root/radiance/ray/src/px/x11image.c
Revision: 2.64
Committed: Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Changes since 2.63: +5 -5 lines
2 static const char RCSid[] = "$Id";
5 * x11image.c - driver for X-windows
6 *
7 * 3/1/90
8 */
9
10 /*
11 * Modified for X11
12 *
13 * January 1990
14 *
15 * Anat Grynberg and Greg Ward
16 */
17
18
19 #include "standard.h"
20
21 #include <string.h>
22 #include <signal.h>
23 #include <X11/Xlib.h>
24 #include <X11/cursorfont.h>
25 #include <X11/Xutil.h>
26 #include <X11/Xatom.h>
27
28 #include "color.h"
29 #include "tonemap.h"
30 #include "view.h"
31 #include "x11raster.h"
32 #include "random.h"
33
34 #define FONTNAME "8x13" /* text font we'll use */
35
36 #define CTRL(c) ((c)-'@')
37
38 #define BORWIDTH 5 /* border width */
39
40 #define ICONSIZ (8*10) /* maximum icon dimension (even 8) */
41
42 #define FIXWEIGHT 20 /* weight to add for fixation points */
43
44 #define ourscreen DefaultScreen(thedisplay)
45 #define ourroot RootWindow(thedisplay,ourscreen)
46
47 #define revline(x0,y0,x1,y1) XDrawLine(thedisplay,wind,revgc,x0,y0,x1,y1)
48
49 #define redraw(x,y,w,h) patch_raster(wind,(x)-xoff,(y)-yoff,x,y,w,h,ourras)
50
51 double gamcor = 2.2; /* gamma correction */
52 char *gamstr = NULL; /* gamma value override */
53
54 int dither = 1; /* dither colors? */
55 int fast = 0; /* keep picture in Pixmap? */
56
57 char *dispname = NULL; /* our display name */
58
59 Window wind = 0; /* our output window */
60 unsigned long ourblack=0, ourwhite=1; /* black and white for this visual */
61 int maxcolors = 0; /* maximum colors */
62 int greyscale = 0; /* in grey */
63
64 int scale = 0; /* scalefactor; power of two */
65
66 int xoff = 0; /* x image offset */
67 int yoff = 0; /* y image offset */
68
69 int parent = 0; /* number of children, -1 if child */
70 int sequential = 0; /* display images in sequence */
71
72 char *tout = "od"; /* output of 't' command */
73 int tinterv = 0; /* interval between mouse reports */
74
75 int tmflags = TM_F_LINEAR; /* tone mapping flags */
76
77 VIEW ourview = STDVIEW; /* image view parameters */
78 int gotview = 0; /* got parameters from file */
79
80 COLR *scanline; /* scan line buffer */
81 TMbright *lscan; /* encoded luminance scanline */
82 BYTE *cscan; /* encoded chroma scanline */
83 BYTE *pscan; /* compute pixel scanline */
84
85 RESOLU inpres; /* input resolution and ordering */
86 int xmax, ymax; /* picture dimensions */
87 int width, height; /* window size */
88 char *fname = NULL; /* input file name */
89 FILE *fin = NULL; /* input file */
90 long *scanpos = NULL; /* scan line positions in file */
91 int cury = 0; /* current scan location */
92
93 double exposure = 1.0; /* exposure compensation used */
94
95 int wrongformat = 0; /* input in another format? */
96
97 GC ourgc; /* standard graphics context */
98 GC revgc; /* graphics context with GXinvert */
99
100 int *ourrank; /* our visual class ranking */
101 XVisualInfo ourvis; /* our visual */
102 XRASTER *ourras; /* our stored image */
103 unsigned char *ourdata; /* our image data */
104
105 struct {
106 int xmin, ymin, xsiz, ysiz;
107 } bbox = {0, 0, 0, 0}; /* current bbox */
108
109 char *geometry = NULL; /* geometry specification */
110
111 char icondata[ICONSIZ*ICONSIZ/8]; /* icon bitmap data */
112 int iconwidth = 0, iconheight = 0;
113
114 char *progname;
115
116 char errmsg[128];
117
118 BYTE clrtab[256][3]; /* global color map */
119
120 extern long ftell();
121
122 extern char *getenv();
123
124 Display *thedisplay;
125 Atom closedownAtom, wmProtocolsAtom;
126
127 int sigrecv;
128
129 void onsig(int i) { sigrecv++; }
130
131
132 main(argc, argv)
133 int argc;
134 char *argv[];
135 {
136 int headline();
137 int i;
138 int pid;
139
140 progname = argv[0];
141 fin = stdin;
142
143 for (i = 1; i < argc; i++)
144 if (argv[i][0] == '-')
145 switch (argv[i][1]) {
146 case 'c': /* number of colors */
147 maxcolors = atoi(argv[++i]);
148 break;
149 case 'b': /* greyscale only */
150 greyscale = !greyscale;
151 break;
152 case 'm': /* monochrome */
153 greyscale = 1;
154 maxcolors = 2;
155 break;
156 case 'd': /* display or dither */
157 if (argv[i][2] == 'i')
158 dispname = argv[++i];
159 else
160 dither = !dither;
161 break;
162 case 'f': /* save pixmap */
163 fast = !fast;
164 break;
165 case 's': /* one at a time */
166 sequential = !sequential;
167 break;
168 case 'o': /* 't' output */
169 tout = argv[i]+2;
170 break;
171 case 't': /* msec interval */
172 tinterv = atoi(argv[++i]);
173 break;
174 case 'e': /* exposure comp. */
175 i++;
176 if (argv[i][0] == 'a') {
177 tmflags = TM_F_CAMERA;
178 break;
179 }
180 if (argv[i][0] == 'h') {
181 tmflags = TM_F_HUMAN;
182 break;
183 }
184 if (argv[i][0] != '+' && argv[i][0] != '-')
185 goto userr;
186 scale = atoi(argv[i]);
187 break;
188 case 'g': /* gamma comp. */
189 if (argv[i][2] == 'e')
190 geometry = argv[++i];
191 else
192 gamstr = argv[++i];
193 break;
194 default:
195 goto userr;
196 }
197 else if (argv[i][0] == '=')
198 geometry = argv[i];
199 else
200 break;
201
202 if (i > argc)
203 goto userr;
204 while (i < argc-1) {
205 sigrecv = 0;
206 signal(SIGCONT, onsig);
207 if ((pid=fork()) == 0) { /* a child for each picture */
208 parent = -1;
209 break;
210 }
211 if (pid < 0)
212 quiterr("fork failed");
213 parent++;
214 while (!sigrecv)
215 pause(); /* wait for wake-up call */
216 i++;
217 }
218 if (i < argc) { /* open picture file */
219 fname = argv[i];
220 fin = fopen(fname, "r");
221 if (fin == NULL)
222 quiterr("cannot open picture file");
223 }
224 /* get header */
225 getheader(fin, headline, NULL);
226 /* get picture dimensions */
227 if (wrongformat || !fgetsresolu(&inpres, fin))
228 quiterr("bad picture format");
229 xmax = scanlen(&inpres);
230 ymax = numscans(&inpres);
231 /* set view parameters */
232 if (gotview && setview(&ourview) != NULL)
233 gotview = 0;
234 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
235 quiterr("out of memory");
236
237 init(argc, argv); /* get file and open window */
238
239 for ( ; ; )
240 getevent(); /* main loop */
241 userr:
242 fprintf(stderr,
243 "Usage: %s [-di disp][[-ge] spec][-b][-m][-d][-f][-c nclrs][-e spec][-g gamcor][-s][-ospec][-t intvl] pic ..\n",
244 progname);
245 exit(1);
246 }
247
248
249 int
250 headline(s) /* get relevant info from header */
251 char *s;
252 {
253 char fmt[32];
254
255 if (isexpos(s))
256 exposure *= exposval(s);
257 else if (formatval(fmt, s))
258 wrongformat = strcmp(fmt, COLRFMT);
259 else if (isview(s) && sscanview(&ourview, s) > 0)
260 gotview++;
261 return(0);
262 }
263
264
265 init(argc, argv) /* get data and open window */
266 int argc;
267 char **argv;
268 {
269 XSetWindowAttributes ourwinattr;
270 XClassHint xclshints;
271 XWMHints xwmhints;
272 XSizeHints xszhints;
273 XTextProperty windowName, iconName;
274 XGCValues xgcv;
275 char *name;
276 register int i;
277
278 if (fname != NULL) {
279 scanpos = (long *)malloc(ymax*sizeof(long));
280 if (scanpos == NULL)
281 quiterr("out of memory");
282 for (i = 0; i < ymax; i++)
283 scanpos[i] = -1;
284 name = fname;
285 } else
286 name = progname;
287 /* remove directory prefix from name */
288 for (i = strlen(name); i-- > 0; )
289 if (name[i] == '/')
290 break;
291 name += i+1;
292 if ((thedisplay = XOpenDisplay(dispname)) == NULL)
293 quiterr("cannot open display");
294 /* set gamma value */
295 if (gamstr == NULL) /* get it from the X server */
296 gamstr = XGetDefault(thedisplay, "radiance", "gamma");
297 if (gamstr == NULL) /* get it from the environment */
298 gamstr = getenv("DISPLAY_GAMMA");
299 if (gamstr != NULL)
300 gamcor = atof(gamstr);
301 /* get best visual for default screen */
302 getbestvis();
303 /* store image */
304 getras();
305 /* get size and position */
306 xszhints.flags = 0;
307 xszhints.width = xmax; xszhints.height = ymax;
308 if (geometry != NULL) {
309 i = XParseGeometry(geometry, &xszhints.x, &xszhints.y,
310 (unsigned *)&xszhints.width,
311 (unsigned *)&xszhints.height);
312 if ((i&(WidthValue|HeightValue)) == (WidthValue|HeightValue))
313 xszhints.flags |= USSize;
314 else
315 xszhints.flags |= PSize;
316 if ((i&(XValue|YValue)) == (XValue|YValue)) {
317 xszhints.flags |= USPosition;
318 if (i & XNegative)
319 xszhints.x += DisplayWidth(thedisplay,
320 ourscreen)-1-xszhints.width-2*BORWIDTH;
321 if (i & YNegative)
322 xszhints.y += DisplayHeight(thedisplay,
323 ourscreen)-1-xszhints.height-2*BORWIDTH;
324 }
325 }
326 /* open window */
327 i = CWEventMask|CWCursor|CWBackPixel|CWBorderPixel;
328 ourwinattr.border_pixel = ourwhite;
329 ourwinattr.background_pixel = ourblack;
330 if (ourvis.visual != DefaultVisual(thedisplay,ourscreen)) {
331 ourwinattr.colormap = newcmap(thedisplay, ourscreen, ourvis.visual);
332 i |= CWColormap;
333 }
334 ourwinattr.event_mask = ExposureMask|KeyPressMask|ButtonPressMask|
335 ButtonReleaseMask|ButtonMotionMask|StructureNotifyMask;
336 ourwinattr.cursor = XCreateFontCursor(thedisplay, XC_diamond_cross);
337 wind = XCreateWindow(thedisplay, ourroot, xszhints.x, xszhints.y,
338 xszhints.width, xszhints.height, BORWIDTH,
339 ourvis.depth, InputOutput, ourvis.visual,
340 i, &ourwinattr);
341 if (wind == 0)
342 quiterr("cannot create window");
343 width = xmax;
344 height = ymax;
345 /* prepare graphics drawing context */
346 if ((xgcv.font = XLoadFont(thedisplay, FONTNAME)) == 0)
347 quiterr("cannot get font");
348 xgcv.foreground = ourblack;
349 xgcv.background = ourwhite;
350 ourgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
351 GCFont, &xgcv);
352 xgcv.function = GXinvert;
353 revgc = XCreateGC(thedisplay, wind, GCForeground|GCBackground|
354 GCFunction, &xgcv);
355
356 /* set up the window manager */
357 xwmhints.flags = InputHint|IconPixmapHint;
358 xwmhints.input = True;
359 xwmhints.icon_pixmap = XCreateBitmapFromData(thedisplay,
360 wind, icondata, iconwidth, iconheight);
361
362 windowName.encoding = iconName.encoding = XA_STRING;
363 windowName.format = iconName.format = 8;
364 windowName.value = (u_char *)name;
365 windowName.nitems = strlen(windowName.value);
366 iconName.value = (u_char *)name;
367 iconName.nitems = strlen(windowName.value);
368
369 xclshints.res_name = NULL;
370 xclshints.res_class = "Ximage";
371 XSetWMProperties(thedisplay, wind, &windowName, &iconName,
372 argv, argc, &xszhints, &xwmhints, &xclshints);
373 closedownAtom = XInternAtom(thedisplay, "WM_DELETE_WINDOW", False);
374 wmProtocolsAtom = XInternAtom(thedisplay, "WM_PROTOCOLS", False);
375 XSetWMProtocols(thedisplay, wind, &closedownAtom, 1);
376
377 XMapWindow(thedisplay, wind);
378 } /* end of init */
379
380
381 quiterr(err) /* print message and exit */
382 char *err;
383 {
384 register int es;
385 int cs;
386
387 if ( (es = err != NULL) )
388 fprintf(stderr, "%s: %s: %s\n", progname,
389 fname==NULL?"<stdin>":fname, err);
390 if (thedisplay != NULL)
391 XCloseDisplay(thedisplay);
392 if ((parent < 0) & (sigrecv == 0))
393 kill(getppid(), SIGCONT);
394 while (parent > 0 && wait(&cs) != -1) { /* wait for any children */
395 if (es == 0)
396 es = cs>>8 & 0xff;
397 parent--;
398 }
399 exit(es);
400 }
401
402
403 static int
404 viscmp(v1,v2) /* compare visual to see which is better, descending */
405 register XVisualInfo *v1, *v2;
406 {
407 int bad1 = 0, bad2 = 0;
408 register int *rp;
409
410 if (v1->class == v2->class) {
411 if (v1->class == TrueColor || v1->class == DirectColor) {
412 /* prefer 24-bit to 32-bit */
413 if (v1->depth == 24 && v2->depth == 32)
414 return(-1);
415 if (v1->depth == 32 && v2->depth == 24)
416 return(1);
417 /* go for maximum depth otherwise */
418 return(v2->depth - v1->depth);
419 }
420 /* don't be too greedy */
421 if (maxcolors <= 1<<v1->depth && maxcolors <= 1<<v2->depth)
422 return(v1->depth - v2->depth);
423 return(v2->depth - v1->depth);
424 }
425 /* prefer Pseudo when < 15-bit */
426 if ((v1->class == TrueColor || v1->class == DirectColor) &&
427 v1->depth < 15)
428 bad1 = 1;
429 if ((v2->class == TrueColor || v2->class == DirectColor) &&
430 v2->depth < 15)
431 bad2 = -1;
432 if (bad1 | bad2)
433 return(bad1+bad2);
434 /* otherwise, use class ranking */
435 for (rp = ourrank; *rp != -1; rp++) {
436 if (v1->class == *rp)
437 return(-1);
438 if (v2->class == *rp)
439 return(1);
440 }
441 return(0);
442 }
443
444
445 getbestvis() /* get the best visual for this screen */
446 {
447 #ifdef DEBUG
448 static char vistype[][12] = {
449 "StaticGray",
450 "GrayScale",
451 "StaticColor",
452 "PseudoColor",
453 "TrueColor",
454 "DirectColor"
455 };
456 #endif
457 static int rankings[3][6] = {
458 {TrueColor,DirectColor,PseudoColor,GrayScale,StaticGray,-1},
459 {PseudoColor,GrayScale,StaticGray,-1},
460 {PseudoColor,GrayScale,StaticGray,-1}
461 };
462 XVisualInfo *xvi;
463 int vismatched;
464 register int i, j;
465
466 if (greyscale) {
467 ourrank = rankings[2];
468 if (maxcolors < 2) maxcolors = 256;
469 } else if (maxcolors >= 2 && maxcolors <= 256)
470 ourrank = rankings[1];
471 else {
472 ourrank = rankings[0];
473 maxcolors = 256;
474 }
475 /* find best visual */
476 ourvis.screen = ourscreen;
477 xvi = XGetVisualInfo(thedisplay,VisualScreenMask,&ourvis,&vismatched);
478 if (xvi == NULL)
479 quiterr("no visuals for this screen!");
480 #ifdef DEBUG
481 fprintf(stderr, "Supported visuals:\n");
482 for (i = 0; i < vismatched; i++)
483 fprintf(stderr, "\ttype %s, depth %d\n",
484 vistype[xvi[i].class], xvi[i].depth);
485 #endif
486 for (i = 0, j = 1; j < vismatched; j++)
487 if (viscmp(&xvi[i],&xvi[j]) > 0)
488 i = j;
489 /* compare to least acceptable */
490 for (j = 0; ourrank[j++] != -1; )
491 ;
492 ourvis.class = ourrank[--j];
493 ourvis.depth = 1;
494 if (viscmp(&xvi[i],&ourvis) > 0)
495 quiterr("inadequate visuals on this screen");
496 /* OK, we'll use it */
497 ourvis = xvi[i];
498 #ifdef DEBUG
499 fprintf(stderr, "Selected visual type %s, depth %d\n",
500 vistype[ourvis.class], ourvis.depth);
501 #endif
502 /* make appropriate adjustments */
503 if (ourvis.class == GrayScale || ourvis.class == StaticGray)
504 greyscale = 1;
505 if (ourvis.depth <= 8 && ourvis.colormap_size < maxcolors)
506 maxcolors = ourvis.colormap_size;
507 if (ourvis.class == StaticGray) {
508 ourblack = 0;
509 ourwhite = 255;
510 } else if (ourvis.class == PseudoColor) {
511 ourblack = BlackPixel(thedisplay,ourscreen);
512 ourwhite = WhitePixel(thedisplay,ourscreen);
513 if ((ourblack|ourwhite) & ~255L) {
514 ourblack = 0;
515 ourwhite = 1;
516 }
517 if (maxcolors > 4)
518 maxcolors -= 2;
519 } else {
520 ourblack = 0;
521 ourwhite = ourvis.red_mask|ourvis.green_mask|ourvis.blue_mask;
522 }
523 XFree((char *)xvi);
524 }
525
526
527 getras() /* get raster file */
528 {
529 XVisualInfo vinfo;
530
531 if (maxcolors <= 2) { /* monochrome */
532 ourdata = (unsigned char *)malloc(ymax*((xmax+7)/8));
533 if (ourdata == NULL)
534 goto fail;
535 ourras = make_raster(thedisplay, &ourvis, 1, ourdata,
536 xmax, ymax, 8);
537 if (ourras == NULL)
538 goto fail;
539 getmono();
540 } else if ((ourvis.class == TrueColor) | (ourvis.class == DirectColor)) {
541 int datsiz = ourvis.depth>16 ? sizeof(int32) : sizeof(int16);
542 ourdata = (unsigned char *)malloc(datsiz*xmax*ymax);
543 if (ourdata == NULL)
544 goto fail;
545 ourras = make_raster(thedisplay, &ourvis, datsiz*8,
546 ourdata, xmax, ymax, datsiz*8);
547 if (ourras == NULL)
548 goto fail;
549 getfull();
550 } else {
551 ourdata = (unsigned char *)malloc(xmax*ymax);
552 if (ourdata == NULL)
553 goto fail;
554 ourras = make_raster(thedisplay, &ourvis, 8, ourdata,
555 xmax, ymax, 8);
556 if (ourras == NULL)
557 goto fail;
558 if (greyscale)
559 getgrey();
560 else
561 getmapped();
562 if (ourvis.class != StaticGray && !init_rcolors(ourras,clrtab))
563 goto fail;
564 }
565 return;
566 fail:
567 quiterr("could not create raster image");
568 }
569
570
571 getevent() /* process the next event */
572 {
573 XEvent xev;
574
575 XNextEvent(thedisplay, &xev);
576 switch ((int)xev.type) {
577 case KeyPress:
578 docom(&xev.xkey);
579 break;
580 case ConfigureNotify:
581 width = xev.xconfigure.width;
582 height = xev.xconfigure.height;
583 break;
584 case MapNotify:
585 map_rcolors(ourras, wind);
586 if (fast)
587 make_rpixmap(ourras, wind);
588 if ((!sequential) & (parent < 0) & (sigrecv == 0)) {
589 kill(getppid(), SIGCONT);
590 sigrecv--;
591 }
592 break;
593 case UnmapNotify:
594 if (!fast)
595 unmap_rcolors(ourras);
596 break;
597 case Expose:
598 redraw(xev.xexpose.x, xev.xexpose.y,
599 xev.xexpose.width, xev.xexpose.height);
600 break;
601 case ButtonPress:
602 if (xev.xbutton.state & (ShiftMask|ControlMask))
603 moveimage(&xev.xbutton);
604 else
605 switch (xev.xbutton.button) {
606 case Button1:
607 getbox(&xev.xbutton);
608 break;
609 case Button2:
610 traceray(xev.xbutton.x, xev.xbutton.y);
611 break;
612 case Button3:
613 trackrays(&xev.xbutton);
614 break;
615 }
616 break;
617 case ClientMessage:
618 if ((xev.xclient.message_type == wmProtocolsAtom) &&
619 (xev.xclient.data.l[0] == closedownAtom))
620 quiterr(NULL);
621 break;
622 }
623 }
624
625
626 traceray(xpos, ypos) /* print requested pixel data */
627 int xpos, ypos;
628 {
629 RREAL hv[2];
630 FVECT rorg, rdir;
631 COLOR cval;
632 register char *cp;
633
634 bbox.xmin = xpos; bbox.xsiz = 1;
635 bbox.ymin = ypos; bbox.ysiz = 1;
636 avgbox(cval);
637 scalecolor(cval, 1./exposure);
638 pix2loc(hv, &inpres, xpos-xoff, ypos-yoff);
639 if (!gotview || viewray(rorg, rdir, &ourview, hv[0], hv[1]) < 0)
640 rorg[0] = rorg[1] = rorg[2] =
641 rdir[0] = rdir[1] = rdir[2] = 0.;
642
643 for (cp = tout; *cp; cp++) /* print what they asked for */
644 switch (*cp) {
645 case 'o': /* origin */
646 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
647 break;
648 case 'd': /* direction */
649 printf("%e %e %e ", rdir[0], rdir[1], rdir[2]);
650 break;
651 case 'v': /* radiance value */
652 printf("%e %e %e ", colval(cval,RED),
653 colval(cval,GRN), colval(cval,BLU));
654 break;
655 case 'l': /* luminance */
656 printf("%e ", luminance(cval));
657 break;
658 case 'p': /* pixel position */
659 printf("%d %d ", (int)(hv[0]*inpres.xr),
660 (int)(hv[1]*inpres.yr));
661 break;
662 }
663 putchar('\n');
664 fflush(stdout);
665 return(0);
666 }
667
668
669 docom(ekey) /* execute command */
670 XKeyPressedEvent *ekey;
671 {
672 char buf[80];
673 COLOR cval;
674 XColor cvx;
675 int com, n;
676 double comp;
677 RREAL hv[2];
678
679 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
680 if (n == 0)
681 return(0);
682 com = buf[0];
683 switch (com) { /* interpret command */
684 case 'q':
685 case 'Q':
686 case CTRL('D'): /* quit */
687 quiterr(NULL);
688 case '\n':
689 case '\r':
690 case 'l':
691 case 'c': /* value */
692 if (!avgbox(cval))
693 return(-1);
694 switch (com) {
695 case '\n':
696 case '\r': /* radiance */
697 sprintf(buf, "%.3f", intens(cval)/exposure);
698 break;
699 case 'l': /* luminance */
700 sprintf(buf, "%.1fL", luminance(cval)/exposure);
701 break;
702 case 'c': /* color */
703 comp = pow(2.0, (double)scale);
704 sprintf(buf, "(%.2f,%.2f,%.2f)",
705 colval(cval,RED)*comp,
706 colval(cval,GRN)*comp,
707 colval(cval,BLU)*comp);
708 break;
709 }
710 XDrawImageString(thedisplay, wind, ourgc,
711 bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf));
712 return(0);
713 case 'i': /* identify (contour) */
714 if (ourras->pixels == NULL)
715 return(-1);
716 n = ourdata[ekey->x-xoff+xmax*(ekey->y-yoff)];
717 n = ourras->pmap[n];
718 cvx.pixel = ourras->cdefs[n].pixel;
719 cvx.red = random() & 65535;
720 cvx.green = random() & 65535;
721 cvx.blue = random() & 65535;
722 cvx.flags = DoRed|DoGreen|DoBlue;
723 XStoreColor(thedisplay, ourras->cmap, &cvx);
724 return(0);
725 case 'p': /* position */
726 pix2loc(hv, &inpres, ekey->x-xoff, ekey->y-yoff);
727 sprintf(buf, "(%d,%d)", (int)(hv[0]*inpres.xr),
728 (int)(hv[1]*inpres.yr));
729 XDrawImageString(thedisplay, wind, ourgc, ekey->x, ekey->y,
730 buf, strlen(buf));
731 return(0);
732 case 't': /* trace */
733 return(traceray(ekey->x, ekey->y));
734 case 'a': /* auto exposure */
735 if (fname == NULL)
736 return(-1);
737 tmflags = TM_F_CAMERA;
738 strcpy(buf, "auto exposure...");
739 goto remap;
740 case 'h': /* human response */
741 if (fname == NULL)
742 return(-1);
743 tmflags = TM_F_HUMAN;
744 strcpy(buf, "human exposure...");
745 goto remap;
746 case '=': /* adjust exposure */
747 case '@': /* adaptation level */
748 if (!avgbox(cval))
749 return(-1);
750 comp = bright(cval);
751 if (comp < 1e-20) {
752 XBell(thedisplay, 0);
753 return(-1);
754 }
755 if (com == '@')
756 comp = 106./exposure/
757 pow(1.219+pow(comp*WHTEFFICACY/exposure,.4),2.5);
758 else
759 comp = .5/comp;
760 comp = log(comp)/.69315 - scale;
761 n = comp < 0 ? comp-.5 : comp+.5 ; /* round */
762 if (tmflags != TM_F_LINEAR)
763 tmflags = TM_F_LINEAR; /* turn off tone mapping */
764 else {
765 if (n == 0) /* else check if any change */
766 return(0);
767 scale_rcolors(ourras, pow(2.0, (double)n));
768 }
769 scale += n;
770 sprintf(buf, "%+d", scale);
771 remap:
772 XDrawImageString(thedisplay, wind, ourgc,
773 bbox.xmin, bbox.ymin+bbox.ysiz, buf, strlen(buf));
774 XFlush(thedisplay);
775 /* free(ourdata); This is done in XDestroyImage()! */
776 free_raster(ourras);
777 getras();
778 /* fall through */
779 case CTRL('R'): /* redraw */
780 case CTRL('L'):
781 unmap_rcolors(ourras);
782 XClearWindow(thedisplay, wind);
783 map_rcolors(ourras, wind);
784 if (fast)
785 make_rpixmap(ourras, wind);
786 redraw(0, 0, width, height);
787 return(0);
788 case 'f': /* turn on fast redraw */
789 fast = 1;
790 make_rpixmap(ourras, wind);
791 return(0);
792 case 'F': /* turn off fast redraw */
793 fast = 0;
794 free_rpixmap(ourras);
795 return(0);
796 case '0': /* recenter origin */
797 if ((xoff == 0) & (yoff == 0))
798 return(0);
799 xoff = yoff = 0;
800 XClearWindow(thedisplay, wind);
801 redraw(0, 0, width, height);
802 return(0);
803 case ' ': /* clear */
804 redraw(bbox.xmin, bbox.ymin, bbox.xsiz, bbox.ysiz);
805 return(0);
806 default:
807 XBell(thedisplay, 0);
808 return(-1);
809 }
810 }
811
812
813 moveimage(ebut) /* shift the image */
814 XButtonPressedEvent *ebut;
815 {
816 XEvent e;
817 int mxo, myo;
818
819 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
820 while (e.type == MotionNotify) {
821 mxo = e.xmotion.x;
822 myo = e.xmotion.y;
823 revline(ebut->x, ebut->y, mxo, myo);
824 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
825 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
826 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
827 revline(ebut->x, ebut->y, mxo, myo);
828 revbox(xoff+mxo-ebut->x, yoff+myo-ebut->y,
829 xoff+mxo-ebut->x+xmax, yoff+myo-ebut->y+ymax);
830 }
831 xoff += e.xbutton.x - ebut->x;
832 yoff += e.xbutton.y - ebut->y;
833 XClearWindow(thedisplay, wind);
834 redraw(0, 0, width, height);
835 }
836
837
838 getbox(ebut) /* get new bbox */
839 XButtonPressedEvent *ebut;
840 {
841 XEvent e;
842
843 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
844 while (e.type == MotionNotify) {
845 revbox(ebut->x, ebut->y, bbox.xmin = e.xmotion.x, bbox.ymin = e.xmotion.y);
846 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
847 revbox(ebut->x, ebut->y, bbox.xmin, bbox.ymin);
848 }
849 bbox.xmin = e.xbutton.x<0 ? 0 : (e.xbutton.x>=width ? width-1 : e.xbutton.x);
850 bbox.ymin = e.xbutton.y<0 ? 0 : (e.xbutton.y>=height ? height-1 : e.xbutton.y);
851 if (bbox.xmin > ebut->x) {
852 bbox.xsiz = bbox.xmin - ebut->x + 1;
853 bbox.xmin = ebut->x;
854 } else {
855 bbox.xsiz = ebut->x - bbox.xmin + 1;
856 }
857 if (bbox.ymin > ebut->y) {
858 bbox.ysiz = bbox.ymin - ebut->y + 1;
859 bbox.ymin = ebut->y;
860 } else {
861 bbox.ysiz = ebut->y - bbox.ymin + 1;
862 }
863 }
864
865
866 trackrays(ebut) /* trace rays as mouse moves */
867 XButtonPressedEvent *ebut;
868 {
869 XEvent e;
870 unsigned long lastrept;
871
872 traceray(ebut->x, ebut->y);
873 lastrept = ebut->time;
874 XMaskEvent(thedisplay, ButtonReleaseMask|ButtonMotionMask, &e);
875 while (e.type == MotionNotify) {
876 if (e.xmotion.time >= lastrept + tinterv) {
877 traceray(e.xmotion.x, e.xmotion.y);
878 lastrept = e.xmotion.time;
879 }
880 XMaskEvent(thedisplay,ButtonReleaseMask|ButtonMotionMask,&e);
881 }
882 }
883
884
885 revbox(x0, y0, x1, y1) /* draw bbox with reversed lines */
886 int x0, y0, x1, y1;
887 {
888 revline(x0, y0, x1, y0);
889 revline(x0, y1, x1, y1);
890 revline(x0, y0, x0, y1);
891 revline(x1, y0, x1, y1);
892 }
893
894
895 void
896 colavg(scn, n, cavg)
897 register COLR *scn;
898 register int n;
899 COLOR cavg;
900 {
901 COLOR col;
902
903 while (n--) {
904 colr_color(col, *scn++);
905 addcolor(cavg, col);
906 }
907 }
908
909
910 int
911 avgbox(cavg) /* average color over current bbox */
912 COLOR cavg;
913 {
914 double d;
915 register int rval;
916
917 setcolor(cavg, 0., 0., 0.);
918 rval = dobox(colavg, (char *)cavg);
919 if (rval > 0) {
920 d = 1./rval;
921 scalecolor(cavg, d);
922 }
923 return(rval);
924 }
925
926
927 int
928 dobox(f, p) /* run function over bbox */
929 void (*f)(); /* function to call for each subscan */
930 char *p; /* pointer to private data */
931 {
932 int left, right, top, bottom;
933 int y;
934
935 left = bbox.xmin - xoff;
936 right = left + bbox.xsiz;
937 if (left < 0)
938 left = 0;
939 if (right > xmax)
940 right = xmax;
941 if (left >= right)
942 return(0);
943 top = bbox.ymin - yoff;
944 bottom = top + bbox.ysiz;
945 if (top < 0)
946 top = 0;
947 if (bottom > ymax)
948 bottom = ymax;
949 if (top >= bottom)
950 return(0);
951 for (y = top; y < bottom; y++) {
952 if (getscan(y) == -1)
953 return(-1);
954 (*f)(scanline+left, right-left, p);
955 }
956 return((right-left)*(bottom-top));
957 }
958
959
960 void
961 addfix(scn, n) /* add fixation points to histogram */
962 COLR *scn;
963 int n;
964 {
965 if (tmCvColrs(lscan, TM_NOCHROM, scn, n))
966 goto tmerr;
967 if (tmAddHisto(lscan, n, FIXWEIGHT))
968 goto tmerr;
969 return;
970 tmerr:
971 quiterr("tone mapping error");
972 }
973
974
975 make_tonemap() /* initialize tone mapping */
976 {
977 int flags, y;
978
979 if (tmflags != TM_F_LINEAR && fname == NULL) {
980 fprintf(stderr, "%s: cannot adjust tone of standard input\n",
981 progname);
982 tmflags = TM_F_LINEAR;
983 }
984 if (tmflags == TM_F_LINEAR) { /* linear with clamping */
985 setcolrcor(pow, 1.0/gamcor);
986 return;
987 }
988 flags = tmflags; /* histogram adjustment */
989 if (greyscale) flags |= TM_F_BW;
990 if (tmTop != NULL) { /* reuse old histogram if one */
991 tmDone(tmTop);
992 tmTop->flags = flags;
993 } else { /* else initialize */
994 if ((lscan = (TMbright *)malloc(xmax*sizeof(TMbright))) == NULL)
995 goto memerr;
996 if (greyscale) {
997 cscan = TM_NOCHROM;
998 if ((pscan = (BYTE *)malloc(sizeof(BYTE)*xmax)) == NULL)
999 goto memerr;
1000 } else if ((pscan=cscan = (BYTE *)malloc(3*sizeof(BYTE)*xmax))
1001 == NULL)
1002 goto memerr;
1003 /* initialize tm library */
1004 if (tmInit(flags, stdprims, gamcor) == NULL)
1005 goto memerr;
1006 if (tmSetSpace(stdprims, WHTEFFICACY/exposure))
1007 goto tmerr;
1008 /* compute picture histogram */
1009 for (y = 0; y < ymax; y++) {
1010 getscan(y);
1011 if (tmCvColrs(lscan, TM_NOCHROM, scanline, xmax))
1012 goto tmerr;
1013 if (tmAddHisto(lscan, xmax, 1))
1014 goto tmerr;
1015 }
1016 }
1017 tmDup(); /* add fixations to duplicate map */
1018 dobox(addfix, NULL);
1019 /* (re)compute tone mapping */
1020 if (tmComputeMapping(gamcor, 0., 0.))
1021 goto tmerr;
1022 return;
1023 memerr:
1024 quiterr("out of memory in make_tonemap");
1025 tmerr:
1026 quiterr("tone mapping error");
1027 }
1028
1029
1030 tmap_colrs(scn, len) /* apply tone mapping to scanline */
1031 register COLR *scn;
1032 int len;
1033 {
1034 register BYTE *ps;
1035
1036 if (tmflags == TM_F_LINEAR) {
1037 if (scale)
1038 shiftcolrs(scn, len, scale);
1039 colrs_gambs(scn, len);
1040 return;
1041 }
1042 if (len > xmax)
1043 quiterr("code error 1 in tmap_colrs");
1044 if (tmCvColrs(lscan, cscan, scn, len))
1045 goto tmerr;
1046 if (tmMapPixels(pscan, lscan, cscan, len))
1047 goto tmerr;
1048 ps = pscan;
1049 if (greyscale)
1050 while (len--) {
1051 scn[0][RED] = scn[0][GRN] = scn[0][BLU] = *ps++;
1052 scn[0][EXP] = COLXS;
1053 scn++;
1054 }
1055 else
1056 while (len--) {
1057 scn[0][RED] = *ps++;
1058 scn[0][GRN] = *ps++;
1059 scn[0][BLU] = *ps++;
1060 scn[0][EXP] = COLXS;
1061 scn++;
1062 }
1063 return;
1064 tmerr:
1065 quiterr("tone mapping error");
1066 }
1067
1068
1069 getmono() /* get monochrome data */
1070 {
1071 register unsigned char *dp;
1072 register int x, err;
1073 int y, errp;
1074 short *cerr;
1075
1076 if ((cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
1077 quiterr("out of memory in getmono");
1078 dp = ourdata - 1;
1079 for (y = 0; y < ymax; y++) {
1080 getscan(y);
1081 add2icon(y, scanline);
1082 normcolrs(scanline, xmax, scale);
1083 err = 0;
1084 for (x = 0; x < xmax; x++) {
1085 if (!(x&7))
1086 *++dp = 0;
1087 errp = err;
1088 err += normbright(scanline[x]) + cerr[x];
1089 if (err > 127)
1090 err -= 255;
1091 else
1092 *dp |= 1<<(7-(x&07));
1093 err /= 3;
1094 cerr[x] = err + errp;
1095 }
1096 }
1097 free((void *)cerr);
1098 }
1099
1100
1101 add2icon(y, scan) /* add a scanline to our icon data */
1102 int y;
1103 COLR *scan;
1104 {
1105 static short cerr[ICONSIZ];
1106 static int ynext;
1107 static char *dp;
1108 COLR clr;
1109 register int err;
1110 register int x, ti;
1111 int errp;
1112
1113 if (iconheight == 0) { /* initialize */
1114 if (xmax <= ICONSIZ && ymax <= ICONSIZ) {
1115 iconwidth = xmax;
1116 iconheight = ymax;
1117 } else if (xmax > ymax) {
1118 iconwidth = ICONSIZ;
1119 iconheight = ICONSIZ*ymax/xmax;
1120 if (iconheight < 1)
1121 iconheight = 1;
1122 } else {
1123 iconwidth = ICONSIZ*xmax/ymax;
1124 if (iconwidth < 1)
1125 iconwidth = 1;
1126 iconheight = ICONSIZ;
1127 }
1128 ynext = 0;
1129 dp = icondata - 1;
1130 }
1131 if (y < ynext*ymax/iconheight) /* skip this one */
1132 return;
1133 err = 0;
1134 for (x = 0; x < iconwidth; x++) {
1135 if (!(x&7))
1136 *++dp = 0;
1137 errp = err;
1138 ti = x*xmax/iconwidth;
1139 copycolr(clr, scan[ti]);
1140 normcolrs(&clr, 1, scale);
1141 err += normbright(clr) + cerr[x];
1142 if (err > 127)
1143 err -= 255;
1144 else
1145 *dp |= 1<<(x&07);
1146 err /= 3;
1147 cerr[x] = err + errp;
1148 }
1149 ynext++;
1150 }
1151
1152
1153 getfull() /* get full (24-bit) data */
1154 {
1155 int y;
1156 register uint32 *dp;
1157 register uint16 *dph;
1158 register int x;
1159 /* initialize tone mapping */
1160 make_tonemap();
1161 /* read and convert file */
1162 dp = (uint32 *)ourdata;
1163 dph = (uint16 *)ourdata;
1164 for (y = 0; y < ymax; y++) {
1165 getscan(y);
1166 add2icon(y, scanline);
1167 tmap_colrs(scanline, xmax);
1168 switch (ourras->image->blue_mask) {
1169 case 0xff: /* 24-bit RGB */
1170 for (x = 0; x < xmax; x++)
1171 *dp++ = (uint32)scanline[x][RED] << 16 |
1172 (uint32)scanline[x][GRN] << 8 |
1173 (uint32)scanline[x][BLU] ;
1174 break;
1175 case 0xff0000: /* 24-bit BGR */
1176 for (x = 0; x < xmax; x++)
1177 *dp++ = (uint32)scanline[x][RED] |
1178 (uint32)scanline[x][GRN] << 8 |
1179 (uint32)scanline[x][BLU] << 16 ;
1180 break;
1181 #if 0
1182 case 0x1f: /* 15-bit RGB */
1183 for (x = 0; x < xmax; x++)
1184 *dph++ = (scanline[x][RED] << 7 & 0x7c00) |
1185 (scanline[x][GRN] << 2 & 0x3e0) |
1186 (unsigned)scanline[x][BLU] >> 3 ;
1187 break;
1188 case 0x7c00: /* 15-bit BGR */
1189 for (x = 0; x < xmax; x++)
1190 *dph++ = (unsigned)scanline[x][RED] >> 3 |
1191 (scanline[x][GRN] << 2 & 0x3e0) |
1192 (scanline[x][BLU] << 7 & 0x7c00) ;
1193 break;
1194 #endif
1195 default: /* unknown */
1196 if (ourvis.depth > 16)
1197 for (x = 0; x < xmax; x++) {
1198 *dp = ourras->image->red_mask &
1199 ourras->image->red_mask*scanline[x][RED]/255;
1200 *dp |= ourras->image->green_mask &
1201 ourras->image->green_mask*scanline[x][GRN]/255;
1202 *dp++ |= ourras->image->blue_mask &
1203 ourras->image->blue_mask*scanline[x][BLU]/255;
1204 }
1205 else
1206 for (x = 0; x < xmax; x++) {
1207 *dph = ourras->image->red_mask &
1208 ourras->image->red_mask*scanline[x][RED]/255;
1209 *dph |= ourras->image->green_mask &
1210 ourras->image->green_mask*scanline[x][GRN]/255;
1211 *dph++ |= ourras->image->blue_mask &
1212 ourras->image->blue_mask*scanline[x][BLU]/255;
1213 }
1214 break;
1215 }
1216 }
1217 }
1218
1219
1220 getgrey() /* get greyscale data */
1221 {
1222 int y;
1223 register unsigned char *dp;
1224 register int x;
1225 /* initialize tone mapping */
1226 make_tonemap();
1227 /* read and convert file */
1228 dp = ourdata;
1229 for (y = 0; y < ymax; y++) {
1230 getscan(y);
1231 add2icon(y, scanline);
1232 tmap_colrs(scanline, xmax);
1233 if (maxcolors < 256)
1234 for (x = 0; x < xmax; x++)
1235 *dp++ = ((int32)scanline[x][GRN] *
1236 maxcolors + maxcolors/2) >> 8;
1237 else
1238 for (x = 0; x < xmax; x++)
1239 *dp++ = scanline[x][GRN];
1240 }
1241 for (x = 0; x < maxcolors; x++)
1242 clrtab[x][RED] = clrtab[x][GRN] =
1243 clrtab[x][BLU] = ((int32)x*256 + 128)/maxcolors;
1244 }
1245
1246
1247 getmapped() /* get color-mapped data */
1248 {
1249 int y;
1250 /* make sure we can do it first */
1251 if (fname == NULL)
1252 quiterr("cannot map colors from standard input");
1253 /* initialize tone mapping */
1254 make_tonemap();
1255 /* make histogram */
1256 if (new_histo((int32)xmax*ymax) == -1)
1257 quiterr("cannot initialize histogram");
1258 for (y = 0; y < ymax; y++) {
1259 if (getscan(y) < 0)
1260 break;
1261 add2icon(y, scanline);
1262 tmap_colrs(scanline, xmax);
1263 cnt_colrs(scanline, xmax);
1264 }
1265 /* map pixels */
1266 if (!new_clrtab(maxcolors))
1267 quiterr("cannot create color map");
1268 for (y = 0; y < ymax; y++) {
1269 getscan(y);
1270 tmap_colrs(scanline, xmax);
1271 if (dither)
1272 dith_colrs(ourdata+y*xmax, scanline, xmax);
1273 else
1274 map_colrs(ourdata+y*xmax, scanline, xmax);
1275 }
1276 }
1277
1278
1279 scale_rcolors(xr, sf) /* scale color map */
1280 register XRASTER *xr;
1281 double sf;
1282 {
1283 register int i;
1284 long maxv;
1285
1286 if (xr->pixels == NULL)
1287 return;
1288
1289 sf = pow(sf, 1.0/gamcor);
1290 maxv = 65535/sf;
1291
1292 for (i = xr->ncolors; i--; ) {
1293 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
1294 65535 :
1295 xr->cdefs[i].red * sf;
1296 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
1297 65535 :
1298 xr->cdefs[i].green * sf;
1299 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
1300 65535 :
1301 xr->cdefs[i].blue * sf;
1302 }
1303 XStoreColors(thedisplay, xr->cmap, xr->cdefs, xr->ncolors);
1304 }
1305
1306
1307 getscan(y)
1308 int y;
1309 {
1310 static int trunced = -1; /* truncated file? */
1311 skipit:
1312 if (trunced >= 0 && y >= trunced) {
1313 memset(scanline, '\0', xmax*sizeof(COLR));
1314 return(-1);
1315 }
1316 if (y != cury) {
1317 if (scanpos == NULL || scanpos[y] == -1)
1318 return(-1);
1319 if (fseek(fin, scanpos[y], 0) == -1)
1320 quiterr("fseek error");
1321 cury = y;
1322 } else if (scanpos != NULL && scanpos[y] == -1)
1323 scanpos[y] = ftell(fin);
1324
1325 if (freadcolrs(scanline, xmax, fin) < 0) {
1326 fprintf(stderr, "%s: %s: unfinished picture\n",
1327 progname, fname==NULL?"<stdin>":fname);
1328 trunced = y;
1329 goto skipit;
1330 }
1331 cury++;
1332 return(0);
1333 }
