| 1 |
/* RCSid: $Id: tardev.h,v 1.3 2003/02/22 02:07:28 greg Exp $ */
| 2 |
| 3 |
* Board types used for targa->boardType
| 4 |
| 5 |
#ifndef _RAD_TARDEV_H_
| 6 |
#define _RAD_TARDEV_H_
| 7 |
| 8 |
#ifdef __cplusplus
| 9 |
extern "C" {
| 10 |
#endif
| 11 |
| 12 |
#define TYPE_8 8
| 13 |
#define TYPE_16 16
| 14 |
#define TYPE_24 24
| 15 |
#define TYPE_32 32
| 16 |
#define TYPE_M8 -8
| 17 |
| 18 |
| 19 |
* TARGA: 400 to 482 rows x 512 pixels/row X 16 bits/pixel
| 20 |
| 21 |
| 22 |
#define XMIN 0
| 23 |
#define YMIN 0
| 24 |
#define XMAX 512 /* maximum X value */
| 25 |
#define YMAX 512 /* maximum Y value */
| 26 |
#define XRES 512 /* X resolution */
| 27 |
#define YRES 512 /* Y Resolution */
| 28 |
#define YVISMAX (2*targa->LinesPerField) /* Maximum visible Y coordinate */
| 29 |
#define YVISMIN 0 /* Minimum visible Y coordiate */
| 30 |
#define DEF_ROWS 400 /* Default number of rows */
| 31 |
| 32 |
| 33 |
#define DEF_IOBASE 0x220
| 34 |
#define IOBASE targa->iobase /* io base location of graphics registers */
| 35 |
#define MEMSEG targa->memloc /* use the variable so we can use */
| 36 |
#define SCNSEG targa->memloc /* the one defined in TARGA */
| 37 |
#define SRCBANK (targa->memloc+0x0800) /* use high-bank as source bank */
| 38 |
#define DESTBANK targa->memloc /* use lo-bank as destination bank */
| 39 |
#define DEF_MEMSEG 0xa000 /* Default screen memory */
| 40 |
| 41 |
| 42 |
* Output register definitions
| 43 |
| 44 |
#define MODEREG (IOBASE+0xC00) /* Mode Register address */
| 45 |
#define MASKREG (IOBASE+0x800) /* Mask Registers */
| 46 |
#define UNDERREG (IOBASE+0x800) /* Underscan register */
| 47 |
#define OVERREG (IOBASE+0x802) /* overscan register */
| 48 |
#define DESTREG (IOBASE+0x802) /* Address of Page Select Lower Register */
| 49 |
#define SRCREG (IOBASE+0x803) /* Address of Page Select Upper Register */
| 50 |
#define VCRCON (IOBASE+0x400) /* Address of Contrast/VidSrc Register */
| 51 |
#define BLNDREG VCRCON
| 52 |
#define SATHUE (IOBASE+0x402) /* Satuation/Hue Register address */
| 53 |
#define DRREG (IOBASE+0x401) /* ADDRESS OF Controller Write Register */
| 54 |
#define VERTPAN (IOBASE+0x403) /* Address of Vertical Pan Register */
| 55 |
#define BORDER (IOBASE) /* Address of Page Select Lower Register */
| 56 |
| 57 |
| 58 |
| 59 |
* Input register definitions
| 60 |
| 61 |
#define VIDEOSTATUS (IOBASE+0xC02) /* Video Status Register */
| 62 |
#define RASTERREG (IOBASE+0xC00) /* Raster counter register */
| 63 |
| 64 |
| 65 |
| 66 |
| 67 |
* Default register values
| 68 |
| 69 |
#define DEF_MODE 1 /* Default mode register value */
| 70 |
/* Memory selected, 512x512, 1x */
| 71 |
/* Display mode */
| 72 |
#define DEF_MASK 0 /* default memory mask */
| 73 |
#define DEF_SATURATION 0x4 /* default saturation value */
| 74 |
#define DEF_HUE 0x10 /* default hue value */
| 75 |
#define DEF_CONTRAST 0x10 /* default contrast value */
| 76 |
#define DEF_VIDSRC 0 /* default video source value - Composite */
| 77 |
#define DEF_VERTPAN 56 /* assumes 400-line output */
| 78 |
#define DEF_BORDER 0 /* default border color */
| 79 |
| 80 |
| 81 |
| 82 |
* MASK AND SHIFT VALUE FOR REGISTERS CONTAINING SUBFIELDS
| 83 |
| 84 |
| 85 |
| 86 |
* MODE REGISTERS
| 87 |
| 88 |
| 89 |
#define MSK_MSEL 0xfffC /* memory select bits */
| 90 |
#define SHF_MSEL 0x0000
| 91 |
#define MSEL 1
| 92 |
| 93 |
#define MSK_IBIT 0xfffb /* Interlace bit */
| 94 |
#define SHF_IBIT 2
| 95 |
| 96 |
#define MSK_RES 0xFFC7 /* disp. resolution and screen select bits */
| 97 |
#define SHF_RES 3
| 98 |
#define S0_512X512_0 0 /* 512x512 resolution screen */
| 99 |
#define S1_512X512_1 1
| 100 |
#define S2_512X256_0 2 /* 512x256 resolution screen 0 */
| 101 |
#define S3_512X256_1 3 /* 512x256 resolution screen 1 */
| 102 |
#define S4_256X256_0 4 /* 256x256 resolution screen 0 */
| 103 |
#define S5_256X256_1 5 /* .... */
| 104 |
#define S6_256X256_2 6
| 105 |
#define S7_256X256_3 7
| 106 |
| 107 |
#define MSK_REGWRITE 0xFFBF /* mask for display register write */
| 108 |
#define SHF_REGWRITE 6
| 109 |
#define REGINDEX 0 /* to write an index value */
| 110 |
#define REGVALUE 1 /* to write a value */
| 111 |
| 112 |
#define MSK_BIT9 0xFF7F /* maks for high-order bit of DR's */
| 113 |
#define SHF_BIT9 7
| 114 |
| 115 |
#define MSK_TAPBITS 0xFCFF /* mask for setting the tap bits */
| 116 |
#define SHF_TAPBITS 8
| 117 |
| 118 |
#define MSK_ZOOM 0xF3FF /* Mask for zoom factor */
| 119 |
#define SHF_ZOOM 10
| 120 |
| 121 |
#define MSK_DISPLAY 0xCFFF /* Mask for display mode */
| 122 |
#define SHF_DISPLAY 12
| 123 |
#define MEMORY_MODE 0
| 124 |
#define LIVE_FIXED 1
| 125 |
#define OVERLAY_MODE 2
| 126 |
#define LIVE_LIVE 3
| 127 |
#define DEF_DISPLAY 0
| 128 |
| 129 |
#define MSK_CAPTURE 0xBFFF /* Mask for capture bit */
| 130 |
#define SHF_CAPTURE 14
| 131 |
| 132 |
#define MSK_GENLOCK 0x7FFF /* MASK FOR GENLOCK */
| 133 |
#define SHF_GENLOCK 15
| 134 |
#define DEF_GENLOCK 0
| 135 |
| 136 |
* Video status input register
| 137 |
| 138 |
#define FIELDBIT 0x0001
| 139 |
#define VIDEOLOSS 0x0002
| 140 |
| 141 |
* VIDEO SOURCE/CONTROL REGISTER
| 142 |
| 143 |
#define MSK_CONTRAST 0xFFC1
| 144 |
#define SHF_CONTRAST 1
| 145 |
#define MAX_CONTRAST 0x1f
| 146 |
| 147 |
#define MSK_RGBORCV 0xBF
| 148 |
#define SHF_RGBORCV 6
| 149 |
#define RGB 1
| 150 |
#define CV 0
| 151 |
| 152 |
#define MSK_VCRORCAMERA 0x7F
| 153 |
#define SHF_VCRORCAMERA 7
| 154 |
#define VCR 1
| 155 |
#define CAMERA 0
| 156 |
| 157 |
| 158 |
* HUE/SATUATION REGISTER
| 159 |
| 160 |
#define MSK_HUE 0xE0
| 161 |
#define SHF_HUE 0
| 162 |
#define MAX_HUE 0x1f
| 163 |
| 164 |
#define MSK_SATURATION 0x1F
| 165 |
#define SHF_SATURATION 5
| 166 |
#define MAX_SATURATION 0x07
| 167 |
| 168 |
| 169 |
| 170 |
| 171 |
* Display register settings
| 172 |
| 173 |
| 174 |
* Screen Positioning Registers:
| 175 |
* DR 0-3
| 176 |
| 177 |
#define LEFTBORDER 0
| 178 |
#define DEF_LEFT 85
| 179 |
#define MIN_LEFT 75
| 180 |
#define MAX_LEFT 95
| 181 |
#define RIGHTBORDER 1
| 182 |
#define DEF_RIGHT (DEF_LEFT+256)
| 183 |
#define TOPBORDER 2
| 184 |
#define DEF_TOP 40
| 185 |
#define MIN_TOP 20
| 186 |
#define BOTTOMBORDER 3
| 187 |
#define DEF_BOTTOM (DEFTOP+DEFROWS/2)
| 188 |
#define MAX_BOTTOM 261
| 189 |
| 190 |
| 191 |
* REgisters which track 0-3
| 192 |
| 193 |
#define DR8 8
| 194 |
#define PRESHIFT DR8
| 195 |
#define EQU_DR8 DR0
| 196 |
#define DR9 9
| 197 |
#define EQU_DR9 DR1
| 198 |
#define DR10 10
| 199 |
#define EQU_DR10 DR2
| 200 |
#define DR11 11
| 201 |
#define EQU_DR11 DR3
| 202 |
| 203 |
| 204 |
* REQUIRED REGISTERS
| 205 |
| 206 |
#define DR4 4
| 207 |
#define DEF_DR4 352
| 208 |
#define DR5 5
| 209 |
#define DEF_DR5 1
| 210 |
#define DR6 6
| 211 |
#define DEF_DR6 0
| 212 |
#define DR7 7
| 213 |
#define DEF_DR7 511
| 214 |
#define DR12 12
| 215 |
#define DEF_DR12 20
| 216 |
#define DR13 13
| 217 |
#define DEF_DR13 22
| 218 |
#define DR14 14
| 219 |
#define DEF_DR14 0
| 220 |
#define DR15 15
| 221 |
#define DEF_DR15 511
| 222 |
#define DR16 16
| 223 |
#define DEF_DR16 0
| 224 |
#define DR17 17
| 225 |
#define DEF_DR17 0
| 226 |
#define DR18 18
| 227 |
#define DEF_DR18 0
| 228 |
#define DR19 19
| 229 |
#define DEF_DR19 4
| 230 |
| 231 |
/* interlace mode register & parameters */
| 232 |
#define DR20 20
| 233 |
#define INTREG 0x14
| 234 |
#define DEF_INT 0 /* default to interlace mode 0 */
| 235 |
#define MSK_INTERLACE 0x0003
| 236 |
| 237 |
| 238 |
| 239 |
struct TARStruct {
| 240 |
/* Board Configuration */
| 241 |
int memloc; /* memory segment */
| 242 |
int iobase; /* IOBASE segment */
| 243 |
int BytesPerPixel; /* number of words per pixel */
| 244 |
int RowsPerBank; /* number of row per 64K bank */
| 245 |
int MaxBanks; /* maximum bank id */
| 246 |
int AddressShift; /* number of bits to shift address */
| 247 |
| 248 |
/* Control registers */
| 249 |
int mode; /* mode register */
| 250 |
int Mask; /* mask register */
| 251 |
int PageMode; /* current page mode (screen res. and page) */
| 252 |
unsigned PageLower; /* Lower Page Select register */
| 253 |
unsigned PageUpper; /* upper Page select register */
| 254 |
int VCRCon; /* VCRContract register */
| 255 |
int SatHue; /* Hue and Saturation register */
| 256 |
long BorderColor; /* Border color register */
| 257 |
int VertShift; /* Vertical Pan Register */
| 258 |
| 259 |
int PanXOrig, PanYOrig; /* x,y pan origin */
| 260 |
| 261 |
/* TARGA-SET PARAMETERS */
| 262 |
int boardType; /* See TYPE_XX IN THIS FILE */
| 263 |
/* FOR DEFINITION OF Board Types */
| 264 |
int xOffset; /* X-offset */
| 265 |
int yOffset; /* Y-Offset */
| 266 |
int LinesPerField; /* maximum visible row count */
| 267 |
int InterlaceMode; /* desired interlace mode */
| 268 |
int AlwaysGenLock; /* Genlock always on or not */
| 269 |
int Contrast; /* Desired Contrast */
| 270 |
int Hue; /* Desired Hue */
| 271 |
int Saturation; /* Desired Satuation */
| 272 |
int RGBorCV; /* CV or RGB Input */
| 273 |
int VCRorCamera; /* VCR or Camera */
| 274 |
int ovrscnAvail, ovrscnOn; /* ovrscnAvail 1 if Overscan installed */
| 275 |
/* ovrscnOn 1 if overscan is stretching */
| 276 |
| 277 |
/* Display Registers */
| 278 |
int DisplayRegister[22];
| 279 |
| 280 |
| 281 |
struct M8Struct {
| 282 |
int there; /* flag to indicate if m8 is present */
| 283 |
/* logical true if M8 present (i.e. 1) */
| 284 |
/* and logical false (0) otherwise */
| 285 |
int inOffset; /* input offset */
| 286 |
int inGain; /* input gain */
| 287 |
int inputMux; /* input channel */
| 288 |
int modeRegister; /* value of the mode register on the M8 top */
| 289 |
int inMap, outMap; /* active input/output color map */
| 290 |
int loopThru; /* logical flag if M8 loop-through is desired */
| 291 |
/* of CGA input 1---YES, 0---No */
| 292 |
int topFunction; /* currently selected top function */
| 293 |
int CGAInterlace; /* interlace mode for a CGA if used */
| 294 |
| 295 |
| 296 |
#define M8MODE 0x400 /* IO Offset for writes to M8 Mode register */
| 297 |
#define M8WRITE 0x402 /* Offset for writes to M8 function registers */
| 298 |
#define M8READ 0x802 /* Offset for reads from M8 function registers */
| 299 |
| 300 |
#define DEF_M8MODE 2
| 301 |
#define DEF_M8GAIN 50
| 302 |
#define DEF_M8OFFSET 50
| 303 |
#define DEF_M8MUX 0
| 304 |
#define DEF_M8INMAP 0
| 305 |
#define DEF_M8OUTMAP 0
| 306 |
#define DEF_CGAINTERLACE 3
| 307 |
| 308 |
| 309 |
struct hdStruct {
| 310 |
char textSize;
| 311 |
char mapType;
| 312 |
char dataType;
| 313 |
int mapOrig;
| 314 |
int mapLength;
| 315 |
char CMapBits;
| 316 |
int XOffset;
| 317 |
int YOffset;
| 318 |
int x;
| 319 |
int y;
| 320 |
int dataBits, imType;
| 321 |
| 322 |
| 323 |
| 324 |
/* stroke font file */
| 325 |
| 326 |
typedef struct{
| 327 |
int width; /* width of character */
| 328 |
int height; /* height of char from baseline */
| 329 |
int descent; /* descent below baseline */
| 330 |
int index; /* index into stroke table */
| 331 |
} SFONTCHAR;
| 332 |
| 333 |
typedef struct {
| 334 |
int dx; /* dx of character */
| 335 |
int dy; /* dy of character */
| 336 |
int dd; /* dy of descenders */
| 337 |
int first; /* value of first char in font */
| 338 |
int last; /* value of last char in font */
| 339 |
int *strokes; /* where the strokes are located */
| 340 |
SFONTCHAR *info; /* info on each character */
| 341 |
} SFONT;
| 342 |
| 343 |
| 344 |
#ifdef __cplusplus
| 345 |
| 346 |
#endif
| 347 |
#endif /* _RAD_TARDEV_H_ */
| 348 |
