--- ray/src/px/x11image.c 2003/06/30 14:59:12 2.61 +++ ray/src/px/x11image.c 2004/04/10 03:02:20 2.67 @@ -20,6 +20,9 @@ static const char RCSid[] = "$Id"; #include #include +#include +#include +#include #include #include #include @@ -27,6 +30,7 @@ static const char RCSid[] = "$Id"; #include "color.h" #include "tonemap.h" +#include "clrtab.h" #include "view.h" #include "x11raster.h" #include "random.h" @@ -117,10 +121,7 @@ char errmsg[128]; BYTE clrtab[256][3]; /* global color map */ -extern long ftell(); -extern char *getenv(); - Display *thedisplay; Atom closedownAtom, wmProtocolsAtom; @@ -128,12 +129,39 @@ int sigrecv; void onsig(int i) { sigrecv++; } +typedef void doboxf_t(COLR *scn, int n, void *); -main(argc, argv) -int argc; -char *argv[]; +static gethfunc headline; +static void init(int argc, char **argv); +static void quiterr(char *err); +static int viscmp(XVisualInfo *v1, XVisualInfo *v2); +static void getbestvis(void); +static void getras(void); +static void getevent(void); +static int traceray(int xpos, int ypos); +static int docom(XKeyPressedEvent *ekey); +static void moveimage(XButtonPressedEvent *ebut); +static void getbox(XButtonPressedEvent *ebut); +static void trackrays(XButtonPressedEvent *ebut); +static void revbox(int x0, int y0, int x1, int y1); +static doboxf_t colavg; +static doboxf_t addfix; +static int avgbox(COLOR cavg); +static int dobox(doboxf_t *f, void *p); +static void make_tonemap(void); +static void tmap_colrs(COLR *scn, int len); +static void getmono(void); +static void add2icon(int y, COLR *scan); +static void getfull(void); +static void getgrey(void); +static void getmapped(void); +static void scale_rcolors(XRASTER *xr, double sf); +static int getscan(int y); + + +int +main(int argc, char *argv[]) { - int headline(); int i; int pid; @@ -246,9 +274,11 @@ userr: } -int -headline(s) /* get relevant info from header */ -char *s; +static int +headline( /* get relevant info from header */ + char *s, + void *p +) { char fmt[32]; @@ -262,9 +292,11 @@ char *s; } -init(argc, argv) /* get data and open window */ -int argc; -char **argv; +static void +init( /* get data and open window */ + int argc, + char **argv +) { XSetWindowAttributes ourwinattr; XClassHint xclshints; @@ -378,18 +410,20 @@ char **argv; } /* end of init */ -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { register int es; int cs; - if (es = err != NULL) + if ( (es = err != NULL) ) fprintf(stderr, "%s: %s: %s\n", progname, fname==NULL?"":fname, err); if (thedisplay != NULL) XCloseDisplay(thedisplay); - if (parent < 0 & sigrecv == 0) + if ((parent < 0) & (sigrecv == 0)) kill(getppid(), SIGCONT); while (parent > 0 && wait(&cs) != -1) { /* wait for any children */ if (es == 0) @@ -401,8 +435,10 @@ char *err; static int -viscmp(v1,v2) /* compare visual to see which is better, descending */ -register XVisualInfo *v1, *v2; +viscmp( /* compare visual to see which is better, descending */ + register XVisualInfo *v1, + register XVisualInfo *v2 +) { int bad1 = 0, bad2 = 0; register int *rp; @@ -442,7 +478,8 @@ register XVisualInfo *v1, *v2; } -getbestvis() /* get the best visual for this screen */ +static void +getbestvis(void) /* get the best visual for this screen */ { #ifdef DEBUG static char vistype[][12] = { @@ -494,7 +531,7 @@ static char vistype[][12] = { if (viscmp(&xvi[i],&ourvis) > 0) quiterr("inadequate visuals on this screen"); /* OK, we'll use it */ - copystruct(&ourvis, &xvi[i]); + ourvis = xvi[i]; #ifdef DEBUG fprintf(stderr, "Selected visual type %s, depth %d\n", vistype[ourvis.class], ourvis.depth); @@ -524,10 +561,9 @@ static char vistype[][12] = { } -getras() /* get raster file */ +static void +getras(void) /* get raster file */ { - XVisualInfo vinfo; - if (maxcolors <= 2) { /* monochrome */ ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8)); if (ourdata == NULL) @@ -537,7 +573,7 @@ getras() /* get raster file */ if (ourras == NULL) goto fail; getmono(); - } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) { + } else if ((ourvis.class == TrueColor) | (ourvis.class == DirectColor)) { int datsiz = ourvis.depth>16 ? sizeof(int32) : sizeof(int16); ourdata = (unsigned char *)malloc(datsiz*xmax*ymax); if (ourdata == NULL) @@ -568,7 +604,8 @@ fail: } -getevent() /* process the next event */ +static void +getevent(void) /* process the next event */ { XEvent xev; @@ -585,7 +622,7 @@ getevent() /* process the next event */ map_rcolors(ourras, wind); if (fast) make_rpixmap(ourras, wind); - if (!sequential & parent < 0 & sigrecv == 0) { + if ((!sequential) & (parent < 0) & (sigrecv == 0)) { kill(getppid(), SIGCONT); sigrecv--; } @@ -623,8 +660,11 @@ getevent() /* process the next event */ } -traceray(xpos, ypos) /* print requested pixel data */ -int xpos, ypos; +static int +traceray( /* print requested pixel data */ + int xpos, + int ypos +) { RREAL hv[2]; FVECT rorg, rdir; @@ -666,8 +706,10 @@ int xpos, ypos; } -docom(ekey) /* execute command */ -XKeyPressedEvent *ekey; +static int +docom( /* execute command */ + XKeyPressedEvent *ekey +) { char buf[80]; COLOR cval; @@ -794,7 +836,7 @@ XKeyPressedEvent *ekey; free_rpixmap(ourras); return(0); case '0': /* recenter origin */ - if (xoff == 0 & yoff == 0) + if ((xoff == 0) & (yoff == 0)) return(0); xoff = yoff = 0; XClearWindow(thedisplay, wind); @@ -810,8 +852,10 @@ XKeyPressedEvent *ekey; } -moveimage(ebut) /* shift the image */ -XButtonPressedEvent *ebut; +static void +moveimage( /* shift the image */ + XButtonPressedEvent *ebut +) { XEvent e; int mxo, myo; @@ -835,8 +879,10 @@ XButtonPressedEvent *ebut; } -getbox(ebut) /* get new bbox */ -XButtonPressedEvent *ebut; +static void +getbox( /* get new bbox */ + XButtonPressedEvent *ebut +) { XEvent e; @@ -863,8 +909,10 @@ XButtonPressedEvent *ebut; } -trackrays(ebut) /* trace rays as mouse moves */ -XButtonPressedEvent *ebut; +static void +trackrays( /* trace rays as mouse moves */ + XButtonPressedEvent *ebut +) { XEvent e; unsigned long lastrept; @@ -882,8 +930,13 @@ XButtonPressedEvent *ebut; } -revbox(x0, y0, x1, y1) /* draw bbox with reversed lines */ -int x0, y0, x1, y1; +static void +revbox( /* draw bbox with reversed lines */ + int x0, + int y0, + int x1, + int y1 +) { revline(x0, y0, x1, y0); revline(x0, y1, x1, y1); @@ -892,24 +945,26 @@ int x0, y0, x1, y1; } -int -colavg(scn, n, cavg) -register COLR *scn; -register int n; -COLOR cavg; +static void +colavg( + register COLR *scn, + register int n, + void *cavg +) { COLOR col; while (n--) { colr_color(col, *scn++); - addcolor(cavg, col); + addcolor((COLORV*)cavg, col); } } -int -avgbox(cavg) /* average color over current bbox */ -COLOR cavg; +static int +avgbox( /* average color over current bbox */ + COLOR cavg +) { double d; register int rval; @@ -924,10 +979,12 @@ COLOR cavg; } -int -dobox(f, p) /* run function over bbox */ -int (*f)(); /* function to call for each subscan */ -char *p; /* pointer to private data */ +static int +dobox( /* run function over bbox */ + //void (*f)(), /* function to call for each subscan */ + doboxf_t *f, /* function to call for each subscan */ + void *p /* pointer to private data */ +) { int left, right, top, bottom; int y; @@ -957,10 +1014,12 @@ char *p; /* pointer to private data */ } -int -addfix(scn, n) /* add fixation points to histogram */ -COLR *scn; -int n; +static void +addfix( /* add fixation points to histogram */ + COLR *scn, + int n, + void *p /*NOTUSED*/ +) { if (tmCvColrs(lscan, TM_NOCHROM, scn, n)) goto tmerr; @@ -972,7 +1031,8 @@ tmerr: } -make_tonemap() /* initialize tone mapping */ +static void +make_tonemap(void) /* initialize tone mapping */ { int flags, y; @@ -1027,9 +1087,11 @@ tmerr: } -tmap_colrs(scn, len) /* apply tone mapping to scanline */ -register COLR *scn; -int len; +static void +tmap_colrs( /* apply tone mapping to scanline */ + register COLR *scn, + int len +) { register BYTE *ps; @@ -1066,7 +1128,8 @@ tmerr: } -getmono() /* get monochrome data */ +static void +getmono(void) /* get monochrome data */ { register unsigned char *dp; register int x, err; @@ -1098,9 +1161,11 @@ getmono() /* get monochrome data */ } -add2icon(y, scan) /* add a scanline to our icon data */ -int y; -COLR *scan; +static void +add2icon( /* add a scanline to our icon data */ + int y, + COLR *scan +) { static short cerr[ICONSIZ]; static int ynext; @@ -1150,7 +1215,8 @@ COLR *scan; } -getfull() /* get full (24-bit) data */ +static void +getfull(void) /* get full (24-bit) data */ { int y; register uint32 *dp; @@ -1217,7 +1283,8 @@ getfull() /* get full (24-bit) data */ } -getgrey() /* get greyscale data */ +static void +getgrey(void) /* get greyscale data */ { int y; register unsigned char *dp; @@ -1244,7 +1311,8 @@ getgrey() /* get greyscale data */ } -getmapped() /* get color-mapped data */ +static void +getmapped(void) /* get color-mapped data */ { int y; /* make sure we can do it first */ @@ -1276,9 +1344,11 @@ getmapped() /* get color-mapped data */ } -scale_rcolors(xr, sf) /* scale color map */ -register XRASTER *xr; -double sf; +static void +scale_rcolors( /* scale color map */ + register XRASTER *xr, + double sf +) { register int i; long maxv; @@ -1304,8 +1374,10 @@ double sf; } -getscan(y) -int y; +static int +getscan( + int y +) { static int trunced = -1; /* truncated file? */ skipit:
