root/radiance/ray/src/px/tardev.h
Revision: 1.4
Committed: Mon Jul 14 22:24:00 2003 UTC (21 years, 9 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 1.3: +15 -1 lines
# User Rev Content
1 schorsch 1.4 /* RCSid: $Id: tardev.h,v 1.3 2003/02/22 02:07:28 greg Exp $ */
2 greg 1.1 /*
3     * Board types used for targa->boardType
4     */
5 schorsch 1.4 #ifndef _RAD_TARDEV_H_
6     #define _RAD_TARDEV_H_
7
8     #ifdef __cplusplus
9     extern "C" {
10     #endif
11
12 greg 1.1 #define TYPE_8 8
13     #define TYPE_16 16
14     #define TYPE_24 24
15     #define TYPE_32 32
16     #define TYPE_M8 -8
17
18     /*
19     * TARGA: 400 to 482 rows x 512 pixels/row X 16 bits/pixel
20     */
21
22     #define XMIN 0
23     #define YMIN 0
24     #define XMAX 512 /* maximum X value */
25     #define YMAX 512 /* maximum Y value */
26     #define XRES 512 /* X resolution */
27     #define YRES 512 /* Y Resolution */
28     #define YVISMAX (2*targa->LinesPerField) /* Maximum visible Y coordinate */
29     #define YVISMIN 0 /* Minimum visible Y coordiate */
30     #define DEF_ROWS 400 /* Default number of rows */
31
32
33     #define DEF_IOBASE 0x220
34     #define IOBASE targa->iobase /* io base location of graphics registers */
35     #define MEMSEG targa->memloc /* use the variable so we can use */
36     #define SCNSEG targa->memloc /* the one defined in TARGA */
37     #define SRCBANK (targa->memloc+0x0800) /* use high-bank as source bank */
38     #define DESTBANK targa->memloc /* use lo-bank as destination bank */
39     #define DEF_MEMSEG 0xa000 /* Default screen memory */
40
41     /*
42     * Output register definitions
43     */
44     #define MODEREG (IOBASE+0xC00) /* Mode Register address */
45     #define MASKREG (IOBASE+0x800) /* Mask Registers */
46     #define UNDERREG (IOBASE+0x800) /* Underscan register */
47     #define OVERREG (IOBASE+0x802) /* overscan register */
48     #define DESTREG (IOBASE+0x802) /* Address of Page Select Lower Register */
49     #define SRCREG (IOBASE+0x803) /* Address of Page Select Upper Register */
50     #define VCRCON (IOBASE+0x400) /* Address of Contrast/VidSrc Register */
51     #define BLNDREG VCRCON
52     #define SATHUE (IOBASE+0x402) /* Satuation/Hue Register address */
53     #define DRREG (IOBASE+0x401) /* ADDRESS OF Controller Write Register */
54     #define VERTPAN (IOBASE+0x403) /* Address of Vertical Pan Register */
55     #define BORDER (IOBASE) /* Address of Page Select Lower Register */
56
57
58     /*
59     * Input register definitions
60     */
61     #define VIDEOSTATUS (IOBASE+0xC02) /* Video Status Register */
62     #define RASTERREG (IOBASE+0xC00) /* Raster counter register */
63
64
65
66     /*
67     * Default register values
68     */
69     #define DEF_MODE 1 /* Default mode register value */
70     /* Memory selected, 512x512, 1x */
71     /* Display mode */
72     #define DEF_MASK 0 /* default memory mask */
73     #define DEF_SATURATION 0x4 /* default saturation value */
74     #define DEF_HUE 0x10 /* default hue value */
75     #define DEF_CONTRAST 0x10 /* default contrast value */
76     #define DEF_VIDSRC 0 /* default video source value - Composite */
77     #define DEF_VERTPAN 56 /* assumes 400-line output */
78     #define DEF_BORDER 0 /* default border color */
79
80
81     /*
82     * MASK AND SHIFT VALUE FOR REGISTERS CONTAINING SUBFIELDS
83     */
84     /*
85     * ******************************************************
86     * MODE REGISTERS
87     * ******************************************************
88     */
89     #define MSK_MSEL 0xfffC /* memory select bits */
90     #define SHF_MSEL 0x0000
91     #define MSEL 1
92
93     #define MSK_IBIT 0xfffb /* Interlace bit */
94     #define SHF_IBIT 2
95
96     #define MSK_RES 0xFFC7 /* disp. resolution and screen select bits */
97     #define SHF_RES 3
98     #define S0_512X512_0 0 /* 512x512 resolution screen */
99     #define S1_512X512_1 1
100     #define S2_512X256_0 2 /* 512x256 resolution screen 0 */
101     #define S3_512X256_1 3 /* 512x256 resolution screen 1 */
102     #define S4_256X256_0 4 /* 256x256 resolution screen 0 */
103     #define S5_256X256_1 5 /* .... */
104     #define S6_256X256_2 6
105     #define S7_256X256_3 7
106
107     #define MSK_REGWRITE 0xFFBF /* mask for display register write */
108     #define SHF_REGWRITE 6
109     #define REGINDEX 0 /* to write an index value */
110     #define REGVALUE 1 /* to write a value */
111
112     #define MSK_BIT9 0xFF7F /* maks for high-order bit of DR's */
113     #define SHF_BIT9 7
114
115     #define MSK_TAPBITS 0xFCFF /* mask for setting the tap bits */
116     #define SHF_TAPBITS 8
117
118     #define MSK_ZOOM 0xF3FF /* Mask for zoom factor */
119     #define SHF_ZOOM 10
120
121     #define MSK_DISPLAY 0xCFFF /* Mask for display mode */
122     #define SHF_DISPLAY 12
123     #define MEMORY_MODE 0
124     #define LIVE_FIXED 1
125     #define OVERLAY_MODE 2
126     #define LIVE_LIVE 3
127     #define DEF_DISPLAY 0
128
129     #define MSK_CAPTURE 0xBFFF /* Mask for capture bit */
130     #define SHF_CAPTURE 14
131
132     #define MSK_GENLOCK 0x7FFF /* MASK FOR GENLOCK */
133     #define SHF_GENLOCK 15
134     #define DEF_GENLOCK 0
135     /*
136     * Video status input register
137     */
138     #define FIELDBIT 0x0001
139     #define VIDEOLOSS 0x0002
140     /*
141     * VIDEO SOURCE/CONTROL REGISTER
142     */
143     #define MSK_CONTRAST 0xFFC1
144     #define SHF_CONTRAST 1
145     #define MAX_CONTRAST 0x1f
146
147     #define MSK_RGBORCV 0xBF
148     #define SHF_RGBORCV 6
149     #define RGB 1
150     #define CV 0
151
152     #define MSK_VCRORCAMERA 0x7F
153     #define SHF_VCRORCAMERA 7
154     #define VCR 1
155     #define CAMERA 0
156
157     /*
158     * HUE/SATUATION REGISTER
159     */
160     #define MSK_HUE 0xE0
161     #define SHF_HUE 0
162     #define MAX_HUE 0x1f
163
164     #define MSK_SATURATION 0x1F
165     #define SHF_SATURATION 5
166     #define MAX_SATURATION 0x07
167
168
169     /*
170     * *********************************************
171     * Display register settings
172     * *********************************************
173     *
174     * Screen Positioning Registers:
175     * DR 0-3
176     */
177     #define LEFTBORDER 0
178     #define DEF_LEFT 85
179     #define MIN_LEFT 75
180     #define MAX_LEFT 95
181     #define RIGHTBORDER 1
182     #define DEF_RIGHT (DEF_LEFT+256)
183     #define TOPBORDER 2
184     #define DEF_TOP 40
185     #define MIN_TOP 20
186     #define BOTTOMBORDER 3
187     #define DEF_BOTTOM (DEFTOP+DEFROWS/2)
188     #define MAX_BOTTOM 261
189
190     /*
191     * REgisters which track 0-3
192     */
193     #define DR8 8
194     #define PRESHIFT DR8
195     #define EQU_DR8 DR0
196     #define DR9 9
197     #define EQU_DR9 DR1
198     #define DR10 10
199     #define EQU_DR10 DR2
200     #define DR11 11
201     #define EQU_DR11 DR3
202
203     /*
204     * REQUIRED REGISTERS
205     */
206     #define DR4 4
207     #define DEF_DR4 352
208     #define DR5 5
209     #define DEF_DR5 1
210     #define DR6 6
211     #define DEF_DR6 0
212     #define DR7 7
213     #define DEF_DR7 511
214     #define DR12 12
215     #define DEF_DR12 20
216     #define DR13 13
217     #define DEF_DR13 22
218     #define DR14 14
219     #define DEF_DR14 0
220     #define DR15 15
221     #define DEF_DR15 511
222     #define DR16 16
223     #define DEF_DR16 0
224     #define DR17 17
225     #define DEF_DR17 0
226     #define DR18 18
227     #define DEF_DR18 0
228     #define DR19 19
229     #define DEF_DR19 4
230
231     /* interlace mode register & parameters */
232     #define DR20 20
233     #define INTREG 0x14
234     #define DEF_INT 0 /* default to interlace mode 0 */
235     #define MSK_INTERLACE 0x0003
236
237
238
239     struct TARStruct {
240     /* Board Configuration */
241     int memloc; /* memory segment */
242     int iobase; /* IOBASE segment */
243     int BytesPerPixel; /* number of words per pixel */
244     int RowsPerBank; /* number of row per 64K bank */
245     int MaxBanks; /* maximum bank id */
246     int AddressShift; /* number of bits to shift address */
247
248     /* Control registers */
249     int mode; /* mode register */
250     int Mask; /* mask register */
251     int PageMode; /* current page mode (screen res. and page) */
252     unsigned PageLower; /* Lower Page Select register */
253     unsigned PageUpper; /* upper Page select register */
254     int VCRCon; /* VCRContract register */
255     int SatHue; /* Hue and Saturation register */
256     long BorderColor; /* Border color register */
257     int VertShift; /* Vertical Pan Register */
258
259     int PanXOrig, PanYOrig; /* x,y pan origin */
260
261     /* TARGA-SET PARAMETERS */
262     int boardType; /* See TYPE_XX IN THIS FILE */
263     /* FOR DEFINITION OF Board Types */
264     int xOffset; /* X-offset */
265     int yOffset; /* Y-Offset */
266     int LinesPerField; /* maximum visible row count */
267     int InterlaceMode; /* desired interlace mode */
268     int AlwaysGenLock; /* Genlock always on or not */
269     int Contrast; /* Desired Contrast */
270     int Hue; /* Desired Hue */
271     int Saturation; /* Desired Satuation */
272     int RGBorCV; /* CV or RGB Input */
273     int VCRorCamera; /* VCR or Camera */
274     int ovrscnAvail, ovrscnOn; /* ovrscnAvail 1 if Overscan installed */
275     /* ovrscnOn 1 if overscan is stretching */
276
277     /* Display Registers */
278     int DisplayRegister[22];
279     };
280
281     struct M8Struct {
282     int there; /* flag to indicate if m8 is present */
283     /* logical true if M8 present (i.e. 1) */
284     /* and logical false (0) otherwise */
285     int inOffset; /* input offset */
286     int inGain; /* input gain */
287     int inputMux; /* input channel */
288     int modeRegister; /* value of the mode register on the M8 top */
289     int inMap, outMap; /* active input/output color map */
290     int loopThru; /* logical flag if M8 loop-through is desired */
291     /* of CGA input 1---YES, 0---No */
292     int topFunction; /* currently selected top function */
293     int CGAInterlace; /* interlace mode for a CGA if used */
294     };
295
296     #define M8MODE 0x400 /* IO Offset for writes to M8 Mode register */
297     #define M8WRITE 0x402 /* Offset for writes to M8 function registers */
298     #define M8READ 0x802 /* Offset for reads from M8 function registers */
299
300     #define DEF_M8MODE 2
301     #define DEF_M8GAIN 50
302     #define DEF_M8OFFSET 50
303     #define DEF_M8MUX 0
304     #define DEF_M8INMAP 0
305     #define DEF_M8OUTMAP 0
306     #define DEF_CGAINTERLACE 3
307
308
309     struct hdStruct {
310     char textSize;
311     char mapType;
312     char dataType;
313     int mapOrig;
314     int mapLength;
315     char CMapBits;
316     int XOffset;
317     int YOffset;
318     int x;
319     int y;
320     int dataBits, imType;
321     } ;
322
323
324     /* stroke font file */
325
326     typedef struct{
327     int width; /* width of character */
328     int height; /* height of char from baseline */
329     int descent; /* descent below baseline */
330     int index; /* index into stroke table */
331     } SFONTCHAR;
332
333     typedef struct {
334     int dx; /* dx of character */
335     int dy; /* dy of character */
336     int dd; /* dy of descenders */
337     int first; /* value of first char in font */
338     int last; /* value of last char in font */
339     int *strokes; /* where the strokes are located */
340     SFONTCHAR *info; /* info on each character */
341     } SFONT;
342 schorsch 1.4
343
344     #ifdef __cplusplus
345     }
346     #endif
347     #endif /* _RAD_TARDEV_H_ */
348
