--- ray/src/px/warp3d.c 1997/02/05 17:18:07 3.3 +++ ray/src/px/warp3d.c 2004/03/28 20:33:14 3.7 @@ -1,15 +1,16 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: warp3d.c,v 3.7 2004/03/28 20:33:14 schorsch Exp $"; #endif - /* * 3D warping routines. */ #include +#include #include + +#include "rterror.h" +#include "rtio.h" #include "fvect.h" #include "warp3d.h" @@ -25,15 +26,24 @@ typedef struct { #define AHUNK 24 /* number of points to allocate at a time */ -#ifndef malloc -extern char *malloc(), *realloc(); -#endif -extern void free(); +double wpdist2(W3VEC p1, W3VEC p2); +static int gridpoint(GNDX ndx, W3VEC rem, W3VEC ipt, struct grid3d *gp); +static int get3dgpt(W3VEC ov, GNDX ndx, WARP3D *wp); +static int get3dgin(W3VEC ov, GNDX ndx, W3VEC rem, WARP3D *wp); +static void l3interp(W3VEC vo, W3VEC *cl, W3VEC dv, int n); +static int warp3dex(W3VEC ov, W3VEC pi, WARP3D *wp); +//static unsigned long gridhash(void *gp); +static lut_hashf_t gridhash; +static int new3dgrid(WARP3D *wp); +static void done3dgrid(struct grid3d *gp); + double -wpdist2(p1, p2) /* compute square of distance between points */ -register W3VEC p1, p2; +wpdist2( /* compute square of distance between points */ + register W3VEC p1, + register W3VEC p2 +) { double d, d2; @@ -45,9 +55,11 @@ register W3VEC p1, p2; int -warp3d(po, pi, wp) /* warp 3D point according to the given map */ -W3VEC po, pi; -register WARP3D *wp; +warp3d( /* warp 3D point according to the given map */ + W3VEC po, + W3VEC pi, + register WARP3D *wp +) { int rval = W3OK; GNDX gi; @@ -69,11 +81,13 @@ register WARP3D *wp; } -int -gridpoint(ndx, rem, ipt, gp) /* compute grid position for ipt */ -GNDX ndx; -W3VEC rem, ipt; -register struct grid3d *gp; +static int +gridpoint( /* compute grid position for ipt */ + GNDX ndx, + W3VEC rem, + W3VEC ipt, + register struct grid3d *gp +) { int rval = W3OK; register int i; @@ -94,11 +108,12 @@ register struct grid3d *gp; } -int -get3dgpt(ov, ndx, wp) /* get value for voxel */ -W3VEC ov; -GNDX ndx; -register WARP3D *wp; +static int +get3dgpt( /* get value for voxel */ + W3VEC ov, + GNDX ndx, + register WARP3D *wp +) { W3VEC gpt; register LUENT *le; @@ -129,11 +144,13 @@ register WARP3D *wp; } -int -get3dgin(ov, ndx, rem, wp) /* interpolate from warp grid */ -W3VEC ov, rem; -GNDX ndx; -WARP3D *wp; +static int +get3dgin( /* interpolate from warp grid */ + W3VEC ov, + GNDX ndx, + W3VEC rem, + WARP3D *wp +) { W3VEC cv[8]; GNDX gi; @@ -153,9 +170,13 @@ WARP3D *wp; } -l3interp(vo, cl, dv, n) /* trilinear interpolation (recursive) */ -W3VEC vo, *cl, dv; -int n; +static void +l3interp( /* trilinear interpolation (recursive) */ + W3VEC vo, + W3VEC *cl, + W3VEC dv, + int n +) { W3VEC v0, v1; register int i; @@ -172,10 +193,12 @@ int n; } -int -warp3dex(ov, pi, wp) /* compute warp using 1/r^2 weighted avg. */ -W3VEC ov, pi; -register WARP3D *wp; +static int +warp3dex( /* compute warp using 1/r^2 weighted avg. */ + W3VEC ov, + W3VEC pi, + register WARP3D *wp +) { double d2, w, wsum; W3VEC vt; @@ -202,8 +225,9 @@ register WARP3D *wp; WARP3D * -new3dw(flgs) /* allocate and initialize WARP3D struct */ -int flgs; +new3dw( /* allocate and initialize WARP3D struct */ + int flgs +) { register WARP3D *wp; @@ -224,9 +248,10 @@ int flgs; WARP3D * -load3dw(fn, wp) /* load 3D warp from file */ -char *fn; -WARP3D *wp; +load3dw( /* load 3D warp from file */ + char *fn, + WARP3D *wp +) { FILE *fp; W3VEC inp, outp; @@ -254,10 +279,11 @@ cleanup: } -int -set3dwfl(wp, flgs) /* reset warp flags */ -register WARP3D *wp; -int flgs; +extern int +set3dwfl( /* reset warp flags */ + register WARP3D *wp, + int flgs +) { if (flgs == wp->grid.flags) return(0); @@ -272,9 +298,11 @@ int flgs; int -add3dpt(wp, pti, pto) /* add 3D point pair to warp structure */ -register WARP3D *wp; -W3VEC pti, pto; +add3dpt( /* add 3D point pair to warp structure */ + register WARP3D *wp, + W3VEC pti, + W3VEC pto +) { double d2; register W3VEC *na; @@ -291,11 +319,11 @@ W3VEC pti, pto; W3VCPY(wp->ulim, pti); } else { if (wp->npts % AHUNK == 0) { /* allocate another hunk */ - na = (W3VEC *)realloc((char *)wp->ip, + na = (W3VEC *)realloc((void *)wp->ip, (wp->npts+AHUNK)*sizeof(W3VEC)); if (na == NULL) return(0); wp->ip = na; - na = (W3VEC *)realloc((char *)wp->ov, + na = (W3VEC *)realloc((void *)wp->ov, (wp->npts+AHUNK)*sizeof(W3VEC)); if (na == NULL) return(0); wp->ov = na; @@ -324,27 +352,33 @@ W3VEC pti, pto; } -free3dw(wp) /* free WARP3D data */ -register WARP3D *wp; +extern void +free3dw( /* free WARP3D data */ + register WARP3D *wp +) { done3dgrid(&wp->grid); - free((char *)wp->ip); - free((char *)wp->ov); - free((char *)wp); + free((void *)wp->ip); + free((void *)wp->ov); + free((void *)wp); } -long -gridhash(gp) /* hash a grid point index */ -GNDX gp; +static unsigned long +gridhash( /* hash a grid point index */ + //GNDX gp + void *gp +) { - return(((unsigned long)gp[0]<gn[0] == 0) return;
