root/radiance/ray/src/px/slide.c
Revision: 1.2
Committed: Thu Feb 2 14:10:41 1989 UTC (35 years, 3 months ago) by greg
Fixed SCCSid
1 /* Copyright 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * slide.c - driver for dicomed film recorder using GRAFPAC under VMS.
9 *
10 * 2/19/86
11 *
12 * Version for color slide ouput.
13 * Link with grafpac driver "DS":
14 * link slide.obj,color.obj,sys_grafpac:ds/lib
15 */
16
17 #include <stdio.h>
18
19 #include "color.h"
20
21 #include "random.h"
22
23
24 #define XSIZE 4096 /* device width */
25 #define YSIZE 4096 /* device length */
26
27 #define NCOLS 4018 /* maximum # columns for output */
28 #define NROWS 2712 /* maximum # rows for output */
29
30 #define XCENTER 2048 /* center for x */
31 #define YCENTER 2048 /* center for y */
32
33 int nrows; /* number of rows for output */
34 int ncols; /* number of columns for output */
35
36 int xoffset; /* offset for x */
37 int yoffset; /* offset for y */
38
39 #define RSIZ 17 /* size of response map */
40
41 float rmap[2*RSIZ] = { /* response map */
42 .0, .0,
43 .0004, .059,
44 .0008, .122,
45 .0018, .184,
46 .0033, .247,
47 .0061, .310,
48 .0119, .373,
49 .0202, .435,
50 .0373, .498,
51 .065, .561,
52 .113, .624,
53 .199, .686,
54 .300, .749,
55 .432, .812,
56 .596, .875,
57 .767, .937,
58 1.000, 1.000,
59 };
60
61
62 main(argc, argv)
63 int argc;
64 char **argv;
65 {
66 extern char *malloc();
67 FILE *fin;
68 COLOR scanline[NCOLS];
69 int mult;
70 char sbuf[128];
71 int i, j;
72
73 /*
74 for (i = 1; i < argc; i++)
75 if (argv[i][0] == '-')
76 switch (argv[i][1]) {
77 default:
78 fprintf(stderr, "unknown option: %s\n", argv[i]);
79 exit(1);
80 break;
81 }
82 else
83 break;
84
85 */
86 argc = 2;
87 argv[1] = "pixfile";
88 i = 1;
89
90 if (argc - i < 1)
91 fin = 0;
92 else if ((fin = fopen(argv[i], "r")) == NULL) {
93 fprintf(stderr, "%s: can't open file \"%s\"\n",
94 argv[0], argv[i]);
95 exit(1);
96 }
97
98 /* discard header */
99 while (fgets(sbuf, sizeof(sbuf), fin) != NULL && sbuf[0] != '\n')
100 ;
101 /* get picture size */
102 if (fgets(sbuf, sizeof(sbuf), fin) == NULL ||
103 sscanf(sbuf, "-Y %d +X %d\n", &nrows, &ncols) != 2) {
104 fprintf(stderr, "%s: bad picture size\n", argv[0]);
105 exit(1);
106 }
107
108 if (ncols > NCOLS || nrows > NROWS) {
109 fprintf(stderr, "%s: resolution mismatch\n", argv[0]);
110 exit(1);
111 }
112
113 mult = NCOLS/ncols;
114 if (NROWS/nrows < mult)
115 mult = NROWS/nrows;
116
117 xoffset = XCENTER/mult - ncols/2;
118 yoffset = YCENTER/mult - nrows/2;
119
120 tvinit();
121 i = XSIZE/mult; j = YSIZE/mult; tvvrs(&i, &j);
122 i = 12; tvset("ifile", &i);
123 tvset("nrco", "rgb");
124
125 for (i = nrows-1; i >= 0; i--) {
126 if (freadscan(scanline, ncols, fin) < 0) {
127 fprintf(stderr, "%s: read error in row %d\n",
128 argv[0], i);
129 exit(1);
130 }
131 scanout(scanline, i);
132 }
133
134 tvsend();
135 tvend();
136
137 return(0);
138 }
139
140
141 scanout(scan, y) /* output scan line */
142 register COLOR *scan;
143 int y;
144 {
145 static int zero;
146 static float rgb[3][NCOLS];
147 int i;
148 register int j;
149
150 zero = xoffset;
151 y += yoffset;
152
153 for (j = 0; j < ncols; j++) {
154 mapcolor(scan[j], scan[j]);
155 for (i = 0; i < 3; i++)
156 rgb[i][j] = scan[j][i] + (.5-frandom())/255.0;
157 }
158 tvrstc(&zero, &y, rgb[0], rgb[1], rgb[2], &ncols);
159 }
160
161
162 mapcolor(c1, c2) /* map c1 into c2 */
163 register COLOR c1;
164 COLOR c2;
165 {
166 static float *mp[3] = {rmap, rmap, rmap};
167 double x;
168 register int i;
169
170 for (i = 0; i < 3; i++) {
171 if (colval(c1,i) >= 1.0) {
172 colval(c2,i) = 1.0;
173 continue;
174 }
175 while (colval(c1,i) >= mp[i][2])
176 mp[i] += 2;
177 while (colval(c1,i) < mp[i][0])
178 mp[i] -= 2;
179 x = (colval(c1,i) - mp[i][0]) / (mp[i][2] - mp[i][0]);
180 colval(c2,i) = (1.0-x)*mp[i][1] + x*mp[i][3];
181 }
182 }
