root/radiance/ray/src/px/ttyimage.c
Changes since 2.4: +9 -7 lines
Changes since 2.3: +3 -7 lines
Changes since 2.2: +2 -4 lines
Mon Sep 21 12:15:22 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +9 -4 lines
Diff to previous 2.1
Changes for PC port
Tue Nov 12 16:05:29 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.8
Mon Nov 11 14:01:29 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.7: +3 -2 lines
Diff to previous 1.7
Thu Apr 18 14:35:47 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.6: +3 -4 lines
Diff to previous 1.6
Fri Jan 26 08:17:41 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.5
Thu Jan 25 08:28:36 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +1 -3 lines
Diff to previous 1.4
Fri Oct 20 20:36:08 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +2 -6 lines
Diff to previous 1.3
change to color normalization calls
Fri Oct 20 16:44:35 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +26 -18 lines
Diff to previous 1.2
eliminated unnecessary use of floating point color
Tue Sep 12 13:04:41 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +1 -2 lines
Diff to previous 1.1
Thu Feb 2 10:49:42 1989 UTC (35 years, 4 months ago) by greg
