root/radiance/ray/src/px/warp3d.h
Revision: 3.4
Committed: Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.3: +13 -1 lines
1 /* RCSid: $Id: warp3d.h,v 3.3 2003/02/22 02:07:28 greg Exp $ */
2 /*
3 * Header file for 3D warping routines.
4 */
5 #ifndef _RAD_WARP3D_H_
6 #define _RAD_WARP3D_H_
7
8 #include "lookup.h"
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 /* interpolation flags */
15 #define W3EXACT 01 /* no interpolation (slow) */
16 #define W3FAST 02 /* discontinuous approx. (fast) */
17
18 /* return flags for warp3d() */
19 #define W3OK 0 /* normal return status */
20 #define W3GAMUT 01 /* out of gamut */
21 #define W3BADMAP 02 /* singular map */
22 #define W3ERROR 04 /* system error (check errno) */
23
24 #define GNBITS 6 /* number of bits per grid size <= 8 */
25 #define MAXGN (1<<GNBITS) /* maximum grid dimension */
26
27 typedef unsigned char GNDX[3]; /* grid index type */
28
29 typedef float W3VEC[3]; /* vector type for 3D warp maps */
30
31 struct grid3d {
32 unsigned char flags; /* interpolation flags */
33 GNDX gn; /* grid dimensions */
34 W3VEC gmin, gstep; /* grid corner and voxel size */
35 LUTAB gtab; /* grid lookup table */
36 }; /* a regular, sparse warping grid */
37
38 typedef struct {
39 W3VEC *ip, *ov; /* discrete input/displ. pairs */
40 int npts; /* number of point pairs */
41 W3VEC llim, ulim; /* lower and upper input limits */
42 double d2min, d2max; /* min. and max. point distance^2 */
43 struct grid3d grid; /* point conversion grid */
44 } WARP3D; /* a warp map */
45
46 extern WARP3D *new3dw(), *load3dw();
47
48 #define W3VCPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
49
50 #ifdef __cplusplus
51 }
52 #endif
53 #endif /* _RAD_WARP3D_H_ */
54
