root/radiance/ray/src/px/warp3d.c
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 3.9: +2 -2 lines
Diff to previous 3.9
Fri Sep 3 21:18:15 2010 UTC (14 years, 8 months ago) by greg
Changes since 3.8: +1 -4 lines
Diff to previous 3.8
Removed '//' comments that don't fit with standard C
Tue May 25 22:04:14 2004 UTC (20 years, 11 months ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 3.6: +94 -51 lines
Diff to previous 3.6
Wed Apr 23 00:52:34 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 3.5
Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.4: +5 -12 lines
Diff to previous 3.4
Wed Sep 2 18:41:44 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3
changed lookup routines to use unsigned long hash values
Wed Feb 5 17:18:07 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.2: +4 -1 lines
Diff to previous 3.2
fixed W3GAMUT return error for W3EXACT mapping
Wed Feb 5 15:59:07 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.1: +73 -54 lines
Diff to previous 3.1
important bug fixes and improvements
Tue Feb 4 16:03:48 1997 UTC (28 years, 3 months ago) by greg
