--- ray/src/px/x11image.c 1994/06/10 12:51:21 2.37 +++ ray/src/px/x11image.c 2006/05/29 17:31:25 2.72 @@ -1,9 +1,6 @@ -/* Copyright (c) 1993 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: x11image.c,v 2.72 2006/05/29 17:31:25 greg Exp $"; #endif - /* * x11image.c - driver for X-windows * @@ -21,25 +18,23 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" +#include #include +#include +#include +#include #include #include #include #include #include "color.h" +#include "tonemap.h" +#include "clrtab.h" #include "view.h" #include "x11raster.h" #include "random.h" -#include "resolu.h" -#ifdef __alpha -#define int4 int -#endif -#ifndef int4 -#define int4 long -#endif - #define FONTNAME "8x13" /* text font we'll use */ #define CTRL(c) ((c)-'@') @@ -48,6 +43,8 @@ static char SCCSid[] = "$SunId$ LBL"; #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */ +#define FIXWEIGHT 20 /* weight to add for fixation points */ + #define ourscreen DefaultScreen(thedisplay) #define ourroot RootWindow(thedisplay,ourscreen) @@ -74,17 +71,26 @@ int xoff = 0; /* x image offset */ int yoff = 0; /* y image offset */ int parent = 0; /* number of children, -1 if child */ +int sequential = 0; /* display images in sequence */ +char *tout = "od"; /* output of 't' command */ +int tinterv = 0; /* interval between mouse reports */ + +int tmflags = TM_F_LINEAR; /* tone mapping flags */ + VIEW ourview = STDVIEW; /* image view parameters */ int gotview = 0; /* got parameters from file */ COLR *scanline; /* scan line buffer */ +TMbright *lscan; /* encoded luminance scanline */ +BYTE *cscan; /* encoded chroma scanline */ +BYTE *pscan; /* compute pixel scanline */ RESOLU inpres; /* input resolution and ordering */ int xmax, ymax; /* picture dimensions */ int width, height; /* window size */ char *fname = NULL; /* input file name */ -FILE *fin = stdin; /* input file */ +FILE *fin = NULL; /* input file */ long *scanpos = NULL; /* scan line positions in file */ int cury = 0; /* current scan location */ @@ -92,6 +98,9 @@ double exposure = 1.0; /* exposure compensation use int wrongformat = 0; /* input in another format? */ +TMstruct *tmGlobal; /* base tone-mapping */ +TMstruct *tmCurrent; /* curren tone-mapping */ + GC ourgc; /* standard graphics context */ GC revgc; /* graphics context with GXinvert */ @@ -102,7 +111,7 @@ unsigned char *ourdata; /* our image data */ struct { int xmin, ymin, xsiz, ysiz; -} box = {0, 0, 0, 0}; /* current box */ +} bbox = {0, 0, 0, 0}; /* current bbox */ char *geometry = NULL; /* geometry specification */ @@ -115,55 +124,99 @@ char errmsg[128]; BYTE clrtab[256][3]; /* global color map */ -extern long ftell(); -extern char *getenv(); - Display *thedisplay; Atom closedownAtom, wmProtocolsAtom; int sigrecv; -int onsig() { sigrecv++; } +void onsig(int i) { sigrecv++; } +typedef void doboxf_t(COLR *scn, int n, void *); -main(argc, argv) -int argc; -char *argv[]; +static gethfunc headline; +static void init(int argc, char **argv); +static void quiterr(char *err); +static int viscmp(XVisualInfo *v1, XVisualInfo *v2); +static void getbestvis(void); +static void getras(void); +static void getevent(void); +static int traceray(int xpos, int ypos); +static int docom(XKeyPressedEvent *ekey); +static void moveimage(XButtonPressedEvent *ebut); +static void getbox(XButtonPressedEvent *ebut); +static void trackrays(XButtonPressedEvent *ebut); +static void revbox(int x0, int y0, int x1, int y1); +static doboxf_t colavg; +static doboxf_t addfix; +static int avgbox(COLOR cavg); +static int dobox(doboxf_t *f, void *p); +static void make_tonemap(void); +static void tmap_colrs(COLR *scn, int len); +static void getmono(void); +static void add2icon(int y, COLR *scan); +static void getfull(void); +static void getgrey(void); +static void getmapped(void); +static void scale_rcolors(XRASTER *xr, double sf); +static int getscan(int y); + + +int +main(int argc, char *argv[]) { - int headline(); int i; int pid; progname = argv[0]; + fin = stdin; for (i = 1; i < argc; i++) if (argv[i][0] == '-') switch (argv[i][1]) { - case 'c': + case 'c': /* number of colors */ maxcolors = atoi(argv[++i]); break; - case 'b': + case 'b': /* greyscale only */ greyscale = !greyscale; break; - case 'm': + case 'm': /* monochrome */ + greyscale = 1; maxcolors = 2; break; - case 'd': + case 'd': /* display or dither */ if (argv[i][2] == 'i') dispname = argv[++i]; else dither = !dither; break; - case 'f': + case 'f': /* save pixmap */ fast = !fast; break; - case 'e': - if (argv[i+1][0] != '+' && argv[i+1][0] != '-') + case 's': /* one at a time */ + sequential = !sequential; + break; + case 'o': /* 't' output */ + tout = argv[i]+2; + break; + case 't': /* msec interval */ + tinterv = atoi(argv[++i]); + break; + case 'e': /* exposure comp. */ + i++; + if (argv[i][0] == 'a') { + tmflags = TM_F_CAMERA; + break; + } + if (argv[i][0] == 'h') { + tmflags = TM_F_HUMAN; + break; + } + if (argv[i][0] != '+' && argv[i][0] != '-') goto userr; - scale = atoi(argv[++i]); + scale = atoi(argv[i]); break; - case 'g': + case 'g': /* gamma comp. */ if (argv[i][2] == 'e') geometry = argv[++i]; else @@ -214,38 +267,39 @@ char *argv[]; init(argc, argv); /* get file and open window */ - if (parent < 0) { - kill(getppid(), SIGCONT); /* signal parent if child */ - sigrecv--; - } for ( ; ; ) getevent(); /* main loop */ userr: fprintf(stderr, -"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops][-g gamcor] pic ..\n", +"Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e spec][-g gamcor][-s][-ospec][-t intvl] pic ..\n", progname); exit(1); } -headline(s) /* get relevant info from header */ -char *s; +static int +headline( /* get relevant info from header */ + char *s, + void *p +) { char fmt[32]; if (isexpos(s)) exposure *= exposval(s); - else if (isformat(s)) { - formatval(fmt, s); + else if (formatval(fmt, s)) wrongformat = strcmp(fmt, COLRFMT); - } else if (isview(s) && sscanview(&ourview, s) > 0) + else if (isview(s) && sscanview(&ourview, s) > 0) gotview++; + return(0); } -init(argc, argv) /* get data and open window */ -int argc; -char **argv; +static void +init( /* get data and open window */ + int argc, + char **argv +) { XSetWindowAttributes ourwinattr; XClassHint xclshints; @@ -276,7 +330,7 @@ char **argv; if (gamstr == NULL) /* get it from the X server */ gamstr = XGetDefault(thedisplay, "radiance", "gamma"); if (gamstr == NULL) /* get it from the environment */ - gamstr = getenv("GAMMA"); + gamstr = getenv("DISPLAY_GAMMA"); if (gamstr != NULL) gamcor = atof(gamstr); /* get best visual for default screen */ @@ -305,17 +359,20 @@ char **argv; } } /* open window */ + i = CWEventMask|CWCursor|CWBackPixel|CWBorderPixel; ourwinattr.border_pixel = ourwhite; ourwinattr.background_pixel = ourblack; - ourwinattr.colormap = XCreateColormap(thedisplay, ourroot, - ourvis.visual, AllocNone); + if (ourvis.visual != DefaultVisual(thedisplay,ourscreen)) { + ourwinattr.colormap = newcmap(thedisplay, ourscreen, ourvis.visual); + i |= CWColormap; + } ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask| ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask; ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross); wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y, xszhints.width, xszhints.height, BORWIDTH, - ourvis.depth, InputOutput, ourvis.visual, CWEventMask| - CWCursor|CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr); + ourvis.depth, InputOutput, ourvis.visual, + i, &ourwinattr); if (wind == 0) quiterr("cannot create window"); width = xmax; @@ -340,9 +397,9 @@ char **argv; windowName.encoding = iconName.encoding = XA_STRING; windowName.format = iconName.format = 8; windowName.value = (u_char *)name; - windowName.nitems = strlen(windowName.value); + windowName.nitems = strlen((char *)windowName.value); iconName.value = (u_char *)name; - iconName.nitems = strlen(windowName.value); + iconName.nitems = strlen((char *)windowName.value); xclshints.res_name = NULL; xclshints.res_class = "Ximage"; @@ -353,22 +410,23 @@ char **argv; XSetWMProtocols(thedisplay, wind, &closedownAtom, 1); XMapWindow(thedisplay, wind); - return; } /* end of init */ -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { register int es; int cs; - if (es = err != NULL) + if ( (es = err != NULL) ) fprintf(stderr, "%s: %s: %s\n", progname, fname==NULL?"":fname, err); if (thedisplay != NULL) XCloseDisplay(thedisplay); - if (parent < 0 & sigrecv == 0) + if ((parent < 0) & (sigrecv == 0)) kill(getppid(), SIGCONT); while (parent > 0 && wait(&cs) != -1) { /* wait for any children */ if (es == 0) @@ -380,32 +438,35 @@ char *err; static int -viscmp(v1,v2) /* compare visual to see which is better, descending */ -register XVisualInfo *v1, *v2; +viscmp( /* compare visual to see which is better, descending */ + register XVisualInfo *v1, + register XVisualInfo *v2 +) { int bad1 = 0, bad2 = 0; register int *rp; if (v1->class == v2->class) { - if (v1->class == TrueColor || v1->class == DirectColor) { - /* prefer 24-bit to 32-bit */ - if (v1->depth == 24 && v2->depth == 32) + if ((v1->class == TrueColor) | (v1->class == DirectColor)) { + /* prefer 24-bit */ + if ((v1->depth == 24) & (v2->depth > 24)) return(-1); - if (v1->depth == 32 && v2->depth == 24) + if ((v1->depth > 24) & (v2->depth == 24)) return(1); - return(0); + /* go for maximum depth otherwise */ + return(v2->depth - v1->depth); } /* don't be too greedy */ - if (maxcolors <= 1<depth && maxcolors <= 1<depth) + if ((maxcolors <= 1<depth) & (maxcolors <= 1<depth)) return(v1->depth - v2->depth); return(v2->depth - v1->depth); } - /* prefer Pseudo when < 24-bit */ - if ((v1->class == TrueColor || v1->class == DirectColor) && - v1->depth < 24) + /* prefer Pseudo when < 15-bit */ + if ((v1->class == TrueColor) | (v1->class == DirectColor) && + v1->depth < 15) bad1 = 1; - if ((v2->class == TrueColor || v2->class == DirectColor) && - v2->depth < 24) + if ((v2->class == TrueColor) | (v2->class == DirectColor) && + v2->depth < 15) bad2 = -1; if (bad1 | bad2) return(bad1+bad2); @@ -420,7 +481,8 @@ register XVisualInfo *v1, *v2; } -getbestvis() /* get the best visual for this screen */ +static void +getbestvis(void) /* get the best visual for this screen */ { #ifdef DEBUG static char vistype[][12] = { @@ -472,7 +534,7 @@ static char vistype[][12] = { if (viscmp(&xvi[i],&ourvis) > 0) quiterr("inadequate visuals on this screen"); /* OK, we'll use it */ - copystruct(&ourvis, &xvi[i]); + ourvis = xvi[i]; #ifdef DEBUG fprintf(stderr, "Selected visual type %s, depth %d\n", vistype[ourvis.class], ourvis.depth); @@ -502,25 +564,25 @@ static char vistype[][12] = { } -getras() /* get raster file */ +static void +getras(void) /* get raster file */ { - XVisualInfo vinfo; - if (maxcolors <= 2) { /* monochrome */ ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8)); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, 1, ourdata, + ourras = make_raster(thedisplay, &ourvis, 1, (char *)ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; getmono(); - } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) { - ourdata = (unsigned char *)malloc(sizeof(int4)*xmax*ymax); + } else if ((ourvis.class == TrueColor) | (ourvis.class == DirectColor)) { + int datsiz = ourvis.depth>16 ? sizeof(int32) : sizeof(int16); + ourdata = (unsigned char *)malloc(datsiz*xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, sizeof(int4)*8, - ourdata, xmax, ymax, 32); + ourras = make_raster(thedisplay, &ourvis, datsiz*8, + (char *)ourdata, xmax, ymax, datsiz*8); if (ourras == NULL) goto fail; getfull(); @@ -528,11 +590,11 @@ getras() /* get raster file */ ourdata = (unsigned char *)malloc(xmax*ymax); if (ourdata == NULL) goto fail; - ourras = make_raster(thedisplay, &ourvis, 8, ourdata, + ourras = make_raster(thedisplay, &ourvis, 8, (char *)ourdata, xmax, ymax, 8); if (ourras == NULL) goto fail; - if (greyscale | ourvis.class == StaticGray) + if (greyscale) getgrey(); else getmapped(); @@ -545,7 +607,8 @@ fail: } -getevent() /* process the next event */ +static void +getevent(void) /* process the next event */ { XEvent xev; @@ -562,6 +625,10 @@ getevent() /* process the next event */ map_rcolors(ourras, wind); if (fast) make_rpixmap(ourras, wind); + if ((!sequential) & (parent < 0) & (sigrecv == 0)) { + kill(getppid(), SIGCONT); + sigrecv--; + } break; case UnmapNotify: if (!fast) @@ -574,10 +641,18 @@ getevent() /* process the next event */ case ButtonPress: if (xev.xbutton.state & (ShiftMask|ControlMask)) moveimage(&xev.xbutton); - else if (xev.xbutton.button == Button2) - traceray(xev.xbutton.x, xev.xbutton.y); else - getbox(&xev.xbutton); + switch (xev.xbutton.button) { + case Button1: + getbox(&xev.xbutton); + break; + case Button2: + traceray(xev.xbutton.x, xev.xbutton.y); + break; + case Button3: + trackrays(&xev.xbutton); + break; + } break; case ClientMessage: if ((xev.xclient.message_type == wmProtocolsAtom) && @@ -588,35 +663,63 @@ getevent() /* process the next event */ } -traceray(xpos, ypos) /* print ray corresponding to pixel */ -int xpos, ypos; +static int +traceray( /* print requested pixel data */ + int xpos, + int ypos +) { - FLOAT hv[2]; + RREAL hv[2]; FVECT rorg, rdir; + COLOR cval; + register char *cp; - if (!gotview) { /* no view, no can do */ - XBell(thedisplay, 0); - return(-1); - } + bbox.xmin = xpos; bbox.xsiz = 1; + bbox.ymin = ypos; bbox.ysiz = 1; + avgbox(cval); + scalecolor(cval, 1./exposure); pix2loc(hv, &inpres, xpos-xoff, ypos-yoff); - if (viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0) - return(-1); - printf("%e %e %e ", rorg[0], rorg[1], rorg[2]); - printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]); + if (!gotview || viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0) + rorg[0] = rorg[1] = rorg[2] = + rdir[0] = rdir[1] = rdir[2] = 0.; + + for (cp = tout; *cp; cp++) /* print what they asked for */ + switch (*cp) { + case 'o': /* origin */ + printf("%e %e %e ", rorg[0], rorg[1], rorg[2]); + break; + case 'd': /* direction */ + printf("%e %e %e ", rdir[0], rdir[1], rdir[2]); + break; + case 'v': /* radiance value */ + printf("%e %e %e ", colval(cval,RED), + colval(cval,GRN), colval(cval,BLU)); + break; + case 'l': /* luminance */ + printf("%e ", luminance(cval)); + break; + case 'p': /* pixel position */ + printf("%d %d ", (int)(hv[0]*inpres.xr), + (int)(hv[1]*inpres.yr)); + break; + } + putchar('\n'); fflush(stdout); return(0); } -docom(ekey) /* execute command */ -XKeyPressedEvent *ekey; +static int +docom( /* execute command */ + XKeyPressedEvent *ekey +) { char buf[80]; COLOR cval; XColor cvx; int com, n; double comp; - FLOAT hv[2]; + RREAL hv[2]; n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL); if (n == 0) @@ -631,7 +734,7 @@ XKeyPressedEvent *ekey; case '\r': case 'l': case 'c': /* value */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); switch (com) { case '\n': @@ -639,7 +742,7 @@ XKeyPressedEvent *ekey; sprintf(buf, "%.3f", intens(cval)/exposure); break; case 'l': /* luminance */ - sprintf(buf, "%.0fL", luminance(cval)/exposure); + sprintf(buf, "%.1fL", luminance(cval)/exposure); break; case 'c': /* color */ comp = pow(2.0, (double)scale); @@ -650,7 +753,7 @@ XKeyPressedEvent *ekey; break; } XDrawImageString(thedisplay, wind, ourgc, - box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); + bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf)); return(0); case 'i': /* identify (contour) */ if (ourras->pixels == NULL) @@ -673,9 +776,21 @@ XKeyPressedEvent *ekey; return(0); case 't': /* trace */ return(traceray(ekey->x, ekey->y)); + case 'a': /* auto exposure */ + if (fname == NULL) + return(-1); + tmflags = TM_F_CAMERA; + strcpy(buf, "auto exposure..."); + goto remap; + case 'h': /* human response */ + if (fname == NULL) + return(-1); + tmflags = TM_F_HUMAN; + strcpy(buf, "human exposure..."); + goto remap; case '=': /* adjust exposure */ case '@': /* adaptation level */ - if (avgbox(cval) == -1) + if (!avgbox(cval)) return(-1); comp = bright(cval); if (comp < 1e-20) { @@ -689,15 +804,20 @@ XKeyPressedEvent *ekey; comp = .5/comp; comp = log(comp)/.69315 - scale; n = comp < 0 ? comp-.5 : comp+.5 ; /* round */ - if (n == 0) - return(0); - scale_rcolors(ourras, pow(2.0, (double)n)); + if (tmflags != TM_F_LINEAR) + tmflags = TM_F_LINEAR; /* turn off tone mapping */ + else { + if (n == 0) /* else check if any change */ + return(0); + scale_rcolors(ourras, pow(2.0, (double)n)); + } scale += n; sprintf(buf, "%+d", scale); + remap: XDrawImageString(thedisplay, wind, ourgc, - box.xmin, box.ymin+box.ysiz, buf, strlen(buf)); + bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf)); XFlush(thedisplay); - free(ourdata); + /* free(ourdata); This is done in XDestroyImage()! */ free_raster(ourras); getras(); /* fall through */ @@ -719,14 +839,14 @@ XKeyPressedEvent *ekey; free_rpixmap(ourras); return(0); case '0': /* recenter origin */ - if (xoff == 0 & yoff == 0) + if ((xoff == 0) & (yoff == 0)) return(0); xoff = yoff = 0; XClearWindow(thedisplay, wind); redraw(0, 0, width, height); return(0); case ' ': /* clear */ - redraw(box.xmin, box.ymin, box.xsiz, box.ysiz); + redraw(bbox.xmin, bbox.ymin, bbox.xsiz, bbox.ysiz); return(0); default: XBell(thedisplay, 0); @@ -735,8 +855,10 @@ XKeyPressedEvent *ekey; } -moveimage(ebut) /* shift the image */ -XButtonPressedEvent *ebut; +static void +moveimage( /* shift the image */ + XButtonPressedEvent *ebut +) { XEvent e; int mxo, myo; @@ -760,37 +882,65 @@ XButtonPressedEvent *ebut; } -getbox(ebut) /* get new box */ -XButtonPressedEvent *ebut; +static void +getbox( /* get new bbox */ + XButtonPressedEvent *ebut +) { XEvent e; XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e); while (e.type == MotionNotify) { - revbox(ebut->x, ebut->y, box.xmin = e.xmotion.x, box.ymin = e.xmotion.y); + revbox(ebut->x, ebut->y, bbox.xmin = e.xmotion.x, bbox.ymin = e.xmotion.y); XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e); - revbox(ebut->x, ebut->y, box.xmin, box.ymin); + revbox(ebut->x, ebut->y, bbox.xmin, bbox.ymin); } - box.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x); - box.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y); - if (box.xmin > ebut->x) { - box.xsiz = box.xmin - ebut->x + 1; - box.xmin = ebut->x; + bbox.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x); + bbox.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y); + if (bbox.xmin > ebut->x) { + bbox.xsiz = bbox.xmin - ebut->x + 1; + bbox.xmin = ebut->x; } else { - box.xsiz = ebut->x - box.xmin + 1; + bbox.xsiz = ebut->x - bbox.xmin + 1; } - if (box.ymin > ebut->y) { - box.ysiz = box.ymin - ebut->y + 1; - box.ymin = ebut->y; + if (bbox.ymin > ebut->y) { + bbox.ysiz = bbox.ymin - ebut->y + 1; + bbox.ymin = ebut->y; } else { - box.ysiz = ebut->y - box.ymin + 1; + bbox.ysiz = ebut->y - bbox.ymin + 1; } } -revbox(x0, y0, x1, y1) /* draw box with reversed lines */ -int x0, y0, x1, y1; +static void +trackrays( /* trace rays as mouse moves */ + XButtonPressedEvent *ebut +) { + XEvent e; + unsigned long lastrept; + + traceray(ebut->x, ebut->y); + lastrept = ebut->time; + XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e); + while (e.type == MotionNotify) { + if (e.xmotion.time >= lastrept + tinterv) { + traceray(e.xmotion.x, e.xmotion.y); + lastrept = e.xmotion.time; + } + XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e); + } +} + + +static void +revbox( /* draw bbox with reversed lines */ + int x0, + int y0, + int x1, + int y1 +) +{ revline(x0, y0, x1, y0); revline(x0, y1, x1, y1); revline(x0, y0, x0, y1); @@ -798,56 +948,196 @@ int x0, y0, x1, y1; } -avgbox(clr) /* average color over current box */ -COLOR clr; +static void +colavg( + register COLR *scn, + register int n, + void *cavg +) { - static COLOR lc; - static int ll, lr, lt, lb; + COLOR col; + + while (n--) { + colr_color(col, *scn++); + addcolor((COLORV*)cavg, col); + } +} + + +static int +avgbox( /* average color over current bbox */ + COLOR cavg +) +{ + double d; + register int rval; + + setcolor(cavg, 0., 0., 0.); + rval = dobox(colavg, (void *)cavg); + if (rval > 0) { + d = 1./rval; + scalecolor(cavg, d); + } + return(rval); +} + + +static int +dobox( /* run function over bbox */ + //void (*f)(), /* function to call for each subscan */ + doboxf_t *f, /* function to call for each subscan */ + void *p /* pointer to private data */ +) +{ int left, right, top, bottom; int y; - double d; - COLOR ctmp; - register int x; - setcolor(clr, 0.0, 0.0, 0.0); - left = box.xmin - xoff; - right = left + box.xsiz; + left = bbox.xmin - xoff; + right = left + bbox.xsiz; if (left < 0) left = 0; if (right > xmax) right = xmax; if (left >= right) - return(-1); - top = box.ymin - yoff; - bottom = top + box.ysiz; + return(0); + top = bbox.ymin - yoff; + bottom = top + bbox.ysiz; if (top < 0) top = 0; if (bottom > ymax) bottom = ymax; if (top >= bottom) - return(-1); - if (left == ll && right == lr && top == lt && bottom == lb) { - copycolor(clr, lc); return(0); - } for (y = top; y < bottom; y++) { if (getscan(y) == -1) return(-1); - for (x = left; x < right; x++) { - colr_color(ctmp, scanline[x]); - addcolor(clr, ctmp); + (*f)(scanline+left, right-left, p); + } + return((right-left)*(bottom-top)); +} + + +static void +addfix( /* add fixation points to histogram */ + COLR *scn, + int n, + void *p +) +{ + TMstruct * tms = (TMstruct *)p; + + if (tmCvColrs(tms, lscan, TM_NOCHROM, scn, n)) + goto tmerr; + if (tmAddHisto(tms, lscan, n, FIXWEIGHT)) + goto tmerr; + return; +tmerr: + quiterr("tone mapping error"); +} + + +static void +make_tonemap(void) /* initialize tone mapping */ +{ + int flags, y; + + if (tmflags != TM_F_LINEAR && fname == NULL) { + fprintf(stderr, "%s: cannot adjust tone of standard input\n", + progname); + tmflags = TM_F_LINEAR; + } + if (tmflags == TM_F_LINEAR) { /* linear with clamping */ + setcolrcor(pow, 1.0/gamcor); + return; + } + flags = tmflags; /* histogram adjustment */ + if (greyscale) flags |= TM_F_BW; + if (tmGlobal != NULL) { /* reuse old histogram if one */ + tmDone(tmCurrent); tmCurrent = NULL; + tmGlobal->flags = flags; + } else { /* else initialize */ + if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL) + goto memerr; + if (greyscale) { + cscan = TM_NOCHROM; + if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL) + goto memerr; + } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax)) + == NULL) + goto memerr; + /* initialize tm library */ + tmGlobal = tmInit(flags, stdprims, gamcor); + if (tmGlobal == NULL) + goto memerr; + if (tmSetSpace(tmGlobal, stdprims, WHTEFFICACY/exposure, NULL)) + goto tmerr; + /* compute picture histogram */ + for (y = 0; y < ymax; y++) { + getscan(y); + if (tmCvColrs(tmGlobal, lscan, TM_NOCHROM, + scanline, xmax)) + goto tmerr; + if (tmAddHisto(tmGlobal, lscan, xmax, 1)) + goto tmerr; } } - d = 1.0/((right-left)*(bottom-top)); - scalecolor(clr, d); - ll = left; lr = right; lt = top; lb = bottom; - copycolor(lc, clr); - return(0); + tmCurrent = tmDup(tmGlobal); /* add fixations to duplicate map */ + dobox(addfix, (void *)tmCurrent); + /* (re)compute tone mapping */ + if (tmComputeMapping(tmCurrent, gamcor, 0., 0.)) + goto tmerr; + return; +memerr: + quiterr("out of memory in make_tonemap"); +tmerr: + quiterr("tone mapping error"); } -getmono() /* get monochrome data */ +static void +tmap_colrs( /* apply tone mapping to scanline */ + register COLR *scn, + int len +) { + register BYTE *ps; + + if (tmflags == TM_F_LINEAR) { + if (scale) + shiftcolrs(scn, len, scale); + colrs_gambs(scn, len); + return; + } + if (len > xmax) + quiterr("code error 1 in tmap_colrs"); + if (tmCvColrs(tmCurrent, lscan, cscan, scn, len)) + goto tmerr; + if (tmMapPixels(tmCurrent, pscan, lscan, cscan, len)) + goto tmerr; + ps = pscan; + if (greyscale) + while (len--) { + scn[0][RED] = scn[0][GRN] = scn[0][BLU] = *ps++; + scn[0][EXP] = COLXS; + scn++; + } + else + while (len--) { + scn[0][RED] = *ps++; + scn[0][GRN] = *ps++; + scn[0][BLU] = *ps++; + scn[0][EXP] = COLXS; + scn++; + } + return; +tmerr: + quiterr("tone mapping error"); +} + + +static void +getmono(void) /* get monochrome data */ +{ register unsigned char *dp; register int x, err; int y, errp; @@ -874,13 +1164,15 @@ getmono() /* get monochrome data */ cerr[x] = err + errp; } } - free((char *)cerr); + free((void *)cerr); } -add2icon(y, scan) /* add a scanline to our icon data */ -int y; -COLR *scan; +static void +add2icon( /* add a scanline to our icon data */ + int y, + COLR *scan +) { static short cerr[ICONSIZ]; static int ynext; @@ -917,7 +1209,7 @@ COLR *scan; errp = err; ti = x*xmax/iconwidth; copycolr(clr, scan[ti]); - normcolrs(clr, 1, scale); + normcolrs(&clr, 1, scale); err += normbright(clr) + cerr[x]; if (err > 127) err -= 255; @@ -930,55 +1222,91 @@ COLR *scan; } -getfull() /* get full (24-bit) data */ +static void +getfull(void) /* get full (24-bit) data */ { int y; - register unsigned int4 *dp; + register uint32 *dp; + register uint16 *dph; register int x; - /* set gamma correction */ - setcolrgam(gamcor); + /* initialize tone mapping */ + make_tonemap(); /* read and convert file */ - dp = (unsigned int4 *)ourdata; + dp = (uint32 *)ourdata; + dph = (uint16 *)ourdata; for (y = 0; y < ymax; y++) { getscan(y); add2icon(y, scanline); - if (scale) - shiftcolrs(scanline, xmax, scale); - colrs_gambs(scanline, xmax); - if (ourras->image->blue_mask & 1) + tmap_colrs(scanline, xmax); + switch (ourras->image->blue_mask) { + case 0xff: /* 24-bit RGB */ for (x = 0; x < xmax; x++) - *dp++ = (unsigned int4)scanline[x][RED] << 16 | - (unsigned int4)scanline[x][GRN] << 8 | - (unsigned int4)scanline[x][BLU] ; - else + *dp++ = (uint32)scanline[x][RED] << 16 | + (uint32)scanline[x][GRN] << 8 | + (uint32)scanline[x][BLU] ; + break; + case 0xff0000: /* 24-bit BGR */ for (x = 0; x < xmax; x++) - *dp++ = (unsigned int4)scanline[x][RED] | - (unsigned int4)scanline[x][GRN] << 8 | - (unsigned int4)scanline[x][BLU] << 16 ; + *dp++ = (uint32)scanline[x][RED] | + (uint32)scanline[x][GRN] << 8 | + (uint32)scanline[x][BLU] << 16 ; + break; +#if 0 + case 0x1f: /* 15-bit RGB */ + for (x = 0; x < xmax; x++) + *dph++ = (scanline[x][RED] << 7 & 0x7c00) | + (scanline[x][GRN] << 2 & 0x3e0) | + (unsigned)scanline[x][BLU] >> 3 ; + break; + case 0x7c00: /* 15-bit BGR */ + for (x = 0; x < xmax; x++) + *dph++ = (unsigned)scanline[x][RED] >> 3 | + (scanline[x][GRN] << 2 & 0x3e0) | + (scanline[x][BLU] << 7 & 0x7c00) ; + break; +#endif + default: /* unknown */ + if (ourvis.depth > 16) + for (x = 0; x < xmax; x++) { + *dp = ourras->image->red_mask & + ourras->image->red_mask*scanline[x][RED]/255; + *dp |= ourras->image->green_mask & + ourras->image->green_mask*scanline[x][GRN]/255; + *dp++ |= ourras->image->blue_mask & + ourras->image->blue_mask*scanline[x][BLU]/255; + } + else + for (x = 0; x < xmax; x++) { + *dph = ourras->image->red_mask & + ourras->image->red_mask*scanline[x][RED]/255; + *dph |= ourras->image->green_mask & + ourras->image->green_mask*scanline[x][GRN]/255; + *dph++ |= ourras->image->blue_mask & + ourras->image->blue_mask*scanline[x][BLU]/255; + } + break; + } } } -getgrey() /* get greyscale data */ +static void +getgrey(void) /* get greyscale data */ { int y; register unsigned char *dp; register int x; - /* set gamma correction */ - setcolrgam(gamcor); + /* initialize tone mapping */ + make_tonemap(); /* read and convert file */ dp = ourdata; for (y = 0; y < ymax; y++) { getscan(y); add2icon(y, scanline); - if (scale) - shiftcolrs(scanline, xmax, scale); - for (x = 0; x < xmax; x++) - scanline[x][GRN] = normbright(scanline[x]); - colrs_gambs(scanline, xmax); + tmap_colrs(scanline, xmax); if (maxcolors < 256) for (x = 0; x < xmax; x++) - *dp++ = ((long)scanline[x][GRN] * + *dp++ = ((int32)scanline[x][GRN] * maxcolors + maxcolors/2) >> 8; else for (x = 0; x < xmax; x++) @@ -986,28 +1314,27 @@ getgrey() /* get greyscale data */ } for (x = 0; x < maxcolors; x++) clrtab[x][RED] = clrtab[x][GRN] = - clrtab[x][BLU] = ((long)x*256 + 128)/maxcolors; + clrtab[x][BLU] = ((int32)x*256 + 128)/maxcolors; } -getmapped() /* get color-mapped data */ +static void +getmapped(void) /* get color-mapped data */ { int y; /* make sure we can do it first */ if (fname == NULL) quiterr("cannot map colors from standard input"); - /* set gamma correction */ - setcolrgam(gamcor); + /* initialize tone mapping */ + make_tonemap(); /* make histogram */ - if (new_histo((long)xmax*ymax) == -1) + if (new_histo((int32)xmax*ymax) == -1) quiterr("cannot initialize histogram"); for (y = 0; y < ymax; y++) { if (getscan(y) < 0) break; add2icon(y, scanline); - if (scale) - shiftcolrs(scanline, xmax, scale); - colrs_gambs(scanline, xmax); + tmap_colrs(scanline, xmax); cnt_colrs(scanline, xmax); } /* map pixels */ @@ -1015,9 +1342,7 @@ getmapped() /* get color-mapped data */ quiterr("cannot create color map"); for (y = 0; y < ymax; y++) { getscan(y); - if (scale) - shiftcolrs(scanline, xmax, scale); - colrs_gambs(scanline, xmax); + tmap_colrs(scanline, xmax); if (dither) dith_colrs(ourdata+y*xmax, scanline, xmax); else @@ -1026,9 +1351,11 @@ getmapped() /* get color-mapped data */ } -scale_rcolors(xr, sf) /* scale color map */ -register XRASTER *xr; -double sf; +static void +scale_rcolors( /* scale color map */ + register XRASTER *xr, + double sf +) { register int i; long maxv; @@ -1054,13 +1381,15 @@ double sf; } -getscan(y) -int y; +static int +getscan( + int y +) { static int trunced = -1; /* truncated file? */ skipit: if (trunced >= 0 && y >= trunced) { - bzero(scanline, xmax*sizeof(COLR)); + memset(scanline, '\0', xmax*sizeof(COLR)); return(-1); } if (y != cury) {
