root/radiance/ray/src/px/vgaimage.c
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.9: +1 -4 lines
Tue Oct 27 09:08:28 1998 UTC (26 years, 6 months ago) by gwlarson
Tue Sep 20 15:48:36 1994 UTC (30 years, 7 months ago) by greg
changed GAMMA environment variable to DISPLAY_GAMMA
Fri Jun 11 16:58:35 1993 UTC (31 years, 11 months ago) by greg
minor 16-bit bug fix
Tue Mar 30 11:37:54 1993 UTC (32 years, 1 month ago) by greg
minor bug fix
Wed Nov 11 17:34:14 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.4: +17 -16 lines
fixed bug in greyscale conversion
Mon Nov 2 16:01:17 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.3: +16 -6 lines
Changes for 32-bit PC port
Fri Oct 16 13:09:36 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.2: +89 -80 lines
Wed Oct 14 18:56:58 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +6 -4 lines
Diff to previous 2.1
fixed problem where text is overwritten by cursor
Tue Oct 13 17:42:07 1992 UTC (32 years, 6 months ago) by greg
