root/radiance/ray/src/px/x11image.c
Revision: 2.32
Committed: Thu Oct 28 11:39:59 1993 UTC (31 years, 6 months ago) by greg
Changes since 2.31: +15 -8 lines
fixed problem where parent would stall after child aborted
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * x11image.c - driver for X-windows
9 *
10 * 3/1/90
11 */
12
13 /*
14 * Modified for X11
15 *
16 * January 1990
17 *
18 * Anat Grynberg and Greg Ward
19 */
20
21
22 #include "standard.h"
23
24 #include <signal.h>
25 #include <X11/Xlib.h>
26 #include <X11/cursorfont.h>
27 #include <X11/Xutil.h>
28 #include <X11/Xatom.h>
29
30 #include "color.h"
31 #include "view.h"
32 #include "x11raster.h"
33 #include "random.h"
34 #include "resolu.h"
35
36 #ifdef __alpha
37 #define int4 int
38 #endif
39 #ifndef int4
40 #define int4 long
41 #endif
42
43 #define FONTNAME "8x13" /* text font we'll use */
44
45 #define CTRL(c) ((c)-'@')
46
47 #define BORWIDTH 5 /* border width */
48
49 #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */
50
51 #define ourscreen DefaultScreen(thedisplay)
52 #define ourroot RootWindow(thedisplay,ourscreen)
53
54 #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1)
55
56 #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
57
58 double gamcor = 2.2; /* gamma correction */
59
60 int dither = 1; /* dither colors? */
61 int fast = 0; /* keep picture in Pixmap? */
62
63 char *dispname = NULL; /* our display name */
64
65 Window wind = 0; /* our output window */
66 unsigned long ourblack=0, ourwhite=1; /* black and white for this visual */
67 int maxcolors = 0; /* maximum colors */
68 int greyscale = 0; /* in grey */
69
70 int scale = 0; /* scalefactor; power of two */
71
72 int xoff = 0; /* x image offset */
73 int yoff = 0; /* y image offset */
74
75 int parent = 0; /* number of children, -1 if child */
76
77 VIEW ourview = STDVIEW; /* image view parameters */
78 int gotview = 0; /* got parameters from file */
79
80 COLR *scanline; /* scan line buffer */
81
82 RESOLU inpres; /* input resolution and ordering */
83 int xmax, ymax; /* picture dimensions */
84 int width, height; /* window size */
85 char *fname = NULL; /* input file name */
86 FILE *fin = stdin; /* input file */
87 long *scanpos = NULL; /* scan line positions in file */
88 int cury = 0; /* current scan location */
89
90 double exposure = 1.0; /* exposure compensation used */
91
92 int wrongformat = 0; /* input in another format? */
93
94 GC ourgc; /* standard graphics context */
95 GC revgc; /* graphics context with GXinvert */
96
97 int *ourrank; /* our visual class ranking */
98 XVisualInfo ourvis; /* our visual */
99 XRASTER *ourras; /* our stored image */
100 unsigned char *ourdata; /* our image data */
101
102 struct {
103 int xmin, ymin, xsiz, ysiz;
104 } box = {0, 0, 0, 0}; /* current box */
105
106 char *geometry = NULL; /* geometry specification */
107
108 char icondata[ICONSIZ*ICONSIZ/8]; /* icon bitmap data */
109 int iconwidth = 0, iconheight = 0;
110
111 char *progname;
112
113 char errmsg[128];
114
115 extern BYTE clrtab[256][3]; /* global color map */
116
117 extern long ftell();
118
119 Display *thedisplay;
120 Atom closedownAtom, wmProtocolsAtom;
121
122 int sigrecv;
123
124 int onsig() { sigrecv++; }
125
126
127 main(argc, argv)
128 int argc;
129 char *argv[];
130 {
131 extern char *getenv();
132 char *gv;
133 int headline();
134 int i;
135 int pid;
136
137 progname = argv[0];
138 if ((gv = getenv("GAMMA")) != NULL)
139 gamcor = atof(gv);
140
141 for (i = 1; i < argc; i++)
142 if (argv[i][0] == '-')
143 switch (argv[i][1]) {
144 case 'c':
145 maxcolors = atoi(argv[++i]);
146 break;
147 case 'b':
148 greyscale = !greyscale;
149 break;
150 case 'm':
151 maxcolors = 2;
152 break;
153 case 'd':
154 if (argv[i][2] == 'i')
155 dispname = argv[++i];
156 else
157 dither = !dither;
158 break;
159 case 'f':
160 fast = !fast;
161 break;
162 case 'e':
163 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
164 goto userr;
165 scale = atoi(argv[++i]);
166 break;
167 case 'g':
168 if (argv[i][2] == 'e')
169 geometry = argv[++i];
170 else
171 gamcor = atof(argv[++i]);
172 break;
173 default:
174 goto userr;
175 }
176 else if (argv[i][0] == '=')
177 geometry = argv[i];
178 else
179 break;
180
181 if (i > argc)
182 goto userr;
183 while (i < argc-1) {
184 sigrecv = 0;
185 signal(SIGCONT, onsig);
186 if ((pid=fork()) == 0) { /* a child for each picture */
187 parent = -1;
188 break;
189 }
190 if (pid < 0)
191 quiterr("fork failed");
192 parent++;
193 while (!sigrecv)
194 pause(); /* wait for wake-up call */
195 i++;
196 }
197 if (i < argc) { /* open picture file */
198 fname = argv[i];
199 fin = fopen(fname, "r");
200 if (fin == NULL) {
201 sprintf(errmsg, "cannot open file \"%s\"", fname);
202 quiterr(errmsg);
203 }
204 }
205 /* get header */
206 getheader(fin, headline, NULL);
207 /* get picture dimensions */
208 if (wrongformat || !fgetsresolu(&inpres, fin))
209 quiterr("bad picture format");
210 xmax = scanlen(&inpres);
211 ymax = numscans(&inpres);
212 /* set view parameters */
213 if (gotview && setview(&ourview) != NULL)
214 gotview = 0;
215 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
216 quiterr("out of memory");
217
218 init(argc, argv); /* get file and open window */
219
220 if (parent < 0) {
221 kill(getppid(), SIGCONT); /* signal parent if child */
222 sigrecv--;
223 }
224 for ( ; ; )
225 getevent(); /* main loop */
226 userr:
227 fprintf(stderr,
228 "Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e +/-stops] pic ..\n",
229 progname);
230 exit(1);
231 }
232
233
234 headline(s) /* get relevant info from header */
235 char *s;
236 {
237 char fmt[32];
238
239 if (isexpos(s))
240 exposure *= exposval(s);
241 else if (isformat(s)) {
242 formatval(fmt, s);
243 wrongformat = strcmp(fmt, COLRFMT);
244 } else if (isview(s) && sscanview(&ourview, s) > 0)
245 gotview++;
246 }
247
248
249 init(argc, argv) /* get data and open window */
250 int argc;
251 char **argv;
252 {
253 XSetWindowAttributes ourwinattr;
254 XClassHint xclshints;
255 XWMHints xwmhints;
256 XSizeHints xszhints;
257 XTextProperty windowName, iconName;
258 XGCValues xgcv;
259 char *name;
260 register int i;
261
262 if (fname != NULL) {
263 scanpos = (long *)malloc(ymax*sizeof(long));
264 if (scanpos == NULL)
265 quiterr("out of memory");
266 for (i = 0; i < ymax; i++)
267 scanpos[i] = -1;
268 name = fname;
269 } else
270 name = progname;
271 /* remove directory prefix from name */
272 for (i = strlen(name); i-- > 0; )
273 if (name[i] == '/')
274 break;
275 name += i+1;
276 if ((thedisplay = XOpenDisplay(dispname)) == NULL)
277 quiterr("cannot open display");
278 /* get best visual for default screen */
279 getbestvis();
280 /* store image */
281 getras();
282 /* get size and position */
283 xszhints.flags = 0;
284 xszhints.width = xmax; xszhints.height = ymax;
285 if (geometry != NULL) {
286 i = XParseGeometry(geometry, &xszhints.x, &xszhints.y,
287 (unsigned *)&xszhints.width,
288 (unsigned *)&xszhints.height);
289 if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
290 xszhints.flags |= USSize;
291 else
292 xszhints.flags |= PSize;
293 if ((i&(XValue|YValue)) == (XValue|YValue)) {
294 xszhints.flags |= USPosition;
295 if (i & XNegative)
296 xszhints.x += DisplayWidth(thedisplay,
297 ourscreen)-1-xszhints.width-2*BORWIDTH;
298 if (i & YNegative)
299 xszhints.y += DisplayHeight(thedisplay,
300 ourscreen)-1-xszhints.height-2*BORWIDTH;
301 }
302 }
303 /* open window */
304 ourwinattr.border_pixel = ourwhite;
305 ourwinattr.background_pixel = ourblack;
306 ourwinattr.colormap = XCreateColormap(thedisplay, ourroot,
307 ourvis.visual, AllocNone);
308 ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask|
309 ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask;
310 ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross);
311 wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y,
312 xszhints.width, xszhints.height, BORWIDTH,
313 ourvis.depth, InputOutput, ourvis.visual, CWEventMask|
314 CWCursor|CWBackPixel|CWBorderPixel|CWColormap, &ourwinattr);
315 if (wind == 0)
316 quiterr("cannot create window");
317 width = xmax;
318 height = ymax;
319 /* prepare graphics drawing context */
320 if ((xgcv.font = XLoadFont(thedisplay, FONTNAME)) == 0)
321 quiterr("cannot get font");
322 xgcv.foreground = ourblack;
323 xgcv.background = ourwhite;
324 ourgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
325 GCFont, &xgcv);
326 xgcv.function = GXinvert;
327 revgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
328 GCFunction, &xgcv);
329
330 /* set up the window manager */
331 xwmhints.flags = InputHint|IconPixmapHint;
332 xwmhints.input = True;
333 xwmhints.icon_pixmap = XCreateBitmapFromData(thedisplay,
334 wind, icondata, iconwidth, iconheight);
335
336 windowName.encoding = iconName.encoding = XA_STRING;
337 windowName.format = iconName.format = 8;
338 windowName.value = (u_char *)name;
339 windowName.nitems = strlen(windowName.value);
340 iconName.value = (u_char *)name;
341 iconName.nitems = strlen(windowName.value);
342
343 xclshints.res_name = NULL;
344 xclshints.res_class = "Ximage";
345 XSetWMProperties(thedisplay, wind, &windowName, &iconName,
346 argv, argc, &xszhints, &xwmhints, &xclshints);
347 closedownAtom = XInternAtom(thedisplay, "WM_DELETE_WINDOW", False);
348 wmProtocolsAtom = XInternAtom(thedisplay, "WM_PROTOCOLS", False);
349 XSetWMProtocols(thedisplay, wind, &closedownAtom, 1);
350
351 XMapWindow(thedisplay, wind);
352 return;
353 } /* end of init */
354
355
356 quiterr(err) /* print message and exit */
357 char *err;
358 {
359 register int es;
360 int cs;
361
362 if (es = err != NULL)
363 fprintf(stderr, "%s: %s: %s\n", progname,
364 fname==NULL?"<stdin>":fname, err);
365 if (parent > 0 & wind != 0) {
366 XDestroyWindow(thedisplay, wind);
367 XFlush(thedisplay);
368 } else if (parent < 0 & sigrecv == 0)
369 kill(getppid(), SIGCONT);
370 while (parent > 0 && wait(&cs) != -1) { /* wait for any children */
371 if (es == 0)
372 es = cs>>8 & 0xff;
373 parent--;
374 }
375 exit(es);
376 }
377
378
379 static int
380 viscmp(v1,v2) /* compare visual to see which is better, descending */
381 register XVisualInfo *v1, *v2;
382 {
383 int bad1 = 0, bad2 = 0;
384 register int *rp;
385
386 if (v1->class == v2->class) {
387 if (v1->class == TrueColor || v1->class == DirectColor) {
388 /* prefer 24-bit to 32-bit */
389 if (v1->depth == 24 && v2->depth == 32)
390 return(-1);
391 if (v1->depth == 32 && v2->depth == 24)
392 return(1);
393 return(0);
394 }
395 /* don't be too greedy */
396 if (maxcolors <= 1<<v1->depth && maxcolors <= 1<<v2->depth)
397 return(v1->depth - v2->depth);
398 return(v2->depth - v1->depth);
399 }
400 /* prefer Pseudo when < 24-bit */
401 if ((v1->class == TrueColor || v1->class == DirectColor) &&
402 v1->depth < 24)
403 bad1 = 1;
404 if ((v2->class == TrueColor || v2->class == DirectColor) &&
405 v2->depth < 24)
406 bad2 = -1;
407 if (bad1 | bad2)
408 return(bad1+bad2);
409 /* otherwise, use class ranking */
410 for (rp = ourrank; *rp != -1; rp++) {
411 if (v1->class == *rp)
412 return(-1);
413 if (v2->class == *rp)
414 return(1);
415 }
416 return(0);
417 }
418
419
420 getbestvis() /* get the best visual for this screen */
421 {
422 #ifdef DEBUG
423 static char vistype[][12] = {
424 "StaticGray",
425 "GrayScale",
426 "StaticColor",
427 "PseudoColor",
428 "TrueColor",
429 "DirectColor"
430 };
431 #endif
432 static int rankings[3][6] = {
433 {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1},
434 {PseudoColor,GrayScale,StaticGray,-1},
435 {PseudoColor,GrayScale,StaticGray,-1}
436 };
437 XVisualInfo *xvi;
438 int vismatched;
439 register int i, j;
440
441 if (greyscale) {
442 ourrank = rankings[2];
443 if (maxcolors < 2) maxcolors = 256;
444 } else if (maxcolors >= 2 && maxcolors <= 256)
445 ourrank = rankings[1];
446 else {
447 ourrank = rankings[0];
448 maxcolors = 256;
449 }
450 /* find best visual */
451 ourvis.screen = ourscreen;
452 xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched);
453 if (xvi == NULL)
454 quiterr("no visuals for this screen!");
455 #ifdef DEBUG
456 fprintf(stderr, "Supported visuals:\n");
457 for (i = 0; i < vismatched; i++)
458 fprintf(stderr, "\ttype %s, depth %d\n",
459 vistype[xvi[i].class], xvi[i].depth);
460 #endif
461 for (i = 0, j = 1; j < vismatched; j++)
462 if (viscmp(&xvi[i],&xvi[j]) > 0)
463 i = j;
464 /* compare to least acceptable */
465 for (j = 0; ourrank[j++] != -1; )
466 ;
467 ourvis.class = ourrank[--j];
468 ourvis.depth = 1;
469 if (viscmp(&xvi[i],&ourvis) > 0)
470 quiterr("inadequate visuals on this screen");
471 /* OK, we'll use it */
472 copystruct(&ourvis, &xvi[i]);
473 #ifdef DEBUG
474 fprintf(stderr, "Selected visual type %s, depth %d\n",
475 vistype[ourvis.class], ourvis.depth);
476 #endif
477 /* make appropriate adjustments */
478 if (ourvis.class == GrayScale || ourvis.class == StaticGray)
479 greyscale = 1;
480 if (ourvis.depth <= 8 && ourvis.colormap_size < maxcolors)
481 maxcolors = ourvis.colormap_size;
482 if (ourvis.class == StaticGray) {
483 ourblack = 0;
484 ourwhite = 255;
485 } else if (ourvis.class == PseudoColor) {
486 ourblack = BlackPixel(thedisplay,ourscreen);
487 ourwhite = WhitePixel(thedisplay,ourscreen);
488 if ((ourblack|ourwhite) & ~255L) {
489 ourblack = 0;
490 ourwhite = 1;
491 }
492 if (maxcolors > 4)
493 maxcolors -= 2;
494 } else {
495 ourblack = 0;
496 ourwhite = ourvis.red_mask|ourvis.green_mask|ourvis.blue_mask;
497 }
498 XFree((char *)xvi);
499 }
500
501
502 getras() /* get raster file */
503 {
504 XVisualInfo vinfo;
505
506 if (maxcolors <= 2) { /* monochrome */
507 ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
508 if (ourdata == NULL)
509 goto fail;
510 ourras = make_raster(thedisplay, &ourvis, 1, ourdata,
511 xmax, ymax, 8);
512 if (ourras == NULL)
513 goto fail;
514 getmono();
515 } else if (ourvis.class == TrueColor | ourvis.class == DirectColor) {
516 ourdata = (unsigned char *)malloc(sizeof(int4)*xmax*ymax);
517 if (ourdata == NULL)
518 goto fail;
519 ourras = make_raster(thedisplay, &ourvis, sizeof(int4)*8,
520 ourdata, xmax, ymax, 32);
521 if (ourras == NULL)
522 goto fail;
523 getfull();
524 } else {
525 ourdata = (unsigned char *)malloc(xmax*ymax);
526 if (ourdata == NULL)
527 goto fail;
528 ourras = make_raster(thedisplay, &ourvis, 8, ourdata,
529 xmax, ymax, 8);
530 if (ourras == NULL)
531 goto fail;
532 if (greyscale | ourvis.class == StaticGray)
533 getgrey();
534 else
535 getmapped();
536 if (ourvis.class != StaticGray && !init_rcolors(ourras,clrtab))
537 goto fail;
538 }
539 return;
540 fail:
541 quiterr("could not create raster image");
542 }
543
544
545 getevent() /* process the next event */
546 {
547 XEvent xev;
548
549 XNextEvent(thedisplay, &xev);
550 switch ((int)xev.type) {
551 case KeyPress:
552 docom(&xev.xkey);
553 break;
554 case ConfigureNotify:
555 width = xev.xconfigure.width;
556 height = xev.xconfigure.height;
557 break;
558 case MapNotify:
559 map_rcolors(ourras, wind);
560 if (fast)
561 make_rpixmap(ourras, wind);
562 break;
563 case UnmapNotify:
564 if (!fast)
565 unmap_rcolors(ourras);
566 break;
567 case Expose:
568 redraw(xev.xexpose.x, xev.xexpose.y,
569 xev.xexpose.width, xev.xexpose.height);
570 break;
571 case ButtonPress:
572 if (xev.xbutton.state & (ShiftMask|ControlMask))
573 moveimage(&xev.xbutton);
574 else if (xev.xbutton.button == Button2)
575 traceray(xev.xbutton.x, xev.xbutton.y);
576 else
577 getbox(&xev.xbutton);
578 break;
579 case ClientMessage:
580 if ((xev.xclient.message_type == wmProtocolsAtom) &&
581 (xev.xclient.data.l[0] == closedownAtom))
582 quiterr(NULL);
583 break;
584 }
585 }
586
587
588 traceray(xpos, ypos) /* print ray corresponding to pixel */
589 int xpos, ypos;
590 {
591 FLOAT hv[2];
592 FVECT rorg, rdir;
593
594 if (!gotview) { /* no view, no can do */
595 XBell(thedisplay, 0);
596 return(-1);
597 }
598 pix2loc(hv, &inpres, xpos-xoff, ypos-yoff);
599 if (viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0)
600 return(-1);
601 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
602 printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
603 fflush(stdout);
604 return(0);
605 }
606
607
608 docom(ekey) /* execute command */
609 XKeyPressedEvent *ekey;
610 {
611 char buf[80];
612 COLOR cval;
613 XColor cvx;
614 int com, n;
615 double comp;
616 FLOAT hv[2];
617
618 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
619 if (n == 0)
620 return(0);
621 com = buf[0];
622 switch (com) { /* interpret command */
623 case 'q':
624 case 'Q':
625 case CTRL('D'): /* quit */
626 quiterr(NULL);
627 case '\n':
628 case '\r':
629 case 'l':
630 case 'c': /* value */
631 if (avgbox(cval) == -1)
632 return(-1);
633 switch (com) {
634 case '\n':
635 case '\r': /* radiance */
636 sprintf(buf, "%.3f", intens(cval)/exposure);
637 break;
638 case 'l': /* luminance */
639 sprintf(buf, "%.0fL", luminance(cval)/exposure);
640 break;
641 case 'c': /* color */
642 comp = pow(2.0, (double)scale);
643 sprintf(buf, "(%.2f,%.2f,%.2f)",
644 colval(cval,RED)*comp,
645 colval(cval,GRN)*comp,
646 colval(cval,BLU)*comp);
647 break;
648 }
649 XDrawImageString(thedisplay, wind, ourgc,
650 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
651 return(0);
652 case 'i': /* identify (contour) */
653 if (ourras->pixels == NULL)
654 return(-1);
655 n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
656 n = ourras->pmap[n];
657 cvx.pixel = ourras->cdefs[n].pixel;
658 cvx.red = random() & 65535;
659 cvx.green = random() & 65535;
660 cvx.blue = random() & 65535;
661 cvx.flags = DoRed|DoGreen|DoBlue;
662 XStoreColor(thedisplay, ourras->cmap, &cvx);
663 return(0);
664 case 'p': /* position */
665 pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff);
666 sprintf(buf, "(%d,%d)", (int)(hv[0]*inpres.xr),
667 (int)(hv[1]*inpres.yr));
668 XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
669 buf, strlen(buf));
670 return(0);
671 case 't': /* trace */
672 return(traceray(ekey->x, ekey->y));
673 case '=': /* adjust exposure */
674 case '@': /* adaptation level */
675 if (avgbox(cval) == -1)
676 return(-1);
677 comp = com=='@'
678 ? 106./pow(1.219+pow(luminance(cval)/exposure,.4),2.5)/exposure
679 : .5/bright(cval) ;
680 comp = log(comp)/.69315 - scale;
681 n = comp < 0 ? comp-.5 : comp+.5 ; /* round */
682 if (n == 0)
683 return(0);
684 scale_rcolors(ourras, pow(2.0, (double)n));
685 scale += n;
686 sprintf(buf, "%+d", scale);
687 XDrawImageString(thedisplay, wind, ourgc,
688 box.xmin, box.ymin+box.ysiz, buf, strlen(buf));
689 XFlush(thedisplay);
690 free(ourdata);
691 free_raster(ourras);
692 getras();
693 /* fall through */
694 case CTRL('R'): /* redraw */
695 case CTRL('L'):
696 unmap_rcolors(ourras);
697 XClearWindow(thedisplay, wind);
698 map_rcolors(ourras, wind);
699 if (fast)
700 make_rpixmap(ourras, wind);
701 redraw(0, 0, width, height);
702 return(0);
703 case 'f': /* turn on fast redraw */
704 fast = 1;
705 make_rpixmap(ourras, wind);
706 return(0);
707 case 'F': /* turn off fast redraw */
708 fast = 0;
709 free_rpixmap(ourras);
710 return(0);
711 case '0': /* recenter origin */
712 if (xoff == 0 & yoff == 0)
713 return(0);
714 xoff = yoff = 0;
715 XClearWindow(thedisplay, wind);
716 redraw(0, 0, width, height);
717 return(0);
718 case ' ': /* clear */
719 redraw(box.xmin, box.ymin, box.xsiz, box.ysiz);
720 return(0);
721 default:
722 XBell(thedisplay, 0);
723 return(-1);
724 }
725 }
726
727
728 moveimage(ebut) /* shift the image */
729 XButtonPressedEvent *ebut;
730 {
731 XEvent e;
732 int mxo, myo;
733
734 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
735 while (e.type == MotionNotify) {
736 mxo = e.xmotion.x;
737 myo = e.xmotion.y;
738 revline(ebut->x, ebut->y, mxo, myo);
739 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
740 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
741 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
742 revline(ebut->x, ebut->y, mxo, myo);
743 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
744 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
745 }
746 xoff += e.xbutton.x - ebut->x;
747 yoff += e.xbutton.y - ebut->y;
748 XClearWindow(thedisplay, wind);
749 redraw(0, 0, width, height);
750 }
751
752
753 getbox(ebut) /* get new box */
754 XButtonPressedEvent *ebut;
755 {
756 XEvent e;
757
758 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
759 while (e.type == MotionNotify) {
760 revbox(ebut->x, ebut->y, box.xmin = e.xmotion.x, box.ymin = e.xmotion.y);
761 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
762 revbox(ebut->x, ebut->y, box.xmin, box.ymin);
763 }
764 box.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x);
765 box.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y);
766 if (box.xmin > ebut->x) {
767 box.xsiz = box.xmin - ebut->x + 1;
768 box.xmin = ebut->x;
769 } else {
770 box.xsiz = ebut->x - box.xmin + 1;
771 }
772 if (box.ymin > ebut->y) {
773 box.ysiz = box.ymin - ebut->y + 1;
774 box.ymin = ebut->y;
775 } else {
776 box.ysiz = ebut->y - box.ymin + 1;
777 }
778 }
779
780
781 revbox(x0, y0, x1, y1) /* draw box with reversed lines */
782 int x0, y0, x1, y1;
783 {
784 revline(x0, y0, x1, y0);
785 revline(x0, y1, x1, y1);
786 revline(x0, y0, x0, y1);
787 revline(x1, y0, x1, y1);
788 }
789
790
791 avgbox(clr) /* average color over current box */
792 COLOR clr;
793 {
794 static COLOR lc;
795 static int ll, lr, lt, lb;
796 int left, right, top, bottom;
797 int y;
798 double d;
799 COLOR ctmp;
800 register int x;
801
802 setcolor(clr, 0.0, 0.0, 0.0);
803 left = box.xmin - xoff;
804 right = left + box.xsiz;
805 if (left < 0)
806 left = 0;
807 if (right > xmax)
808 right = xmax;
809 if (left >= right)
810 return(-1);
811 top = box.ymin - yoff;
812 bottom = top + box.ysiz;
813 if (top < 0)
814 top = 0;
815 if (bottom > ymax)
816 bottom = ymax;
817 if (top >= bottom)
818 return(-1);
819 if (left == ll && right == lr && top == lt && bottom == lb) {
820 copycolor(clr, lc);
821 return(0);
822 }
823 for (y = top; y < bottom; y++) {
824 if (getscan(y) == -1)
825 return(-1);
826 for (x = left; x < right; x++) {
827 colr_color(ctmp, scanline[x]);
828 addcolor(clr, ctmp);
829 }
830 }
831 d = 1.0/((right-left)*(bottom-top));
832 scalecolor(clr, d);
833 ll = left; lr = right; lt = top; lb = bottom;
834 copycolor(lc, clr);
835 return(0);
836 }
837
838
839 getmono() /* get monochrome data */
840 {
841 register unsigned char *dp;
842 register int x, err;
843 int y, errp;
844 short *cerr;
845
846 if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
847 quiterr("out of memory in getmono");
848 dp = ourdata - 1;
849 for (y = 0; y < ymax; y++) {
850 getscan(y);
851 add2icon(y, scanline);
852 normcolrs(scanline, xmax, scale);
853 err = 0;
854 for (x = 0; x < xmax; x++) {
855 if (!(x&7))
856 *++dp = 0;
857 errp = err;
858 err += normbright(scanline[x]) + cerr[x];
859 if (err > 127)
860 err -= 255;
861 else
862 *dp |= 1<<(7-(x&07));
863 err /= 3;
864 cerr[x] = err + errp;
865 }
866 }
867 free((char *)cerr);
868 }
869
870
871 add2icon(y, scan) /* add a scanline to our icon data */
872 int y;
873 COLR *scan;
874 {
875 static short cerr[ICONSIZ];
876 static int ynext;
877 static char *dp;
878 COLR clr;
879 register int err;
880 register int x, ti;
881 int errp;
882
883 if (iconheight == 0) { /* initialize */
884 if (xmax <= ICONSIZ && ymax <= ICONSIZ) {
885 iconwidth = xmax;
886 iconheight = ymax;
887 } else if (xmax > ymax) {
888 iconwidth = ICONSIZ;
889 iconheight = ICONSIZ*ymax/xmax;
890 if (iconheight < 1)
891 iconheight = 1;
892 } else {
893 iconwidth = ICONSIZ*xmax/ymax;
894 if (iconwidth < 1)
895 iconwidth = 1;
896 iconheight = ICONSIZ;
897 }
898 ynext = 0;
899 dp = icondata - 1;
900 }
901 if (y < ynext*ymax/iconheight) /* skip this one */
902 return;
903 err = 0;
904 for (x = 0; x < iconwidth; x++) {
905 if (!(x&7))
906 *++dp = 0;
907 errp = err;
908 ti = x*xmax/iconwidth;
909 copycolr(clr, scan[ti]);
910 normcolrs(clr, 1, scale);
911 err += normbright(clr) + cerr[x];
912 if (err > 127)
913 err -= 255;
914 else
915 *dp |= 1<<(x&07);
916 err /= 3;
917 cerr[x] = err + errp;
918 }
919 ynext++;
920 }
921
922
923 getfull() /* get full (24-bit) data */
924 {
925 int y;
926 register unsigned int4 *dp;
927 register int x;
928 /* set gamma correction */
929 setcolrgam(gamcor);
930 /* read and convert file */
931 dp = (unsigned int4 *)ourdata;
932 for (y = 0; y < ymax; y++) {
933 getscan(y);
934 add2icon(y, scanline);
935 if (scale)
936 shiftcolrs(scanline, xmax, scale);
937 colrs_gambs(scanline, xmax);
938 if (ourras->image->blue_mask & 1)
939 for (x = 0; x < xmax; x++)
940 *dp++ = scanline[x][RED] << 16 |
941 scanline[x][GRN] << 8 |
942 scanline[x][BLU] ;
943 else
944 for (x = 0; x < xmax; x++)
945 *dp++ = scanline[x][RED] |
946 scanline[x][GRN] << 8 |
947 scanline[x][BLU] << 16 ;
948 }
949 }
950
951
952 getgrey() /* get greyscale data */
953 {
954 int y;
955 register unsigned char *dp;
956 register int x;
957 /* set gamma correction */
958 setcolrgam(gamcor);
959 /* read and convert file */
960 dp = ourdata;
961 for (y = 0; y < ymax; y++) {
962 getscan(y);
963 add2icon(y, scanline);
964 if (scale)
965 shiftcolrs(scanline, xmax, scale);
966 for (x = 0; x < xmax; x++)
967 scanline[x][GRN] = normbright(scanline[x]);
968 colrs_gambs(scanline, xmax);
969 if (maxcolors < 256)
970 for (x = 0; x < xmax; x++)
971 *dp++ = ((long)scanline[x][GRN] *
972 maxcolors + maxcolors/2) >> 8;
973 else
974 for (x = 0; x < xmax; x++)
975 *dp++ = scanline[x][GRN];
976 }
977 for (x = 0; x < maxcolors; x++)
978 clrtab[x][RED] = clrtab[x][GRN] =
979 clrtab[x][BLU] = ((long)x*256 + 128)/maxcolors;
980 }
981
982
983 getmapped() /* get color-mapped data */
984 {
985 int y;
986 /* make sure we can do it first */
987 if (fname == NULL)
988 quiterr("cannot map colors from standard input");
989 /* set gamma correction */
990 setcolrgam(gamcor);
991 /* make histogram */
992 new_histo();
993 for (y = 0; y < ymax; y++) {
994 if (getscan(y) < 0)
995 break;
996 add2icon(y, scanline);
997 if (scale)
998 shiftcolrs(scanline, xmax, scale);
999 colrs_gambs(scanline, xmax);
1000 cnt_colrs(scanline, xmax);
1001 }
1002 /* map pixels */
1003 if (!new_clrtab(maxcolors))
1004 quiterr("cannot create color map");
1005 for (y = 0; y < ymax; y++) {
1006 getscan(y);
1007 if (scale)
1008 shiftcolrs(scanline, xmax, scale);
1009 colrs_gambs(scanline, xmax);
1010 if (dither)
1011 dith_colrs(ourdata+y*xmax, scanline, xmax);
1012 else
1013 map_colrs(ourdata+y*xmax, scanline, xmax);
1014 }
1015 }
1016
1017
1018 scale_rcolors(xr, sf) /* scale color map */
1019 register XRASTER *xr;
1020 double sf;
1021 {
1022 register int i;
1023 long maxv;
1024
1025 if (xr->pixels == NULL)
1026 return;
1027
1028 sf = pow(sf, 1.0/gamcor);
1029 maxv = 65535/sf;
1030
1031 for (i = xr->ncolors; i--; ) {
1032 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
1033 65535 :
1034 xr->cdefs[i].red * sf;
1035 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
1036 65535 :
1037 xr->cdefs[i].green * sf;
1038 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
1039 65535 :
1040 xr->cdefs[i].blue * sf;
1041 }
1042 XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
1043 }
1044
1045
1046 getscan(y)
1047 int y;
1048 {
1049 static int trunced = -1; /* truncated file? */
1050 skipit:
1051 if (trunced >= 0 && y >= trunced) {
1052 bzero(scanline, xmax*sizeof(COLR));
1053 return(-1);
1054 }
1055 if (y != cury) {
1056 if (scanpos == NULL || scanpos[y] == -1)
1057 return(-1);
1058 if (fseek(fin, scanpos[y], 0) == -1)
1059 quiterr("fseek error");
1060 cury = y;
1061 } else if (scanpos != NULL && scanpos[y] == -1)
1062 scanpos[y] = ftell(fin);
1063
1064 if (freadcolrs(scanline, xmax, fin) < 0) {
1065 fprintf(stderr, "%s: %s: unfinished picture\n",
1066 progname, fname==NULL?"<stdin>":fname);
1067 trunced = y;
1068 goto skipit;
1069 }
1070 cury++;
1071 return(0);
1072 }
