root/radiance/ray/src/px/x11image.c
Revision: 1.3
Committed: Fri Mar 2 12:22:37 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +36 -24 lines
final bug fixes, working version of x11image
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * x11image.c - driver for X-windows
9 *
10 * 3/1/90
11 */
12
13 /*
14 * Modified for X11
15 *
16 * January 1990
17 *
18 * Anat Grynberg and Greg Ward
19 */
20
21
22 #include "standard.h"
23
24 #include <X11/Xlib.h>
25 #include <X11/cursorfont.h>
26 #include <X11/Xutil.h>
27
28 #include "color.h"
29 #include "view.h"
30 #include "pic.h"
31 #include "x11raster.h"
32 #include "random.h"
33
34 #define FONTNAME "8x13" /* text font we'll use */
35
36 #define CTRL(c) ('c'-'@')
37
38 #define BORWIDTH 5 /* border width */
39
40 #define ourscreen DefaultScreen(thedisplay)
41 #define ourblack BlackPixel(thedisplay,ourscreen)
42 #define ourwhite WhitePixel(thedisplay,ourscreen)
43 #define ourroot RootWindow(thedisplay,ourscreen)
44 #define ourgc DefaultGC(thedisplay,ourscreen)
45
46 #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
47
48 double gamcor = 2.2; /* gamma correction */
49
50 int dither = 1; /* dither colors? */
51 int fast = 0; /* keep picture in Pixmap? */
52
53 Window wind = 0; /* our output window */
54 Font fontid; /* our font */
55
56 int maxcolors = 0; /* maximum colors */
57 int greyscale = 0; /* in grey */
58
59 int scale = 0; /* scalefactor; power of two */
60
61 int xoff = 0; /* x image offset */
62 int yoff = 0; /* y image offset */
63
64 VIEW ourview = STDVIEW; /* image view parameters */
65 int gotview = 0; /* got parameters from file */
66
67 COLR *scanline; /* scan line buffer */
68
69 int xmax, ymax; /* picture resolution */
70 int width, height; /* window size */
71 char *fname = NULL; /* input file name */
72 FILE *fin = stdin; /* input file */
73 long *scanpos = NULL; /* scan line positions in file */
74 int cury = 0; /* current scan location */
75
76 double exposure = 1.0; /* exposure compensation used */
77
78 XRASTER *ourras; /* our stored image */
79 unsigned char *ourdata; /* our image data */
80
81 struct {
82 int xmin, ymin, xsiz, ysiz;
83 } box = {0, 0, 0, 0}; /* current box */
84
85 char *geometry = NULL; /* geometry specification */
86
87 char *progname;
88
89 char errmsg[128];
90
91 extern long ftell();
92
93 extern char *malloc(), *calloc();
94
95 extern double atof(), pow(), log();
96
97 Display *thedisplay;
98
99 main(argc, argv)
100 int argc;
101 char *argv[];
102 {
103 int headline();
104 int i;
105
106 progname = argv[0];
107
108 for (i = 1; i < argc; i++)
109 if (argv[i][0] == '-')
110 switch (argv[i][1]) {
111 case 'c':
112 maxcolors = atoi(argv[++i]);
113 break;
114 case 'b':
115 greyscale = !greyscale;
116 break;
117 case 'm':
118 maxcolors = 2;
119 break;
120 case 'd':
121 dither = !dither;
122 break;
123 case 'f':
124 fast = !fast;
125 break;
126 case 'e':
127 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
128 goto userr;
129 scale = atoi(argv[++i]);
130 break;
131 case 'g':
132 if (!strcmp(argv[i], "-geometry"))
133 geometry = argv[++i];
134 else
135 gamcor = atof(argv[++i]);
136 break;
137 default:
138 goto userr;
139 }
140 else if (argv[i][0] == '=')
141 geometry = argv[i];
142 else
143 break;
144
145 if (i == argc-1) {
146 fname = argv[i];
147 fin = fopen(fname, "r");
148 if (fin == NULL) {
149 sprintf(errmsg, "can't open file \"%s\"", fname);
150 quiterr(errmsg);
151 }
152 } else if (i != argc)
153 goto userr;
154 /* get header */
155 getheader(fin, headline);
156 /* get picture dimensions */
157 if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR))
158 quiterr("bad picture size");
159 /* set view parameters */
160 if (gotview && setview(&ourview) != NULL)
161 gotview = 0;
162 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
163 quiterr("out of memory");
164
165 init(); /* get file and open window */
166
167 for ( ; ; )
168 getevent(); /* main loop */
169 userr:
170 fprintf(stderr,
171 "Usage: %s [-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n",
172 progname);
173 quit(1);
174 }
175
176
177 headline(s) /* get relevant info from header */
178 char *s;
179 {
180 static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL};
181 register char **an;
182
183 if (isexpos(s))
184 exposure *= exposval(s);
185 else
186 for (an = altname; *an != NULL; an++)
187 if (!strncmp(*an, s, strlen(*an))) {
188 if (sscanview(&ourview, s+strlen(*an)) > 0)
189 gotview++;
190 return;
191 }
192 }
193
194
195 init() /* get data and open window */
196 {
197 XSizeHints oursizhints;
198 register int i;
199
200 if (fname != NULL) {
201 scanpos = (long *)malloc(ymax*sizeof(long));
202 if (scanpos == NULL)
203 goto memerr;
204 for (i = 0; i < ymax; i++)
205 scanpos[i] = -1;
206 }
207 if ((thedisplay = XOpenDisplay(NULL)) == NULL)
208 quiterr("can't open display; DISPLAY variable set?");
209 wind = XCreateSimpleWindow(thedisplay,
210 ourroot, 0, 0, xmax, ymax, BORWIDTH, ourblack, ourwhite);
211 if (wind == 0)
212 quiterr("can't create window");
213 if (maxcolors == 0) { /* get number of available colors */
214 i = DisplayPlanes(thedisplay,ourscreen);
215 maxcolors = i > 8 ? 256 : 1<<i;
216 if (maxcolors > 4) maxcolors -= 2;
217 }
218 fontid = XLoadFont(thedisplay, FONTNAME);
219 if (fontid == 0)
220 quiterr("can't get font");
221 XSetFont(thedisplay, ourgc, fontid);
222 XStoreName(thedisplay, wind, fname == NULL ? progname : fname);
223 XDefineCursor(thedisplay, wind, XCreateFontCursor(thedisplay,
224 XC_diamond_cross));
225 if (geometry != NULL) {
226 bzero((char *)&oursizhints, sizeof(oursizhints));
227 i = XParseGeometry(geometry, &oursizhints.x, &oursizhints.y,
228 &oursizhints.width, &oursizhints.height);
229 if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
230 oursizhints.flags |= USSize;
231 else {
232 oursizhints.width = xmax;
233 oursizhints.height = ymax;
234 oursizhints.flags |= PSize;
235 }
236 if ((i&(XValue|YValue)) == (XValue|YValue)) {
237 oursizhints.flags |= USPosition;
238 if (i & XNegative)
239 oursizhints.x += DisplayWidth(thedisplay,
240 ourscreen)-1-oursizhints.width-2*BORWIDTH;
241 if (i & YNegative)
242 oursizhints.y += DisplayHeight(thedisplay,
243 ourscreen)-1-oursizhints.height-2*BORWIDTH;
244 }
245 XSetNormalHints(thedisplay, wind, &oursizhints);
246 }
247 /* store image */
248 getras();
249 XSelectInput(thedisplay, wind, ButtonPressMask|ButtonReleaseMask
250 |ButtonMotionMask|StructureNotifyMask
251 |KeyPressMask|ExposureMask);
252 XMapWindow(thedisplay, wind);
253 return;
254 memerr:
255 quiterr("out of memory");
256 } /* end of init */
257
258
259 quiterr(err) /* print message and exit */
260 char *err;
261 {
262 if (err != NULL) {
263 fprintf(stderr, "%s: %s\n", progname, err);
264 exit(1);
265 }
266 exit(0);
267 }
268
269
270 eputs(s)
271 char *s;
272 {
273 fputs(s, stderr);
274 }
275
276
277 quit(code)
278 int code;
279 {
280 exit(code);
281 }
282
283
284 getras() /* get raster file */
285 {
286 colormap ourmap;
287 XVisualInfo vinfo;
288
289 if (maxcolors <= 2) { /* monochrome */
290 ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
291 if (ourdata == NULL)
292 goto fail;
293 ourras = make_raster(thedisplay, ourscreen, 1, ourdata,
294 xmax, ymax, 8);
295 if (ourras == NULL)
296 goto fail;
297 getmono();
298 } else if (XMatchVisualInfo(thedisplay,ourscreen,24,TrueColor,&vinfo)) {
299 ourdata = (unsigned char *)malloc(xmax*ymax*3);
300 if (ourdata == NULL)
301 goto fail;
302 ourras = make_raster(thedisplay, ourscreen, 24, ourdata,
303 xmax, ymax, 8);
304 if (ourras == NULL)
305 goto fail;
306 getfull();
307 } else {
308 ourdata = (unsigned char *)malloc(xmax*ymax);
309 if (ourdata == NULL)
310 goto fail;
311 ourras = make_raster(thedisplay, ourscreen, 8, ourdata,
312 xmax, ymax, 8);
313 if (ourras == NULL)
314 goto fail;
315 if (greyscale)
316 biq(dither,maxcolors,1,ourmap);
317 else
318 ciq(dither,maxcolors,1,ourmap);
319 if (init_rcolors(ourras, ourmap[0], ourmap[1], ourmap[2]) == 0)
320 goto fail;
321 }
322 return;
323 fail:
324 quit("could not create raster image");
325 }
326
327
328 getevent() /* process the next event */
329 {
330 union {
331 XEvent u;
332 XConfigureEvent c;
333 XExposeEvent e;
334 XButtonPressedEvent b;
335 XKeyPressedEvent k;
336 } e;
337
338 XNextEvent(thedisplay, &e.u);
339 switch (e.u.type) {
340 case KeyPress:
341 docom(&e.k);
342 break;
343 case ConfigureNotify:
344 width = e.c.width;
345 height = e.c.height;
346 break;
347 case MapNotify:
348 map_rcolors(ourras, wind);
349 if (fast)
350 make_rpixmap(ourras);
351 break;
352 case UnmapNotify:
353 unmap_rcolors(ourras);
354 break;
355 case Expose:
356 redraw(e.e.x, e.e.y, e.e.width, e.e.height);
357 break;
358 case ButtonPress:
359 if (e.b.state & (ShiftMask|ControlMask))
360 moveimage(&e.b);
361 else
362 getbox(&e.b);
363 break;
364 }
365 }
366
367
368 docom(ekey) /* execute command */
369 XKeyPressedEvent *ekey;
370 {
371 char buf[80];
372 COLOR cval;
373 XColor cvx;
374 int com, n;
375 double comp;
376 FVECT rorg, rdir;
377
378 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
379 if (n == 0)
380 return(0);
381 com = buf[0];
382 switch (com) { /* interpret command */
383 case 'q':
384 case CTRL(D): /* quit */
385 quit(0);
386 case '\n':
387 case '\r':
388 case 'l':
389 case 'c': /* value */
390 if (avgbox(cval) == -1)
391 return(-1);
392 switch (com) {
393 case '\n':
394 case '\r': /* radiance */
395 sprintf(buf, "%.3f", intens(cval)/exposure);
396 break;
397 case 'l': /* luminance */
398 sprintf(buf, "%.0fn", bright(cval)*683.0/exposure);
399 break;
400 case 'c': /* color */
401 comp = pow(2.0, (double)scale);
402 sprintf(buf, "(%.2f,%.2f,%.2f)",
403 colval(cval,RED)*comp,
404 colval(cval,GRN)*comp,
405 colval(cval,BLU)*comp);
406 break;
407 }
408 XDrawImageString(thedisplay, wind, ourgc,
409 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
410 return(0);
411 case 'i': /* identify (contour) */
412 if (ourras->pixels == NULL)
413 return(-1);
414 n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
415 n = ourras->pmap[n];
416 cvx.pixel = ourras->cdefs[n].pixel;
417 cvx.red = random() & 65535;
418 cvx.green = random() & 65535;
419 cvx.blue = random() & 65535;
420 cvx.flags = DoRed|DoGreen|DoBlue;
421 XStoreColor(thedisplay, ourras->cmap, &cvx);
422 return(0);
423 case 'p': /* position */
424 sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff);
425 XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
426 buf, strlen(buf));
427 return(0);
428 case 't': /* trace */
429 if (!gotview) {
430 XBell(thedisplay, 0);
431 return(-1);
432 }
433 viewray(rorg, rdir, &ourview,
434 (ekey->x-xoff+.5)/xmax,
435 (ymax-1-ekey->y+yoff+.5)/ymax);
436 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
437 printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
438 fflush(stdout);
439 return(0);
440 case '=': /* adjust exposure */
441 if (avgbox(cval) == -1)
442 return(-1);
443 n = log(.5/bright(cval))/.69315 - scale; /* truncate */
444 if (n == 0)
445 return(0);
446 scale_rcolors(ourras, pow(2.0, (double)n));
447 scale += n;
448 sprintf(buf, "%+d", scale);
449 XDrawImageString(thedisplay, wind, ourgc,
450 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
451 XFlush(thedisplay);
452 free(ourdata);
453 free_raster(ourras);
454 getras();
455 /* fall through */
456 case CTRL(R): /* redraw */
457 case CTRL(L):
458 unmap_rcolors(ourras);
459 XClearWindow(thedisplay, wind);
460 map_rcolors(ourras, wind);
461 if (fast)
462 make_rpixmap(ourras);
463 redraw(0, 0, width, height);
464 return(0);
465 case ' ': /* clear */
466 redraw(box.xmin, box.ymin, box.xsiz, box.ysiz);
467 return(0);
468 default:
469 XBell(thedisplay, 0);
470 return(-1);
471 }
472 }
473
474
475 moveimage(ebut) /* shift the image */
476 XButtonPressedEvent *ebut;
477 {
478 union {
479 XEvent u;
480 XButtonReleasedEvent b;
481 XPointerMovedEvent m;
482 } e;
483 int nxo, nyo;
484
485 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e.u);
486 while (e.u.type == MotionNotify) {
487 nxo = xoff + e.m.x - ebut->x;
488 nyo = yoff + e.m.y - ebut->y;
489 revbox(nxo, nyo, nxo+xmax, nyo+ymax);
490 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e.u);
491 revbox(nxo, nyo, nxo+xmax, nyo+ymax);
492 }
493 xoff += e.b.x - ebut->x;
494 yoff += e.b.y - ebut->y;
495 XClearWindow(thedisplay, wind);
496 redraw(0, 0, width, height);
497 }
498
499
500 getbox(ebut) /* get new box */
501 XButtonPressedEvent *ebut;
502 {
503 union {
504 XEvent u;
505 XButtonReleasedEvent b;
506 XPointerMovedEvent m;
507 } e;
508
509 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e.u);
510 while (e.u.type == MotionNotify) {
511 revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y);
512 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e.u);
513 revbox(ebut->x, ebut->y, box.xmin, box.ymin);
514 }
515 box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x);
516 box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y);
517 if (box.xmin > ebut->x) {
518 box.xsiz = box.xmin - ebut->x + 1;
519 box.xmin = ebut->x;
520 } else {
521 box.xsiz = ebut->x - box.xmin + 1;
522 }
523 if (box.ymin > ebut->y) {
524 box.ysiz = box.ymin - ebut->y + 1;
525 box.ymin = ebut->y;
526 } else {
527 box.ysiz = ebut->y - box.ymin + 1;
528 }
529 }
530
531
532 revbox(x0, y0, x1, y1) /* draw box with reversed lines */
533 int x0, y0, x1, y1;
534 {
535 static GC mygc = 0;
536
537 if (mygc == 0) {
538 mygc = XCreateGC(thedisplay, wind, 0, 0);
539 XSetFunction(thedisplay, mygc, GXinvert);
540 }
541 XDrawLine(thedisplay, wind, mygc, x0, y0, x1, y0);
542 XDrawLine(thedisplay, wind, mygc, x0, y1, x1, y1);
543 XDrawLine(thedisplay, wind, mygc, x0, y0, x0, y1);
544 XDrawLine(thedisplay, wind, mygc, x1, y0, x1, y1);
545 } /* end of revbox */
546
547
548 avgbox(clr) /* average color over current box */
549 COLOR clr;
550 {
551 int left, right, top, bottom;
552 int y;
553 double d;
554 COLOR ctmp;
555 register int x;
556
557 setcolor(clr, 0.0, 0.0, 0.0);
558 left = box.xmin - xoff;
559 right = left + box.xsiz;
560 if (left < 0)
561 left = 0;
562 if (right > xmax)
563 right = xmax;
564 if (left >= right)
565 return(-1);
566 top = box.ymin - yoff;
567 bottom = top + box.ysiz;
568 if (top < 0)
569 top = 0;
570 if (bottom > ymax)
571 bottom = ymax;
572 if (top >= bottom)
573 return(-1);
574 for (y = top; y < bottom; y++) {
575 if (getscan(y) == -1)
576 return(-1);
577 for (x = left; x < right; x++) {
578 colr_color(ctmp, scanline[x]);
579 addcolor(clr, ctmp);
580 }
581 }
582 d = 1.0/((right-left)*(bottom-top));
583 scalecolor(clr, d);
584 return(0);
585 }
586
587
588 getmono() /* get monochrome data */
589 {
590 register unsigned char *dp;
591 register int x, err;
592 int y;
593 rgbpixel *inline;
594 short *cerr;
595
596 if ((inline = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL
597 || (cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
598 quit("out of memory in getmono");
599 dp = ourdata - 1;
600 for (y = 0; y < ymax; y++) {
601 picreadline3(y, inline);
602 err = 0;
603 for (x = 0; x < xmax; x++) {
604 if (!(x&7))
605 *++dp = 0;
606 err += rgb_bright(&inline[x]) + cerr[x];
607 if (err > 127)
608 err -= 255;
609 else
610 *dp |= 1<<(7-(x&07));
611 cerr[x] = err >>= 1;
612 }
613 }
614 free((char *)inline);
615 free((char *)cerr);
616 }
617
618
619 getfull() /* get full (24-bit) data */
620 {
621 int y;
622
623 for (y = 0; y < ymax; y++)
624 picreadline3(y, (rgbpixel *)(ourdata+y*xmax*3));
625 }
626
627
628 scale_rcolors(xr, sf) /* scale color map */
629 register XRASTER *xr;
630 double sf;
631 {
632 register int i;
633 long maxv;
634
635 if (xr->pixels == NULL)
636 return;
637
638 sf = pow(sf, 1.0/gamcor);
639 maxv = 65535/sf;
640
641 for (i = xr->ncolors; i--; ) {
642 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
643 65535 :
644 xr->cdefs[i].red * sf;
645 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
646 65535 :
647 xr->cdefs[i].green * sf;
648 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
649 65535 :
650 xr->cdefs[i].blue * sf;
651 }
652 XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
653 }
654
655
656 getscan(y)
657 int y;
658 {
659 if (y != cury) {
660 if (scanpos == NULL || scanpos[y] == -1)
661 return(-1);
662 if (fseek(fin, scanpos[y], 0) == -1)
663 quit("fseek error");
664 cury = y;
665 } else if (scanpos != NULL)
666 scanpos[y] = ftell(fin);
667
668 if (freadcolrs(scanline, xmax, fin) < 0)
669 quiterr("read error");
670
671 cury++;
672 return(0);
673 }
674
675
676 picreadline3(y, l3) /* read in 3-byte scanline */
677 int y;
678 register rgbpixel *l3;
679 {
680 register int i;
681 /* read scanline */
682 if (getscan(y) < 0)
683 quiterr("cannot seek for picreadline");
684 /* convert scanline */
685 normcolrs(scanline, xmax, scale);
686 for (i = 0; i < xmax; i++) {
687 l3[i].r = scanline[i][RED];
688 l3[i].g = scanline[i][GRN];
689 l3[i].b = scanline[i][BLU];
690 }
691 }
692
693
694 picwriteline(y, l) /* add 8-bit scanline to image */
695 int y;
696 pixel *l;
697 {
698 bcopy((char *)l, (char *)ourdata+y*xmax, xmax);
699 }
700
701
702 picreadcm(map) /* do gamma correction */
703 colormap map;
704 {
705 extern double pow();
706 register int i, val;
707
708 for (i = 0; i < 256; i++) {
709 val = pow(i/256.0, 1.0/gamcor) * 256.0;
710 map[0][i] = map[1][i] = map[2][i] = val;
711 }
712 }
713
714
715 picwritecm(map) /* handled elsewhere */
716 colormap map;
717 {
718 #ifdef DEBUG
719 register int i;
720
721 for (i = 0; i < 256; i++)
722 printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]);
723 #endif
724 }
