--- ray/src/px/x11image.c 1992/05/27 14:28:50 2.6 +++ ray/src/px/x11image.c 1992/05/29 14:21:12 2.8 @@ -41,8 +41,6 @@ static char SCCSid[] = "$SunId$ LBL"; #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */ #define ourscreen DefaultScreen(thedisplay) -#define ourblack BlackPixel(thedisplay,ourscreen) -#define ourwhite WhitePixel(thedisplay,ourscreen) #define ourroot RootWindow(thedisplay,ourscreen) #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1) @@ -57,6 +55,7 @@ int fast = 0; /* keep picture in Pixmap? */ char *dispname = NULL; /* our display name */ Window wind = 0; /* our output window */ +unsigned long ourblack=1, ourwhite=0; /* black and white for this visual */ Font fontid; /* our font */ int maxcolors = 0; /* maximum colors */ @@ -135,11 +134,10 @@ char *argv[]; maxcolors = 2; break; case 'd': - if (argv[i][2] == 'i') { + if (argv[i][2] == 'i') dispname = argv[++i]; - break; - } - dither = !dither; + else + dither = !dither; break; case 'f': fast = !fast; @@ -150,7 +148,7 @@ char *argv[]; scale = atoi(argv[++i]); break; case 'g': - if (!strcmp(argv[i], "-geometry")) + if (argv[i][2] == 'e') geometry = argv[++i]; else gamcor = atof(argv[++i]); @@ -191,7 +189,7 @@ char *argv[]; getevent(); /* main loop */ userr: fprintf(stderr, - "Usage: %s [-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n", + "Usage: %s [-display disp][-geometry spec][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n", progname); quit(1); } @@ -245,8 +243,7 @@ init() /* get data and open window */ width = xmax; height = ymax; ourgc = XCreateGC(thedisplay, wind, 0, 0); - XSetState(thedisplay, ourgc, BlackPixel(thedisplay,ourscreen), - WhitePixel(thedisplay,ourscreen), GXcopy, AllPlanes); + XSetState(thedisplay, ourgc, ourblack, ourwhite, GXcopy, AllPlanes); revgc = XCreateGC(thedisplay, wind, 0, 0); XSetFunction(thedisplay, revgc, GXinvert); fontid = XLoadFont(thedisplay, FONTNAME); @@ -362,6 +359,7 @@ register XVisualInfo *v1, *v2; getbestvis() /* get the best visual for this screen */ { +#ifdef DEBUG static char vistype[][12] = { "StaticGray", "GrayScale", @@ -370,10 +368,11 @@ static char vistype[][12] = { "TrueColor", "DirectColor" }; +#endif static int rankings[3][6] = { {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1}, - {PseudoColor,GrayScale,-1}, - {PseudoColor,GrayScale,-1} + {PseudoColor,GrayScale,StaticGray,-1}, + {PseudoColor,GrayScale,StaticGray,-1} }; XVisualInfo *xvi; int vismatched; @@ -393,8 +392,12 @@ static char vistype[][12] = { xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched); if (xvi == NULL) quiterr("no visuals for this screen!"); -for (i = 0; i < vismatched; i++) -fprintf(stderr, "Type %s, depth %d\n", vistype[xvi[i].class], xvi[i].depth); +#ifdef DEBUG + fprintf(stderr, "Supported visuals:\n"); + for (i = 0; i < vismatched; i++) + fprintf(stderr, "\ttype %s, depth %d\n", + vistype[xvi[i].class], xvi[i].depth); +#endif for (i = 0, j = 1; j < vismatched; j++) if (viscmp(&xvi[i],&xvi[j]) > 0) i = j; @@ -407,14 +410,27 @@ fprintf(stderr, "Type %s, depth %d\n", vistype[xvi[i]. quiterr("inadequate visuals on this screen"); /* OK, we'll use it */ copystruct(&ourvis, &xvi[i]); -fprintf(stderr, "Selected visual type %s, depth %d\n", vistype[ourvis.class], -ourvis.depth); +#ifdef DEBUG + fprintf(stderr, "Selected visual type %s, depth %d\n", + vistype[ourvis.class], ourvis.depth); +#endif + /* make appropriate adjustments */ if (ourvis.class == GrayScale || ourvis.class == StaticGray) greyscale = 1; - if (1< 4) maxcolors -= 2; + if (ourvis.class == StaticGray) { + ourblack = 0; + ourwhite = 255; + } else if (ourvis.class == PseudoColor) { + ourblack = BlackPixel(thedisplay,ourscreen); + ourwhite = WhitePixel(thedisplay,ourscreen); + } else { + ourblack = 0; + ourwhite = ~0; + } XFree((char *)xvi); } @@ -450,14 +466,19 @@ getras() /* get raster file */ xmax, ymax, 8); if (ourras == NULL) goto fail; - if (greyscale) - biq(dither,maxcolors,1,ourmap); - else - ciq(dither,maxcolors,1,ourmap); - if (init_rcolors(ourras, ourmap[0], ourmap[1], ourmap[2]) == 0) - goto fail; + if (ourvis.class == StaticGray) + getgrey(); + else { + if (greyscale) + biq(dither,maxcolors,1,ourmap); + else + ciq(dither,maxcolors,1,ourmap); + if (init_rcolors(ourras, ourmap[0], + ourmap[1], ourmap[2]) == 0) + goto fail; + } } - return; + return; fail: quiterr("could not create raster image"); } @@ -488,7 +509,8 @@ getevent() /* process the next event */ make_rpixmap(ourras, wind); break; case UnmapNotify: - unmap_rcolors(ourras); + if (!fast) + unmap_rcolors(ourras); break; case Expose: redraw(e.e.x, e.e.y, e.e.width, e.e.height); @@ -844,6 +866,33 @@ getfull() /* get full (24-bit) data */ } +getgrey() /* get greyscale data */ +{ + int y; + register unsigned char *dp; + register int x; + /* set gamma correction */ + setcolrgam(gamcor); + /* read and convert file */ + dp = ourdata; + for (y = 0; y < ymax; y++) { + if (getscan(y) < 0) + quiterr("seek error in getfull"); + if (scale) + shiftcolrs(scanline, xmax, scale); + colrs_gambs(scanline, xmax); + add2icon(y, scanline); + if (ourvis.colormap_size < 256) + for (x = 0; x < xmax; x++) + *dp++ = ((long)normbright(scanline[x]) * + ourvis.colormap_size + 128) >> 8; + else + for (x = 0; x < xmax; x++) + *dp++ = normbright(scanline[x]); + } +} + + scale_rcolors(xr, sf) /* scale color map */ register XRASTER *xr; double sf; @@ -935,7 +984,7 @@ colormap map; picwritecm(map) /* handled elsewhere */ colormap map; { -#ifdef DEBUG +#if 0 register int i; for (i = 0; i < 256; i++)
