root/radiance/ray/src/px/tardev.h
Revision: 1.4
Committed: Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 1.3: +15 -1 lines
1 /* RCSid: $Id: tardev.h,v 1.3 2003/02/22 02:07:28 greg Exp $ */
2 /*
3 * Board types used for targa->boardType
4 */
5 #ifndef _RAD_TARDEV_H_
6 #define _RAD_TARDEV_H_
7
8 #ifdef __cplusplus
9 extern "C" {
10 #endif
11
12 #define TYPE_8 8
13 #define TYPE_16 16
14 #define TYPE_24 24
15 #define TYPE_32 32
16 #define TYPE_M8 -8
17
18 /*
19 * TARGA: 400 to 482 rows x 512 pixels/row X 16 bits/pixel
20 */
21
22 #define XMIN 0
23 #define YMIN 0
24 #define XMAX 512 /* maximum X value */
25 #define YMAX 512 /* maximum Y value */
26 #define XRES 512 /* X resolution */
27 #define YRES 512 /* Y Resolution */
28 #define YVISMAX (2*targa->LinesPerField) /* Maximum visible Y coordinate */
29 #define YVISMIN 0 /* Minimum visible Y coordiate */
30 #define DEF_ROWS 400 /* Default number of rows */
31
32
33 #define DEF_IOBASE 0x220
34 #define IOBASE targa->iobase /* io base location of graphics registers */
35 #define MEMSEG targa->memloc /* use the variable so we can use */
36 #define SCNSEG targa->memloc /* the one defined in TARGA */
37 #define SRCBANK (targa->memloc+0x0800) /* use high-bank as source bank */
38 #define DESTBANK targa->memloc /* use lo-bank as destination bank */
39 #define DEF_MEMSEG 0xa000 /* Default screen memory */
40
41 /*
42 * Output register definitions
43 */
44 #define MODEREG (IOBASE+0xC00) /* Mode Register address */
45 #define MASKREG (IOBASE+0x800) /* Mask Registers */
46 #define UNDERREG (IOBASE+0x800) /* Underscan register */
47 #define OVERREG (IOBASE+0x802) /* overscan register */
48 #define DESTREG (IOBASE+0x802) /* Address of Page Select Lower Register */
49 #define SRCREG (IOBASE+0x803) /* Address of Page Select Upper Register */
50 #define VCRCON (IOBASE+0x400) /* Address of Contrast/VidSrc Register */
51 #define BLNDREG VCRCON
52 #define SATHUE (IOBASE+0x402) /* Satuation/Hue Register address */
53 #define DRREG (IOBASE+0x401) /* ADDRESS OF Controller Write Register */
54 #define VERTPAN (IOBASE+0x403) /* Address of Vertical Pan Register */
55 #define BORDER (IOBASE) /* Address of Page Select Lower Register */
56
57
58 /*
59 * Input register definitions
60 */
61 #define VIDEOSTATUS (IOBASE+0xC02) /* Video Status Register */
62 #define RASTERREG (IOBASE+0xC00) /* Raster counter register */
63
64
65
66 /*
67 * Default register values
68 */
69 #define DEF_MODE 1 /* Default mode register value */
70 /* Memory selected, 512x512, 1x */
71 /* Display mode */
72 #define DEF_MASK 0 /* default memory mask */
73 #define DEF_SATURATION 0x4 /* default saturation value */
74 #define DEF_HUE 0x10 /* default hue value */
75 #define DEF_CONTRAST 0x10 /* default contrast value */
76 #define DEF_VIDSRC 0 /* default video source value - Composite */
77 #define DEF_VERTPAN 56 /* assumes 400-line output */
78 #define DEF_BORDER 0 /* default border color */
79
80
81 /*
82 * MASK AND SHIFT VALUE FOR REGISTERS CONTAINING SUBFIELDS
83 */
84 /*
85 * ******************************************************
86 * MODE REGISTERS
87 * ******************************************************
88 */
89 #define MSK_MSEL 0xfffC /* memory select bits */
90 #define SHF_MSEL 0x0000
91 #define MSEL 1
92
93 #define MSK_IBIT 0xfffb /* Interlace bit */
94 #define SHF_IBIT 2
95
96 #define MSK_RES 0xFFC7 /* disp. resolution and screen select bits */
97 #define SHF_RES 3
98 #define S0_512X512_0 0 /* 512x512 resolution screen */
99 #define S1_512X512_1 1
100 #define S2_512X256_0 2 /* 512x256 resolution screen 0 */
101 #define S3_512X256_1 3 /* 512x256 resolution screen 1 */
102 #define S4_256X256_0 4 /* 256x256 resolution screen 0 */
103 #define S5_256X256_1 5 /* .... */
104 #define S6_256X256_2 6
105 #define S7_256X256_3 7
106
107 #define MSK_REGWRITE 0xFFBF /* mask for display register write */
108 #define SHF_REGWRITE 6
109 #define REGINDEX 0 /* to write an index value */
110 #define REGVALUE 1 /* to write a value */
111
112 #define MSK_BIT9 0xFF7F /* maks for high-order bit of DR's */
113 #define SHF_BIT9 7
114
115 #define MSK_TAPBITS 0xFCFF /* mask for setting the tap bits */
116 #define SHF_TAPBITS 8
117
118 #define MSK_ZOOM 0xF3FF /* Mask for zoom factor */
119 #define SHF_ZOOM 10
120
121 #define MSK_DISPLAY 0xCFFF /* Mask for display mode */
122 #define SHF_DISPLAY 12
123 #define MEMORY_MODE 0
124 #define LIVE_FIXED 1
125 #define OVERLAY_MODE 2
126 #define LIVE_LIVE 3
127 #define DEF_DISPLAY 0
128
129 #define MSK_CAPTURE 0xBFFF /* Mask for capture bit */
130 #define SHF_CAPTURE 14
131
132 #define MSK_GENLOCK 0x7FFF /* MASK FOR GENLOCK */
133 #define SHF_GENLOCK 15
134 #define DEF_GENLOCK 0
135 /*
136 * Video status input register
137 */
138 #define FIELDBIT 0x0001
139 #define VIDEOLOSS 0x0002
140 /*
141 * VIDEO SOURCE/CONTROL REGISTER
142 */
143 #define MSK_CONTRAST 0xFFC1
144 #define SHF_CONTRAST 1
145 #define MAX_CONTRAST 0x1f
146
147 #define MSK_RGBORCV 0xBF
148 #define SHF_RGBORCV 6
149 #define RGB 1
150 #define CV 0
151
152 #define MSK_VCRORCAMERA 0x7F
153 #define SHF_VCRORCAMERA 7
154 #define VCR 1
155 #define CAMERA 0
156
157 /*
158 * HUE/SATUATION REGISTER
159 */
160 #define MSK_HUE 0xE0
161 #define SHF_HUE 0
162 #define MAX_HUE 0x1f
163
164 #define MSK_SATURATION 0x1F
165 #define SHF_SATURATION 5
166 #define MAX_SATURATION 0x07
167
168
169 /*
170 * *********************************************
171 * Display register settings
172 * *********************************************
173 *
174 * Screen Positioning Registers:
175 * DR 0-3
176 */
177 #define LEFTBORDER 0
178 #define DEF_LEFT 85
179 #define MIN_LEFT 75
180 #define MAX_LEFT 95
181 #define RIGHTBORDER 1
182 #define DEF_RIGHT (DEF_LEFT+256)
183 #define TOPBORDER 2
184 #define DEF_TOP 40
185 #define MIN_TOP 20
186 #define BOTTOMBORDER 3
187 #define DEF_BOTTOM (DEFTOP+DEFROWS/2)
188 #define MAX_BOTTOM 261
189
190 /*
191 * REgisters which track 0-3
192 */
193 #define DR8 8
194 #define PRESHIFT DR8
195 #define EQU_DR8 DR0
196 #define DR9 9
197 #define EQU_DR9 DR1
198 #define DR10 10
199 #define EQU_DR10 DR2
200 #define DR11 11
201 #define EQU_DR11 DR3
202
203 /*
204 * REQUIRED REGISTERS
205 */
206 #define DR4 4
207 #define DEF_DR4 352
208 #define DR5 5
209 #define DEF_DR5 1
210 #define DR6 6
211 #define DEF_DR6 0
212 #define DR7 7
213 #define DEF_DR7 511
214 #define DR12 12
215 #define DEF_DR12 20
216 #define DR13 13
217 #define DEF_DR13 22
218 #define DR14 14
219 #define DEF_DR14 0
220 #define DR15 15
221 #define DEF_DR15 511
222 #define DR16 16
223 #define DEF_DR16 0
224 #define DR17 17
225 #define DEF_DR17 0
226 #define DR18 18
227 #define DEF_DR18 0
228 #define DR19 19
229 #define DEF_DR19 4
230
231 /* interlace mode register & parameters */
232 #define DR20 20
233 #define INTREG 0x14
234 #define DEF_INT 0 /* default to interlace mode 0 */
235 #define MSK_INTERLACE 0x0003
236
237
238
239 struct TARStruct {
240 /* Board Configuration */
241 int memloc; /* memory segment */
242 int iobase; /* IOBASE segment */
243 int BytesPerPixel; /* number of words per pixel */
244 int RowsPerBank; /* number of row per 64K bank */
245 int MaxBanks; /* maximum bank id */
246 int AddressShift; /* number of bits to shift address */
247
248 /* Control registers */
249 int mode; /* mode register */
250 int Mask; /* mask register */
251 int PageMode; /* current page mode (screen res. and page) */
252 unsigned PageLower; /* Lower Page Select register */
253 unsigned PageUpper; /* upper Page select register */
254 int VCRCon; /* VCRContract register */
255 int SatHue; /* Hue and Saturation register */
256 long BorderColor; /* Border color register */
257 int VertShift; /* Vertical Pan Register */
258
259 int PanXOrig, PanYOrig; /* x,y pan origin */
260
261 /* TARGA-SET PARAMETERS */
262 int boardType; /* See TYPE_XX IN THIS FILE */
263 /* FOR DEFINITION OF Board Types */
264 int xOffset; /* X-offset */
265 int yOffset; /* Y-Offset */
266 int LinesPerField; /* maximum visible row count */
267 int InterlaceMode; /* desired interlace mode */
268 int AlwaysGenLock; /* Genlock always on or not */
269 int Contrast; /* Desired Contrast */
270 int Hue; /* Desired Hue */
271 int Saturation; /* Desired Satuation */
272 int RGBorCV; /* CV or RGB Input */
273 int VCRorCamera; /* VCR or Camera */
274 int ovrscnAvail, ovrscnOn; /* ovrscnAvail 1 if Overscan installed */
275 /* ovrscnOn 1 if overscan is stretching */
276
277 /* Display Registers */
278 int DisplayRegister[22];
279 };
280
281 struct M8Struct {
282 int there; /* flag to indicate if m8 is present */
283 /* logical true if M8 present (i.e. 1) */
284 /* and logical false (0) otherwise */
285 int inOffset; /* input offset */
286 int inGain; /* input gain */
287 int inputMux; /* input channel */
288 int modeRegister; /* value of the mode register on the M8 top */
289 int inMap, outMap; /* active input/output color map */
290 int loopThru; /* logical flag if M8 loop-through is desired */
291 /* of CGA input 1---YES, 0---No */
292 int topFunction; /* currently selected top function */
293 int CGAInterlace; /* interlace mode for a CGA if used */
294 };
295
296 #define M8MODE 0x400 /* IO Offset for writes to M8 Mode register */
297 #define M8WRITE 0x402 /* Offset for writes to M8 function registers */
298 #define M8READ 0x802 /* Offset for reads from M8 function registers */
299
300 #define DEF_M8MODE 2
301 #define DEF_M8GAIN 50
302 #define DEF_M8OFFSET 50
303 #define DEF_M8MUX 0
304 #define DEF_M8INMAP 0
305 #define DEF_M8OUTMAP 0
306 #define DEF_CGAINTERLACE 3
307
308
309 struct hdStruct {
310 char textSize;
311 char mapType;
312 char dataType;
313 int mapOrig;
314 int mapLength;
315 char CMapBits;
316 int XOffset;
317 int YOffset;
318 int x;
319 int y;
320 int dataBits, imType;
321 } ;
322
323
324 /* stroke font file */
325
326 typedef struct{
327 int width; /* width of character */
328 int height; /* height of char from baseline */
329 int descent; /* descent below baseline */
330 int index; /* index into stroke table */
331 } SFONTCHAR;
332
333 typedef struct {
334 int dx; /* dx of character */
335 int dy; /* dy of character */
336 int dd; /* dy of descenders */
337 int first; /* value of first char in font */
338 int last; /* value of last char in font */
339 int *strokes; /* where the strokes are located */
340 SFONTCHAR *info; /* info on each character */
341 } SFONT;
342
343
344 #ifdef __cplusplus
345 }
346 #endif
347 #endif /* _RAD_TARDEV_H_ */
348
