--- ray/src/px/x11image.c 1991/05/01 12:40:00 1.16 +++ ray/src/px/x11image.c 1991/12/23 23:20:09 2.3 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -30,14 +30,16 @@ static char SCCSid[] = "$SunId$ LBL"; #include "pic.h" #include "x11raster.h" #include "random.h" -#include "x11icon.h" +#include "resolu.h" #define FONTNAME "8x13" /* text font we'll use */ -#define CTRL(c) ('c'-'@') +#define CTRL(c) ((c)-'@') #define BORWIDTH 5 /* border width */ +#define ICONSIZ (8*10) /* maximum icon dimension (even 8) */ + #define ourscreen DefaultScreen(thedisplay) #define ourblack BlackPixel(thedisplay,ourscreen) #define ourwhite WhitePixel(thedisplay,ourscreen) @@ -69,7 +71,8 @@ int gotview = 0; /* got parameters from file */ COLR *scanline; /* scan line buffer */ -int xmax, ymax; /* picture resolution */ +RESOLU inpres; /* input resolution and ordering */ +int xmax, ymax; /* picture dimensions */ int width, height; /* window size */ char *fname = NULL; /* input file name */ FILE *fin = stdin; /* input file */ @@ -91,6 +94,9 @@ struct { char *geometry = NULL; /* geometry specification */ +char icondata[ICONSIZ*ICONSIZ/8]; /* icon bitmap data */ +int iconwidth = 0, iconheight = 0; + char *progname; char errmsg[128]; @@ -99,7 +105,7 @@ extern long ftell(); extern char *malloc(), *calloc(); -extern double atof(), pow(), log(); +extern double pow(), log(); Display *thedisplay; @@ -161,8 +167,10 @@ char *argv[]; /* get header */ getheader(fin, headline, NULL); /* get picture dimensions */ - if (wrongformat || fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) + if (wrongformat || !fgetsresolu(&inpres, fin)) quiterr("bad picture format"); + xmax = scanlen(&inpres); + ymax = numscans(&inpres); /* set view parameters */ if (gotview && setview(&ourview) != NULL) gotview = 0; @@ -242,9 +250,9 @@ init() /* get data and open window */ XSetFont(thedisplay, ourgc, fontid); revgc = XCreateGC(thedisplay, wind, 0, 0); XSetFunction(thedisplay, revgc, GXinvert); - XStoreName(thedisplay, wind, fname == NULL ? progname : fname); XDefineCursor(thedisplay, wind, XCreateFontCursor(thedisplay, XC_diamond_cross)); + XStoreName(thedisplay, wind, fname == NULL ? progname : fname); if (geometry != NULL) { bzero((char *)&oursizhints, sizeof(oursizhints)); i = XParseGeometry(geometry, &oursizhints.x, &oursizhints.y, @@ -271,7 +279,7 @@ init() /* get data and open window */ ourxwmhints.flags = InputHint|IconPixmapHint; ourxwmhints.input = True; ourxwmhints.icon_pixmap = XCreateBitmapFromData(thedisplay, - wind, x11icon_bits, x11icon_width, x11icon_height); + wind, icondata, iconwidth, iconheight); XSetWMHints(thedisplay, wind, &ourxwmhints); XSelectInput(thedisplay, wind, ButtonPressMask|ButtonReleaseMask |ButtonMotionMask|StructureNotifyMask @@ -402,6 +410,7 @@ XKeyPressedEvent *ekey; XColor cvx; int com, n; double comp; + FLOAT hv[2]; FVECT rorg, rdir; n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL); @@ -410,7 +419,7 @@ XKeyPressedEvent *ekey; com = buf[0]; switch (com) { /* interpret command */ case 'q': - case CTRL(D): /* quit */ + case CTRL('D'): /* quit */ quit(0); case '\n': case '\r': @@ -450,7 +459,9 @@ XKeyPressedEvent *ekey; XStoreColor(thedisplay, ourras->cmap, &cvx); return(0); case 'p': /* position */ - sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff); + pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff); + sprintf(buf, "(%d,%d)", (int)(hv[0]*inpres.xr), + (int)(hv[1]*inpres.yr)); XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y, buf, strlen(buf)); return(0); @@ -459,9 +470,8 @@ XKeyPressedEvent *ekey; XBell(thedisplay, 0); return(-1); } - if (viewray(rorg, rdir, &ourview, - (ekey->x-xoff+.5)/xmax, - (ymax-1-ekey->y+yoff+.5)/ymax) < 0) + pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff); + if (viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0) return(-1); printf("%e %e %e ", rorg[0], rorg[1], rorg[2]); printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]); @@ -483,8 +493,8 @@ XKeyPressedEvent *ekey; free_raster(ourras); getras(); /* fall through */ - case CTRL(R): /* redraw */ - case CTRL(L): + case CTRL('R'): /* redraw */ + case CTRL('L'): unmap_rcolors(ourras); XClearWindow(thedisplay, wind); map_rcolors(ourras, wind); @@ -576,6 +586,8 @@ int x0, y0, x1, y1; avgbox(clr) /* average color over current box */ COLOR clr; { + static COLOR lc; + static int ll, lr, lt, lb; int left, right, top, bottom; int y; double d; @@ -599,6 +611,10 @@ COLOR clr; bottom = ymax; if (top >= bottom) return(-1); + if (left == ll && right == lr && top == lt && bottom == lb) { + copycolor(clr, lc); + return; + } for (y = top; y < bottom; y++) { if (getscan(y) == -1) return(-1); @@ -609,6 +625,8 @@ COLOR clr; } d = 1.0/((right-left)*(bottom-top)); scalecolor(clr, d); + ll = left; lr = right; lt = top; lb = bottom; + copycolor(lc, clr); return(0); } @@ -617,7 +635,7 @@ getmono() /* get monochrome data */ { register unsigned char *dp; register int x, err; - int y; + int y, errp; short *cerr; if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL) @@ -627,22 +645,74 @@ getmono() /* get monochrome data */ if (getscan(y) < 0) quiterr("seek error in getmono"); normcolrs(scanline, xmax, scale); + add2icon(y, scanline); err = 0; for (x = 0; x < xmax; x++) { if (!(x&7)) *++dp = 0; + errp = err; err += normbright(scanline[x]) + cerr[x]; if (err > 127) err -= 255; else *dp |= 1<<(7-(x&07)); - cerr[x] = err >>= 1; + err /= 3; + cerr[x] = err + errp; } } free((char *)cerr); } +add2icon(y, scan) /* add a scanline to our icon data */ +int y; +COLR *scan; +{ + static short cerr[ICONSIZ]; + static int ynext; + static char *dp; + register int err; + register int x, ti; + int errp; + + if (iconheight == 0) { /* initialize */ + if (xmax <= ICONSIZ && ymax <= ICONSIZ) { + iconwidth = xmax; + iconheight = ymax; + } else if (xmax > ymax) { + iconwidth = ICONSIZ; + iconheight = ICONSIZ*ymax/xmax; + if (iconheight < 1) + iconheight = 1; + } else { + iconwidth = ICONSIZ*xmax/ymax; + if (iconwidth < 1) + iconwidth = 1; + iconheight = ICONSIZ; + } + ynext = 0; + dp = icondata - 1; + } + if (y < ynext*ymax/iconheight) /* skip this one */ + return; + err = 0; + for (x = 0; x < iconwidth; x++) { + if (!(x&7)) + *++dp = 0; + errp = err; + ti = x*xmax/iconwidth; + err += normbright(scan[ti]) + cerr[x]; + if (err > 127) + err -= 255; + else + *dp |= 1<<(x&07); + err /= 3; + cerr[x] = err + errp; + } + ynext++; +} + + getfull() /* get full (24-bit) data */ { int y; @@ -658,6 +728,7 @@ getfull() /* get full (24-bit) data */ if (scale) shiftcolrs(scanline, xmax, scale); colrs_gambs(scanline, xmax); + add2icon(y, scanline); for (x = 0; x < xmax; x++) { *dp++ = scanline[x][RED]; *dp++ = scanline[x][GRN]; @@ -725,6 +796,7 @@ register rgbpixel *l3; quiterr("cannot seek for picreadline"); /* convert scanline */ normcolrs(scanline, xmax, scale); + add2icon(y, scanline); for (i = 0; i < xmax; i++) { l3[i].r = scanline[i][RED]; l3[i].g = scanline[i][GRN];
