root/Development/ray/src/px/warp3d.h
Revision: 3.1
Committed: Tue Feb 4 16:03:49 1997 UTC (28 years, 9 months ago) by greg
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for 3D warping routines.
7 */
8
9 #include "lookup.h"
10
11 /* interpolation flags */
12 #define W3EXACT 01 /* no interpolation (slow) */
13 #define W3FAST 02 /* discontinuous approx. (fast) */
14
15 /* return flags for warp3d() */
16 #define W3OK 0 /* normal return status */
17 #define W3GAMUT 01 /* out of gamut */
18 #define W3BADMAP 02 /* singular map */
19 #define W3ERROR 04 /* system error (check errno) */
20
21 #define GNBITS 6 /* number of bits per grid size <= 8 */
22 #define MAXGN (1<<GNBITS) /* maximum grid dimension */
23
24 typedef unsigned char GNDX[3]; /* grid index type */
25
26 typedef float W3VEC[3]; /* vector type for 3D warp maps */
27
28 struct grid3d {
29 W3VEC gmin, gmax; /* grid boundaries */
30 GNDX gn; /* grid dimensions */
31 W3VEC gstep; /* grid voxel size */
32 unsigned char flags; /* interpolation flags */
33 LUTAB gtab; /* grid lookup table */
34 }; /* a regular, sparse warping grid */
35
36 typedef struct {
37 W3VEC *ip, *op; /* discrete input/output pairs */
38 int npts; /* number of point pairs */
39 W3VEC llim, ulim; /* lower and upper input limits */
40 double d2min, d2max; /* min. and max. point distance^2 */
41 struct grid3d grid; /* point conversion grid */
42 } WARP3D; /* a warp map */
43
44 extern WARP3D *new3dw(), *load3dw();
45
46 #define W3VCPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
