--- ray/src/px/x11image.c 2003/07/27 22:12:03 2.64 +++ ray/src/px/x11image.c 2008/11/10 19:08:19 2.73 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id"; +static const char RCSid[] = "$Id: x11image.c,v 2.73 2008/11/10 19:08:19 greg Exp $"; #endif /* * x11image.c - driver for X-windows @@ -20,6 +20,9 @@ static const char RCSid[] = "$Id"; #include #include +#include +#include +#include #include #include #include @@ -27,6 +30,7 @@ static const char RCSid[] = "$Id"; #include "color.h" #include "tonemap.h" +#include "clrtab.h" #include "view.h" #include "x11raster.h" #include "random.h" @@ -94,6 +98,9 @@ double exposure = 1.0; /* exposure compensation use int wrongformat = 0; /* input in another format? */ +TMstruct *tmGlobal; /* base tone-mapping */ +TMstruct *tmCurrent; /* curren tone-mapping */ + GC ourgc; /* standard graphics context */ GC revgc; /* graphics context with GXinvert */ @@ -117,10 +124,7 @@ char errmsg[128]; BYTE clrtab[256][3]; /* global color map */ -extern long ftell(); -extern char *getenv(); - Display *thedisplay; Atom closedownAtom, wmProtocolsAtom; @@ -128,12 +132,39 @@ int sigrecv; void onsig(int i) { sigrecv++; } +typedef void doboxf_t(COLR *scn, int n, void *); -main(argc, argv) -int argc; -char *argv[]; +static gethfunc headline; +static void init(int argc, char **argv); +static void quiterr(char *err); +static int viscmp(XVisualInfo *v1, XVisualInfo *v2); +static void getbestvis(void); +static void getras(void); +static void getevent(void); +static int traceray(int xpos, int ypos); +static int docom(XKeyPressedEvent *ekey); +static void moveimage(XButtonPressedEvent *ebut); +static void getbox(XButtonPressedEvent *ebut); +static void trackrays(XButtonPressedEvent *ebut); +static void revbox(int x0, int y0, int x1, int y1); +static doboxf_t colavg; +static doboxf_t addfix; +static int avgbox(COLOR cavg); +static int dobox(doboxf_t *f, void *p); +static void make_tonemap(void); +static void tmap_colrs(COLR *scn, int len); +static void getmono(void); +static void add2icon(int y, COLR *scan); +static void getfull(void); +static void getgrey(void); +static void getmapped(void); +static void scale_rcolors(XRASTER *xr, double sf); +static int getscan(int y); + + +int +main(int argc, char *argv[]) { - int headline(); int i; int pid; @@ -240,15 +271,17 @@ char *argv[]; getevent(); /* main loop */ userr: fprintf(stderr, -"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e spec][-g gamcor][-s][-ospec][-t intvl] pic ..\n", +"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e spec][-g gamcor][-s][-ospec][-t intvl] hdr ..\n", progname); exit(1); } -int -headline(s) /* get relevant info from header */ -char *s; +static int +headline( /* get relevant info from header */ + char *s, + void *p +) { char fmt[32]; @@ -262,9 +295,11 @@ char *s; } -init(argc, argv) /* get data and open window */ -int argc; -char **argv; +static void +init( /* get data and open window */ + int argc, + char **argv +) { XSetWindowAttributes ourwinattr; XClassHint xclshints; @@ -362,9 +397,9 @@ char **argv; windowName.encoding = iconName.encoding = XA_STRING; windowName.format = iconName.format = 8; windowName.value = (u_char *)name; - windowName.nitems = strlen(windowName.value); + windowName.nitems = strlen((char *)windowName.value); iconName.value = (u_char *)name; - iconName.nitems = strlen(windowName.value); + iconName.nitems = strlen((char *)windowName.value); xclshints.res_name = NULL; xclshints.res_class = "Ximage"; @@ -378,8 +413,10 @@ char **argv; } /* end of init */ -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { register int es; int cs; @@ -401,32 +438,34 @@ char *err; static int -viscmp(v1,v2) /* compare visual to see which is better, descending */ -register XVisualInfo *v1, *v2; +viscmp( /* compare visual to see which is better, descending */ + register XVisualInfo *v1, + register XVisualInfo *v2 +) { int bad1 = 0, bad2 = 0; register int *rp; if (v1->class == v2->class) { - if (v1->class == TrueColor || v1->class == DirectColor) { - /* prefer 24-bit to 32-bit */ - if (v1->depth == 24 && v2->depth == 32) + if ((v1->class == TrueColor) | (v1->class == DirectColor)) { + /* prefer 24-bit */ + if ((v1->depth == 24) & (v2->depth > 24)) return(-1); - if (v1->depth == 32 && v2->depth == 24) + if ((v1->depth > 24) & (v2->depth == 24)) return(1); /* go for maximum depth otherwise */ return(v2->depth - v1->depth); } /* don't be too greedy */ - if (maxcolors <= 1<depth && maxcolors <= 1<depth) + if ((maxcolors <= 1<depth) & (maxcolors <= 1<depth)) return(v1->depth - v2->depth); return(v2->depth - v1->depth); } /* prefer Pseudo when < 15-bit */ - if ((v1->class == TrueColor || v1->class == DirectColor) && + if ((v1->class == TrueColor) | (v1->class == DirectColor) && v1->depth < 15) bad1 = 1; - if ((v2->class == TrueColor || v2->class == DirectColor) && + if ((v2->class == TrueColor) | (v2->class == DirectColor) && v2->depth < 15) bad2 = -1; if (bad1 | bad2) @@ -442,7 +481,8 @@ register XVisualInfo *v1, *v2; } -getbestvis() /* get the best visual for this screen */ +static void +getbestvis(void) /* get the best visual for this screen */ { #ifdef DEBUG static char vistype[][12] = { @@ -524,15 +564,14 @@ static char vistype[][12] = { } -getras() /* get raster file */ +static void +getras(void) /* get raster file */ { - XVisualInfo vinfo; - if (maxcolors <= 2) { /* monochrome */ ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8)); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, 1, ourdata, + ourras = make_raster(thedisplay, &ourvis, 1, (char *)ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; @@ -543,7 +582,7 @@ getras() /* get raster file */ if (ourdata == NULL) goto fail; ourras = make_raster(thedisplay, &ourvis, datsiz*8, - ourdata, xmax, ymax, datsiz*8); + (char *)ourdata, xmax, ymax, datsiz*8); if (ourras == NULL) goto fail; getfull(); @@ -551,7 +590,7 @@ getras() /* get raster file */ ourdata = (unsigned char *)malloc(xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, 8, ourdata, + ourras = make_raster(thedisplay, &ourvis, 8, (char *)ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; @@ -568,7 +607,8 @@ fail: } -getevent() /* process the next event */ +static void +getevent(void) /* process the next event */ { XEvent xev; @@ -623,8 +663,11 @@ getevent() /* process the next event */ } -traceray(xpos, ypos) /* print requested pixel data */ -int xpos, ypos; +static int +traceray( /* print requested pixel data */ + int xpos, + int ypos +) { RREAL hv[2]; FVECT rorg, rdir; @@ -666,8 +709,10 @@ int xpos, ypos; } -docom(ekey) /* execute command */ -XKeyPressedEvent *ekey; +static int +docom( /* execute command */ + XKeyPressedEvent *ekey +) { char buf[80]; COLOR cval; @@ -810,8 +855,10 @@ XKeyPressedEvent *ekey; } -moveimage(ebut) /* shift the image */ -XButtonPressedEvent *ebut; +static void +moveimage( /* shift the image */ + XButtonPressedEvent *ebut +) { XEvent e; int mxo, myo; @@ -835,8 +882,10 @@ XButtonPressedEvent *ebut; } -getbox(ebut) /* get new bbox */ -XButtonPressedEvent *ebut; +static void +getbox( /* get new bbox */ + XButtonPressedEvent *ebut +) { XEvent e; @@ -863,8 +912,10 @@ XButtonPressedEvent *ebut; } -trackrays(ebut) /* trace rays as mouse moves */ -XButtonPressedEvent *ebut; +static void +trackrays( /* trace rays as mouse moves */ + XButtonPressedEvent *ebut +) { XEvent e; unsigned long lastrept; @@ -882,8 +933,13 @@ XButtonPressedEvent *ebut; } -revbox(x0, y0, x1, y1) /* draw bbox with reversed lines */ -int x0, y0, x1, y1; +static void +revbox( /* draw bbox with reversed lines */ + int x0, + int y0, + int x1, + int y1 +) { revline(x0, y0, x1, y0); revline(x0, y1, x1, y1); @@ -892,30 +948,32 @@ int x0, y0, x1, y1; } -void -colavg(scn, n, cavg) -register COLR *scn; -register int n; -COLOR cavg; +static void +colavg( + register COLR *scn, + register int n, + void *cavg +) { COLOR col; while (n--) { colr_color(col, *scn++); - addcolor(cavg, col); + addcolor((COLORV*)cavg, col); } } -int -avgbox(cavg) /* average color over current bbox */ -COLOR cavg; +static int +avgbox( /* average color over current bbox */ + COLOR cavg +) { double d; register int rval; setcolor(cavg, 0., 0., 0.); - rval = dobox(colavg, (char *)cavg); + rval = dobox(colavg, (void *)cavg); if (rval > 0) { d = 1./rval; scalecolor(cavg, d); @@ -924,10 +982,12 @@ COLOR cavg; } -int -dobox(f, p) /* run function over bbox */ -void (*f)(); /* function to call for each subscan */ -char *p; /* pointer to private data */ +static int +dobox( /* run function over bbox */ + //void (*f)(), /* function to call for each subscan */ + doboxf_t *f, /* function to call for each subscan */ + void *p /* pointer to private data */ +) { int left, right, top, bottom; int y; @@ -957,14 +1017,18 @@ char *p; /* pointer to private data */ } -void -addfix(scn, n) /* add fixation points to histogram */ -COLR *scn; -int n; +static void +addfix( /* add fixation points to histogram */ + COLR *scn, + int n, + void *p +) { - if (tmCvColrs(lscan, TM_NOCHROM, scn, n)) + TMstruct * tms = (TMstruct *)p; + + if (tmCvColrs(tms, lscan, TM_NOCHROM, scn, n)) goto tmerr; - if (tmAddHisto(lscan, n, FIXWEIGHT)) + if (tmAddHisto(tms, lscan, n, FIXWEIGHT)) goto tmerr; return; tmerr: @@ -972,7 +1036,8 @@ tmerr: } -make_tonemap() /* initialize tone mapping */ +static void +make_tonemap(void) /* initialize tone mapping */ { int flags, y; @@ -987,9 +1052,9 @@ make_tonemap() /* initialize tone mapping */ } flags = tmflags; /* histogram adjustment */ if (greyscale) flags |= TM_F_BW; - if (tmTop != NULL) { /* reuse old histogram if one */ - tmDone(tmTop); - tmTop->flags = flags; + if (tmGlobal != NULL) { /* reuse old histogram if one */ + tmDone(tmCurrent); tmCurrent = NULL; + tmGlobal->flags = flags; } else { /* else initialize */ if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) goto memerr; @@ -1001,23 +1066,25 @@ make_tonemap() /* initialize tone mapping */ == NULL) goto memerr; /* initialize tm library */ - if (tmInit(flags, stdprims, gamcor) == NULL) + tmGlobal = tmInit(flags, stdprims, gamcor); + if (tmGlobal == NULL) goto memerr; - if (tmSetSpace(stdprims, WHTEFFICACY/exposure)) + if (tmSetSpace(tmGlobal, stdprims, WHTEFFICACY/exposure, NULL)) goto tmerr; /* compute picture histogram */ for (y = 0; y < ymax; y++) { getscan(y); - if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax)) + if (tmCvColrs(tmGlobal, lscan, TM_NOCHROM, + scanline, xmax)) goto tmerr; - if (tmAddHisto(lscan, xmax, 1)) + if (tmAddHisto(tmGlobal, lscan, xmax, 1)) goto tmerr; } } - tmDup(); /* add fixations to duplicate map */ - dobox(addfix, NULL); + tmCurrent = tmDup(tmGlobal); /* add fixations to duplicate map */ + dobox(addfix, (void *)tmCurrent); /* (re)compute tone mapping */ - if (tmComputeMapping(gamcor, 0., 0.)) + if (tmComputeMapping(tmCurrent, gamcor, 0., 0.)) goto tmerr; return; memerr: @@ -1027,9 +1094,11 @@ tmerr: } -tmap_colrs(scn, len) /* apply tone mapping to scanline */ -register COLR *scn; -int len; +static void +tmap_colrs( /* apply tone mapping to scanline */ + register COLR *scn, + int len +) { register BYTE *ps; @@ -1041,9 +1110,9 @@ int len; } if (len > xmax) quiterr("code error 1 in tmap_colrs"); - if (tmCvColrs(lscan, cscan, scn, len)) + if (tmCvColrs(tmCurrent, lscan, cscan, scn, len)) goto tmerr; - if (tmMapPixels(pscan, lscan, cscan, len)) + if (tmMapPixels(tmCurrent, pscan, lscan, cscan, len)) goto tmerr; ps = pscan; if (greyscale) @@ -1066,7 +1135,8 @@ tmerr: } -getmono() /* get monochrome data */ +static void +getmono(void) /* get monochrome data */ { register unsigned char *dp; register int x, err; @@ -1098,9 +1168,11 @@ getmono() /* get monochrome data */ } -add2icon(y, scan) /* add a scanline to our icon data */ -int y; -COLR *scan; +static void +add2icon( /* add a scanline to our icon data */ + int y, + COLR *scan +) { static short cerr[ICONSIZ]; static int ynext; @@ -1150,7 +1222,8 @@ COLR *scan; } -getfull() /* get full (24-bit) data */ +static void +getfull(void) /* get full (24-bit) data */ { int y; register uint32 *dp; @@ -1217,7 +1290,8 @@ getfull() /* get full (24-bit) data */ } -getgrey() /* get greyscale data */ +static void +getgrey(void) /* get greyscale data */ { int y; register unsigned char *dp; @@ -1244,7 +1318,8 @@ getgrey() /* get greyscale data */ } -getmapped() /* get color-mapped data */ +static void +getmapped(void) /* get color-mapped data */ { int y; /* make sure we can do it first */ @@ -1276,9 +1351,11 @@ getmapped() /* get color-mapped data */ } -scale_rcolors(xr, sf) /* scale color map */ -register XRASTER *xr; -double sf; +static void +scale_rcolors( /* scale color map */ + register XRASTER *xr, + double sf +) { register int i; long maxv; @@ -1304,8 +1381,10 @@ double sf; } -getscan(y) -int y; +static int +getscan( + int y +) { static int trunced = -1; /* truncated file? */ skipit:
