--- ray/src/px/x11image.c 1993/11/15 10:55:33 2.34 +++ ray/src/px/x11image.c 1995/01/25 10:53:02 2.41 @@ -1,4 +1,4 @@ -/* Copyright (c) 1993 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -56,6 +56,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras) double gamcor = 2.2; /* gamma correction */ +char *gamstr = NULL; /* gamma value override */ int dither = 1; /* dither colors? */ int fast = 0; /* keep picture in Pixmap? */ @@ -73,6 +74,7 @@ int xoff = 0; /* x image offset */ int yoff = 0; /* y image offset */ int parent = 0; /* number of children, -1 if child */ +int sequential = 0; /* display images in sequence */ VIEW ourview = STDVIEW; /* image view parameters */ int gotview = 0; /* got parameters from file */ @@ -112,10 +114,12 @@ char *progname; char errmsg[128]; -extern BYTE clrtab[256][3]; /* global color map */ +BYTE clrtab[256][3]; /* global color map */ extern long ftell(); +extern char *getenv(); + Display *thedisplay; Atom closedownAtom, wmProtocolsAtom; @@ -128,15 +132,11 @@ main(argc, argv) int argc; char *argv[]; { - extern char *getenv(); - char *gv; int headline(); int i; int pid; progname = argv[0]; - if ((gv = getenv("GAMMA")) != NULL) - gamcor = atof(gv); for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -148,6 +148,7 @@ char *argv[]; greyscale = !greyscale; break; case 'm': + greyscale = 1; maxcolors = 2; break; case 'd': @@ -159,6 +160,9 @@ char *argv[]; case 'f': fast = !fast; break; + case 's': + sequential = !sequential; + break; case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-') goto userr; @@ -168,7 +172,7 @@ char *argv[]; if (argv[i][2] == 'e') geometry = argv[++i]; else - gamcor = atof(argv[++i]); + gamstr = argv[++i]; break; default: goto userr; @@ -215,15 +219,11 @@ char *argv[]; init(argc, argv); /* get file and open window */ - if (parent < 0) { - kill(getppid(), SIGCONT); /* signal parent if child */ - sigrecv--; - } for ( ; ; ) getevent(); /* main loop */ userr: fprintf(stderr, -"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops] pic ..\n", +"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops][-g gamcor][-s] pic ..\n", progname); exit(1); } @@ -273,6 +273,13 @@ char **argv; name += i+1; if ((thedisplay = XOpenDisplay(dispname)) == NULL) quiterr("cannot open display"); + /* set gamma value */ + if (gamstr == NULL) /* get it from the X server */ + gamstr = XGetDefault(thedisplay, "radiance", "gamma"); + if (gamstr == NULL) /* get it from the environment */ + gamstr = getenv("DISPLAY_GAMMA"); + if (gamstr != NULL) + gamcor = atof(gamstr); /* get best visual for default screen */ getbestvis(); /* store image */ @@ -299,17 +306,20 @@ char **argv; } } /* open window */ + i = CWEventMask|CWCursor|CWBackPixel|CWBorderPixel; ourwinattr.border_pixel = ourwhite; ourwinattr.background_pixel = ourblack; - ourwinattr.colormap = XCreateColormap(thedisplay, ourroot, - ourvis.visual, AllocNone); + if (ourvis.visual != DefaultVisual(thedisplay,ourscreen)) { + ourwinattr.colormap = newcmap(thedisplay, ourscreen, ourvis.visual); + i |= CWColormap; + } ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask| ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask; ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross); wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y, xszhints.width, xszhints.height, BORWIDTH, - ourvis.depth, InputOutput, ourvis.visual, CWEventMask| - CWCursor|CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); + ourvis.depth, InputOutput, ourvis.visual, + i, &ourwinattr); if (wind == 0) quiterr("cannot create window"); width = xmax; @@ -347,7 +357,6 @@ char **argv; XSetWMProtocols(thedisplay, wind, &closedownAtom, 1); XMapWindow(thedisplay, wind); - return; } /* end of init */ @@ -360,10 +369,9 @@ char *err; if (es = err != NULL) fprintf(stderr, "%s: %s: %s\n", progname, fname==NULL?"":fname, err); - if (parent > 0 & wind != 0) { - XDestroyWindow(thedisplay, wind); - XFlush(thedisplay); - } else if (parent < 0 & sigrecv == 0) + if (thedisplay != NULL) + XCloseDisplay(thedisplay); + if (parent < 0 & sigrecv == 0) kill(getppid(), SIGCONT); while (parent > 0 && wait(&cs) != -1) { /* wait for any children */ if (es == 0) @@ -557,6 +565,10 @@ getevent() /* process the next event */ map_rcolors(ourras, wind); if (fast) make_rpixmap(ourras, wind); + if (!sequential & parent < 0 & sigrecv == 0) { + kill(getppid(), SIGCONT); + sigrecv--; + } break; case UnmapNotify: if (!fast) @@ -942,14 +954,14 @@ getfull() /* get full (24-bit) data */ colrs_gambs(scanline, xmax); if (ourras->image->blue_mask & 1) for (x = 0; x < xmax; x++) - *dp++ = scanline[x][RED] << 16 | - scanline[x][GRN] << 8 | - scanline[x][BLU] ; + *dp++ = (unsigned int4)scanline[x][RED] << 16 | + (unsigned int4)scanline[x][GRN] << 8 | + (unsigned int4)scanline[x][BLU] ; else for (x = 0; x < xmax; x++) - *dp++ = scanline[x][RED] | - scanline[x][GRN] << 8 | - scanline[x][BLU] << 16 ; + *dp++ = (unsigned int4)scanline[x][RED] | + (unsigned int4)scanline[x][GRN] << 8 | + (unsigned int4)scanline[x][BLU] << 16 ; } } @@ -994,7 +1006,8 @@ getmapped() /* get color-mapped data */ /* set gamma correction */ setcolrgam(gamcor); /* make histogram */ - new_histo(); + if (new_histo((long)xmax*ymax) == -1) + quiterr("cannot initialize histogram"); for (y = 0; y < ymax; y++) { if (getscan(y) < 0) break;
