root/radiance/ray/src/px/warp3d.c
Thu Feb 22 17:45:27 2024 UTC (3 months, 2 weeks ago) by greg
Changes since 3.11: +25 -25 lines
Diff to previous 3.11
style: got rid of register keywords
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 3.10: +1 -2 lines
Diff to previous 3.10
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 3.9: +2 -2 lines
Diff to previous 3.9
Fri Sep 3 21:18:15 2010 UTC (13 years, 9 months ago) by greg
Changes since 3.8: +1 -4 lines
Diff to previous 3.8
Removed '//' comments that don't fit with standard C
Tue May 25 22:04:14 2004 UTC (20 years ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7
Changes since 3.6: +94 -51 lines
Diff to previous 3.6
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 3.5
Changes since 3.4: +5 -12 lines
Diff to previous 3.4
Wed Sep 2 18:41:44 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3
changed lookup routines to use unsigned long hash values
Wed Feb 5 17:18:07 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.2: +4 -1 lines
Diff to previous 3.2
fixed W3GAMUT return error for W3EXACT mapping
Wed Feb 5 15:59:07 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.1: +73 -54 lines
important bug fixes and improvements
Tue Feb 4 16:03:48 1997 UTC (27 years, 4 months ago) by greg
