--- ray/src/px/x11image.c 1997/04/15 18:33:31 2.45 +++ ray/src/px/x11image.c 2003/03/10 17:26:26 2.57 @@ -1,9 +1,6 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id"; #endif - /* * x11image.c - driver for X-windows * @@ -27,18 +24,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include -#undef NOPROTO -#define NOPROTO 1 +#include "color.h" #include "tonemap.h" #include "view.h" #include "x11raster.h" #include "random.h" -#include "resolu.h" -#ifndef int4 -#define int4 int /* most int's are 32-bit */ -#endif - #define FONTNAME "8x13" /* text font we'll use */ #define CTRL(c) ((c)-'@') @@ -47,6 +38,8 @@ static char SCCSid[] = "$SunId$ LBL"; #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */ +#define FIXWEIGHT 20 /* weight to add for fixation points */ + #define ourscreen DefaultScreen(thedisplay) #define ourroot RootWindow(thedisplay,ourscreen) @@ -78,7 +71,7 @@ int sequential = 0; /* display images in sequence * char *tout = "od"; /* output of 't' command */ int tinterv = 0; /* interval between mouse reports */ -int tmflags = -1; /* tone mapping flags (-1 for none) */ +int tmflags = TM_F_LINEAR; /* tone mapping flags */ VIEW ourview = STDVIEW; /* image view parameters */ int gotview = 0; /* got parameters from file */ @@ -92,7 +85,7 @@ RESOLU inpres; /* input resolution and ordering */ int xmax, ymax; /* picture dimensions */ int width, height; /* window size */ char *fname = NULL; /* input file name */ -FILE *fin = stdin; /* input file */ +FILE *fin = NULL; /* input file */ long *scanpos = NULL; /* scan line positions in file */ int cury = 0; /* current scan location */ @@ -110,7 +103,7 @@ unsigned char *ourdata; /* our image data */ struct { int xmin, ymin, xsiz, ysiz; -} box = {0, 0, 0, 0}; /* current box */ +} bbox = {0, 0, 0, 0}; /* current bbox */ char *geometry = NULL; /* geometry specification */ @@ -144,6 +137,7 @@ char *argv[]; int pid; progname = argv[0]; + fin = stdin; for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -178,11 +172,11 @@ char *argv[]; break; case 'e': /* exposure comp. */ i++; - if (!strcmp(argv[i], "auto")) { + if (argv[i][0] == 'a') { tmflags = TM_F_CAMERA; break; } - if (!strcmp(argv[i], "human")) { + if (argv[i][0] == 'h') { tmflags = TM_F_HUMAN; break; } @@ -251,6 +245,7 @@ userr: } +int headline(s) /* get relevant info from header */ char *s; { @@ -262,6 +257,7 @@ char *s; wrongformat = strcmp(fmt, COLRFMT); else if (isview(s) && sscanview(&ourview, s) > 0) gotview++; + return(0); } @@ -417,19 +413,20 @@ register XVisualInfo *v1, *v2; return(-1); if (v1->depth == 32 && v2->depth == 24) return(1); - return(0); + /* go for maximum depth otherwise */ + return(v2->depth - v1->depth); } /* don't be too greedy */ if (maxcolors <= 1<depth && maxcolors <= 1<depth) return(v1->depth - v2->depth); return(v2->depth - v1->depth); } - /* prefer Pseudo when < 24-bit */ + /* prefer Pseudo when < 15-bit */ if ((v1->class == TrueColor || v1->class == DirectColor) && - v1->depth < 24) + v1->depth < 15) bad1 = 1; if ((v2->class == TrueColor || v2->class == DirectColor) && - v2->depth < 24) + v2->depth < 15) bad2 = -1; if (bad1 | bad2) return(bad1+bad2); @@ -540,11 +537,12 @@ getras() /* get raster file */ goto fail; getmono(); } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) { - ourdata = (unsigned char *)malloc(sizeof(int4)*xmax*ymax); + int datsiz = ourvis.depth>16 ? sizeof(int4) : sizeof(int2); + ourdata = (unsigned char *)malloc(datsiz*xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, sizeof(int4)*8, - ourdata, xmax, ymax, 32); + ourras = make_raster(thedisplay, &ourvis, datsiz*8, + ourdata, xmax, ymax, datsiz*8); if (ourras == NULL) goto fail; getfull(); @@ -627,14 +625,13 @@ getevent() /* process the next event */ traceray(xpos, ypos) /* print requested pixel data */ int xpos, ypos; { - extern char *index(); FLOAT hv[2]; FVECT rorg, rdir; COLOR cval; register char *cp; - box.xmin = xpos; box.xsiz = 1; - box.ymin = ypos; box.ysiz = 1; + bbox.xmin = xpos; bbox.xsiz = 1; + bbox.ymin = ypos; bbox.ysiz = 1; avgbox(cval); scalecolor(cval, 1./exposure); pix2loc(hv, &inpres, xpos-xoff, ypos-yoff); @@ -691,7 +688,7 @@ XKeyPressedEvent *ekey; case '\r': case 'l': case 'c': /* value */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); switch (com) { case '\n': @@ -699,7 +696,7 @@ XKeyPressedEvent *ekey; sprintf(buf, "%.3f", intens(cval)/exposure); break; case 'l': /* luminance */ - sprintf(buf, "%.0fL", luminance(cval)/exposure); + sprintf(buf, "%.1fL", luminance(cval)/exposure); break; case 'c': /* color */ comp = pow(2.0, (double)scale); @@ -710,7 +707,7 @@ XKeyPressedEvent *ekey; break; } XDrawImageString(thedisplay, wind, ourgc, - box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); + bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf)); return(0); case 'i': /* identify (contour) */ if (ourras->pixels == NULL) @@ -733,9 +730,21 @@ XKeyPressedEvent *ekey; return(0); case 't': /* trace */ return(traceray(ekey->x, ekey->y)); + case 'a': /* auto exposure */ + if (fname == NULL) + return(-1); + tmflags = TM_F_CAMERA; + strcpy(buf, "auto exposure..."); + goto remap; + case 'h': /* human response */ + if (fname == NULL) + return(-1); + tmflags = TM_F_HUMAN; + strcpy(buf, "human exposure..."); + goto remap; case '=': /* adjust exposure */ case '@': /* adaptation level */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); comp = bright(cval); if (comp < 1e-20) { @@ -749,8 +758,8 @@ XKeyPressedEvent *ekey; comp = .5/comp; comp = log(comp)/.69315 - scale; n = comp < 0 ? comp-.5 : comp+.5 ; /* round */ - if (tmflags != -1) - tmflags = -1; /* turn off tone mapping */ + if (tmflags != TM_F_LINEAR) + tmflags = TM_F_LINEAR; /* turn off tone mapping */ else { if (n == 0) /* else check if any change */ return(0); @@ -758,10 +767,11 @@ XKeyPressedEvent *ekey; } scale += n; sprintf(buf, "%+d", scale); + remap: XDrawImageString(thedisplay, wind, ourgc, - box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); + bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf)); XFlush(thedisplay); - free(ourdata); + /* free(ourdata); This is done in XDestroyImage()! */ free_raster(ourras); getras(); /* fall through */ @@ -790,7 +800,7 @@ XKeyPressedEvent *ekey; redraw(0, 0, width, height); return(0); case ' ': /* clear */ - redraw(box.xmin, box.ymin, box.xsiz, box.ysiz); + redraw(bbox.xmin, bbox.ymin, bbox.xsiz, bbox.ysiz); return(0); default: XBell(thedisplay, 0); @@ -824,30 +834,30 @@ XButtonPressedEvent *ebut; } -getbox(ebut) /* get new box */ +getbox(ebut) /* get new bbox */ XButtonPressedEvent *ebut; { XEvent e; XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e); while (e.type == MotionNotify) { - revbox(ebut->x, ebut->y, box.xmin = e.xmotion.x, box.ymin = e.xmotion.y); + revbox(ebut->x, ebut->y, bbox.xmin = e.xmotion.x, bbox.ymin = e.xmotion.y); XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e); - revbox(ebut->x, ebut->y, box.xmin, box.ymin); + revbox(ebut->x, ebut->y, bbox.xmin, bbox.ymin); } - box.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x); - box.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y); - if (box.xmin > ebut->x) { - box.xsiz = box.xmin - ebut->x + 1; - box.xmin = ebut->x; + bbox.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x); + bbox.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y); + if (bbox.xmin > ebut->x) { + bbox.xsiz = bbox.xmin - ebut->x + 1; + bbox.xmin = ebut->x; } else { - box.xsiz = ebut->x - box.xmin + 1; + bbox.xsiz = ebut->x - bbox.xmin + 1; } - if (box.ymin > ebut->y) { - box.ysiz = box.ymin - ebut->y + 1; - box.ymin = ebut->y; + if (bbox.ymin > ebut->y) { + bbox.ysiz = bbox.ymin - ebut->y + 1; + bbox.ymin = ebut->y; } else { - box.ysiz = ebut->y - box.ymin + 1; + bbox.ysiz = ebut->y - bbox.ymin + 1; } } @@ -871,7 +881,7 @@ XButtonPressedEvent *ebut; } -revbox(x0, y0, x1, y1) /* draw box with reversed lines */ +revbox(x0, y0, x1, y1) /* draw bbox with reversed lines */ int x0, y0, x1, y1; { revline(x0, y0, x1, y0); @@ -881,95 +891,133 @@ int x0, y0, x1, y1; } -avgbox(clr) /* average color over current box */ -COLOR clr; +int +colavg(scn, n, cavg) +register COLR *scn; +register int n; +COLOR cavg; { - static COLOR lc; - static int ll, lr, lt, lb; + COLOR col; + + while (n--) { + colr_color(col, *scn++); + addcolor(cavg, col); + } +} + + +int +avgbox(cavg) /* average color over current bbox */ +COLOR cavg; +{ + double d; + register int rval; + + setcolor(cavg, 0., 0., 0.); + rval = dobox(colavg, (char *)cavg); + if (rval > 0) { + d = 1./rval; + scalecolor(cavg, d); + } + return(rval); +} + + +int +dobox(f, p) /* run function over bbox */ +int (*f)(); /* function to call for each subscan */ +char *p; /* pointer to private data */ +{ int left, right, top, bottom; int y; - double d; - COLOR ctmp; - register int x; - setcolor(clr, 0.0, 0.0, 0.0); - left = box.xmin - xoff; - right = left + box.xsiz; + left = bbox.xmin - xoff; + right = left + bbox.xsiz; if (left < 0) left = 0; if (right > xmax) right = xmax; if (left >= right) - return(-1); - top = box.ymin - yoff; - bottom = top + box.ysiz; + return(0); + top = bbox.ymin - yoff; + bottom = top + bbox.ysiz; if (top < 0) top = 0; if (bottom > ymax) bottom = ymax; if (top >= bottom) - return(-1); - if (left == ll && right == lr && top == lt && bottom == lb) { - copycolor(clr, lc); return(0); - } for (y = top; y < bottom; y++) { if (getscan(y) == -1) return(-1); - for (x = left; x < right; x++) { - colr_color(ctmp, scanline[x]); - addcolor(clr, ctmp); - } + (*f)(scanline+left, right-left, p); } - d = 1.0/((right-left)*(bottom-top)); - scalecolor(clr, d); - ll = left; lr = right; lt = top; lb = bottom; - copycolor(lc, clr); - return(0); + return((right-left)*(bottom-top)); } +int +addfix(scn, n) /* add fixation points to histogram */ +COLR *scn; +int n; +{ + if (tmCvColrs(lscan, TM_NOCHROM, scn, n)) + goto tmerr; + if (tmAddHisto(lscan, n, FIXWEIGHT)) + goto tmerr; + return; +tmerr: + quiterr("tone mapping error"); +} + + make_tonemap() /* initialize tone mapping */ { - int y; + int flags, y; - if (tmflags != -1 && fname == NULL) { + if (tmflags != TM_F_LINEAR && fname == NULL) { fprintf(stderr, "%s: cannot adjust tone of standard input\n", progname); - tmflags = -1; + tmflags = TM_F_LINEAR; } - if (tmflags == -1) { + if (tmflags == TM_F_LINEAR) { /* linear with clamping */ setcolrcor(pow, 1.0/gamcor); return; } - if (greyscale) - tmflags |= TM_F_BW; - /* initialize tm library */ - if (tmInit(tmflags, stdprims, gamcor) == NULL) - goto memerr; - if (tmSetSpace(stdprims, WHTEFFICACY/exposure)) - goto tmerr; - /* allocate encoding buffers */ - if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) - goto memerr; - if (tmflags & TM_F_BW) { - cscan = TM_NOCHROM; - if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL) + flags = tmflags; /* histogram adjustment */ + if (greyscale) flags |= TM_F_BW; + if (tmTop != NULL) { /* reuse old histogram if one */ + tmDone(tmTop); + tmTop->flags = flags; + } else { /* else initialize */ + if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) goto memerr; - } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax)) == NULL) - goto memerr; - /* compute picture histogram */ - for (y = 0; y < ymax; y++) { - getscan(y); - if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax)) + if (greyscale) { + cscan = TM_NOCHROM; + if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL) + goto memerr; + } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax)) + == NULL) + goto memerr; + /* initialize tm library */ + if (tmInit(flags, stdprims, gamcor) == NULL) + goto memerr; + if (tmSetSpace(stdprims, WHTEFFICACY/exposure)) goto tmerr; - if (tmAddHisto(lscan, xmax, 1)) - goto tmerr; + /* compute picture histogram */ + for (y = 0; y < ymax; y++) { + getscan(y); + if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax)) + goto tmerr; + if (tmAddHisto(lscan, xmax, 1)) + goto tmerr; + } } - /* compute tone mapping */ + tmDup(); /* add fixations to duplicate map */ + dobox(addfix, NULL); + /* (re)compute tone mapping */ if (tmComputeMapping(gamcor, 0., 0.)) goto tmerr; - free((char *)lscan); return; memerr: quiterr("out of memory in make_tonemap"); @@ -984,7 +1032,7 @@ int len; { register BYTE *ps; - if (tmflags == -1) { + if (tmflags == TM_F_LINEAR) { if (scale) shiftcolrs(scn, len, scale); colrs_gambs(scn, len); @@ -997,7 +1045,7 @@ int len; if (tmMapPixels(pscan, lscan, cscan, len)) goto tmerr; ps = pscan; - if (tmflags & TM_F_BW) + if (greyscale) while (len--) { scn[0][RED] = scn[0][GRN] = scn[0][BLU] = *ps++; scn[0][EXP] = COLXS; @@ -1017,16 +1065,6 @@ tmerr: } -done_tonemap() /* clean up after tone mapping is done */ -{ - if (tmflags == -1 || tmTop == NULL) - return; - tmDone(tmTop); /* clear old mapping */ - free((char *)lscan); /* free memory */ - free((char *)pscan); -} - - getmono() /* get monochrome data */ { register unsigned char *dp; @@ -1055,7 +1093,7 @@ getmono() /* get monochrome data */ cerr[x] = err + errp; } } - free((char *)cerr); + free((void *)cerr); } @@ -1098,7 +1136,7 @@ COLR *scan; errp = err; ti = x*xmax/iconwidth; copycolr(clr, scan[ti]); - normcolrs(clr, 1, scale); + normcolrs(&clr, 1, scale); err += normbright(clr) + cerr[x]; if (err > 127) err -= 255; @@ -1115,27 +1153,66 @@ getfull() /* get full (24-bit) data */ { int y; register unsigned int4 *dp; + register unsigned int2 *dph; register int x; /* initialize tone mapping */ make_tonemap(); /* read and convert file */ dp = (unsigned int4 *)ourdata; + dph = (unsigned int2 *)ourdata; for (y = 0; y < ymax; y++) { getscan(y); add2icon(y, scanline); tmap_colrs(scanline, xmax); - if (ourras->image->blue_mask & 1) + switch (ourras->image->blue_mask) { + case 0xff: /* 24-bit RGB */ for (x = 0; x < xmax; x++) *dp++ = (unsigned int4)scanline[x][RED] << 16 | (unsigned int4)scanline[x][GRN] << 8 | (unsigned int4)scanline[x][BLU] ; - else + break; + case 0xff0000: /* 24-bit BGR */ for (x = 0; x < xmax; x++) *dp++ = (unsigned int4)scanline[x][RED] | (unsigned int4)scanline[x][GRN] << 8 | (unsigned int4)scanline[x][BLU] << 16 ; + break; +#if 0 + case 0x1f: /* 15-bit RGB */ + for (x = 0; x < xmax; x++) + *dph++ = (scanline[x][RED] << 7 & 0x7c00) | + (scanline[x][GRN] << 2 & 0x3e0) | + (unsigned)scanline[x][BLU] >> 3 ; + break; + case 0x7c00: /* 15-bit BGR */ + for (x = 0; x < xmax; x++) + *dph++ = (unsigned)scanline[x][RED] >> 3 | + (scanline[x][GRN] << 2 & 0x3e0) | + (scanline[x][BLU] << 7 & 0x7c00) ; + break; +#endif + default: /* unknown */ + if (ourvis.depth > 16) + for (x = 0; x < xmax; x++) { + *dp = ourras->image->red_mask & + ourras->image->red_mask*scanline[x][RED]/255; + *dp |= ourras->image->green_mask & + ourras->image->green_mask*scanline[x][GRN]/255; + *dp++ |= ourras->image->blue_mask & + ourras->image->blue_mask*scanline[x][BLU]/255; + } + else + for (x = 0; x < xmax; x++) { + *dph = ourras->image->red_mask & + ourras->image->red_mask*scanline[x][RED]/255; + *dph |= ourras->image->green_mask & + ourras->image->green_mask*scanline[x][GRN]/255; + *dph++ |= ourras->image->blue_mask & + ourras->image->blue_mask*scanline[x][BLU]/255; + } + break; + } } - done_tonemap(); } @@ -1163,7 +1240,6 @@ getgrey() /* get greyscale data */ for (x = 0; x < maxcolors; x++) clrtab[x][RED] = clrtab[x][GRN] = clrtab[x][BLU] = ((int4)x*256 + 128)/maxcolors; - done_tonemap(); } @@ -1196,7 +1272,6 @@ getmapped() /* get color-mapped data */ else map_colrs(ourdata+y*xmax, scanline, xmax); } - done_tonemap(); }
