root/radiance/ray/src/px/warp3d.h
Revision: 3.5
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 3.4: +7 -2 lines
1 /* RCSid: $Id: warp3d.h,v 3.4 2003/07/14 22:24:00 schorsch Exp $ */
2 /*
3 * Header file for 3D warping routines.
4 */
5 #ifndef _RAD_WARP3D_H_
6 #define _RAD_WARP3D_H_
7
8 #include "lookup.h"
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 /* interpolation flags */
15 #define W3EXACT 01 /* no interpolation (slow) */
16 #define W3FAST 02 /* discontinuous approx. (fast) */
17
18 /* return flags for warp3d() */
19 #define W3OK 0 /* normal return status */
20 #define W3GAMUT 01 /* out of gamut */
21 #define W3BADMAP 02 /* singular map */
22 #define W3ERROR 04 /* system error (check errno) */
23
24 #define GNBITS 6 /* number of bits per grid size <= 8 */
25 #define MAXGN (1<<GNBITS) /* maximum grid dimension */
26
27 typedef unsigned char GNDX[3]; /* grid index type */
28
29 typedef float W3VEC[3]; /* vector type for 3D warp maps */
30
31 struct grid3d {
32 unsigned char flags; /* interpolation flags */
33 GNDX gn; /* grid dimensions */
34 W3VEC gmin, gstep; /* grid corner and voxel size */
35 LUTAB gtab; /* grid lookup table */
36 }; /* a regular, sparse warping grid */
37
38 typedef struct {
39 W3VEC *ip, *ov; /* discrete input/displ. pairs */
40 int npts; /* number of point pairs */
41 W3VEC llim, ulim; /* lower and upper input limits */
42 double d2min, d2max; /* min. and max. point distance^2 */
43 struct grid3d grid; /* point conversion grid */
44 } WARP3D; /* a warp map */
45
46 extern int warp3d(W3VEC po, W3VEC pi, WARP3D *wp);
47 extern int add3dpt(WARP3D* wp, W3VEC pti, W3VEC pto);
48 extern WARP3D* new3dw(int flgs);
49 extern WARP3D* load3dw(char *fn, WARP3D *wp);
50 extern void free3dw(WARP3D *wp);
51 extern int set3dwfl(WARP3D *wp, int flgs);
52
53 #define W3VCPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
54
55 #ifdef __cplusplus
56 }
57 #endif
58 #endif /* _RAD_WARP3D_H_ */
59
