root/radiance/ray/src/px/x11image.c
Revision: 2.28
Committed: Mon Jul 19 15:18:05 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.27: +11 -4 lines
fixes for DEC Alpha running OSF (sizeof long == 8)
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * x11image.c - driver for X-windows
9 *
10 * 3/1/90
11 */
12
13 /*
14 * Modified for X11
15 *
16 * January 1990
17 *
18 * Anat Grynberg and Greg Ward
19 */
20
21
22 #include "standard.h"
23
24 #include <X11/Xlib.h>
25 #include <X11/cursorfont.h>
26 #include <X11/Xutil.h>
27 #include <X11/Xatom.h>
28
29 #include "color.h"
30 #include "view.h"
31 #include "x11raster.h"
32 #include "random.h"
33 #include "resolu.h"
34
35 #ifdef __alpha
36 #define int4 int
37 #endif
38 #ifndef int4
39 #define int4 long
40 #endif
41
42 #define FONTNAME "8x13" /* text font we'll use */
43
44 #define CTRL(c) ((c)-'@')
45
46 #define BORWIDTH 5 /* border width */
47
48 #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */
49
50 #define ourscreen DefaultScreen(thedisplay)
51 #define ourroot RootWindow(thedisplay,ourscreen)
52
53 #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1)
54
55 #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
56
57 double gamcor = 2.2; /* gamma correction */
58
59 int dither = 1; /* dither colors? */
60 int fast = 0; /* keep picture in Pixmap? */
61
62 char *dispname = NULL; /* our display name */
63
64 Window wind = 0; /* our output window */
65 unsigned long ourblack=0, ourwhite=1; /* black and white for this visual */
66 int maxcolors = 0; /* maximum colors */
67 int greyscale = 0; /* in grey */
68
69 int scale = 0; /* scalefactor; power of two */
70
71 int xoff = 0; /* x image offset */
72 int yoff = 0; /* y image offset */
73
74 VIEW ourview = STDVIEW; /* image view parameters */
75 int gotview = 0; /* got parameters from file */
76
77 COLR *scanline; /* scan line buffer */
78
79 RESOLU inpres; /* input resolution and ordering */
80 int xmax, ymax; /* picture dimensions */
81 int width, height; /* window size */
82 char *fname = NULL; /* input file name */
83 FILE *fin = stdin; /* input file */
84 long *scanpos = NULL; /* scan line positions in file */
85 int cury = 0; /* current scan location */
86
87 double exposure = 1.0; /* exposure compensation used */
88
89 int wrongformat = 0; /* input in another format? */
90
91 GC ourgc; /* standard graphics context */
92 GC revgc; /* graphics context with GXinvert */
93
94 int *ourrank; /* our visual class ranking */
95 XVisualInfo ourvis; /* our visual */
96 XRASTER *ourras; /* our stored image */
97 unsigned char *ourdata; /* our image data */
98
99 struct {
100 int xmin, ymin, xsiz, ysiz;
101 } box = {0, 0, 0, 0}; /* current box */
102
103 char *geometry = NULL; /* geometry specification */
104
105 char icondata[ICONSIZ*ICONSIZ/8]; /* icon bitmap data */
106 int iconwidth = 0, iconheight = 0;
107
108 char *progname;
109
110 char errmsg[128];
111
112 extern BYTE clrtab[256][3]; /* global color map */
113
114 extern long ftell();
115
116 Display *thedisplay;
117 Atom closedownAtom, wmProtocolsAtom;
118
119
120 main(argc, argv)
121 int argc;
122 char *argv[];
123 {
124 extern char *getenv();
125 char *gv;
126 int headline();
127 int i;
128
129 progname = argv[0];
130 if ((gv = getenv("GAMMA")) != NULL)
131 gamcor = atof(gv);
132
133 for (i = 1; i < argc; i++)
134 if (argv[i][0] == '-')
135 switch (argv[i][1]) {
136 case 'c':
137 maxcolors = atoi(argv[++i]);
138 break;
139 case 'b':
140 greyscale = !greyscale;
141 break;
142 case 'm':
143 maxcolors = 2;
144 break;
145 case 'd':
146 if (argv[i][2] == 'i')
147 dispname = argv[++i];
148 else
149 dither = !dither;
150 break;
151 case 'f':
152 fast = !fast;
153 break;
154 case 'e':
155 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
156 goto userr;
157 scale = atoi(argv[++i]);
158 break;
159 case 'g':
160 if (argv[i][2] == 'e')
161 geometry = argv[++i];
162 else
163 gamcor = atof(argv[++i]);
164 break;
165 default:
166 goto userr;
167 }
168 else if (argv[i][0] == '=')
169 geometry = argv[i];
170 else
171 break;
172
173 if (i == argc-1) {
174 fname = argv[i];
175 fin = fopen(fname, "r");
176 if (fin == NULL) {
177 sprintf(errmsg, "cannot open file \"%s\"", fname);
178 quiterr(errmsg);
179 }
180 } else if (i != argc)
181 goto userr;
182 /* get header */
183 getheader(fin, headline, NULL);
184 /* get picture dimensions */
185 if (wrongformat || !fgetsresolu(&inpres, fin))
186 quiterr("bad picture format");
187 xmax = scanlen(&inpres);
188 ymax = numscans(&inpres);
189 /* set view parameters */
190 if (gotview && setview(&ourview) != NULL)
191 gotview = 0;
192 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
193 quiterr("out of memory");
194
195 init(argc, argv); /* get file and open window */
196
197 for ( ; ; )
198 getevent(); /* main loop */
199 userr:
200 fprintf(stderr,
201 "Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops] pic\n",
202 progname);
203 exit(1);
204 }
205
206
207 headline(s) /* get relevant info from header */
208 char *s;
209 {
210 char fmt[32];
211
212 if (isexpos(s))
213 exposure *= exposval(s);
214 else if (isformat(s)) {
215 formatval(fmt, s);
216 wrongformat = strcmp(fmt, COLRFMT);
217 } else if (isview(s) && sscanview(&ourview, s) > 0)
218 gotview++;
219 }
220
221
222 init(argc, argv) /* get data and open window */
223 int argc;
224 char **argv;
225 {
226 XSetWindowAttributes ourwinattr;
227 XClassHint xclshints;
228 XWMHints xwmhints;
229 XSizeHints xszhints;
230 XTextProperty windowName, iconName;
231 XGCValues xgcv;
232 char *name;
233 register int i;
234
235 if (fname != NULL) {
236 scanpos = (long *)malloc(ymax*sizeof(long));
237 if (scanpos == NULL)
238 quiterr("out of memory");
239 for (i = 0; i < ymax; i++)
240 scanpos[i] = -1;
241 name = fname;
242 } else
243 name = progname;
244 /* remove directory prefix from name */
245 for (i = strlen(name); i-- > 0; )
246 if (name[i] == '/')
247 break;
248 name += i+1;
249 if ((thedisplay = XOpenDisplay(dispname)) == NULL)
250 quiterr("cannot open display");
251 /* get best visual for default screen */
252 getbestvis();
253 /* store image */
254 getras();
255 /* get size and position */
256 xszhints.flags = 0;
257 xszhints.width = xmax; xszhints.height = ymax;
258 if (geometry != NULL) {
259 i = XParseGeometry(geometry, &xszhints.x, &xszhints.y,
260 (unsigned *)&xszhints.width,
261 (unsigned *)&xszhints.height);
262 if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
263 xszhints.flags |= USSize;
264 else
265 xszhints.flags |= PSize;
266 if ((i&(XValue|YValue)) == (XValue|YValue)) {
267 xszhints.flags |= USPosition;
268 if (i & XNegative)
269 xszhints.x += DisplayWidth(thedisplay,
270 ourscreen)-1-xszhints.width-2*BORWIDTH;
271 if (i & YNegative)
272 xszhints.y += DisplayHeight(thedisplay,
273 ourscreen)-1-xszhints.height-2*BORWIDTH;
274 }
275 }
276 /* open window */
277 ourwinattr.border_pixel = ourwhite;
278 ourwinattr.background_pixel = ourblack;
279 ourwinattr.colormap = XCreateColormap(thedisplay, ourroot,
280 ourvis.visual, AllocNone);
281 ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask|
282 ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask;
283 ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross);
284 wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y,
285 xszhints.width, xszhints.height, BORWIDTH,
286 ourvis.depth, InputOutput, ourvis.visual, CWEventMask|
287 CWCursor|CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
288 if (wind == 0)
289 quiterr("cannot create window");
290 width = xmax;
291 height = ymax;
292 xgcv.foreground = ourblack;
293 xgcv.background = ourwhite;
294 if ((xgcv.font = XLoadFont(thedisplay, FONTNAME)) == 0)
295 quiterr("cannot get font");
296 ourgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
297 GCFont, &xgcv);
298 xgcv.function = GXinvert;
299 revgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
300 GCFunction, &xgcv);
301
302 /* set up the window manager */
303 xwmhints.flags = InputHint|IconPixmapHint;
304 xwmhints.input = True;
305 xwmhints.icon_pixmap = XCreateBitmapFromData(thedisplay,
306 wind, icondata, iconwidth, iconheight);
307
308 windowName.encoding = iconName.encoding = XA_STRING;
309 windowName.format = iconName.format = 8;
310 windowName.value = (u_char *)name;
311 windowName.nitems = strlen(windowName.value);
312 iconName.value = (u_char *)name;
313 iconName.nitems = strlen(windowName.value);
314
315 xclshints.res_name = NULL;
316 xclshints.res_class = "Ximage";
317 XSetWMProperties(thedisplay, wind, &windowName, &iconName,
318 argv, argc, &xszhints, &xwmhints, &xclshints);
319 closedownAtom = XInternAtom(thedisplay, "WM_DELETE_WINDOW", False);
320 wmProtocolsAtom = XInternAtom(thedisplay, "WM_PROTOCOLS", False);
321 XSetWMProtocols(thedisplay, wind, &closedownAtom, 1);
322
323 XMapWindow(thedisplay, wind);
324 return;
325 } /* end of init */
326
327
328 quiterr(err) /* print message and exit */
329 char *err;
330 {
331 if (err != NULL) {
332 fprintf(stderr, "%s: %s\n", progname, err);
333 exit(1);
334 }
335 exit(0);
336 }
337
338
339 static int
340 viscmp(v1,v2) /* compare visual to see which is better, descending */
341 register XVisualInfo *v1, *v2;
342 {
343 int bad1 = 0, bad2 = 0;
344 register int *rp;
345
346 if (v1->class == v2->class) {
347 if (v1->class == TrueColor || v1->class == DirectColor) {
348 /* prefer 24-bit to 32-bit */
349 if (v1->depth == 24 && v2->depth == 32)
350 return(-1);
351 if (v1->depth == 32 && v2->depth == 24)
352 return(1);
353 return(0);
354 }
355 /* don't be too greedy */
356 if (maxcolors <= 1<<v1->depth && maxcolors <= 1<<v2->depth)
357 return(v1->depth - v2->depth);
358 return(v2->depth - v1->depth);
359 }
360 /* prefer Pseudo when < 24-bit */
361 if ((v1->class == TrueColor || v1->class == DirectColor) &&
362 v1->depth < 24)
363 bad1 = 1;
364 if ((v2->class == TrueColor || v2->class == DirectColor) &&
365 v2->depth < 24)
366 bad2 = -1;
367 if (bad1 | bad2)
368 return(bad1+bad2);
369 /* otherwise, use class ranking */
370 for (rp = ourrank; *rp != -1; rp++) {
371 if (v1->class == *rp)
372 return(-1);
373 if (v2->class == *rp)
374 return(1);
375 }
376 return(0);
377 }
378
379
380 getbestvis() /* get the best visual for this screen */
381 {
382 #ifdef DEBUG
383 static char vistype[][12] = {
384 "StaticGray",
385 "GrayScale",
386 "StaticColor",
387 "PseudoColor",
388 "TrueColor",
389 "DirectColor"
390 };
391 #endif
392 static int rankings[3][6] = {
393 {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1},
394 {PseudoColor,GrayScale,StaticGray,-1},
395 {PseudoColor,GrayScale,StaticGray,-1}
396 };
397 XVisualInfo *xvi;
398 int vismatched;
399 register int i, j;
400
401 if (greyscale) {
402 ourrank = rankings[2];
403 if (maxcolors < 2) maxcolors = 256;
404 } else if (maxcolors >= 2 && maxcolors <= 256)
405 ourrank = rankings[1];
406 else {
407 ourrank = rankings[0];
408 maxcolors = 256;
409 }
410 /* find best visual */
411 ourvis.screen = ourscreen;
412 xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched);
413 if (xvi == NULL)
414 quiterr("no visuals for this screen!");
415 #ifdef DEBUG
416 fprintf(stderr, "Supported visuals:\n");
417 for (i = 0; i < vismatched; i++)
418 fprintf(stderr, "\ttype %s, depth %d\n",
419 vistype[xvi[i].class], xvi[i].depth);
420 #endif
421 for (i = 0, j = 1; j < vismatched; j++)
422 if (viscmp(&xvi[i],&xvi[j]) > 0)
423 i = j;
424 /* compare to least acceptable */
425 for (j = 0; ourrank[j++] != -1; )
426 ;
427 ourvis.class = ourrank[--j];
428 ourvis.depth = 1;
429 if (viscmp(&xvi[i],&ourvis) > 0)
430 quiterr("inadequate visuals on this screen");
431 /* OK, we'll use it */
432 copystruct(&ourvis, &xvi[i]);
433 #ifdef DEBUG
434 fprintf(stderr, "Selected visual type %s, depth %d\n",
435 vistype[ourvis.class], ourvis.depth);
436 #endif
437 /* make appropriate adjustments */
438 if (ourvis.class == GrayScale || ourvis.class == StaticGray)
439 greyscale = 1;
440 if (ourvis.depth <= 8 && ourvis.colormap_size < maxcolors)
441 maxcolors = ourvis.colormap_size;
442 if (ourvis.class == StaticGray) {
443 ourblack = 0;
444 ourwhite = 255;
445 } else if (ourvis.class == PseudoColor) {
446 ourblack = BlackPixel(thedisplay,ourscreen);
447 ourwhite = WhitePixel(thedisplay,ourscreen);
448 if ((ourblack|ourwhite) & ~255L) {
449 ourblack = 0;
450 ourwhite = 1;
451 }
452 if (maxcolors > 4)
453 maxcolors -= 2;
454 } else {
455 ourblack = 0;
456 ourwhite = ourvis.red_mask|ourvis.green_mask|ourvis.blue_mask;
457 }
458 XFree((char *)xvi);
459 }
460
461
462 getras() /* get raster file */
463 {
464 XVisualInfo vinfo;
465
466 if (maxcolors <= 2) { /* monochrome */
467 ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
468 if (ourdata == NULL)
469 goto fail;
470 ourras = make_raster(thedisplay, &ourvis, 1, ourdata,
471 xmax, ymax, 8);
472 if (ourras == NULL)
473 goto fail;
474 getmono();
475 } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) {
476 ourdata = (unsigned char *)malloc(sizeof(int4)*xmax*ymax);
477 if (ourdata == NULL)
478 goto fail;
479 ourras = make_raster(thedisplay, &ourvis, sizeof(int4)*8,
480 ourdata, xmax, ymax, 32);
481 if (ourras == NULL)
482 goto fail;
483 getfull();
484 } else {
485 ourdata = (unsigned char *)malloc(xmax*ymax);
486 if (ourdata == NULL)
487 goto fail;
488 ourras = make_raster(thedisplay, &ourvis, 8, ourdata,
489 xmax, ymax, 8);
490 if (ourras == NULL)
491 goto fail;
492 if (greyscale | ourvis.class == StaticGray)
493 getgrey();
494 else
495 getmapped();
496 if (ourvis.class != StaticGray && !init_rcolors(ourras,clrtab))
497 goto fail;
498 }
499 return;
500 fail:
501 quiterr("could not create raster image");
502 }
503
504
505 getevent() /* process the next event */
506 {
507 XEvent xev;
508
509 XNextEvent(thedisplay, &xev);
510 switch ((int)xev.type) {
511 case KeyPress:
512 docom(&xev.xkey);
513 break;
514 case ConfigureNotify:
515 width = xev.xconfigure.width;
516 height = xev.xconfigure.height;
517 break;
518 case MapNotify:
519 map_rcolors(ourras, wind);
520 if (fast)
521 make_rpixmap(ourras, wind);
522 break;
523 case UnmapNotify:
524 if (!fast)
525 unmap_rcolors(ourras);
526 break;
527 case Expose:
528 redraw(xev.xexpose.x, xev.xexpose.y,
529 xev.xexpose.width, xev.xexpose.height);
530 break;
531 case ButtonPress:
532 if (xev.xbutton.state & (ShiftMask|ControlMask))
533 moveimage(&xev.xbutton);
534 else if (xev.xbutton.button == Button2)
535 traceray(xev.xbutton.x, xev.xbutton.y);
536 else
537 getbox(&xev.xbutton);
538 break;
539 case ClientMessage:
540 if ((xev.xclient.message_type == wmProtocolsAtom) &&
541 (xev.xclient.data.l[0] == closedownAtom))
542 quiterr(NULL);
543 break;
544 }
545 }
546
547
548 traceray(xpos, ypos) /* print ray corresponding to pixel */
549 int xpos, ypos;
550 {
551 FLOAT hv[2];
552 FVECT rorg, rdir;
553
554 if (!gotview) { /* no view, no can do */
555 XBell(thedisplay, 0);
556 return(-1);
557 }
558 pix2loc(hv, &inpres, xpos-xoff, ypos-yoff);
559 if (viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0)
560 return(-1);
561 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
562 printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
563 fflush(stdout);
564 return(0);
565 }
566
567
568 docom(ekey) /* execute command */
569 XKeyPressedEvent *ekey;
570 {
571 char buf[80];
572 COLOR cval;
573 XColor cvx;
574 int com, n;
575 double comp;
576 FLOAT hv[2];
577
578 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
579 if (n == 0)
580 return(0);
581 com = buf[0];
582 switch (com) { /* interpret command */
583 case 'q':
584 case 'Q':
585 case CTRL('D'): /* quit */
586 quiterr(NULL);
587 case '\n':
588 case '\r':
589 case 'l':
590 case 'c': /* value */
591 if (avgbox(cval) == -1)
592 return(-1);
593 switch (com) {
594 case '\n':
595 case '\r': /* radiance */
596 sprintf(buf, "%.3f", intens(cval)/exposure);
597 break;
598 case 'l': /* luminance */
599 sprintf(buf, "%.0fL", luminance(cval)/exposure);
600 break;
601 case 'c': /* color */
602 comp = pow(2.0, (double)scale);
603 sprintf(buf, "(%.2f,%.2f,%.2f)",
604 colval(cval,RED)*comp,
605 colval(cval,GRN)*comp,
606 colval(cval,BLU)*comp);
607 break;
608 }
609 XDrawImageString(thedisplay, wind, ourgc,
610 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
611 return(0);
612 case 'i': /* identify (contour) */
613 if (ourras->pixels == NULL)
614 return(-1);
615 n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
616 n = ourras->pmap[n];
617 cvx.pixel = ourras->cdefs[n].pixel;
618 cvx.red = random() & 65535;
619 cvx.green = random() & 65535;
620 cvx.blue = random() & 65535;
621 cvx.flags = DoRed|DoGreen|DoBlue;
622 XStoreColor(thedisplay, ourras->cmap, &cvx);
623 return(0);
624 case 'p': /* position */
625 pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff);
626 sprintf(buf, "(%d,%d)", (int)(hv[0]*inpres.xr),
627 (int)(hv[1]*inpres.yr));
628 XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
629 buf, strlen(buf));
630 return(0);
631 case 't': /* trace */
632 return(traceray(ekey->x, ekey->y));
633 case '=': /* adjust exposure */
634 case '@': /* adaptation level */
635 if (avgbox(cval) == -1)
636 return(-1);
637 comp = com=='@'
638 ? 106./pow(1.219+pow(luminance(cval)/exposure,.4),2.5)/exposure
639 : .5/bright(cval) ;
640 comp = log(comp)/.69315 - scale;
641 n = comp < 0 ? comp-.5 : comp+.5 ; /* round */
642 if (n == 0)
643 return(0);
644 scale_rcolors(ourras, pow(2.0, (double)n));
645 scale += n;
646 sprintf(buf, "%+d", scale);
647 XDrawImageString(thedisplay, wind, ourgc,
648 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
649 XFlush(thedisplay);
650 free(ourdata);
651 free_raster(ourras);
652 getras();
653 /* fall through */
654 case CTRL('R'): /* redraw */
655 case CTRL('L'):
656 unmap_rcolors(ourras);
657 XClearWindow(thedisplay, wind);
658 map_rcolors(ourras, wind);
659 if (fast)
660 make_rpixmap(ourras, wind);
661 redraw(0, 0, width, height);
662 return(0);
663 case 'f': /* turn on fast redraw */
664 fast = 1;
665 make_rpixmap(ourras, wind);
666 return(0);
667 case 'F': /* turn off fast redraw */
668 fast = 0;
669 free_rpixmap(ourras);
670 return(0);
671 case '0': /* recenter origin */
672 if (xoff == 0 & yoff == 0)
673 return(0);
674 xoff = yoff = 0;
675 XClearWindow(thedisplay, wind);
676 redraw(0, 0, width, height);
677 return(0);
678 case ' ': /* clear */
679 redraw(box.xmin, box.ymin, box.xsiz, box.ysiz);
680 return(0);
681 default:
682 XBell(thedisplay, 0);
683 return(-1);
684 }
685 }
686
687
688 moveimage(ebut) /* shift the image */
689 XButtonPressedEvent *ebut;
690 {
691 XEvent e;
692 int mxo, myo;
693
694 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
695 while (e.type == MotionNotify) {
696 mxo = e.xmotion.x;
697 myo = e.xmotion.y;
698 revline(ebut->x, ebut->y, mxo, myo);
699 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
700 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
701 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
702 revline(ebut->x, ebut->y, mxo, myo);
703 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
704 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
705 }
706 xoff += e.xbutton.x - ebut->x;
707 yoff += e.xbutton.y - ebut->y;
708 XClearWindow(thedisplay, wind);
709 redraw(0, 0, width, height);
710 }
711
712
713 getbox(ebut) /* get new box */
714 XButtonPressedEvent *ebut;
715 {
716 XEvent e;
717
718 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
719 while (e.type == MotionNotify) {
720 revbox(ebut->x, ebut->y, box.xmin = e.xmotion.x, box.ymin = e.xmotion.y);
721 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
722 revbox(ebut->x, ebut->y, box.xmin, box.ymin);
723 }
724 box.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x);
725 box.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y);
726 if (box.xmin > ebut->x) {
727 box.xsiz = box.xmin - ebut->x + 1;
728 box.xmin = ebut->x;
729 } else {
730 box.xsiz = ebut->x - box.xmin + 1;
731 }
732 if (box.ymin > ebut->y) {
733 box.ysiz = box.ymin - ebut->y + 1;
734 box.ymin = ebut->y;
735 } else {
736 box.ysiz = ebut->y - box.ymin + 1;
737 }
738 }
739
740
741 revbox(x0, y0, x1, y1) /* draw box with reversed lines */
742 int x0, y0, x1, y1;
743 {
744 revline(x0, y0, x1, y0);
745 revline(x0, y1, x1, y1);
746 revline(x0, y0, x0, y1);
747 revline(x1, y0, x1, y1);
748 }
749
750
751 avgbox(clr) /* average color over current box */
752 COLOR clr;
753 {
754 static COLOR lc;
755 static int ll, lr, lt, lb;
756 int left, right, top, bottom;
757 int y;
758 double d;
759 COLOR ctmp;
760 register int x;
761
762 setcolor(clr, 0.0, 0.0, 0.0);
763 left = box.xmin - xoff;
764 right = left + box.xsiz;
765 if (left < 0)
766 left = 0;
767 if (right > xmax)
768 right = xmax;
769 if (left >= right)
770 return(-1);
771 top = box.ymin - yoff;
772 bottom = top + box.ysiz;
773 if (top < 0)
774 top = 0;
775 if (bottom > ymax)
776 bottom = ymax;
777 if (top >= bottom)
778 return(-1);
779 if (left == ll && right == lr && top == lt && bottom == lb) {
780 copycolor(clr, lc);
781 return(0);
782 }
783 for (y = top; y < bottom; y++) {
784 if (getscan(y) == -1)
785 return(-1);
786 for (x = left; x < right; x++) {
787 colr_color(ctmp, scanline[x]);
788 addcolor(clr, ctmp);
789 }
790 }
791 d = 1.0/((right-left)*(bottom-top));
792 scalecolor(clr, d);
793 ll = left; lr = right; lt = top; lb = bottom;
794 copycolor(lc, clr);
795 return(0);
796 }
797
798
799 getmono() /* get monochrome data */
800 {
801 register unsigned char *dp;
802 register int x, err;
803 int y, errp;
804 short *cerr;
805
806 if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
807 quiterr("out of memory in getmono");
808 dp = ourdata - 1;
809 for (y = 0; y < ymax; y++) {
810 getscan(y);
811 add2icon(y, scanline);
812 normcolrs(scanline, xmax, scale);
813 err = 0;
814 for (x = 0; x < xmax; x++) {
815 if (!(x&7))
816 *++dp = 0;
817 errp = err;
818 err += normbright(scanline[x]) + cerr[x];
819 if (err > 127)
820 err -= 255;
821 else
822 *dp |= 1<<(7-(x&07));
823 err /= 3;
824 cerr[x] = err + errp;
825 }
826 }
827 free((char *)cerr);
828 }
829
830
831 add2icon(y, scan) /* add a scanline to our icon data */
832 int y;
833 COLR *scan;
834 {
835 static short cerr[ICONSIZ];
836 static int ynext;
837 static char *dp;
838 COLR clr;
839 register int err;
840 register int x, ti;
841 int errp;
842
843 if (iconheight == 0) { /* initialize */
844 if (xmax <= ICONSIZ && ymax <= ICONSIZ) {
845 iconwidth = xmax;
846 iconheight = ymax;
847 } else if (xmax > ymax) {
848 iconwidth = ICONSIZ;
849 iconheight = ICONSIZ*ymax/xmax;
850 if (iconheight < 1)
851 iconheight = 1;
852 } else {
853 iconwidth = ICONSIZ*xmax/ymax;
854 if (iconwidth < 1)
855 iconwidth = 1;
856 iconheight = ICONSIZ;
857 }
858 ynext = 0;
859 dp = icondata - 1;
860 }
861 if (y < ynext*ymax/iconheight) /* skip this one */
862 return;
863 err = 0;
864 for (x = 0; x < iconwidth; x++) {
865 if (!(x&7))
866 *++dp = 0;
867 errp = err;
868 ti = x*xmax/iconwidth;
869 copycolr(clr, scan[ti]);
870 normcolrs(clr, 1, scale);
871 err += normbright(clr) + cerr[x];
872 if (err > 127)
873 err -= 255;
874 else
875 *dp |= 1<<(x&07);
876 err /= 3;
877 cerr[x] = err + errp;
878 }
879 ynext++;
880 }
881
882
883 getfull() /* get full (24-bit) data */
884 {
885 int y;
886 register unsigned int4 *dp;
887 register int x;
888 /* set gamma correction */
889 setcolrgam(gamcor);
890 /* read and convert file */
891 dp = (unsigned int4 *)ourdata;
892 for (y = 0; y < ymax; y++) {
893 getscan(y);
894 add2icon(y, scanline);
895 if (scale)
896 shiftcolrs(scanline, xmax, scale);
897 colrs_gambs(scanline, xmax);
898 if (ourras->image->blue_mask & 1)
899 for (x = 0; x < xmax; x++)
900 *dp++ = scanline[x][RED] << 16 |
901 scanline[x][GRN] << 8 |
902 scanline[x][BLU] ;
903 else
904 for (x = 0; x < xmax; x++)
905 *dp++ = scanline[x][RED] |
906 scanline[x][GRN] << 8 |
907 scanline[x][BLU] << 16 ;
908 }
909 }
910
911
912 getgrey() /* get greyscale data */
913 {
914 int y;
915 register unsigned char *dp;
916 register int x;
917 /* set gamma correction */
918 setcolrgam(gamcor);
919 /* read and convert file */
920 dp = ourdata;
921 for (y = 0; y < ymax; y++) {
922 getscan(y);
923 add2icon(y, scanline);
924 if (scale)
925 shiftcolrs(scanline, xmax, scale);
926 for (x = 0; x < xmax; x++)
927 scanline[x][GRN] = normbright(scanline[x]);
928 colrs_gambs(scanline, xmax);
929 if (maxcolors < 256)
930 for (x = 0; x < xmax; x++)
931 *dp++ = ((long)scanline[x][GRN] *
932 maxcolors + maxcolors/2) >> 8;
933 else
934 for (x = 0; x < xmax; x++)
935 *dp++ = scanline[x][GRN];
936 }
937 for (x = 0; x < maxcolors; x++)
938 clrtab[x][RED] = clrtab[x][GRN] =
939 clrtab[x][BLU] = ((long)x*256 + 128)/maxcolors;
940 }
941
942
943 getmapped() /* get color-mapped data */
944 {
945 int y;
946 /* set gamma correction */
947 setcolrgam(gamcor);
948 /* make histogram */
949 new_histo();
950 for (y = 0; y < ymax; y++) {
951 if (getscan(y) < 0)
952 quiterr("seek error in getmapped");
953 add2icon(y, scanline);
954 if (scale)
955 shiftcolrs(scanline, xmax, scale);
956 colrs_gambs(scanline, xmax);
957 cnt_colrs(scanline, xmax);
958 }
959 /* map pixels */
960 if (!new_clrtab(maxcolors))
961 quiterr("cannot create color map");
962 for (y = 0; y < ymax; y++) {
963 if (getscan(y) < 0)
964 quiterr("seek error in getmapped");
965 if (scale)
966 shiftcolrs(scanline, xmax, scale);
967 colrs_gambs(scanline, xmax);
968 if (dither)
969 dith_colrs(ourdata+y*xmax, scanline, xmax);
970 else
971 map_colrs(ourdata+y*xmax, scanline, xmax);
972 }
973 }
974
975
976 scale_rcolors(xr, sf) /* scale color map */
977 register XRASTER *xr;
978 double sf;
979 {
980 register int i;
981 long maxv;
982
983 if (xr->pixels == NULL)
984 return;
985
986 sf = pow(sf, 1.0/gamcor);
987 maxv = 65535/sf;
988
989 for (i = xr->ncolors; i--; ) {
990 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
991 65535 :
992 xr->cdefs[i].red * sf;
993 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
994 65535 :
995 xr->cdefs[i].green * sf;
996 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
997 65535 :
998 xr->cdefs[i].blue * sf;
999 }
1000 XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
1001 }
1002
1003
1004 getscan(y)
1005 int y;
1006 {
1007 if (y != cury) {
1008 if (scanpos == NULL || scanpos[y] == -1)
1009 return(-1);
1010 if (fseek(fin, scanpos[y], 0) == -1)
1011 quiterr("fseek error");
1012 cury = y;
1013 } else if (scanpos != NULL && scanpos[y] == -1)
1014 scanpos[y] = ftell(fin);
1015
1016 if (freadcolrs(scanline, xmax, fin) < 0)
1017 quiterr("read error");
1018
1019 cury++;
1020 return(0);
1021 }
