root/radiance/ray/src/px/tardev.h
Revision: 1.3
Committed: Sat Feb 22 02:07:28 2003 UTC (21 years, 3 months ago) by greg
Changes since 1.2: +1 -4 lines
# User Rev Content
1 greg 1.3 /* RCSid: $Id$ */
2 greg 1.1 /*
3     * Board types used for targa->boardType
4     */
5     #define TYPE_8 8
6     #define TYPE_16 16
7     #define TYPE_24 24
8     #define TYPE_32 32
9     #define TYPE_M8 -8
10
11     /*
12     * TARGA: 400 to 482 rows x 512 pixels/row X 16 bits/pixel
13     */
14
15     #define XMIN 0
16     #define YMIN 0
17     #define XMAX 512 /* maximum X value */
18     #define YMAX 512 /* maximum Y value */
19     #define XRES 512 /* X resolution */
20     #define YRES 512 /* Y Resolution */
21     #define YVISMAX (2*targa->LinesPerField) /* Maximum visible Y coordinate */
22     #define YVISMIN 0 /* Minimum visible Y coordiate */
23     #define DEF_ROWS 400 /* Default number of rows */
24
25
26     #define DEF_IOBASE 0x220
27     #define IOBASE targa->iobase /* io base location of graphics registers */
28     #define MEMSEG targa->memloc /* use the variable so we can use */
29     #define SCNSEG targa->memloc /* the one defined in TARGA */
30     #define SRCBANK (targa->memloc+0x0800) /* use high-bank as source bank */
31     #define DESTBANK targa->memloc /* use lo-bank as destination bank */
32     #define DEF_MEMSEG 0xa000 /* Default screen memory */
33
34     /*
35     * Output register definitions
36     */
37     #define MODEREG (IOBASE+0xC00) /* Mode Register address */
38     #define MASKREG (IOBASE+0x800) /* Mask Registers */
39     #define UNDERREG (IOBASE+0x800) /* Underscan register */
40     #define OVERREG (IOBASE+0x802) /* overscan register */
41     #define DESTREG (IOBASE+0x802) /* Address of Page Select Lower Register */
42     #define SRCREG (IOBASE+0x803) /* Address of Page Select Upper Register */
43     #define VCRCON (IOBASE+0x400) /* Address of Contrast/VidSrc Register */
44     #define BLNDREG VCRCON
45     #define SATHUE (IOBASE+0x402) /* Satuation/Hue Register address */
46     #define DRREG (IOBASE+0x401) /* ADDRESS OF Controller Write Register */
47     #define VERTPAN (IOBASE+0x403) /* Address of Vertical Pan Register */
48     #define BORDER (IOBASE) /* Address of Page Select Lower Register */
49
50
51     /*
52     * Input register definitions
53     */
54     #define VIDEOSTATUS (IOBASE+0xC02) /* Video Status Register */
55     #define RASTERREG (IOBASE+0xC00) /* Raster counter register */
56
57
58
59     /*
60     * Default register values
61     */
62     #define DEF_MODE 1 /* Default mode register value */
63     /* Memory selected, 512x512, 1x */
64     /* Display mode */
65     #define DEF_MASK 0 /* default memory mask */
66     #define DEF_SATURATION 0x4 /* default saturation value */
67     #define DEF_HUE 0x10 /* default hue value */
68     #define DEF_CONTRAST 0x10 /* default contrast value */
69     #define DEF_VIDSRC 0 /* default video source value - Composite */
70     #define DEF_VERTPAN 56 /* assumes 400-line output */
71     #define DEF_BORDER 0 /* default border color */
72
73
74     /*
75     * MASK AND SHIFT VALUE FOR REGISTERS CONTAINING SUBFIELDS
76     */
77     /*
78     * ******************************************************
79     * MODE REGISTERS
80     * ******************************************************
81     */
82     #define MSK_MSEL 0xfffC /* memory select bits */
83     #define SHF_MSEL 0x0000
84     #define MSEL 1
85
86     #define MSK_IBIT 0xfffb /* Interlace bit */
87     #define SHF_IBIT 2
88
89     #define MSK_RES 0xFFC7 /* disp. resolution and screen select bits */
90     #define SHF_RES 3
91     #define S0_512X512_0 0 /* 512x512 resolution screen */
92     #define S1_512X512_1 1
93     #define S2_512X256_0 2 /* 512x256 resolution screen 0 */
94     #define S3_512X256_1 3 /* 512x256 resolution screen 1 */
95     #define S4_256X256_0 4 /* 256x256 resolution screen 0 */
96     #define S5_256X256_1 5 /* .... */
97     #define S6_256X256_2 6
98     #define S7_256X256_3 7
99
100     #define MSK_REGWRITE 0xFFBF /* mask for display register write */
101     #define SHF_REGWRITE 6
102     #define REGINDEX 0 /* to write an index value */
103     #define REGVALUE 1 /* to write a value */
104
105     #define MSK_BIT9 0xFF7F /* maks for high-order bit of DR's */
106     #define SHF_BIT9 7
107
108     #define MSK_TAPBITS 0xFCFF /* mask for setting the tap bits */
109     #define SHF_TAPBITS 8
110
111     #define MSK_ZOOM 0xF3FF /* Mask for zoom factor */
112     #define SHF_ZOOM 10
113
114     #define MSK_DISPLAY 0xCFFF /* Mask for display mode */
115     #define SHF_DISPLAY 12
116     #define MEMORY_MODE 0
117     #define LIVE_FIXED 1
118     #define OVERLAY_MODE 2
119     #define LIVE_LIVE 3
120     #define DEF_DISPLAY 0
121
122     #define MSK_CAPTURE 0xBFFF /* Mask for capture bit */
123     #define SHF_CAPTURE 14
124
125     #define MSK_GENLOCK 0x7FFF /* MASK FOR GENLOCK */
126     #define SHF_GENLOCK 15
127     #define DEF_GENLOCK 0
128     /*
129     * Video status input register
130     */
131     #define FIELDBIT 0x0001
132     #define VIDEOLOSS 0x0002
133     /*
134     * VIDEO SOURCE/CONTROL REGISTER
135     */
136     #define MSK_CONTRAST 0xFFC1
137     #define SHF_CONTRAST 1
138     #define MAX_CONTRAST 0x1f
139
140     #define MSK_RGBORCV 0xBF
141     #define SHF_RGBORCV 6
142     #define RGB 1
143     #define CV 0
144
145     #define MSK_VCRORCAMERA 0x7F
146     #define SHF_VCRORCAMERA 7
147     #define VCR 1
148     #define CAMERA 0
149
150     /*
151     * HUE/SATUATION REGISTER
152     */
153     #define MSK_HUE 0xE0
154     #define SHF_HUE 0
155     #define MAX_HUE 0x1f
156
157     #define MSK_SATURATION 0x1F
158     #define SHF_SATURATION 5
159     #define MAX_SATURATION 0x07
160
161
162     /*
163     * *********************************************
164     * Display register settings
165     * *********************************************
166     *
167     * Screen Positioning Registers:
168     * DR 0-3
169     */
170     #define LEFTBORDER 0
171     #define DEF_LEFT 85
172     #define MIN_LEFT 75
173     #define MAX_LEFT 95
174     #define RIGHTBORDER 1
175     #define DEF_RIGHT (DEF_LEFT+256)
176     #define TOPBORDER 2
177     #define DEF_TOP 40
178     #define MIN_TOP 20
179     #define BOTTOMBORDER 3
180     #define DEF_BOTTOM (DEFTOP+DEFROWS/2)
181     #define MAX_BOTTOM 261
182
183     /*
184     * REgisters which track 0-3
185     */
186     #define DR8 8
187     #define PRESHIFT DR8
188     #define EQU_DR8 DR0
189     #define DR9 9
190     #define EQU_DR9 DR1
191     #define DR10 10
192     #define EQU_DR10 DR2
193     #define DR11 11
194     #define EQU_DR11 DR3
195
196     /*
197     * REQUIRED REGISTERS
198     */
199     #define DR4 4
200     #define DEF_DR4 352
201     #define DR5 5
202     #define DEF_DR5 1
203     #define DR6 6
204     #define DEF_DR6 0
205     #define DR7 7
206     #define DEF_DR7 511
207     #define DR12 12
208     #define DEF_DR12 20
209     #define DR13 13
210     #define DEF_DR13 22
211     #define DR14 14
212     #define DEF_DR14 0
213     #define DR15 15
214     #define DEF_DR15 511
215     #define DR16 16
216     #define DEF_DR16 0
217     #define DR17 17
218     #define DEF_DR17 0
219     #define DR18 18
220     #define DEF_DR18 0
221     #define DR19 19
222     #define DEF_DR19 4
223
224     /* interlace mode register & parameters */
225     #define DR20 20
226     #define INTREG 0x14
227     #define DEF_INT 0 /* default to interlace mode 0 */
228     #define MSK_INTERLACE 0x0003
229
230
231
232     struct TARStruct {
233     /* Board Configuration */
234     int memloc; /* memory segment */
235     int iobase; /* IOBASE segment */
236     int BytesPerPixel; /* number of words per pixel */
237     int RowsPerBank; /* number of row per 64K bank */
238     int MaxBanks; /* maximum bank id */
239     int AddressShift; /* number of bits to shift address */
240
241     /* Control registers */
242     int mode; /* mode register */
243     int Mask; /* mask register */
244     int PageMode; /* current page mode (screen res. and page) */
245     unsigned PageLower; /* Lower Page Select register */
246     unsigned PageUpper; /* upper Page select register */
247     int VCRCon; /* VCRContract register */
248     int SatHue; /* Hue and Saturation register */
249     long BorderColor; /* Border color register */
250     int VertShift; /* Vertical Pan Register */
251
252     int PanXOrig, PanYOrig; /* x,y pan origin */
253
254     /* TARGA-SET PARAMETERS */
255     int boardType; /* See TYPE_XX IN THIS FILE */
256     /* FOR DEFINITION OF Board Types */
257     int xOffset; /* X-offset */
258     int yOffset; /* Y-Offset */
259     int LinesPerField; /* maximum visible row count */
260     int InterlaceMode; /* desired interlace mode */
261     int AlwaysGenLock; /* Genlock always on or not */
262     int Contrast; /* Desired Contrast */
263     int Hue; /* Desired Hue */
264     int Saturation; /* Desired Satuation */
265     int RGBorCV; /* CV or RGB Input */
266     int VCRorCamera; /* VCR or Camera */
267     int ovrscnAvail, ovrscnOn; /* ovrscnAvail 1 if Overscan installed */
268     /* ovrscnOn 1 if overscan is stretching */
269
270     /* Display Registers */
271     int DisplayRegister[22];
272     };
273
274     struct M8Struct {
275     int there; /* flag to indicate if m8 is present */
276     /* logical true if M8 present (i.e. 1) */
277     /* and logical false (0) otherwise */
278     int inOffset; /* input offset */
279     int inGain; /* input gain */
280     int inputMux; /* input channel */
281     int modeRegister; /* value of the mode register on the M8 top */
282     int inMap, outMap; /* active input/output color map */
283     int loopThru; /* logical flag if M8 loop-through is desired */
284     /* of CGA input 1---YES, 0---No */
285     int topFunction; /* currently selected top function */
286     int CGAInterlace; /* interlace mode for a CGA if used */
287     };
288
289     #define M8MODE 0x400 /* IO Offset for writes to M8 Mode register */
290     #define M8WRITE 0x402 /* Offset for writes to M8 function registers */
291     #define M8READ 0x802 /* Offset for reads from M8 function registers */
292
293     #define DEF_M8MODE 2
294     #define DEF_M8GAIN 50
295     #define DEF_M8OFFSET 50
296     #define DEF_M8MUX 0
297     #define DEF_M8INMAP 0
298     #define DEF_M8OUTMAP 0
299     #define DEF_CGAINTERLACE 3
300
301
302     struct hdStruct {
303     char textSize;
304     char mapType;
305     char dataType;
306     int mapOrig;
307     int mapLength;
308     char CMapBits;
309     int XOffset;
310     int YOffset;
311     int x;
312     int y;
313     int dataBits, imType;
314     } ;
315
316
317     /* stroke font file */
318
319     typedef struct{
320     int width; /* width of character */
321     int height; /* height of char from baseline */
322     int descent; /* descent below baseline */
323     int index; /* index into stroke table */
324     } SFONTCHAR;
325
326     typedef struct {
327     int dx; /* dx of character */
328     int dy; /* dy of character */
329     int dd; /* dy of descenders */
330     int first; /* value of first char in font */
331     int last; /* value of last char in font */
332     int *strokes; /* where the strokes are located */
333     SFONTCHAR *info; /* info on each character */
334     } SFONT;
