1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* vgaimage.c - driver for VGA board under DOS |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include <graph.h> |
13 |
#include "color.h" |
14 |
#include "random.h" |
15 |
#include "resolu.h" |
16 |
#include <dos.h> |
17 |
#include <i86.h> |
18 |
19 |
#define M_RDOWN 0x8 |
20 |
#define M_RUP 0x10 |
21 |
#define M_LDOWN 0x2 |
22 |
#define M_LUP 0x4 |
23 |
#define M_MOTION 0x1 |
24 |
25 |
int crad; |
26 |
#define right_button (mouse_event & M_RIGHTBUTT) |
27 |
#define left_button (mouse_event & M_LEFTBUTT) |
28 |
int mouse_event = 0; |
29 |
int mouse_xpos = -1; |
30 |
int mouse_ypos = -1; |
31 |
32 |
33 |
#define CTRL(c) ((c)-'@') |
34 |
35 |
#define MAXWIDTH 1024 |
36 |
#define MAXHEIGHT 768 |
37 |
38 |
short ourblack = 0; ourwhite = 1; |
39 |
40 |
double gamcor = 2.2; /* gamma correction */ |
41 |
42 |
int dither = 1; /* dither colors? */ |
43 |
44 |
int maxcolors = 0; /* maximum colors */ |
45 |
int minpix = 0; /* minimum pixel value */ |
46 |
int greyscale = 0; /* in grey */ |
47 |
48 |
int scale = 0; /* scalefactor; power of two */ |
49 |
50 |
COLR scanline[MAXWIDTH]; /* scan line buffer */ |
51 |
52 |
int xmax, ymax; /* picture dimensions */ |
53 |
FILE *fin = stdin; /* input file */ |
54 |
long scanpos[MAXHEIGHT]; /* scan line positions in file */ |
55 |
int cury = 0; /* current scan location */ |
56 |
57 |
double exposure = 1.0; /* exposure compensation used */ |
58 |
59 |
int wrongformat = 0; /* input in another format? */ |
60 |
61 |
struct { |
62 |
int xmin, ymin, xsiz, ysiz; |
63 |
} box = {0, 0, 0, 0}; /* current box */ |
64 |
65 |
int initialized = 0; |
66 |
int cheight, cwidth; |
67 |
68 |
#define postext(x,y) _settextposition(1+(y)/cheight,1+(x)/cwidth) |
69 |
70 |
char *progname; |
71 |
72 |
char errmsg[128]; |
73 |
74 |
extern BYTE clrtab[256][3]; /* global color map */ |
75 |
76 |
extern long ftell(); |
77 |
78 |
79 |
main(argc, argv) |
80 |
int argc; |
81 |
char *argv[]; |
82 |
83 |
extern char *getenv(), *fixargv0(); |
84 |
char *gv; |
85 |
int headline(); |
86 |
int i; |
87 |
88 |
progname = argv[0] = fixargv0(argv[0]); |
89 |
if ((gv = getenv("GAMMA")) != NULL) |
90 |
gamcor = atof(gv); |
91 |
92 |
for (i = 1; i < argc; i++) |
93 |
if (argv[i][0] == '-') |
94 |
switch (argv[i][1]) { |
95 |
case 'c': |
96 |
maxcolors = atoi(argv[++i]); |
97 |
break; |
98 |
case 'b': |
99 |
greyscale = !greyscale; |
100 |
break; |
101 |
case 'm': |
102 |
maxcolors = 2; |
103 |
break; |
104 |
case 'd': |
105 |
dither = !dither; |
106 |
break; |
107 |
case 'e': |
108 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
109 |
goto userr; |
110 |
scale = atoi(argv[++i]); |
111 |
break; |
112 |
case 'g': |
113 |
gamcor = atof(argv[++i]); |
114 |
break; |
115 |
default: |
116 |
goto userr; |
117 |
118 |
else |
119 |
break; |
120 |
121 |
if (i == argc-1) { /* open picture */ |
122 |
fin = fopen(argv[i], "r"); |
123 |
if (fin == NULL) { |
124 |
sprintf(errmsg, "cannot open file \"%s\"", argv[i]); |
125 |
quiterr(errmsg); |
126 |
127 |
} else if (i != argc) |
128 |
goto userr; |
129 |
setmode(fileno(fin), O_BINARY); |
130 |
/* get header */ |
131 |
getheader(fin, headline, NULL); |
132 |
/* get picture dimensions */ |
133 |
if (wrongformat || fgetresolu(&xmax, &ymax, fin) < 0) |
134 |
quiterr("bad picture format"); |
135 |
if (xmax > MAXWIDTH | ymax > MAXHEIGHT) |
136 |
quiterr("input picture too large for VGA"); |
137 |
138 |
init(); /* initialize and display */ |
139 |
140 |
while (docommand()) /* loop on command */ |
141 |
142 |
quiterr(NULL); |
143 |
userr: |
144 |
fprintf(stderr, |
145 |
"Usage: %s [-b][-m][-d][-c ncolors][-e +/-stops] file\n", progname); |
146 |
exit(1); |
147 |
148 |
149 |
150 |
headline(s) /* get relevant info from header */ |
151 |
char *s; |
152 |
153 |
char fmt[32]; |
154 |
155 |
if (isexpos(s)) |
156 |
exposure *= exposval(s); |
157 |
else if (isformat(s)) { |
158 |
formatval(fmt, s); |
159 |
wrongformat = strcmp(fmt, COLRFMT); |
160 |
161 |
162 |
163 |
164 |
init() /* initialize and load display */ |
165 |
166 |
static struct { |
167 |
short mode; |
168 |
short xsiz, ysiz; |
169 |
} video[] = { |
170 |
{_MRES256COLOR, 320, 200}, |
171 |
{_VRES256COLOR, 640, 400}, |
172 |
{_SVRES256COLOR, 800, 600}, |
173 |
{_XRES256COLOR, 1024, 768}, |
174 |
-1 |
175 |
176 |
struct videoconfig config; |
177 |
register int i; |
178 |
/* pick a card... */ |
179 |
for (i = 0; video[i].mode != -1; i++) |
180 |
if (video[i].xsiz >= xmax && video[i].ysiz >= ymax) |
181 |
break; |
182 |
if (video[i].mode == -1) |
183 |
quiterr("input picture too large"); |
184 |
if (_setvideomode(video[i].mode) == 0) |
185 |
quiterr("inadequate display card for picture"); |
186 |
initialized = 1; |
187 |
_getvideoconfig(&config); |
188 |
if (maxcolors == 0) |
189 |
maxcolors = config.numcolors; |
190 |
if (maxcolors > 4) { |
191 |
maxcolors -= minpix = 2; |
192 |
_settextcolor(ourwhite); |
193 |
194 |
cheight = config.numypixels/config.numtextrows; |
195 |
cwidth = config.numxpixels/config.numtextcols; |
196 |
/* clear scan position array */ |
197 |
for (i = 0; i < ymax; i++) |
198 |
scanpos[i] = -1; |
199 |
/* display image */ |
200 |
if (greyscale) |
201 |
greyimage(); |
202 |
else |
203 |
mappedimage(); |
204 |
205 |
206 |
207 |
quiterr(err) /* print message and exit */ |
208 |
char *err; |
209 |
210 |
if (initialized) |
211 |
_setvideomode(_DEFAULTMODE); |
212 |
if (err != NULL) { |
213 |
fprintf(stderr, "%s: %s\n", progname, err); |
214 |
exit(1); |
215 |
216 |
exit(0); |
217 |
218 |
219 |
220 |
int |
221 |
docommand() /* execute command */ |
222 |
223 |
char buf[64]; |
224 |
COLOR cval; |
225 |
int com; |
226 |
double comp; |
227 |
228 |
while (!kbhit()) |
229 |
watch_mouse(); |
230 |
com = getch(); |
231 |
switch (com) { /* interpret command */ |
232 |
case 'q': |
233 |
case CTRL('Z'): /* quit */ |
234 |
return(0); |
235 |
case '\n': |
236 |
case '\r': |
237 |
case 'l': |
238 |
case 'c': /* value */ |
239 |
if (avgbox(cval) == -1) |
240 |
return(-1); |
241 |
switch (com) { |
242 |
case '\n': |
243 |
case '\r': /* radiance */ |
244 |
sprintf(buf, "%.3f", intens(cval)/exposure); |
245 |
break; |
246 |
case 'l': /* luminance */ |
247 |
sprintf(buf, "%.0fL", luminance(cval)/exposure); |
248 |
break; |
249 |
case 'c': /* color */ |
250 |
comp = pow(2.0, (double)scale); |
251 |
sprintf(buf, "(%.2f,%.2f,%.2f)", |
252 |
colval(cval,RED)*comp, |
253 |
colval(cval,GRN)*comp, |
254 |
colval(cval,BLU)*comp); |
255 |
break; |
256 |
257 |
postext(box.xmin+box.xsiz/2, box.ymin+box.ysiz/2); |
258 |
_outtext(buf); |
259 |
return(1); |
260 |
default: |
261 |
return(-1); |
262 |
263 |
264 |
265 |
266 |
watch_mouse() /* look after mousie */ |
267 |
268 |
static int mouse_installed = 0; |
269 |
int a_x, a_y, l_x, l_y; |
270 |
271 |
if (!mouse_installed) { |
272 |
ms_init(); |
273 |
mouse_installed = 1; |
274 |
275 |
if (mouse_event & M_MOTION) |
276 |
move_cursor(mouse_xpos, mouse_ypos); |
277 |
if (!(mouse_event & M_LDOWN)) |
278 |
return; |
279 |
l_x = a_x = mouse_xpos; l_y = a_y = mouse_ypos; |
280 |
move_cursor(-1, -1); /* hide cursor */ |
281 |
revbox(a_x, a_y, l_x, l_y); /* show box */ |
282 |
do { |
283 |
mouse_event = 0; |
284 |
while (!mouse_event) |
285 |
286 |
if (mouse_event & M_MOTION) { |
287 |
revbox(a_x, a_y, l_x, l_y); |
288 |
revbox(a_x, a_y, l_x=mouse_xpos, l_y=mouse_ypos); |
289 |
290 |
} while (!(mouse_event & M_LUP)); |
291 |
revbox(a_x, a_y, l_x, l_y); /* hide box */ |
292 |
move_cursor(mouse_xpos, mouse_ypos); /* show cursor */ |
293 |
box.xmin = mouse_xpos; |
294 |
box.ymin = mouse_ypos; |
295 |
if (box.xmin > a_x) { |
296 |
box.xsiz = box.xmin - a_x + 1; |
297 |
box.xmin = a_x; |
298 |
} else { |
299 |
box.xsiz = a_x - box.xmin + 1; |
300 |
301 |
if (box.ymin > a_y) { |
302 |
box.ysiz = box.ymin - a_y + 1; |
303 |
box.ymin = a_y; |
304 |
} else { |
305 |
box.ysiz = a_y - box.ymin + 1; |
306 |
307 |
mouse_event = 0; |
308 |
309 |
310 |
311 |
revbox(x0, y0, x1, y1) /* draw box with reversed lines */ |
312 |
int x0, y0, x1, y1; |
313 |
314 |
_setplotaction(_GXOR); |
315 |
_setcolor(255); |
316 |
_moveto(x0, y0); |
317 |
_lineto(x1, y0); |
318 |
_lineto(x1, y1); |
319 |
_lineto(x0, y1); |
320 |
_lineto(x0, y0); |
321 |
322 |
323 |
324 |
int |
325 |
avgbox(clr) /* average color over current box */ |
326 |
COLOR clr; |
327 |
328 |
static COLOR lc; |
329 |
static int ll, lr, lt, lb; |
330 |
int left, right, top, bottom; |
331 |
int y; |
332 |
double d; |
333 |
COLOR ctmp; |
334 |
register int x; |
335 |
336 |
setcolor(clr, 0.0, 0.0, 0.0); |
337 |
left = box.xmin; |
338 |
right = left + box.xsiz; |
339 |
if (left < 0) |
340 |
left = 0; |
341 |
if (right > xmax) |
342 |
right = xmax; |
343 |
if (left >= right) |
344 |
return(-1); |
345 |
top = box.ymin; |
346 |
bottom = top + box.ysiz; |
347 |
if (top < 0) |
348 |
top = 0; |
349 |
if (bottom > ymax) |
350 |
bottom = ymax; |
351 |
if (top >= bottom) |
352 |
return(-1); |
353 |
if (left == ll && right == lr && top == lt && bottom == lb) { |
354 |
copycolor(clr, lc); |
355 |
return(0); |
356 |
357 |
for (y = top; y < bottom; y++) { |
358 |
if (getscan(y) == -1) |
359 |
return(-1); |
360 |
for (x = left; x < right; x++) { |
361 |
colr_color(ctmp, scanline[x]); |
362 |
addcolor(clr, ctmp); |
363 |
364 |
365 |
d = 1.0/((right-left)*(bottom-top)); |
366 |
scalecolor(clr, d); |
367 |
ll = left; lr = right; lt = top; lb = bottom; |
368 |
copycolor(lc, clr); |
369 |
return(0); |
370 |
371 |
372 |
373 |
setpalette() /* set our palette using clrtab */ |
374 |
375 |
long cvals[256]; |
376 |
register int i; |
377 |
378 |
if (minpix >= 2) { |
379 |
cvals[ourblack] = _BLACK; cvals[ourwhite] = _BRIGHTWHITE; |
380 |
381 |
for (i = 0; i < maxcolors; i++) |
382 |
cvals[i+minpix] = clrtab[i][BLU]<<14 & 0x3f0000L | |
383 |
clrtab[i][GRN]<<6 & 0x3f00 | |
384 |
clrtab[i][RED]>>2; |
385 |
_remapallpalette(cvals); |
386 |
387 |
388 |
389 |
greyimage() /* display greyscale image */ |
390 |
391 |
short thiscolor, lastcolor = -1; |
392 |
int y; |
393 |
register int x; |
394 |
/* set gamma correction */ |
395 |
setcolrgam(gamcor); |
396 |
/* set up color map */ |
397 |
for (x = 0; x < maxcolors; x++) |
398 |
clrtab[x][RED] = clrtab[x][GRN] = |
399 |
clrtab[x][BLU] = ((long)x*256+maxcolors/2)/maxcolors; |
400 |
setpalette(); |
401 |
_setplotaction(_GPSET); |
402 |
/* read and display file */ |
403 |
for (y = 0; y < ymax; y++) { |
404 |
getscan(y); |
405 |
if (scale) |
406 |
shiftcolrs(scanline, xmax, scale); |
407 |
colrs_gambs(scanline, xmax); |
408 |
if (maxcolors < 256) |
409 |
for (x = 0; x < xmax; x++) { |
410 |
thiscolor = ((long)normbright(scanline[x]) * |
411 |
maxcolors + 128) >> 8; |
412 |
if (thiscolor != lastcolor) |
413 |
_setcolor((lastcolor=thiscolor)+minpix); |
414 |
_setpixel(x, y); |
415 |
416 |
else |
417 |
418 |
thiscolor = normbright(scanline[x]); |
419 |
420 |
421 |
_setpixel(x, y); |
422 |
423 |
424 |
425 |
426 |
427 |
mappedimage() /* display color-mapped image */ |
428 |
429 |
BYTE bscan[MAXWIDTH]; |
430 |
int y; |
431 |
register int x; |
432 |
433 |
434 |
/* make histogram */ |
435 |
new_histo(); |
436 |
437 |
if (getscan(y) < 0) |
438 |
quiterr("seek error in getmapped"); |
439 |
if (scale) |
440 |
441 |
442 |
cnt_colrs(scanline, xmax); |
443 |
444 |
/* map pixels */ |
445 |
if (!new_clrtab(maxcolors)) |
446 |
quiterr("cannot create color map"); |
447 |
setpalette(); |
448 |
449 |
450 |
451 |
452 |
453 |
if (scale) |
454 |
455 |
456 |
if (dither) |
457 |
dith_colrs(bscan, scanline, xmax); |
458 |
else |
459 |
map_colrs(bscan, scanline, xmax); |
460 |
461 |
if (x==0 || bscan[x] != bscan[x-1]) |
462 |
_setcolor(bscan[x]+minpix); |
463 |
_setpixel(x, y); |
464 |
465 |
466 |
467 |
468 |
469 |
getscan(y) |
470 |
int y; |
471 |
472 |
if (y != cury) { |
473 |
if (scanpos[y] == -1) |
474 |
return(-1); |
475 |
if (fseek(fin, scanpos[y], 0) == -1) |
476 |
quiterr("fseek error"); |
477 |
cury = y; |
478 |
} else if (scanpos != NULL && scanpos[y] == -1) |
479 |
scanpos[y] = ftell(fin); |
480 |
481 |
if (freadcolrs(scanline, xmax, fin) < 0) |
482 |
quiterr("picture read error"); |
483 |
484 |
cury++; |
485 |
return(0); |
486 |
487 |
488 |
489 |
490 |
* Microsoft Mouse handling routines |
491 |
492 |
493 |
494 |
#pragma off (check_stack) |
495 |
void _loadds far mouse_handler (int max, int mcx, int mdx) |
496 |
497 |
#pragma aux mouse_handler parm [EAX] [ECX] [EDX] |
498 |
mouse_event = max; |
499 |
mouse_xpos = mcx; |
500 |
mouse_ypos = mdx * (long)ymax / 200; /* kludge */ |
501 |
if (mouse_xpos >= xmax) mouse_xpos = xmax-1; |
502 |
if (mouse_ypos >= ymax) mouse_ypos = ymax-1; |
503 |
504 |
#pragma on (check_stack) |
505 |
506 |
507 |
void |
508 |
move_cursor(newx, newy) /* move cursor to new position */ |
509 |
int newx, newy; |
510 |
511 |
static char *imp = NULL; |
512 |
static int curx = -1, cury = -1; |
513 |
#define xcmin (curx-crad<0 ? 0 : curx-crad) |
514 |
#define ycmin (cury-crad<0 ? 0 : cury-crad) |
515 |
#define xcmax (curx+crad>=xmax ? xmax-1 : curx+crad) |
516 |
#define ycmax (cury+crad>=ymax ? ymax-1 : cury+crad) |
517 |
518 |
if (newx == curx & newy == cury) |
519 |
return; |
520 |
if (imp == NULL && |
521 |
(imp = bmalloc(_imagesize(0,0,2*crad+1,2*crad+1))) == NULL) { |
522 |
quiterr("out of memory in move_cursor"); |
523 |
524 |
if (curx >= 0 & cury >= 0) /* clear old cursor */ |
525 |
_putimage(xcmin, ycmin, imp, _GPSET); |
526 |
/* record new position */ |
527 |
curx = newx; cury = newy; |
528 |
if (curx < 0 | cury < 0) |
529 |
return; /* no cursor */ |
530 |
/* save under new cursor */ |
531 |
_getimage(xcmin, ycmin, xcmax, ycmax, imp); |
532 |
/* draw new cursor */ |
533 |
534 |
_setcolor(ourwhite); |
535 |
_rectangle(_GFILLINTERIOR, xcmin, cury-1, xcmax, cury+1); |
536 |
_rectangle(_GFILLINTERIOR, curx-1, ycmin, curx+1, ycmax); |
537 |
_setcolor(ourblack); |
538 |
_moveto(xcmin+1, cury); |
539 |
_lineto(xcmax-1, cury); |
540 |
_moveto(curx, ycmin+1); |
541 |
_lineto(curx, ycmax-1); |
542 |
#undef xcmin |
543 |
#undef ycmin |
544 |
#undef xcmax |
545 |
#undef ycmax |
546 |
547 |
548 |
549 |
int |
550 |
ms_init() |
551 |
552 |
struct SREGS sregs; |
553 |
union REGS inregs, outregs; |
554 |
int far *ptr; |
555 |
int (far *function_ptr)(); |
556 |
557 |
segread(&sregs); |
558 |
559 |
/* check for mouse driver */ |
560 |
561 |
inregs.w.ax = 0; |
562 |
int386 (0x33, &inregs, &outregs); |
563 |
if( outregs.w.ax != -1 ) { |
564 |
return(0); |
565 |
566 |
567 |
crad = ymax/40; |
568 |
569 |
/* install watcher */ |
570 |
571 |
inregs.w.ax = 0xC; |
572 |
inregs.w.cx = M_LDOWN | M_LUP | M_MOTION; |
573 |
function_ptr = mouse_handler; |
574 |
inregs.x.edx = FP_OFF( function_ptr ); |
575 |
sregs.es = FP_SEG( function_ptr ); |
576 |
int386x( 0x33, &inregs, &outregs, &sregs ); |
577 |
578 |
return(1); |
579 |
