root/Development/ray/src/px/vlpic.csh
Revision: 3.5
Committed: Thu Jun 22 16:40:11 2023 UTC (2 years, 6 months ago) by greg
Content type: application/x-csh
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 3.4: +3 -2 lines
fix(normpat,pacuity,vlpic): Made handling of resolution string more robust
1 #!/bin/csh -f
2 # RCSid: $Id: vlpic.csh,v 3.4 2008/08/25 04:50:32 greg Exp $
3 #
4 # Compute falsecolor image of visibility level
5 # using the wacky formulas of Werner Adrian.
6 #
7 set age=40 # default age (years)
8 set tim=.2 # default time (seconds)
9 while ($#argv > 1)
10 switch ($argv[1])
11 case -a:
12 shift argv
13 set age="$argv[1]"
14 breaksw
15 case -t:
16 shift argv
17 set tim="$argv[1]"
18 breaksw
19 default:
20 echo bad option "'$argv[1]'"
21 exit 1
22 endsw
23 shift argv
24 end
25 set tc=`mktemp /tmp/vlcal.XXXXXXX`
26 set tp1=`mktemp /tmp/vlpic.XXXXXX`
27 set tp2=`mktemp /tmp/vlr2pic.XXXXXX`
28 set tp4=`mktemp /tmp/vlr4pic.XXXXXX`
29 set tp8=`mktemp /tmp/vlr8pic.XXXXXX`
30 set tf=($tc $tp1 $tp2 $tp4 $tp8)
31 set inpic=$argv[1]
32 onintr quit
33 set pr=`getinfo -d < $inpic`
34 set pr=($pr[4] $pr[2])
35 # ( vwright V < $inpic ; cat ) > $tc << _EOF_
36 cat > $tc << _EOF_
37 { A : 3438 * sqrt(Vhn/xmax*Vvn/ymax); { pixel size (in minutes) } }
38 PI : 3.14159265358979323846;
39 A = 180*60/PI * sqrt(S(1)/PI);
40 sq(x) : x*x;
41 max(a,b) : if(a-b, a, b);
42 Lv : 0; { veiling luminance {temporarily zero} }
43 { find direction of maximum contrast }
44 xoff(d) = select(d, 1, 1, 0, -1, -1, -1, 0, 1);
45 yoff(d) = select(d, 0, 1, 1, 1, 0, -1, -1, -1);
46 cf(lf, lb) = (lf - lb)/(lb + Lv);
47 contrast(d) = cf(li(1,xoff(d),yoff(d)), li(1,-xoff(d),-yoff(d)));
48 cwin(d1, d2) = if(contrast(d1) - contrast(d2), d1, d2);
49 bestdir(d) = if(d-1.5, cwin(d, bestdir(d-1)), d);
50 maxdir = bestdir(8);
51 Lt = WE*li(1,xoff(maxdir),yoff(maxdir)) + Lv;
52 La = WE*li(1,-xoff(maxdir),-yoff(maxdir)) + Lv;
53 LLa = log10(La);
54 F = if(La-.6, log10(4.1925) + LLa*.1556 + .1684*La^.5867,
55 if(La-.00418, 10^(-.072 + LLa*(.3372 + LLa*.0866)),
56 10^(.028 + .173*LLa)));
57 L = if(La-.6, .05946*La^.466,
58 if(La-.00418, 10^(-1.256 + .319*LLa),
59 10^(-.891 + LLa*(.5275 + LLa*.0227))));
60 LAt = log10(A) + .523;
61 AA = .36 - .0972*LAt*LAt/(LAt*(LAt - 2.513) + 2.7895);
62 LLat = LLa + 6;
63 AL = .355 - .1217*LLat*LLat/(LLat*(LLat - 10.4) + 52.28);
64 AZ = sqrt(AA*AA + AL*AL)/2.1;
65 DL1 = 2.6*sq(F/A + L);
66 M = if(La-.004, 10^-(10^-(if(La-.1,.125,.075)*sq(LLa+1) + .0245)), 0);
67 TGB = .6*La^-.1488;
68 FCP = 1 - M*A^-TGB/(2.4*(DL1*(AZ+2)/2));
69 DL2 = DL1*(AZ + T)/T;
70 FA = if(Age-64, sq(Age-56.6)/116.3 + 1.43, sq(Age-19)/2160 + .99);
71 DL3 = DL2 * FA;
72 DL4 = if(La-Lt, DL3*FCP, DL3);
73 lo = (Lt - La)/DL4; { Output VL }
74 _EOF_
75 pcomb -w -e "Age:$age;T:$tim" -f $tc -o $inpic > $tp1
76 pfilt -1 -x /2 -y /2 $inpic \
77 | pcomb -w -e "Age:$age;T:$tim" -f $tc -o - \
78 | pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp2
79 pfilt -1 -x /4 -y /4 $inpic \
80 | pcomb -w -e "Age:$age;T:$tim" -f $tc -o - \
81 | pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp4
82 pfilt -1 -x /8 -y /8 $inpic \
83 | pcomb -w -e "Age:$age;T:$tim" -f $tc -o - \
84 | pfilt -1 -r 1 -x $pr[1] -y $pr[2] > $tp8
85 pcomb -e 'max(a,b):if(a-b,a,b)' -e 'lo=max(gi(1),max(gi(2),max(gi(3),gi(4))))' \
86 $tp1 $tp2 $tp4 $tp8 \
87 | falsecolor -l VL -s 56 -m 1 -r 'if(v-1/8,1.6*8/7*(v-1/8)-.6,0)' \
88 -g 'if(v-1/8,if(v-.453125,1.6-1.6*8/7*(v-1/8),8/3*8/7*(v-1/8)),0)' \
89 -b 'if(v-1/8,1-8/3*8/7*(v-1/8),0)'
90 quit:
91 rm -f $tf
