root/radiance/ray/src/px/slide.c
Revision: 1.4
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: slide.c,v 1.3 2003/02/22 02:07:28 greg Exp $";
5 * slide.c - driver for dicomed film recorder using GRAFPAC under VMS.
6 *
7 * 2/19/86
8 *
9 * Version for color slide ouput.
10 * Link with grafpac driver "DS":
11 * link slide.obj,color.obj,sys_grafpac:ds/lib
12 */
13
14 #include <stdio.h>
15
16 #include "color.h"
17
18 #include "random.h"
19
20
21 #define XSIZE 4096 /* device width */
22 #define YSIZE 4096 /* device length */
23
24 #define NCOLS 4018 /* maximum # columns for output */
25 #define NROWS 2712 /* maximum # rows for output */
26
27 #define XCENTER 2048 /* center for x */
28 #define YCENTER 2048 /* center for y */
29
30 int nrows; /* number of rows for output */
31 int ncols; /* number of columns for output */
32
33 int xoffset; /* offset for x */
34 int yoffset; /* offset for y */
35
36 #define RSIZ 17 /* size of response map */
37
38 float rmap[2*RSIZ] = { /* response map */
39 .0, .0,
40 .0004, .059,
41 .0008, .122,
42 .0018, .184,
43 .0033, .247,
44 .0061, .310,
45 .0119, .373,
46 .0202, .435,
47 .0373, .498,
48 .065, .561,
49 .113, .624,
50 .199, .686,
51 .300, .749,
52 .432, .812,
53 .596, .875,
54 .767, .937,
55 1.000, 1.000,
56 };
57
58
59 main(argc, argv)
60 int argc;
61 char **argv;
62 {
63 FILE *fin;
64 COLOR scanline[NCOLS];
65 int mult;
66 char sbuf[128];
67 int i, j;
68
69 /*
70 for (i = 1; i < argc; i++)
71 if (argv[i][0] == '-')
72 switch (argv[i][1]) {
73 default:
74 fprintf(stderr, "unknown option: %s\n", argv[i]);
75 exit(1);
76 break;
77 }
78 else
79 break;
80
81 */
82 argc = 2;
83 argv[1] = "pixfile";
84 i = 1;
85
86 if (argc - i < 1)
87 fin = 0;
88 else if ((fin = fopen(argv[i], "r")) == NULL) {
89 fprintf(stderr, "%s: can't open file \"%s\"\n",
90 argv[0], argv[i]);
91 exit(1);
92 }
93
94 /* discard header */
95 while (fgets(sbuf, sizeof(sbuf), fin) != NULL && sbuf[0] != '\n')
96 ;
97 /* get picture size */
98 if (fgets(sbuf, sizeof(sbuf), fin) == NULL ||
99 sscanf(sbuf, "-Y %d +X %d\n", &nrows, &ncols) != 2) {
100 fprintf(stderr, "%s: bad picture size\n", argv[0]);
101 exit(1);
102 }
103
104 if (ncols > NCOLS || nrows > NROWS) {
105 fprintf(stderr, "%s: resolution mismatch\n", argv[0]);
106 exit(1);
107 }
108
109 mult = NCOLS/ncols;
110 if (NROWS/nrows < mult)
111 mult = NROWS/nrows;
112
113 xoffset = XCENTER/mult - ncols/2;
114 yoffset = YCENTER/mult - nrows/2;
115
116 tvinit();
117 i = XSIZE/mult; j = YSIZE/mult; tvvrs(&i, &j);
118 i = 12; tvset("ifile", &i);
119 tvset("nrco", "rgb");
120
121 for (i = nrows-1; i >= 0; i--) {
122 if (freadscan(scanline, ncols, fin) < 0) {
123 fprintf(stderr, "%s: read error in row %d\n",
124 argv[0], i);
125 exit(1);
126 }
127 scanout(scanline, i);
128 }
129
130 tvsend();
131 tvend();
132
133 return(0);
134 }
135
136
137 scanout(scan, y) /* output scan line */
138 register COLOR *scan;
139 int y;
140 {
141 static int zero;
142 static float rgb[3][NCOLS];
143 int i;
144 register int j;
145
146 zero = xoffset;
147 y += yoffset;
148
149 for (j = 0; j < ncols; j++) {
150 mapcolor(scan[j], scan[j]);
151 for (i = 0; i < 3; i++)
152 rgb[i][j] = scan[j][i] + (.5-frandom())/255.0;
153 }
154 tvrstc(&zero, &y, rgb[0], rgb[1], rgb[2], &ncols);
155 }
156
157
158 mapcolor(c1, c2) /* map c1 into c2 */
159 register COLOR c1;
160 COLOR c2;
161 {
162 static float *mp[3] = {rmap, rmap, rmap};
163 double x;
164 register int i;
165
166 for (i = 0; i < 3; i++) {
167 if (colval(c1,i) >= 1.0) {
168 colval(c2,i) = 1.0;
169 continue;
170 }
171 while (colval(c1,i) >= mp[i][2])
172 mp[i] += 2;
173 while (colval(c1,i) < mp[i][0])
174 mp[i] -= 2;
175 x = (colval(c1,i) - mp[i][0]) / (mp[i][2] - mp[i][0]);
176 colval(c2,i) = (1.0-x)*mp[i][1] + x*mp[i][3];
177 }
178 }
