root/radiance/ray/src/px/slide.c
Revision: 1.1
Committed: Thu Feb 2 10:49:39 1989 UTC (35 years, 4 months ago) by greg
1 /*
2
3 #ifndef lint
5 #endif
6 * slide.c - driver for dicomed film recorder using GRAFPAC under VMS.
7 *
8 * 2/19/86
9 *
10 * Version for color slide ouput.
11 * Link with grafpac driver "DS":
12 * link slide.obj,color.obj,sys_grafpac:ds/lib
13 */
14
15 #include <stdio.h>
16
17 #include "color.h"
18
19 #include "random.h"
20
21
22 #define XSIZE 4096 /* device width */
23 #define YSIZE 4096 /* device length */
24
25 #define NCOLS 4018 /* maximum # columns for output */
26 #define NROWS 2712 /* maximum # rows for output */
27
28 #define XCENTER 2048 /* center for x */
29 #define YCENTER 2048 /* center for y */
30
31 int nrows; /* number of rows for output */
32 int ncols; /* number of columns for output */
33
34 int xoffset; /* offset for x */
35 int yoffset; /* offset for y */
36
37 #define RSIZ 17 /* size of response map */
38
39 float rmap[2*RSIZ] = { /* response map */
40 .0, .0,
41 .0004, .059,
42 .0008, .122,
43 .0018, .184,
44 .0033, .247,
45 .0061, .310,
46 .0119, .373,
47 .0202, .435,
48 .0373, .498,
49 .065, .561,
50 .113, .624,
51 .199, .686,
52 .300, .749,
53 .432, .812,
54 .596, .875,
55 .767, .937,
56 1.000, 1.000,
57 };
58
59
60 main(argc, argv)
61 int argc;
62 char **argv;
63 {
64 extern char *malloc();
65 FILE *fin;
66 COLOR scanline[NCOLS];
67 int mult;
68 char sbuf[128];
69 int i, j;
70
71 /*
72 for (i = 1; i < argc; i++)
73 if (argv[i][0] == '-')
74 switch (argv[i][1]) {
75 default:
76 fprintf(stderr, "unknown option: %s\n", argv[i]);
77 exit(1);
78 break;
79 }
80 else
81 break;
82
83 */
84 argc = 2;
85 argv[1] = "pixfile";
86 i = 1;
87
88 if (argc - i < 1)
89 fin = 0;
90 else if ((fin = fopen(argv[i], "r")) == NULL) {
91 fprintf(stderr, "%s: can't open file \"%s\"\n",
92 argv[0], argv[i]);
93 exit(1);
94 }
95
96 /* discard header */
97 while (fgets(sbuf, sizeof(sbuf), fin) != NULL && sbuf[0] != '\n')
98 ;
99 /* get picture size */
100 if (fgets(sbuf, sizeof(sbuf), fin) == NULL ||
101 sscanf(sbuf, "-Y %d +X %d\n", &nrows, &ncols) != 2) {
102 fprintf(stderr, "%s: bad picture size\n", argv[0]);
103 exit(1);
104 }
105
106 if (ncols > NCOLS || nrows > NROWS) {
107 fprintf(stderr, "%s: resolution mismatch\n", argv[0]);
108 exit(1);
109 }
110
111 mult = NCOLS/ncols;
112 if (NROWS/nrows < mult)
113 mult = NROWS/nrows;
114
115 xoffset = XCENTER/mult - ncols/2;
116 yoffset = YCENTER/mult - nrows/2;
117
118 tvinit();
119 i = XSIZE/mult; j = YSIZE/mult; tvvrs(&i, &j);
120 i = 12; tvset("ifile", &i);
121 tvset("nrco", "rgb");
122
123 for (i = nrows-1; i >= 0; i--) {
124 if (freadscan(scanline, ncols, fin) < 0) {
125 fprintf(stderr, "%s: read error in row %d\n",
126 argv[0], i);
127 exit(1);
128 }
129 scanout(scanline, i);
130 }
131
132 tvsend();
133 tvend();
134
135 return(0);
136 }
137
138
139 scanout(scan, y) /* output scan line */
140 register COLOR *scan;
141 int y;
142 {
143 static int zero;
144 static float rgb[3][NCOLS];
145 int i;
146 register int j;
147
148 zero = xoffset;
149 y += yoffset;
150
151 for (j = 0; j < ncols; j++) {
152 mapcolor(scan[j], scan[j]);
153 for (i = 0; i < 3; i++)
154 rgb[i][j] = scan[j][i] + (.5-frandom())/255.0;
155 }
156 tvrstc(&zero, &y, rgb[0], rgb[1], rgb[2], &ncols);
157 }
158
159
160 mapcolor(c1, c2) /* map c1 into c2 */
161 register COLOR c1;
162 COLOR c2;
163 {
164 static float *mp[3] = {rmap, rmap, rmap};
165 double x;
166 register int i;
167
168 for (i = 0; i < 3; i++) {
169 if (colval(c1,i) >= 1.0) {
170 colval(c2,i) = 1.0;
171 continue;
172 }
173 while (colval(c1,i) >= mp[i][2])
174 mp[i] += 2;
175 while (colval(c1,i) < mp[i][0])
176 mp[i] -= 2;
177 x = (colval(c1,i) - mp[i][0]) / (mp[i][2] - mp[i][0]);
178 colval(c2,i) = (1.0-x)*mp[i][1] + x*mp[i][3];
179 }
180 }
