root/Development/ray/src/px/tmaptiff.c
Revision: 3.3
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.2: +0 -0 lines
State: FILE REMOVED
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Perform tone mapping on TIFF input.
9 */
10
11 #include <stdio.h>
12 #include "tiffio.h"
13 #include "tmprivat.h"
14
15
16 int
17 tmLoadTIFF(lpp, cpp, xp, yp, fname, tp) /* load and convert TIFF */
18 TMbright **lpp;
19 BYTE **cpp;
20 int *xp, *yp;
21 char *fname;
22 TIFF *tp;
23 {
24 char *funcName = fname==NULL ? "tmLoadTIFF" : fname;
25 TIFF *tif;
26 int err;
27 union {uint16 *w; uint32 *l; MEM_PTR p;} sl;
28 uint16 comp, phot, pconf;
29 uint32 width, height;
30 double stonits;
31 int y;
32 /* check arguments */
33 if (tmTop == NULL)
34 returnErr(TM_E_TMINVAL);
35 if (lpp == NULL | xp == NULL | yp == NULL |
36 (fname == NULL & tp == NULL))
37 returnErr(TM_E_ILLEGAL);
38 /* check/get TIFF tags */
39 sl.p = NULL; *lpp = NULL;
40 if (cpp != TM_NOCHROMP) *cpp = TM_NOCHROM;
41 err = TM_E_BADFILE;
42 if ((tif = tp) == NULL && (tif = TIFFOpen(fname, "r")) == NULL)
43 returnErr(TM_E_BADFILE);
44 TIFFGetFieldDefaulted(tif, TIFFTAG_PHOTOMETRIC, &phot);
45 TIFFGetFieldDefaulted(tif, TIFFTAG_COMPRESSION, &comp);
46 if (!TIFFGetField(tif, TIFFTAG_IMAGEWIDTH, &width) ||
47 !TIFFGetField(tif, TIFFTAG_IMAGELENGTH, &height))
48 goto done;
49 *xp = width; *yp = height;
50 TIFFGetFieldDefaulted(tif, TIFFTAG_PLANARCONFIG, &pconf);
51 if (pconf != PLANARCONFIG_CONTIG)
52 goto done;
53 if (!TIFFGetField(tif, TIFFTAG_STONITS, &stonits))
54 stonits = 1.;
55 if (phot == PHOTOMETRIC_LOGLUV) {
56 if (comp != COMPRESSION_SGILOG && comp != COMPRESSION_SGILOG24)
57 goto done;
58 TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_RAW);
59 sl.l = (uint32 *)malloc(width*sizeof(uint32));
60 if (cpp != TM_NOCHROMP) {
61 *cpp = (BYTE *)malloc(width*height*3*sizeof(BYTE));
62 if (*cpp == NULL) {
63 err = TM_E_NOMEM;
64 goto done;
65 }
66 }
67 } else if (phot == PHOTOMETRIC_LOGL) {
68 if (comp != COMPRESSION_SGILOG)
69 goto done;
70 TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_16BIT);
71 sl.w = (uint16 *)malloc(width*sizeof(uint16));
72 } else
73 goto done;
74 *lpp = (TMbright *)malloc(width*height*sizeof(TMbright));
75 if (sl.p == NULL | *lpp == NULL) {
76 err = TM_E_NOMEM;
77 goto done;
78 }
79 /* set input color space */
80 tmSetSpace(TM_XYZPRIM, stonits);
81 /* read and convert each scanline */
82 for (y = 0; y < height; y++) {
83 if (TIFFReadScanline(tif, sl.p, y, 0) < 0) {
84 err = TM_E_BADFILE;
85 break;
86 }
87 if (phot == PHOTOMETRIC_LOGL)
88 err = tmCvL16(*lpp + y*width, sl.w, width);
89 else if (comp == COMPRESSION_SGILOG24)
90 err = tmCvLuv24(*lpp + y*width,
91 cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width,
92 sl.l, width);
93 else
94 err = tmCvLuv32(*lpp + y*width,
95 cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width,
96 sl.l, width);
97 if (err != TM_E_OK)
98 break;
99 }
100 done: /* clean up */
101 if (tp == NULL)
102 TIFFClose(tif);
103 if (sl.p != NULL)
104 free(sl.p);
105 if (err != TM_E_OK) { /* free buffers on error */
106 if (*lpp != NULL)
107 free((MEM_PTR)*lpp);
108 *lpp = NULL;
109 if (cpp != TM_NOCHROMP) {
110 if (*cpp != TM_NOCHROM)
111 free((MEM_PTR)*cpp);
112 *cpp = NULL;
113 }
114 *xp = *yp = 0;
115 returnErr(err);
116 }
117 returnOK;
118 }
119
120
121 /*
122 * Load and tone-map a SGILOG TIFF.
123 * Beware of greyscale input -- you must check the PHOTOMETRIC tag to
124 * determine that the returned array contains only grey values, not RGB.
125 * As in tmMapPicture(), grey values are also returned if flags&TM_F_BW.
126 */
127 int
128 tmMapTIFF(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname, tp)
129 BYTE **psp;
130 int *xp, *yp;
131 int flags;
132 RGBPRIMP monpri;
133 double gamval, Lddyn, Ldmax;
134 char *fname;
135 TIFF *tp;
136 {
137 char *funcName = fname==NULL ? "tmMapTIFF" : fname;
138 TMbright *lp;
139 BYTE *cp;
140 int err;
141 /* check arguments */
142 if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL |
143 (fname == NULL & tp == NULL))
144 returnErr(TM_E_ILLEGAL);
145 if (gamval < MINGAM) gamval = DEFGAM;
146 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
147 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
148 if (flags & TM_F_BW) monpri = stdprims;
149 /* initialize tone mapping */
150 if (tmInit(flags, monpri, gamval) == NULL)
151 returnErr(TM_E_NOMEM);
152 /* load and convert TIFF */
153 cp = TM_NOCHROM;
154 err = tmLoadTIFF(&lp, flags&TM_F_BW ? TM_NOCHROMP : &cp,
155 xp, yp, fname, tp);
156 if (err != TM_E_OK) {
157 tmDone(NULL);
158 return(err);
159 }
160 if (cp == TM_NOCHROM) {
161 *psp = (BYTE *)malloc(*xp * *yp * sizeof(BYTE));
162 if (*psp == NULL) {
163 free((MEM_PTR)lp);
164 tmDone(NULL);
165 returnErr(TM_E_NOMEM);
166 }
167 } else
168 *psp = cp;
169 /* compute color mapping */
170 err = tmAddHisto(lp, *xp * *yp, 1);
171 if (err != TM_E_OK)
172 goto done;
173 err = tmComputeMapping(gamval, Lddyn, Ldmax);
174 if (err != TM_E_OK)
175 goto done;
176 /* map pixels */
177 err = tmMapPixels(*psp, lp, cp, *xp * *yp);
178
179 done: /* clean up */
180 free((MEM_PTR)lp);
181 tmDone(NULL);
182 if (err != TM_E_OK) { /* free memory on error */
183 free((MEM_PTR)*psp);
184 *psp = NULL;
185 *xp = *yp = 0;
186 returnErr(err);
187 }
188 returnOK;
189 }
