root/radiance/ray/src/px/x11image.c
Revision: 2.33
Committed: Thu Nov 4 12:04:55 1993 UTC (31 years, 6 months ago) by greg
Changes since 2.32: +2 -4 lines
simplified error message
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * x11image.c - driver for X-windows
9 *
10 * 3/1/90
11 */
12
13 /*
14 * Modified for X11
15 *
16 * January 1990
17 *
18 * Anat Grynberg and Greg Ward
19 */
20
21
22 #include "standard.h"
23
24 #include <signal.h>
25 #include <X11/Xlib.h>
26 #include <X11/cursorfont.h>
27 #include <X11/Xutil.h>
28 #include <X11/Xatom.h>
29
30 #include "color.h"
31 #include "view.h"
32 #include "x11raster.h"
33 #include "random.h"
34 #include "resolu.h"
35
36 #ifdef __alpha
37 #define int4 int
38 #endif
39 #ifndef int4
40 #define int4 long
41 #endif
42
43 #define FONTNAME "8x13" /* text font we'll use */
44
45 #define CTRL(c) ((c)-'@')
46
47 #define BORWIDTH 5 /* border width */
48
49 #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */
50
51 #define ourscreen DefaultScreen(thedisplay)
52 #define ourroot RootWindow(thedisplay,ourscreen)
53
54 #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1)
55
56 #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
57
58 double gamcor = 2.2; /* gamma correction */
59
60 int dither = 1; /* dither colors? */
61 int fast = 0; /* keep picture in Pixmap? */
62
63 char *dispname = NULL; /* our display name */
64
65 Window wind = 0; /* our output window */
66 unsigned long ourblack=0, ourwhite=1; /* black and white for this visual */
67 int maxcolors = 0; /* maximum colors */
68 int greyscale = 0; /* in grey */
69
70 int scale = 0; /* scalefactor; power of two */
71
72 int xoff = 0; /* x image offset */
73 int yoff = 0; /* y image offset */
74
75 int parent = 0; /* number of children, -1 if child */
76
77 VIEW ourview = STDVIEW; /* image view parameters */
78 int gotview = 0; /* got parameters from file */
79
80 COLR *scanline; /* scan line buffer */
81
82 RESOLU inpres; /* input resolution and ordering */
83 int xmax, ymax; /* picture dimensions */
84 int width, height; /* window size */
85 char *fname = NULL; /* input file name */
86 FILE *fin = stdin; /* input file */
87 long *scanpos = NULL; /* scan line positions in file */
88 int cury = 0; /* current scan location */
89
90 double exposure = 1.0; /* exposure compensation used */
91
92 int wrongformat = 0; /* input in another format? */
93
94 GC ourgc; /* standard graphics context */
95 GC revgc; /* graphics context with GXinvert */
96
97 int *ourrank; /* our visual class ranking */
98 XVisualInfo ourvis; /* our visual */
99 XRASTER *ourras; /* our stored image */
100 unsigned char *ourdata; /* our image data */
101
102 struct {
103 int xmin, ymin, xsiz, ysiz;
104 } box = {0, 0, 0, 0}; /* current box */
105
106 char *geometry = NULL; /* geometry specification */
107
108 char icondata[ICONSIZ*ICONSIZ/8]; /* icon bitmap data */
109 int iconwidth = 0, iconheight = 0;
110
111 char *progname;
112
113 char errmsg[128];
114
115 extern BYTE clrtab[256][3]; /* global color map */
116
117 extern long ftell();
118
119 Display *thedisplay;
120 Atom closedownAtom, wmProtocolsAtom;
121
122 int sigrecv;
123
124 int onsig() { sigrecv++; }
125
126
127 main(argc, argv)
128 int argc;
129 char *argv[];
130 {
131 extern char *getenv();
132 char *gv;
133 int headline();
134 int i;
135 int pid;
136
137 progname = argv[0];
138 if ((gv = getenv("GAMMA")) != NULL)
139 gamcor = atof(gv);
140
141 for (i = 1; i < argc; i++)
142 if (argv[i][0] == '-')
143 switch (argv[i][1]) {
144 case 'c':
145 maxcolors = atoi(argv[++i]);
146 break;
147 case 'b':
148 greyscale = !greyscale;
149 break;
150 case 'm':
151 maxcolors = 2;
152 break;
153 case 'd':
154 if (argv[i][2] == 'i')
155 dispname = argv[++i];
156 else
157 dither = !dither;
158 break;
159 case 'f':
160 fast = !fast;
161 break;
162 case 'e':
163 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
164 goto userr;
165 scale = atoi(argv[++i]);
166 break;
167 case 'g':
168 if (argv[i][2] == 'e')
169 geometry = argv[++i];
170 else
171 gamcor = atof(argv[++i]);
172 break;
173 default:
174 goto userr;
175 }
176 else if (argv[i][0] == '=')
177 geometry = argv[i];
178 else
179 break;
180
181 if (i > argc)
182 goto userr;
183 while (i < argc-1) {
184 sigrecv = 0;
185 signal(SIGCONT, onsig);
186 if ((pid=fork()) == 0) { /* a child for each picture */
187 parent = -1;
188 break;
189 }
190 if (pid < 0)
191 quiterr("fork failed");
192 parent++;
193 while (!sigrecv)
194 pause(); /* wait for wake-up call */
195 i++;
196 }
197 if (i < argc) { /* open picture file */
198 fname = argv[i];
199 fin = fopen(fname, "r");
200 if (fin == NULL)
201 quiterr("cannot open picture file");
202 }
203 /* get header */
204 getheader(fin, headline, NULL);
205 /* get picture dimensions */
206 if (wrongformat || !fgetsresolu(&inpres, fin))
207 quiterr("bad picture format");
208 xmax = scanlen(&inpres);
209 ymax = numscans(&inpres);
210 /* set view parameters */
211 if (gotview && setview(&ourview) != NULL)
212 gotview = 0;
213 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
214 quiterr("out of memory");
215
216 init(argc, argv); /* get file and open window */
217
218 if (parent < 0) {
219 kill(getppid(), SIGCONT); /* signal parent if child */
220 sigrecv--;
221 }
222 for ( ; ; )
223 getevent(); /* main loop */
224 userr:
225 fprintf(stderr,
226 "Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops] pic ..\n",
227 progname);
228 exit(1);
229 }
230
231
232 headline(s) /* get relevant info from header */
233 char *s;
234 {
235 char fmt[32];
236
237 if (isexpos(s))
238 exposure *= exposval(s);
239 else if (isformat(s)) {
240 formatval(fmt, s);
241 wrongformat = strcmp(fmt, COLRFMT);
242 } else if (isview(s) && sscanview(&ourview, s) > 0)
243 gotview++;
244 }
245
246
247 init(argc, argv) /* get data and open window */
248 int argc;
249 char **argv;
250 {
251 XSetWindowAttributes ourwinattr;
252 XClassHint xclshints;
253 XWMHints xwmhints;
254 XSizeHints xszhints;
255 XTextProperty windowName, iconName;
256 XGCValues xgcv;
257 char *name;
258 register int i;
259
260 if (fname != NULL) {
261 scanpos = (long *)malloc(ymax*sizeof(long));
262 if (scanpos == NULL)
263 quiterr("out of memory");
264 for (i = 0; i < ymax; i++)
265 scanpos[i] = -1;
266 name = fname;
267 } else
268 name = progname;
269 /* remove directory prefix from name */
270 for (i = strlen(name); i-- > 0; )
271 if (name[i] == '/')
272 break;
273 name += i+1;
274 if ((thedisplay = XOpenDisplay(dispname)) == NULL)
275 quiterr("cannot open display");
276 /* get best visual for default screen */
277 getbestvis();
278 /* store image */
279 getras();
280 /* get size and position */
281 xszhints.flags = 0;
282 xszhints.width = xmax; xszhints.height = ymax;
283 if (geometry != NULL) {
284 i = XParseGeometry(geometry, &xszhints.x, &xszhints.y,
285 (unsigned *)&xszhints.width,
286 (unsigned *)&xszhints.height);
287 if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
288 xszhints.flags |= USSize;
289 else
290 xszhints.flags |= PSize;
291 if ((i&(XValue|YValue)) == (XValue|YValue)) {
292 xszhints.flags |= USPosition;
293 if (i & XNegative)
294 xszhints.x += DisplayWidth(thedisplay,
295 ourscreen)-1-xszhints.width-2*BORWIDTH;
296 if (i & YNegative)
297 xszhints.y += DisplayHeight(thedisplay,
298 ourscreen)-1-xszhints.height-2*BORWIDTH;
299 }
300 }
301 /* open window */
302 ourwinattr.border_pixel = ourwhite;
303 ourwinattr.background_pixel = ourblack;
304 ourwinattr.colormap = XCreateColormap(thedisplay, ourroot,
305 ourvis.visual, AllocNone);
306 ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask|
307 ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask;
308 ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross);
309 wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y,
310 xszhints.width, xszhints.height, BORWIDTH,
311 ourvis.depth, InputOutput, ourvis.visual, CWEventMask|
312 CWCursor|CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
313 if (wind == 0)
314 quiterr("cannot create window");
315 width = xmax;
316 height = ymax;
317 /* prepare graphics drawing context */
318 if ((xgcv.font = XLoadFont(thedisplay, FONTNAME)) == 0)
319 quiterr("cannot get font");
320 xgcv.foreground = ourblack;
321 xgcv.background = ourwhite;
322 ourgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
323 GCFont, &xgcv);
324 xgcv.function = GXinvert;
325 revgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
326 GCFunction, &xgcv);
327
328 /* set up the window manager */
329 xwmhints.flags = InputHint|IconPixmapHint;
330 xwmhints.input = True;
331 xwmhints.icon_pixmap = XCreateBitmapFromData(thedisplay,
332 wind, icondata, iconwidth, iconheight);
333
334 windowName.encoding = iconName.encoding = XA_STRING;
335 windowName.format = iconName.format = 8;
336 windowName.value = (u_char *)name;
337 windowName.nitems = strlen(windowName.value);
338 iconName.value = (u_char *)name;
339 iconName.nitems = strlen(windowName.value);
340
341 xclshints.res_name = NULL;
342 xclshints.res_class = "Ximage";
343 XSetWMProperties(thedisplay, wind, &windowName, &iconName,
344 argv, argc, &xszhints, &xwmhints, &xclshints);
345 closedownAtom = XInternAtom(thedisplay, "WM_DELETE_WINDOW", False);
346 wmProtocolsAtom = XInternAtom(thedisplay, "WM_PROTOCOLS", False);
347 XSetWMProtocols(thedisplay, wind, &closedownAtom, 1);
348
349 XMapWindow(thedisplay, wind);
350 return;
351 } /* end of init */
352
353
354 quiterr(err) /* print message and exit */
355 char *err;
356 {
357 register int es;
358 int cs;
359
360 if (es = err != NULL)
361 fprintf(stderr, "%s: %s: %s\n", progname,
362 fname==NULL?"<stdin>":fname, err);
363 if (parent > 0 & wind != 0) {
364 XDestroyWindow(thedisplay, wind);
365 XFlush(thedisplay);
366 } else if (parent < 0 & sigrecv == 0)
367 kill(getppid(), SIGCONT);
368 while (parent > 0 && wait(&cs) != -1) { /* wait for any children */
369 if (es == 0)
370 es = cs>>8 & 0xff;
371 parent--;
372 }
373 exit(es);
374 }
375
376
377 static int
378 viscmp(v1,v2) /* compare visual to see which is better, descending */
379 register XVisualInfo *v1, *v2;
380 {
381 int bad1 = 0, bad2 = 0;
382 register int *rp;
383
384 if (v1->class == v2->class) {
385 if (v1->class == TrueColor || v1->class == DirectColor) {
386 /* prefer 24-bit to 32-bit */
387 if (v1->depth == 24 && v2->depth == 32)
388 return(-1);
389 if (v1->depth == 32 && v2->depth == 24)
390 return(1);
391 return(0);
392 }
393 /* don't be too greedy */
394 if (maxcolors <= 1<<v1->depth && maxcolors <= 1<<v2->depth)
395 return(v1->depth - v2->depth);
396 return(v2->depth - v1->depth);
397 }
398 /* prefer Pseudo when < 24-bit */
399 if ((v1->class == TrueColor || v1->class == DirectColor) &&
400 v1->depth < 24)
401 bad1 = 1;
402 if ((v2->class == TrueColor || v2->class == DirectColor) &&
403 v2->depth < 24)
404 bad2 = -1;
405 if (bad1 | bad2)
406 return(bad1+bad2);
407 /* otherwise, use class ranking */
408 for (rp = ourrank; *rp != -1; rp++) {
409 if (v1->class == *rp)
410 return(-1);
411 if (v2->class == *rp)
412 return(1);
413 }
414 return(0);
415 }
416
417
418 getbestvis() /* get the best visual for this screen */
419 {
420 #ifdef DEBUG
421 static char vistype[][12] = {
422 "StaticGray",
423 "GrayScale",
424 "StaticColor",
425 "PseudoColor",
426 "TrueColor",
427 "DirectColor"
428 };
429 #endif
430 static int rankings[3][6] = {
431 {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1},
432 {PseudoColor,GrayScale,StaticGray,-1},
433 {PseudoColor,GrayScale,StaticGray,-1}
434 };
435 XVisualInfo *xvi;
436 int vismatched;
437 register int i, j;
438
439 if (greyscale) {
440 ourrank = rankings[2];
441 if (maxcolors < 2) maxcolors = 256;
442 } else if (maxcolors >= 2 && maxcolors <= 256)
443 ourrank = rankings[1];
444 else {
445 ourrank = rankings[0];
446 maxcolors = 256;
447 }
448 /* find best visual */
449 ourvis.screen = ourscreen;
450 xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched);
451 if (xvi == NULL)
452 quiterr("no visuals for this screen!");
453 #ifdef DEBUG
454 fprintf(stderr, "Supported visuals:\n");
455 for (i = 0; i < vismatched; i++)
456 fprintf(stderr, "\ttype %s, depth %d\n",
457 vistype[xvi[i].class], xvi[i].depth);
458 #endif
459 for (i = 0, j = 1; j < vismatched; j++)
460 if (viscmp(&xvi[i],&xvi[j]) > 0)
461 i = j;
462 /* compare to least acceptable */
463 for (j = 0; ourrank[j++] != -1; )
464 ;
465 ourvis.class = ourrank[--j];
466 ourvis.depth = 1;
467 if (viscmp(&xvi[i],&ourvis) > 0)
468 quiterr("inadequate visuals on this screen");
469 /* OK, we'll use it */
470 copystruct(&ourvis, &xvi[i]);
471 #ifdef DEBUG
472 fprintf(stderr, "Selected visual type %s, depth %d\n",
473 vistype[ourvis.class], ourvis.depth);
474 #endif
475 /* make appropriate adjustments */
476 if (ourvis.class == GrayScale || ourvis.class == StaticGray)
477 greyscale = 1;
478 if (ourvis.depth <= 8 && ourvis.colormap_size < maxcolors)
479 maxcolors = ourvis.colormap_size;
480 if (ourvis.class == StaticGray) {
481 ourblack = 0;
482 ourwhite = 255;
483 } else if (ourvis.class == PseudoColor) {
484 ourblack = BlackPixel(thedisplay,ourscreen);
485 ourwhite = WhitePixel(thedisplay,ourscreen);
486 if ((ourblack|ourwhite) & ~255L) {
487 ourblack = 0;
488 ourwhite = 1;
489 }
490 if (maxcolors > 4)
491 maxcolors -= 2;
492 } else {
493 ourblack = 0;
494 ourwhite = ourvis.red_mask|ourvis.green_mask|ourvis.blue_mask;
495 }
496 XFree((char *)xvi);
497 }
498
499
500 getras() /* get raster file */
501 {
502 XVisualInfo vinfo;
503
504 if (maxcolors <= 2) { /* monochrome */
505 ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
506 if (ourdata == NULL)
507 goto fail;
508 ourras = make_raster(thedisplay, &ourvis, 1, ourdata,
509 xmax, ymax, 8);
510 if (ourras == NULL)
511 goto fail;
512 getmono();
513 } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) {
514 ourdata = (unsigned char *)malloc(sizeof(int4)*xmax*ymax);
515 if (ourdata == NULL)
516 goto fail;
517 ourras = make_raster(thedisplay, &ourvis, sizeof(int4)*8,
518 ourdata, xmax, ymax, 32);
519 if (ourras == NULL)
520 goto fail;
521 getfull();
522 } else {
523 ourdata = (unsigned char *)malloc(xmax*ymax);
524 if (ourdata == NULL)
525 goto fail;
526 ourras = make_raster(thedisplay, &ourvis, 8, ourdata,
527 xmax, ymax, 8);
528 if (ourras == NULL)
529 goto fail;
530 if (greyscale | ourvis.class == StaticGray)
531 getgrey();
532 else
533 getmapped();
534 if (ourvis.class != StaticGray && !init_rcolors(ourras,clrtab))
535 goto fail;
536 }
537 return;
538 fail:
539 quiterr("could not create raster image");
540 }
541
542
543 getevent() /* process the next event */
544 {
545 XEvent xev;
546
547 XNextEvent(thedisplay, &xev);
548 switch ((int)xev.type) {
549 case KeyPress:
550 docom(&xev.xkey);
551 break;
552 case ConfigureNotify:
553 width = xev.xconfigure.width;
554 height = xev.xconfigure.height;
555 break;
556 case MapNotify:
557 map_rcolors(ourras, wind);
558 if (fast)
559 make_rpixmap(ourras, wind);
560 break;
561 case UnmapNotify:
562 if (!fast)
563 unmap_rcolors(ourras);
564 break;
565 case Expose:
566 redraw(xev.xexpose.x, xev.xexpose.y,
567 xev.xexpose.width, xev.xexpose.height);
568 break;
569 case ButtonPress:
570 if (xev.xbutton.state & (ShiftMask|ControlMask))
571 moveimage(&xev.xbutton);
572 else if (xev.xbutton.button == Button2)
573 traceray(xev.xbutton.x, xev.xbutton.y);
574 else
575 getbox(&xev.xbutton);
576 break;
577 case ClientMessage:
578 if ((xev.xclient.message_type == wmProtocolsAtom) &&
579 (xev.xclient.data.l[0] == closedownAtom))
580 quiterr(NULL);
581 break;
582 }
583 }
584
585
586 traceray(xpos, ypos) /* print ray corresponding to pixel */
587 int xpos, ypos;
588 {
589 FLOAT hv[2];
590 FVECT rorg, rdir;
591
592 if (!gotview) { /* no view, no can do */
593 XBell(thedisplay, 0);
594 return(-1);
595 }
596 pix2loc(hv, &inpres, xpos-xoff, ypos-yoff);
597 if (viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0)
598 return(-1);
599 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
600 printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
601 fflush(stdout);
602 return(0);
603 }
604
605
606 docom(ekey) /* execute command */
607 XKeyPressedEvent *ekey;
608 {
609 char buf[80];
610 COLOR cval;
611 XColor cvx;
612 int com, n;
613 double comp;
614 FLOAT hv[2];
615
616 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
617 if (n == 0)
618 return(0);
619 com = buf[0];
620 switch (com) { /* interpret command */
621 case 'q':
622 case 'Q':
623 case CTRL('D'): /* quit */
624 quiterr(NULL);
625 case '\n':
626 case '\r':
627 case 'l':
628 case 'c': /* value */
629 if (avgbox(cval) == -1)
630 return(-1);
631 switch (com) {
632 case '\n':
633 case '\r': /* radiance */
634 sprintf(buf, "%.3f", intens(cval)/exposure);
635 break;
636 case 'l': /* luminance */
637 sprintf(buf, "%.0fL", luminance(cval)/exposure);
638 break;
639 case 'c': /* color */
640 comp = pow(2.0, (double)scale);
641 sprintf(buf, "(%.2f,%.2f,%.2f)",
642 colval(cval,RED)*comp,
643 colval(cval,GRN)*comp,
644 colval(cval,BLU)*comp);
645 break;
646 }
647 XDrawImageString(thedisplay, wind, ourgc,
648 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
649 return(0);
650 case 'i': /* identify (contour) */
651 if (ourras->pixels == NULL)
652 return(-1);
653 n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
654 n = ourras->pmap[n];
655 cvx.pixel = ourras->cdefs[n].pixel;
656 cvx.red = random() & 65535;
657 cvx.green = random() & 65535;
658 cvx.blue = random() & 65535;
659 cvx.flags = DoRed|DoGreen|DoBlue;
660 XStoreColor(thedisplay, ourras->cmap, &cvx);
661 return(0);
662 case 'p': /* position */
663 pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff);
664 sprintf(buf, "(%d,%d)", (int)(hv[0]*inpres.xr),
665 (int)(hv[1]*inpres.yr));
666 XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
667 buf, strlen(buf));
668 return(0);
669 case 't': /* trace */
670 return(traceray(ekey->x, ekey->y));
671 case '=': /* adjust exposure */
672 case '@': /* adaptation level */
673 if (avgbox(cval) == -1)
674 return(-1);
675 comp = com=='@'
676 ? 106./pow(1.219+pow(luminance(cval)/exposure,.4),2.5)/exposure
677 : .5/bright(cval) ;
678 comp = log(comp)/.69315 - scale;
679 n = comp < 0 ? comp-.5 : comp+.5 ; /* round */
680 if (n == 0)
681 return(0);
682 scale_rcolors(ourras, pow(2.0, (double)n));
683 scale += n;
684 sprintf(buf, "%+d", scale);
685 XDrawImageString(thedisplay, wind, ourgc,
686 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
687 XFlush(thedisplay);
688 free(ourdata);
689 free_raster(ourras);
690 getras();
691 /* fall through */
692 case CTRL('R'): /* redraw */
693 case CTRL('L'):
694 unmap_rcolors(ourras);
695 XClearWindow(thedisplay, wind);
696 map_rcolors(ourras, wind);
697 if (fast)
698 make_rpixmap(ourras, wind);
699 redraw(0, 0, width, height);
700 return(0);
701 case 'f': /* turn on fast redraw */
702 fast = 1;
703 make_rpixmap(ourras, wind);
704 return(0);
705 case 'F': /* turn off fast redraw */
706 fast = 0;
707 free_rpixmap(ourras);
708 return(0);
709 case '0': /* recenter origin */
710 if (xoff == 0 & yoff == 0)
711 return(0);
712 xoff = yoff = 0;
713 XClearWindow(thedisplay, wind);
714 redraw(0, 0, width, height);
715 return(0);
716 case ' ': /* clear */
717 redraw(box.xmin, box.ymin, box.xsiz, box.ysiz);
718 return(0);
719 default:
720 XBell(thedisplay, 0);
721 return(-1);
722 }
723 }
724
725
726 moveimage(ebut) /* shift the image */
727 XButtonPressedEvent *ebut;
728 {
729 XEvent e;
730 int mxo, myo;
731
732 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
733 while (e.type == MotionNotify) {
734 mxo = e.xmotion.x;
735 myo = e.xmotion.y;
736 revline(ebut->x, ebut->y, mxo, myo);
737 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
738 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
739 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
740 revline(ebut->x, ebut->y, mxo, myo);
741 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
742 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
743 }
744 xoff += e.xbutton.x - ebut->x;
745 yoff += e.xbutton.y - ebut->y;
746 XClearWindow(thedisplay, wind);
747 redraw(0, 0, width, height);
748 }
749
750
751 getbox(ebut) /* get new box */
752 XButtonPressedEvent *ebut;
753 {
754 XEvent e;
755
756 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
757 while (e.type == MotionNotify) {
758 revbox(ebut->x, ebut->y, box.xmin = e.xmotion.x, box.ymin = e.xmotion.y);
759 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
760 revbox(ebut->x, ebut->y, box.xmin, box.ymin);
761 }
762 box.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x);
763 box.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y);
764 if (box.xmin > ebut->x) {
765 box.xsiz = box.xmin - ebut->x + 1;
766 box.xmin = ebut->x;
767 } else {
768 box.xsiz = ebut->x - box.xmin + 1;
769 }
770 if (box.ymin > ebut->y) {
771 box.ysiz = box.ymin - ebut->y + 1;
772 box.ymin = ebut->y;
773 } else {
774 box.ysiz = ebut->y - box.ymin + 1;
775 }
776 }
777
778
779 revbox(x0, y0, x1, y1) /* draw box with reversed lines */
780 int x0, y0, x1, y1;
781 {
782 revline(x0, y0, x1, y0);
783 revline(x0, y1, x1, y1);
784 revline(x0, y0, x0, y1);
785 revline(x1, y0, x1, y1);
786 }
787
788
789 avgbox(clr) /* average color over current box */
790 COLOR clr;
791 {
792 static COLOR lc;
793 static int ll, lr, lt, lb;
794 int left, right, top, bottom;
795 int y;
796 double d;
797 COLOR ctmp;
798 register int x;
799
800 setcolor(clr, 0.0, 0.0, 0.0);
801 left = box.xmin - xoff;
802 right = left + box.xsiz;
803 if (left < 0)
804 left = 0;
805 if (right > xmax)
806 right = xmax;
807 if (left >= right)
808 return(-1);
809 top = box.ymin - yoff;
810 bottom = top + box.ysiz;
811 if (top < 0)
812 top = 0;
813 if (bottom > ymax)
814 bottom = ymax;
815 if (top >= bottom)
816 return(-1);
817 if (left == ll && right == lr && top == lt && bottom == lb) {
818 copycolor(clr, lc);
819 return(0);
820 }
821 for (y = top; y < bottom; y++) {
822 if (getscan(y) == -1)
823 return(-1);
824 for (x = left; x < right; x++) {
825 colr_color(ctmp, scanline[x]);
826 addcolor(clr, ctmp);
827 }
828 }
829 d = 1.0/((right-left)*(bottom-top));
830 scalecolor(clr, d);
831 ll = left; lr = right; lt = top; lb = bottom;
832 copycolor(lc, clr);
833 return(0);
834 }
835
836
837 getmono() /* get monochrome data */
838 {
839 register unsigned char *dp;
840 register int x, err;
841 int y, errp;
842 short *cerr;
843
844 if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
845 quiterr("out of memory in getmono");
846 dp = ourdata - 1;
847 for (y = 0; y < ymax; y++) {
848 getscan(y);
849 add2icon(y, scanline);
850 normcolrs(scanline, xmax, scale);
851 err = 0;
852 for (x = 0; x < xmax; x++) {
853 if (!(x&7))
854 *++dp = 0;
855 errp = err;
856 err += normbright(scanline[x]) + cerr[x];
857 if (err > 127)
858 err -= 255;
859 else
860 *dp |= 1<<(7-(x&07));
861 err /= 3;
862 cerr[x] = err + errp;
863 }
864 }
865 free((char *)cerr);
866 }
867
868
869 add2icon(y, scan) /* add a scanline to our icon data */
870 int y;
871 COLR *scan;
872 {
873 static short cerr[ICONSIZ];
874 static int ynext;
875 static char *dp;
876 COLR clr;
877 register int err;
878 register int x, ti;
879 int errp;
880
881 if (iconheight == 0) { /* initialize */
882 if (xmax <= ICONSIZ && ymax <= ICONSIZ) {
883 iconwidth = xmax;
884 iconheight = ymax;
885 } else if (xmax > ymax) {
886 iconwidth = ICONSIZ;
887 iconheight = ICONSIZ*ymax/xmax;
888 if (iconheight < 1)
889 iconheight = 1;
890 } else {
891 iconwidth = ICONSIZ*xmax/ymax;
892 if (iconwidth < 1)
893 iconwidth = 1;
894 iconheight = ICONSIZ;
895 }
896 ynext = 0;
897 dp = icondata - 1;
898 }
899 if (y < ynext*ymax/iconheight) /* skip this one */
900 return;
901 err = 0;
902 for (x = 0; x < iconwidth; x++) {
903 if (!(x&7))
904 *++dp = 0;
905 errp = err;
906 ti = x*xmax/iconwidth;
907 copycolr(clr, scan[ti]);
908 normcolrs(clr, 1, scale);
909 err += normbright(clr) + cerr[x];
910 if (err > 127)
911 err -= 255;
912 else
913 *dp |= 1<<(x&07);
914 err /= 3;
915 cerr[x] = err + errp;
916 }
917 ynext++;
918 }
919
920
921 getfull() /* get full (24-bit) data */
922 {
923 int y;
924 register unsigned int4 *dp;
925 register int x;
926 /* set gamma correction */
927 setcolrgam(gamcor);
928 /* read and convert file */
929 dp = (unsigned int4 *)ourdata;
930 for (y = 0; y < ymax; y++) {
931 getscan(y);
932 add2icon(y, scanline);
933 if (scale)
934 shiftcolrs(scanline, xmax, scale);
935 colrs_gambs(scanline, xmax);
936 if (ourras->image->blue_mask & 1)
937 for (x = 0; x < xmax; x++)
938 *dp++ = scanline[x][RED] << 16 |
939 scanline[x][GRN] << 8 |
940 scanline[x][BLU] ;
941 else
942 for (x = 0; x < xmax; x++)
943 *dp++ = scanline[x][RED] |
944 scanline[x][GRN] << 8 |
945 scanline[x][BLU] << 16 ;
946 }
947 }
948
949
950 getgrey() /* get greyscale data */
951 {
952 int y;
953 register unsigned char *dp;
954 register int x;
955 /* set gamma correction */
956 setcolrgam(gamcor);
957 /* read and convert file */
958 dp = ourdata;
959 for (y = 0; y < ymax; y++) {
960 getscan(y);
961 add2icon(y, scanline);
962 if (scale)
963 shiftcolrs(scanline, xmax, scale);
964 for (x = 0; x < xmax; x++)
965 scanline[x][GRN] = normbright(scanline[x]);
966 colrs_gambs(scanline, xmax);
967 if (maxcolors < 256)
968 for (x = 0; x < xmax; x++)
969 *dp++ = ((long)scanline[x][GRN] *
970 maxcolors + maxcolors/2) >> 8;
971 else
972 for (x = 0; x < xmax; x++)
973 *dp++ = scanline[x][GRN];
974 }
975 for (x = 0; x < maxcolors; x++)
976 clrtab[x][RED] = clrtab[x][GRN] =
977 clrtab[x][BLU] = ((long)x*256 + 128)/maxcolors;
978 }
979
980
981 getmapped() /* get color-mapped data */
982 {
983 int y;
984 /* make sure we can do it first */
985 if (fname == NULL)
986 quiterr("cannot map colors from standard input");
987 /* set gamma correction */
988 setcolrgam(gamcor);
989 /* make histogram */
990 new_histo();
991 for (y = 0; y < ymax; y++) {
992 if (getscan(y) < 0)
993 break;
994 add2icon(y, scanline);
995 if (scale)
996 shiftcolrs(scanline, xmax, scale);
997 colrs_gambs(scanline, xmax);
998 cnt_colrs(scanline, xmax);
999 }
1000 /* map pixels */
1001 if (!new_clrtab(maxcolors))
1002 quiterr("cannot create color map");
1003 for (y = 0; y < ymax; y++) {
1004 getscan(y);
1005 if (scale)
1006 shiftcolrs(scanline, xmax, scale);
1007 colrs_gambs(scanline, xmax);
1008 if (dither)
1009 dith_colrs(ourdata+y*xmax, scanline, xmax);
1010 else
1011 map_colrs(ourdata+y*xmax, scanline, xmax);
1012 }
1013 }
1014
1015
1016 scale_rcolors(xr, sf) /* scale color map */
1017 register XRASTER *xr;
1018 double sf;
1019 {
1020 register int i;
1021 long maxv;
1022
1023 if (xr->pixels == NULL)
1024 return;
1025
1026 sf = pow(sf, 1.0/gamcor);
1027 maxv = 65535/sf;
1028
1029 for (i = xr->ncolors; i--; ) {
1030 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
1031 65535 :
1032 xr->cdefs[i].red * sf;
1033 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
1034 65535 :
1035 xr->cdefs[i].green * sf;
1036 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
1037 65535 :
1038 xr->cdefs[i].blue * sf;
1039 }
1040 XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
1041 }
1042
1043
1044 getscan(y)
1045 int y;
1046 {
1047 static int trunced = -1; /* truncated file? */
1048 skipit:
1049 if (trunced >= 0 && y >= trunced) {
1050 bzero(scanline, xmax*sizeof(COLR));
1051 return(-1);
1052 }
1053 if (y != cury) {
1054 if (scanpos == NULL || scanpos[y] == -1)
1055 return(-1);
1056 if (fseek(fin, scanpos[y], 0) == -1)
1057 quiterr("fseek error");
1058 cury = y;
1059 } else if (scanpos != NULL && scanpos[y] == -1)
1060 scanpos[y] = ftell(fin);
1061
1062 if (freadcolrs(scanline, xmax, fin) < 0) {
1063 fprintf(stderr, "%s: %s: unfinished picture\n",
1064 progname, fname==NULL?"<stdin>":fname);
1065 trunced = y;
1066 goto skipit;
1067 }
1068 cury++;
1069 return(0);
1070 }
