--- ray/src/px/x11image.c 1997/04/15 18:33:31 2.45 +++ ray/src/px/x11image.c 1998/08/17 18:00:11 2.52 @@ -1,7 +1,7 @@ -/* Copyright (c) 1997 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -29,16 +29,13 @@ static char SCCSid[] = "$SunId$ LBL"; #undef NOPROTO #define NOPROTO 1 +#include "color.h" #include "tonemap.h" #include "view.h" #include "x11raster.h" #include "random.h" #include "resolu.h" -#ifndef int4 -#define int4 int /* most int's are 32-bit */ -#endif - #define FONTNAME "8x13" /* text font we'll use */ #define CTRL(c) ((c)-'@') @@ -47,6 +44,8 @@ static char SCCSid[] = "$SunId$ LBL"; #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */ +#define FIXWEIGHT 20 /* weight to add for fixation points */ + #define ourscreen DefaultScreen(thedisplay) #define ourroot RootWindow(thedisplay,ourscreen) @@ -78,7 +77,7 @@ int sequential = 0; /* display images in sequence * char *tout = "od"; /* output of 't' command */ int tinterv = 0; /* interval between mouse reports */ -int tmflags = -1; /* tone mapping flags (-1 for none) */ +int tmflags = TM_F_LINEAR; /* tone mapping flags */ VIEW ourview = STDVIEW; /* image view parameters */ int gotview = 0; /* got parameters from file */ @@ -178,11 +177,11 @@ char *argv[]; break; case 'e': /* exposure comp. */ i++; - if (!strcmp(argv[i], "auto")) { + if (argv[i][0] == 'a') { tmflags = TM_F_CAMERA; break; } - if (!strcmp(argv[i], "human")) { + if (argv[i][0] == 'h') { tmflags = TM_F_HUMAN; break; } @@ -691,7 +690,7 @@ XKeyPressedEvent *ekey; case '\r': case 'l': case 'c': /* value */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); switch (com) { case '\n': @@ -733,9 +732,21 @@ XKeyPressedEvent *ekey; return(0); case 't': /* trace */ return(traceray(ekey->x, ekey->y)); + case 'a': /* auto exposure */ + if (fname == NULL) + return(-1); + tmflags = TM_F_CAMERA; + strcpy(buf, "auto exposure..."); + goto remap; + case 'h': /* human response */ + if (fname == NULL) + return(-1); + tmflags = TM_F_HUMAN; + strcpy(buf, "human exposure..."); + goto remap; case '=': /* adjust exposure */ case '@': /* adaptation level */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); comp = bright(cval); if (comp < 1e-20) { @@ -749,8 +760,8 @@ XKeyPressedEvent *ekey; comp = .5/comp; comp = log(comp)/.69315 - scale; n = comp < 0 ? comp-.5 : comp+.5 ; /* round */ - if (tmflags != -1) - tmflags = -1; /* turn off tone mapping */ + if (tmflags != TM_F_LINEAR) + tmflags = TM_F_LINEAR; /* turn off tone mapping */ else { if (n == 0) /* else check if any change */ return(0); @@ -758,6 +769,7 @@ XKeyPressedEvent *ekey; } scale += n; sprintf(buf, "%+d", scale); + remap: XDrawImageString(thedisplay, wind, ourgc, box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); XFlush(thedisplay); @@ -881,18 +893,46 @@ int x0, y0, x1, y1; } -avgbox(clr) /* average color over current box */ -COLOR clr; +int +colavg(scn, n, cavg) +register COLR *scn; +register int n; +COLOR cavg; { - static COLOR lc; - static int ll, lr, lt, lb; + COLOR col; + + while (n--) { + colr_color(col, scn++); + addcolor(cavg, col); + } +} + + +int +avgbox(cavg) /* average color over current box */ +COLOR cavg; +{ + double d; + register int rval; + + setcolor(cavg, 0., 0., 0.); + rval = dobox(colavg, (char *)cavg); + if (rval > 0) { + d = 1./rval; + scalecolor(cavg, d); + } + return(rval); +} + + +int +dobox(f, p) /* run function over box */ +int (*f)(); /* function to call for each subscan */ +char *p; /* pointer to private data */ +{ int left, right, top, bottom; int y; - double d; - COLOR ctmp; - register int x; - setcolor(clr, 0.0, 0.0, 0.0); left = box.xmin - xoff; right = left + box.xsiz; if (left < 0) @@ -900,7 +940,7 @@ COLOR clr; if (right > xmax) right = xmax; if (left >= right) - return(-1); + return(0); top = box.ymin - yoff; bottom = top + box.ysiz; if (top < 0) @@ -908,68 +948,78 @@ COLOR clr; if (bottom > ymax) bottom = ymax; if (top >= bottom) - return(-1); - if (left == ll && right == lr && top == lt && bottom == lb) { - copycolor(clr, lc); return(0); - } for (y = top; y < bottom; y++) { if (getscan(y) == -1) return(-1); - for (x = left; x < right; x++) { - colr_color(ctmp, scanline[x]); - addcolor(clr, ctmp); - } + (*f)(scanline+left, right-left, p); } - d = 1.0/((right-left)*(bottom-top)); - scalecolor(clr, d); - ll = left; lr = right; lt = top; lb = bottom; - copycolor(lc, clr); - return(0); + return((right-left)*(bottom-top)); } +int +addfix(scn, n) /* add fixation points to histogram */ +COLR *scn; +int n; +{ + if (tmCvColrs(lscan, TM_NOCHROM, scn, n)) + goto tmerr; + if (tmAddHisto(lscan, n, FIXWEIGHT)) + goto tmerr; + return; +tmerr: + quiterr("tone mapping error"); +} + + make_tonemap() /* initialize tone mapping */ { - int y; + int flags, y; - if (tmflags != -1 && fname == NULL) { + if (tmflags != TM_F_LINEAR && fname == NULL) { fprintf(stderr, "%s: cannot adjust tone of standard input\n", progname); - tmflags = -1; + tmflags = TM_F_LINEAR; } - if (tmflags == -1) { + if (tmflags == TM_F_LINEAR) { /* linear with clamping */ setcolrcor(pow, 1.0/gamcor); return; } - if (greyscale) - tmflags |= TM_F_BW; - /* initialize tm library */ - if (tmInit(tmflags, stdprims, gamcor) == NULL) - goto memerr; - if (tmSetSpace(stdprims, WHTEFFICACY/exposure)) - goto tmerr; - /* allocate encoding buffers */ - if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) - goto memerr; - if (tmflags & TM_F_BW) { - cscan = TM_NOCHROM; - if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL) + flags = tmflags; /* histogram adjustment */ + if (greyscale) flags |= TM_F_BW; + if (tmTop != NULL) { /* reuse old histogram if one */ + tmDone(tmTop); + tmTop->flags = flags; + } else { /* else initialize */ + if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) goto memerr; - } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax)) == NULL) - goto memerr; - /* compute picture histogram */ - for (y = 0; y < ymax; y++) { - getscan(y); - if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax)) + if (greyscale) { + cscan = TM_NOCHROM; + if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL) + goto memerr; + } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax)) + == NULL) + goto memerr; + /* initialize tm library */ + if (tmInit(flags, stdprims, gamcor) == NULL) + goto memerr; + if (tmSetSpace(stdprims, WHTEFFICACY/exposure)) goto tmerr; - if (tmAddHisto(lscan, xmax, 1)) - goto tmerr; + /* compute picture histogram */ + for (y = 0; y < ymax; y++) { + getscan(y); + if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax)) + goto tmerr; + if (tmAddHisto(lscan, xmax, 1)) + goto tmerr; + } } - /* compute tone mapping */ + tmDup(); /* add fixations to duplicate map */ + dobox(addfix, NULL); + /* (re)compute tone mapping */ if (tmComputeMapping(gamcor, 0., 0.)) goto tmerr; - free((char *)lscan); return; memerr: quiterr("out of memory in make_tonemap"); @@ -984,7 +1034,7 @@ int len; { register BYTE *ps; - if (tmflags == -1) { + if (tmflags == TM_F_LINEAR) { if (scale) shiftcolrs(scn, len, scale); colrs_gambs(scn, len); @@ -997,7 +1047,7 @@ int len; if (tmMapPixels(pscan, lscan, cscan, len)) goto tmerr; ps = pscan; - if (tmflags & TM_F_BW) + if (greyscale) while (len--) { scn[0][RED] = scn[0][GRN] = scn[0][BLU] = *ps++; scn[0][EXP] = COLXS; @@ -1017,16 +1067,6 @@ tmerr: } -done_tonemap() /* clean up after tone mapping is done */ -{ - if (tmflags == -1 || tmTop == NULL) - return; - tmDone(tmTop); /* clear old mapping */ - free((char *)lscan); /* free memory */ - free((char *)pscan); -} - - getmono() /* get monochrome data */ { register unsigned char *dp; @@ -1135,7 +1175,6 @@ getfull() /* get full (24-bit) data */ (unsigned int4)scanline[x][GRN] << 8 | (unsigned int4)scanline[x][BLU] << 16 ; } - done_tonemap(); } @@ -1163,7 +1202,6 @@ getgrey() /* get greyscale data */ for (x = 0; x < maxcolors; x++) clrtab[x][RED] = clrtab[x][GRN] = clrtab[x][BLU] = ((int4)x*256 + 128)/maxcolors; - done_tonemap(); } @@ -1196,7 +1234,6 @@ getmapped() /* get color-mapped data */ else map_colrs(ourdata+y*xmax, scanline, xmax); } - done_tonemap(); }
