root/radiance/ray/src/px/tardev.h
Revision: 1.3
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.2: +1 -4 lines
1 /* RCSid: $Id$ */
2 /*
3 * Board types used for targa->boardType
4 */
5 #define TYPE_8 8
6 #define TYPE_16 16
7 #define TYPE_24 24
8 #define TYPE_32 32
9 #define TYPE_M8 -8
10
11 /*
12 * TARGA: 400 to 482 rows x 512 pixels/row X 16 bits/pixel
13 */
14
15 #define XMIN 0
16 #define YMIN 0
17 #define XMAX 512 /* maximum X value */
18 #define YMAX 512 /* maximum Y value */
19 #define XRES 512 /* X resolution */
20 #define YRES 512 /* Y Resolution */
21 #define YVISMAX (2*targa->LinesPerField) /* Maximum visible Y coordinate */
22 #define YVISMIN 0 /* Minimum visible Y coordiate */
23 #define DEF_ROWS 400 /* Default number of rows */
24
25
26 #define DEF_IOBASE 0x220
27 #define IOBASE targa->iobase /* io base location of graphics registers */
28 #define MEMSEG targa->memloc /* use the variable so we can use */
29 #define SCNSEG targa->memloc /* the one defined in TARGA */
30 #define SRCBANK (targa->memloc+0x0800) /* use high-bank as source bank */
31 #define DESTBANK targa->memloc /* use lo-bank as destination bank */
32 #define DEF_MEMSEG 0xa000 /* Default screen memory */
33
34 /*
35 * Output register definitions
36 */
37 #define MODEREG (IOBASE+0xC00) /* Mode Register address */
38 #define MASKREG (IOBASE+0x800) /* Mask Registers */
39 #define UNDERREG (IOBASE+0x800) /* Underscan register */
40 #define OVERREG (IOBASE+0x802) /* overscan register */
41 #define DESTREG (IOBASE+0x802) /* Address of Page Select Lower Register */
42 #define SRCREG (IOBASE+0x803) /* Address of Page Select Upper Register */
43 #define VCRCON (IOBASE+0x400) /* Address of Contrast/VidSrc Register */
44 #define BLNDREG VCRCON
45 #define SATHUE (IOBASE+0x402) /* Satuation/Hue Register address */
46 #define DRREG (IOBASE+0x401) /* ADDRESS OF Controller Write Register */
47 #define VERTPAN (IOBASE+0x403) /* Address of Vertical Pan Register */
48 #define BORDER (IOBASE) /* Address of Page Select Lower Register */
49
50
51 /*
52 * Input register definitions
53 */
54 #define VIDEOSTATUS (IOBASE+0xC02) /* Video Status Register */
55 #define RASTERREG (IOBASE+0xC00) /* Raster counter register */
56
57
58
59 /*
60 * Default register values
61 */
62 #define DEF_MODE 1 /* Default mode register value */
63 /* Memory selected, 512x512, 1x */
64 /* Display mode */
65 #define DEF_MASK 0 /* default memory mask */
66 #define DEF_SATURATION 0x4 /* default saturation value */
67 #define DEF_HUE 0x10 /* default hue value */
68 #define DEF_CONTRAST 0x10 /* default contrast value */
69 #define DEF_VIDSRC 0 /* default video source value - Composite */
70 #define DEF_VERTPAN 56 /* assumes 400-line output */
71 #define DEF_BORDER 0 /* default border color */
72
73
74 /*
75 * MASK AND SHIFT VALUE FOR REGISTERS CONTAINING SUBFIELDS
76 */
77 /*
78 * ******************************************************
79 * MODE REGISTERS
80 * ******************************************************
81 */
82 #define MSK_MSEL 0xfffC /* memory select bits */
83 #define SHF_MSEL 0x0000
84 #define MSEL 1
85
86 #define MSK_IBIT 0xfffb /* Interlace bit */
87 #define SHF_IBIT 2
88
89 #define MSK_RES 0xFFC7 /* disp. resolution and screen select bits */
90 #define SHF_RES 3
91 #define S0_512X512_0 0 /* 512x512 resolution screen */
92 #define S1_512X512_1 1
93 #define S2_512X256_0 2 /* 512x256 resolution screen 0 */
94 #define S3_512X256_1 3 /* 512x256 resolution screen 1 */
95 #define S4_256X256_0 4 /* 256x256 resolution screen 0 */
96 #define S5_256X256_1 5 /* .... */
97 #define S6_256X256_2 6
98 #define S7_256X256_3 7
99
100 #define MSK_REGWRITE 0xFFBF /* mask for display register write */
101 #define SHF_REGWRITE 6
102 #define REGINDEX 0 /* to write an index value */
103 #define REGVALUE 1 /* to write a value */
104
105 #define MSK_BIT9 0xFF7F /* maks for high-order bit of DR's */
106 #define SHF_BIT9 7
107
108 #define MSK_TAPBITS 0xFCFF /* mask for setting the tap bits */
109 #define SHF_TAPBITS 8
110
111 #define MSK_ZOOM 0xF3FF /* Mask for zoom factor */
112 #define SHF_ZOOM 10
113
114 #define MSK_DISPLAY 0xCFFF /* Mask for display mode */
115 #define SHF_DISPLAY 12
116 #define MEMORY_MODE 0
117 #define LIVE_FIXED 1
118 #define OVERLAY_MODE 2
119 #define LIVE_LIVE 3
120 #define DEF_DISPLAY 0
121
122 #define MSK_CAPTURE 0xBFFF /* Mask for capture bit */
123 #define SHF_CAPTURE 14
124
125 #define MSK_GENLOCK 0x7FFF /* MASK FOR GENLOCK */
126 #define SHF_GENLOCK 15
127 #define DEF_GENLOCK 0
128 /*
129 * Video status input register
130 */
131 #define FIELDBIT 0x0001
132 #define VIDEOLOSS 0x0002
133 /*
134 * VIDEO SOURCE/CONTROL REGISTER
135 */
136 #define MSK_CONTRAST 0xFFC1
137 #define SHF_CONTRAST 1
138 #define MAX_CONTRAST 0x1f
139
140 #define MSK_RGBORCV 0xBF
141 #define SHF_RGBORCV 6
142 #define RGB 1
143 #define CV 0
144
145 #define MSK_VCRORCAMERA 0x7F
146 #define SHF_VCRORCAMERA 7
147 #define VCR 1
148 #define CAMERA 0
149
150 /*
151 * HUE/SATUATION REGISTER
152 */
153 #define MSK_HUE 0xE0
154 #define SHF_HUE 0
155 #define MAX_HUE 0x1f
156
157 #define MSK_SATURATION 0x1F
158 #define SHF_SATURATION 5
159 #define MAX_SATURATION 0x07
160
161
162 /*
163 * *********************************************
164 * Display register settings
165 * *********************************************
166 *
167 * Screen Positioning Registers:
168 * DR 0-3
169 */
170 #define LEFTBORDER 0
171 #define DEF_LEFT 85
172 #define MIN_LEFT 75
173 #define MAX_LEFT 95
174 #define RIGHTBORDER 1
175 #define DEF_RIGHT (DEF_LEFT+256)
176 #define TOPBORDER 2
177 #define DEF_TOP 40
178 #define MIN_TOP 20
179 #define BOTTOMBORDER 3
180 #define DEF_BOTTOM (DEFTOP+DEFROWS/2)
181 #define MAX_BOTTOM 261
182
183 /*
184 * REgisters which track 0-3
185 */
186 #define DR8 8
187 #define PRESHIFT DR8
188 #define EQU_DR8 DR0
189 #define DR9 9
190 #define EQU_DR9 DR1
191 #define DR10 10
192 #define EQU_DR10 DR2
193 #define DR11 11
194 #define EQU_DR11 DR3
195
196 /*
197 * REQUIRED REGISTERS
198 */
199 #define DR4 4
200 #define DEF_DR4 352
201 #define DR5 5
202 #define DEF_DR5 1
203 #define DR6 6
204 #define DEF_DR6 0
205 #define DR7 7
206 #define DEF_DR7 511
207 #define DR12 12
208 #define DEF_DR12 20
209 #define DR13 13
210 #define DEF_DR13 22
211 #define DR14 14
212 #define DEF_DR14 0
213 #define DR15 15
214 #define DEF_DR15 511
215 #define DR16 16
216 #define DEF_DR16 0
217 #define DR17 17
218 #define DEF_DR17 0
219 #define DR18 18
220 #define DEF_DR18 0
221 #define DR19 19
222 #define DEF_DR19 4
223
224 /* interlace mode register & parameters */
225 #define DR20 20
226 #define INTREG 0x14
227 #define DEF_INT 0 /* default to interlace mode 0 */
228 #define MSK_INTERLACE 0x0003
229
230
231
232 struct TARStruct {
233 /* Board Configuration */
234 int memloc; /* memory segment */
235 int iobase; /* IOBASE segment */
236 int BytesPerPixel; /* number of words per pixel */
237 int RowsPerBank; /* number of row per 64K bank */
238 int MaxBanks; /* maximum bank id */
239 int AddressShift; /* number of bits to shift address */
240
241 /* Control registers */
242 int mode; /* mode register */
243 int Mask; /* mask register */
244 int PageMode; /* current page mode (screen res. and page) */
245 unsigned PageLower; /* Lower Page Select register */
246 unsigned PageUpper; /* upper Page select register */
247 int VCRCon; /* VCRContract register */
248 int SatHue; /* Hue and Saturation register */
249 long BorderColor; /* Border color register */
250 int VertShift; /* Vertical Pan Register */
251
252 int PanXOrig, PanYOrig; /* x,y pan origin */
253
254 /* TARGA-SET PARAMETERS */
255 int boardType; /* See TYPE_XX IN THIS FILE */
256 /* FOR DEFINITION OF Board Types */
257 int xOffset; /* X-offset */
258 int yOffset; /* Y-Offset */
259 int LinesPerField; /* maximum visible row count */
260 int InterlaceMode; /* desired interlace mode */
261 int AlwaysGenLock; /* Genlock always on or not */
262 int Contrast; /* Desired Contrast */
263 int Hue; /* Desired Hue */
264 int Saturation; /* Desired Satuation */
265 int RGBorCV; /* CV or RGB Input */
266 int VCRorCamera; /* VCR or Camera */
267 int ovrscnAvail, ovrscnOn; /* ovrscnAvail 1 if Overscan installed */
268 /* ovrscnOn 1 if overscan is stretching */
269
270 /* Display Registers */
271 int DisplayRegister[22];
272 };
273
274 struct M8Struct {
275 int there; /* flag to indicate if m8 is present */
276 /* logical true if M8 present (i.e. 1) */
277 /* and logical false (0) otherwise */
278 int inOffset; /* input offset */
279 int inGain; /* input gain */
280 int inputMux; /* input channel */
281 int modeRegister; /* value of the mode register on the M8 top */
282 int inMap, outMap; /* active input/output color map */
283 int loopThru; /* logical flag if M8 loop-through is desired */
284 /* of CGA input 1---YES, 0---No */
285 int topFunction; /* currently selected top function */
286 int CGAInterlace; /* interlace mode for a CGA if used */
287 };
288
289 #define M8MODE 0x400 /* IO Offset for writes to M8 Mode register */
290 #define M8WRITE 0x402 /* Offset for writes to M8 function registers */
291 #define M8READ 0x802 /* Offset for reads from M8 function registers */
292
293 #define DEF_M8MODE 2
294 #define DEF_M8GAIN 50
295 #define DEF_M8OFFSET 50
296 #define DEF_M8MUX 0
297 #define DEF_M8INMAP 0
298 #define DEF_M8OUTMAP 0
299 #define DEF_CGAINTERLACE 3
300
301
302 struct hdStruct {
303 char textSize;
304 char mapType;
305 char dataType;
306 int mapOrig;
307 int mapLength;
308 char CMapBits;
309 int XOffset;
310 int YOffset;
311 int x;
312 int y;
313 int dataBits, imType;
314 } ;
315
316
317 /* stroke font file */
318
319 typedef struct{
320 int width; /* width of character */
321 int height; /* height of char from baseline */
322 int descent; /* descent below baseline */
323 int index; /* index into stroke table */
324 } SFONTCHAR;
325
326 typedef struct {
327 int dx; /* dx of character */
328 int dy; /* dy of character */
329 int dd; /* dy of descenders */
330 int first; /* value of first char in font */
331 int last; /* value of last char in font */
332 int *strokes; /* where the strokes are located */
333 SFONTCHAR *info; /* info on each character */
334 } SFONT;
