:28:39 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.21: +1 -9 lines
Diff to previous 1.21 , to selected 2.42
changed storage of name back to beginning
Fri May 3 12:01:44 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.20: +8 -1 lines
Diff to previous 1.20 , to selected 2.42
makes sure that image is up before StoreName() call
Fri May 3 10:54:47 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.19: +8 -9 lines
Diff to previous 1.19 , to selected 2.42
fixed major bug in add2icon()
Fri May 3 09:54:31 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.18 , to selected 2.42
moved location of call to StoreName as signal that we're ready
Fri May 3 09:49:02 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.17: +4 -4 lines
Diff to previous 1.17 , to selected 2.42
minor tweaks to icon bitmap code
Thu May 2 17:24:54 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.16: +52 -2 lines
Diff to previous 1.16 , to selected 2.42
added bitmap icon from image
Wed May 1 12:40:00 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.15 , to selected 2.42
changed 'n' to 'L' in luminance display
Fri Apr 19 14:59:14 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.14: +7 -0 lines
Diff to previous 1.14 , to selected 2.42
fixed bug with some window managers, added icon pixmap
Thu Apr 18 14:35:49 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.13: +10 -4 lines
Diff to previous 1.13 , to selected 2.42
Mon Mar 18 09:35:06 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.12 , to selected 2.42
added luminance() macro to color.h
Fri Dec 21 17:20:11 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.11: +2 -1 lines
Diff to previous 1.11 , to selected 2.42
minor compiler complaints
Wed Nov 7 13:10:36 1990 UTC (34 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 2.42
minor improvement in gamma correction
Sun Oct 21 10:48:17 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.9: +23 -9 lines
Diff to previous 1.9 , to selected 2.42
added gamma correction to 24-bit mode
Wed Oct 17 14:56:18 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.8 , to selected 2.42
fixed calls to quit() that should have been to quiterr()
Sat Oct 13 21:31:48 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.7: +3 -2 lines
Diff to previous 1.7 , to selected 2.42
added fisheye view types
Thu Aug 30 11:21:34 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 2.42
added poor support of DirectColor
Mon Mar 12 15:14:53 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.5: +5 -5 lines
Diff to previous 1.5 , to selected 2.42
changed "inline" to "inl" for compiler compatibility
Wed Mar 7 11:39:26 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.4: +22 -16 lines
Diff to previous 1.4 , to selected 2.42
improved interactivity in moveimage
Fri Mar 2 14:58:57 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.3: +11 -6 lines
Diff to previous 1.3 , to selected 2.42
changed order of call to XCreateWindow to support different visuals
Fri Mar 2 12:22:37 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.2: +36 -24 lines
Diff to previous 1.2 , to selected 2.42
final bug fixes, working version of x11image
Thu Mar 1 18:13:31 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.1: +27 -31 lines
Diff to previous 1.1 , to selected 2.42
Various bug fixes
Thu Mar 1 13:18:22 1990 UTC (35 years, 4 months ago) by greg
Diff to selected 2.42
