1 |
#!/bin/csh -f |
2 |
# RCSid: $Id: vlpic.csh,v 3.2 2005/01/18 03:59:41 greg Exp $ |
3 |
4 |
# Compute falsecolor image of visibility level |
5 |
# using the wacky formulas of Werner Adrian. |
6 |
7 |
set age=40 # default age (years) |
8 |
set tim=.2 # default time (seconds) |
9 |
while ($#argv > 1) |
10 |
switch ($argv[1]) |
11 |
case -a: |
12 |
shift argv |
13 |
set age="$argv[1]" |
14 |
breaksw |
15 |
case -t: |
16 |
shift argv |
17 |
set tim="$argv[1]" |
18 |
breaksw |
19 |
default: |
20 |
echo bad option "'$argv[1]'" |
21 |
exit 1 |
22 |
endsw |
23 |
shift argv |
24 |
end |
25 |
set tc=/tmp/vl$$.cal |
26 |
set tp1=/tmp/vl$$r1.pic |
27 |
set tp2=/tmp/vl$$r2.pic |
28 |
set tp4=/tmp/vl$$r4.pic |
29 |
set tp8=/tmp/vl$$r8.pic |
30 |
set tf=($tc $tp1 $tp2 $tp4 $tp8) |
31 |
set inpic=$argv[1] |
32 |
onintr quit |
33 |
set pr=(`getinfo -d < $inpic | sed 's/^-Y \([1-9][0-9]*\) +X \([1-9][0-9]*\)$/\2 \1/'`) |
34 |
# ( vwright V < $inpic ; cat ) > $tc << _EOF_ |
35 |
cat > $tc << _EOF_ |
36 |
{ A : 3438 * sqrt(Vhn/xmax*Vvn/ymax); { pixel size (in minutes) } } |
37 |
PI : 3.14159265358979323846; |
38 |
A = 180*60/PI * sqrt(S(1)/PI); |
39 |
sq(x) : x*x; |
40 |
max(a,b) : if(a-b, a, b); |
41 |
Lv : 0; { veiling luminance {temporarily zero} } |
42 |
{ find direction of maximum contrast } |
43 |
xoff(d) = select(d, 1, 1, 0, -1, -1, -1, 0, 1); |
44 |
yoff(d) = select(d, 0, 1, 1, 1, 0, -1, -1, -1); |
45 |
cf(lf, lb) = (lf - lb)/(lb + Lv); |
46 |
contrast(d) = cf(li(1,xoff(d),yoff(d)), li(1,-xoff(d),-yoff(d))); |
47 |
cwin(d1, d2) = if(contrast(d1) - contrast(d2), d1, d2); |
48 |
bestdir(d) = if(d-1.5, cwin(d, bestdir(d-1)), d); |
49 |
maxdir = bestdir(8); |
50 |
Lt = WE*li(1,xoff(maxdir),yoff(maxdir)) + Lv; |
51 |
La = WE*li(1,-xoff(maxdir),-yoff(maxdir)) + Lv; |
52 |
LLa = log10(La); |
53 |
F = if(La-.6, log10(4.1925) + LLa*.1556 + .1684*La^.5867, |
54 |
if(La-.00418, 10^(-.072 + LLa*(.3372 + LLa*.0866)), |
55 |
10^(.028 + .173*LLa))); |
56 |
L = if(La-.6, .05946*La^.466, |
57 |
if(La-.00418, 10^(-1.256 + .319*LLa), |
58 |
10^(-.891 + LLa*(.5275 + LLa*.0227)))); |
59 |
LAt = log10(A) + .523; |
60 |
AA = .36 - .0972*LAt*LAt/(LAt*(LAt - 2.513) + 2.7895); |
61 |
LLat = LLa + 6; |
62 |
AL = .355 - .1217*LLat*LLat/(LLat*(LLat - 10.4) + 52.28); |
63 |
AZ = sqrt(AA*AA + AL*AL)/2.1; |
64 |
DL1 = 2.6*sq(F/A + L); |
65 |
M = if(La-.004, 10^-(10^-(if(La-.1,.125,.075)*sq(LLa+1) + .0245)), 0); |
66 |
TGB = .6*La^-.1488; |
67 |
FCP = 1 - M*A^-TGB/(2.4*(DL1*(AZ+2)/2)); |
68 |
DL2 = DL1*(AZ + T)/T; |
69 |
FA = if(Age-64, sq(Age-56.6)/116.3 + 1.43, sq(Age-19)/2160 + .99); |
70 |
DL3 = DL2 * FA; |
71 |
DL4 = if(La-Lt, DL3*FCP, DL3); |
72 |
lo = (Lt - La)/DL4; { Output VL } |
73 |
_EOF_ |
74 |
pcomb -w -e "Age:$age;T:$tim" -f $tc -o $inpic > $tp1 |
75 |
pfilt -1 -x /2 -y /2 $inpic \ |
76 |
| pcomb -w -e "Age:$age;T:$tim" -f $tc -o - \ |
77 |
| pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp2 |
78 |
pfilt -1 -x /4 -y /4 $inpic \ |
79 |
80 |
| pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp4 |
81 |
pfilt -1 -x /8 -y /8 $inpic \ |
82 |
83 |
| pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp8 |
84 |
pcomb -e 'max(a,b):if(a-b,a,b)' -e 'lo=max(gi(1),max(gi(2),max(gi(3),gi(4))))' \ |
85 |
$tp1 $tp2 $tp4 $tp8 \ |
86 |
| falsecolor -l VL -s 56 -m 1 -r 'if(v-1/8,1.6*8/7*(v-1/8)-.6,0)' \ |
87 |
-g 'if(v-1/8,if(v-.453125,1.6-1.6*8/7*(v-1/8),8/3*8/7*(v-1/8)),0)' \ |
88 |
-b 'if(v-1/8,1-8/3*8/7*(v-1/8),0)' |
89 |
quit: |
90 |
rm -f $tf |
