--- ray/src/px/x11image.c 1992/05/19 14:22:46 2.5 +++ ray/src/px/x11image.c 1992/05/28 09:43:09 2.7 @@ -44,7 +44,6 @@ static char SCCSid[] = "$SunId$ LBL"; #define ourblack BlackPixel(thedisplay,ourscreen) #define ourwhite WhitePixel(thedisplay,ourscreen) #define ourroot RootWindow(thedisplay,ourscreen) -#define ourgc DefaultGC(thedisplay,ourscreen) #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1) @@ -55,6 +54,8 @@ double gamcor = 2.2; /* gamma correction */ int dither = 1; /* dither colors? */ int fast = 0; /* keep picture in Pixmap? */ +char *dispname = NULL; /* our display name */ + Window wind = 0; /* our output window */ Font fontid; /* our font */ @@ -83,9 +84,12 @@ double exposure = 1.0; /* exposure compensation use int wrongformat = 0; /* input in another format? */ +GC ourgc; /* standard graphics context */ GC revgc; /* graphics context with GXinvert */ -XRASTER *ourras; /* our stored image */ +int *ourrank; /* our visual class ranking */ +XVisualInfo ourvis; /* our visual */ +XRASTER *ourras; /* our stored image */ unsigned char *ourdata; /* our image data */ struct { @@ -131,7 +135,10 @@ char *argv[]; maxcolors = 2; break; case 'd': - dither = !dither; + if (argv[i][2] == 'i') + dispname = argv[++i]; + else + dither = !dither; break; case 'f': fast = !fast; @@ -142,7 +149,7 @@ char *argv[]; scale = atoi(argv[++i]); break; case 'g': - if (!strcmp(argv[i], "-geometry")) + if (argv[i][2] == 'e') geometry = argv[++i]; else gamcor = atof(argv[++i]); @@ -159,7 +166,7 @@ char *argv[]; fname = argv[i]; fin = fopen(fname, "r"); if (fin == NULL) { - sprintf(errmsg, "can't open file \"%s\"", fname); + sprintf(errmsg, "cannot open file \"%s\"", fname); quiterr(errmsg); } } else if (i != argc) @@ -183,7 +190,7 @@ char *argv[]; getevent(); /* main loop */ userr: fprintf(stderr, - "Usage: %s [-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n", + "Usage: %s [-display disp][-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n", progname); quit(1); } @@ -208,8 +215,8 @@ init() /* get data and open window */ { XWMHints ourxwmhints; XSetWindowAttributes ourwinattr; - XSizeHints oursizhints; - register int i; + XSizeHints oursizhints; + register int i; if (fname != NULL) { scanpos = (long *)malloc(ymax*sizeof(long)); @@ -218,31 +225,33 @@ init() /* get data and open window */ for (i = 0; i < ymax; i++) scanpos[i] = -1; } - if ((thedisplay = XOpenDisplay(NULL)) == NULL) - quiterr("can't open display; DISPLAY variable set?"); - if (maxcolors == 0) { /* get number of available colors */ - i = DisplayPlanes(thedisplay,ourscreen); - maxcolors = i > 8 ? 256 : 1< 4) maxcolors -= 2; - } + if ((thedisplay = XOpenDisplay(dispname)) == NULL) + quiterr("cannot open display"); + /* get best visual for default screen */ + getbestvis(); /* store image */ getras(); /* open window */ ourwinattr.border_pixel = ourblack; ourwinattr.background_pixel = ourwhite; + ourwinattr.colormap = XCreateColormap(thedisplay, ourroot, + ourvis.visual, AllocNone); wind = XCreateWindow(thedisplay, ourroot, 0, 0, xmax, ymax, BORWIDTH, - 0, InputOutput, ourras->visual, - CWBackPixel|CWBorderPixel, &ourwinattr); + ourvis.depth, InputOutput, ourvis.visual, + CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); if (wind == 0) - quiterr("can't create window"); + quiterr("cannot create window"); width = xmax; height = ymax; + ourgc = XCreateGC(thedisplay, wind, 0, 0); + XSetState(thedisplay, ourgc, BlackPixel(thedisplay,ourscreen), + WhitePixel(thedisplay,ourscreen), GXcopy, AllPlanes); + revgc = XCreateGC(thedisplay, wind, 0, 0); + XSetFunction(thedisplay, revgc, GXinvert); fontid = XLoadFont(thedisplay, FONTNAME); if (fontid == 0) - quiterr("can't get font"); + quiterr("cannot get font"); XSetFont(thedisplay, ourgc, fontid); - revgc = XCreateGC(thedisplay, wind, 0, 0); - XSetFunction(thedisplay, revgc, GXinvert); XDefineCursor(thedisplay, wind, XCreateFontCursor(thedisplay, XC_diamond_cross)); XStoreName(thedisplay, wind, fname == NULL ? progname : fname); @@ -309,6 +318,114 @@ int code; } +static int +viscmp(v1,v2) /* compare visual to see which is better, descending */ +register XVisualInfo *v1, *v2; +{ + int bad1 = 0, bad2 = 0; + register int *rp; + + if (v1->class == v2->class) { + if (v1->class == TrueColor || v1->class == DirectColor) { + /* prefer 24-bit to 32-bit */ + if (v1->depth == 24 && v2->depth == 32) + return(-1); + if (v1->depth == 32 && v2->depth == 24) + return(1); + return(0); + } + /* don't be too greedy */ + if (maxcolors <= 1<depth && maxcolors <= 1<depth) + return(v1->depth - v2->depth); + return(v2->depth - v1->depth); + } + /* prefer Pseudo when < 24-bit */ + if ((v1->class == TrueColor || v1->class == DirectColor) && + v1->depth < 24) + bad1 = 1; + if ((v2->class == TrueColor || v2->class == DirectColor) && + v2->depth < 24) + bad2 = -1; + if (bad1 | bad2) + return(bad1+bad2); + /* otherwise, use class ranking */ + for (rp = ourrank; *rp != -1; rp++) { + if (v1->class == *rp) + return(-1); + if (v2->class == *rp) + return(1); + } + return(0); +} + + +getbestvis() /* get the best visual for this screen */ +{ +#ifdef DEBUG +static char vistype[][12] = { + "StaticGray", + "GrayScale", + "StaticColor", + "PseudoColor", + "TrueColor", + "DirectColor" +}; +#endif + static int rankings[3][6] = { + {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1}, + {PseudoColor,GrayScale,StaticGray,-1}, + {PseudoColor,GrayScale,StaticGray,-1} + }; + XVisualInfo *xvi; + int vismatched; + register int i, j; + + if (greyscale) { + ourrank = rankings[2]; + if (maxcolors < 2) maxcolors = 256; + } else if (maxcolors >= 2 && maxcolors <= 256) + ourrank = rankings[1]; + else { + ourrank = rankings[0]; + maxcolors = 256; + } + /* find best visual */ + ourvis.screen = ourscreen; + xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched); + if (xvi == NULL) + quiterr("no visuals for this screen!"); +#ifdef DEBUG + fprintf(stderr, "Supported visuals:\n"); + for (i = 0; i < vismatched; i++) + fprintf(stderr, "\ttype %s, depth %d\n", + vistype[xvi[i].class], xvi[i].depth); +#endif + for (i = 0, j = 1; j < vismatched; j++) + if (viscmp(&xvi[i],&xvi[j]) > 0) + i = j; + /* compare to least acceptable */ + for (j = 0; ourrank[j++] != -1; ) + ; + ourvis.class = ourrank[--j]; + ourvis.depth = 1; + if (viscmp(&xvi[i],&ourvis) > 0) + quiterr("inadequate visuals on this screen"); + /* OK, we'll use it */ + copystruct(&ourvis, &xvi[i]); +#ifdef DEBUG + fprintf(stderr, "Selected visual type %s, depth %d\n", + vistype[ourvis.class], ourvis.depth); +#endif + if (ourvis.class == GrayScale || ourvis.class == StaticGray) + greyscale = 1; + if (ourvis.depth <= 8 && ourvis.colormap_size < maxcolors) + maxcolors = ourvis.colormap_size; + if (maxcolors > 4) + maxcolors -= 2; + XFree((char *)xvi); +} + + getras() /* get raster file */ { colormap ourmap; @@ -318,19 +435,17 @@ getras() /* get raster file */ ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8)); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, ourscreen, 1, ourdata, + ourras = make_raster(thedisplay, &ourvis, 1, ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; getmono(); - } else if (XMatchVisualInfo(thedisplay,ourscreen,24,TrueColor,&vinfo) - /* kludge for DirectColor */ - || XMatchVisualInfo(thedisplay,ourscreen,24,DirectColor,&vinfo)) { - ourdata = (unsigned char *)malloc(xmax*ymax*3); + } else if (ourvis.class == TrueColor || ourvis.class == DirectColor) { + ourdata = (unsigned char *)malloc(4*xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, ourscreen, 24, ourdata, - xmax, ymax, 8); + ourras = make_raster(thedisplay, &ourvis, 32, + ourdata, xmax, ymax, 32); if (ourras == NULL) goto fail; getfull(); @@ -338,18 +453,23 @@ getras() /* get raster file */ ourdata = (unsigned char *)malloc(xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, ourscreen, 8, ourdata, + ourras = make_raster(thedisplay, &ourvis, 8, ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; - if (greyscale) - biq(dither,maxcolors,1,ourmap); - else - ciq(dither,maxcolors,1,ourmap); - if (init_rcolors(ourras, ourmap[0], ourmap[1], ourmap[2]) == 0) - goto fail; + if (ourvis.class == StaticGray) + getgrey(); + else { + if (greyscale) + biq(dither,maxcolors,1,ourmap); + else + ciq(dither,maxcolors,1,ourmap); + if (init_rcolors(ourras, ourmap[0], + ourmap[1], ourmap[2]) == 0) + goto fail; + } } - return; + return; fail: quiterr("could not create raster image"); } @@ -377,10 +497,11 @@ getevent() /* process the next event */ case MapNotify: map_rcolors(ourras, wind); if (fast) - make_rpixmap(ourras); + make_rpixmap(ourras, wind); break; case UnmapNotify: - unmap_rcolors(ourras); + if (!fast) + unmap_rcolors(ourras); break; case Expose: redraw(e.e.x, e.e.y, e.e.width, e.e.height); @@ -709,6 +830,36 @@ COLR *scan; getfull() /* get full (24-bit) data */ { int y; + register unsigned long *dp; + register int x; + /* set gamma correction */ + setcolrgam(gamcor); + /* read and convert file */ + dp = (unsigned long *)ourdata; + for (y = 0; y < ymax; y++) { + if (getscan(y) < 0) + quiterr("seek error in getfull"); + if (scale) + shiftcolrs(scanline, xmax, scale); + colrs_gambs(scanline, xmax); + add2icon(y, scanline); + if (ourras->image->blue_mask & 1) + for (x = 0; x < xmax; x++) + *dp++ = scanline[x][RED] << 16 | + scanline[x][GRN] << 8 | + scanline[x][BLU] ; + else + for (x = 0; x < xmax; x++) + *dp++ = scanline[x][RED] | + scanline[x][GRN] << 8 | + scanline[x][BLU] << 16 ; + } +} + + +getgrey() /* get greyscale data */ +{ + int y; register unsigned char *dp; register int x; /* set gamma correction */ @@ -722,11 +873,13 @@ getfull() /* get full (24-bit) data */ shiftcolrs(scanline, xmax, scale); colrs_gambs(scanline, xmax); add2icon(y, scanline); - for (x = 0; x < xmax; x++) { /* BGR byte ordering */ - *dp++ = scanline[x][BLU]; - *dp++ = scanline[x][GRN]; - *dp++ = scanline[x][RED]; - } + if (ourvis.colormap_size < 256) + for (x = 0; x < xmax; x++) + *dp++ = ((long)normbright(scanline[x]) * + ourvis.colormap_size + 128) >> 8; + else + for (x = 0; x < xmax; x++) + *dp++ = normbright(scanline[x]); } } @@ -822,7 +975,7 @@ colormap map; picwritecm(map) /* handled elsewhere */ colormap map; { -#ifdef DEBUG +#if 0 register int i; for (i = 0; i < 256; i++)
