| 1 |
/* RCSid: $Id: rasterfile.h,v 3.1 2003/02/22 02:07:28 greg Exp $ */
| 2 |
/* @(#)rasterfile.h 1.11 89/08/21 SMI */
| 3 |
| 4 |
| 5 |
* Description of header for files containing raster images
| 6 |
| 7 |
#ifndef _RAD_RASTERFILE_H_
| 8 |
#define _RAD_RASTERFILE_H_
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
| 14 |
struct rasterfile {
| 15 |
int ras_magic; /* magic number */
| 16 |
int ras_width; /* width (pixels) of image */
| 17 |
int ras_height; /* height (pixels) of image */
| 18 |
int ras_depth; /* depth (1, 8, or 24 bits) of pixel */
| 19 |
int ras_length; /* length (bytes) of image */
| 20 |
int ras_type; /* type of file; see RT_* below */
| 21 |
int ras_maptype; /* type of colormap; see RMT_* below */
| 22 |
int ras_maplength; /* length (bytes) of following map */
| 23 |
/* color map follows for ras_maplength bytes, followed by image */
| 24 |
| 25 |
#define RAS_MAGIC 0x59a66a95
| 26 |
| 27 |
/* Sun supported ras_type's */
| 28 |
#define RT_OLD 0 /* Raw pixrect image in 68000 byte order */
| 29 |
#define RT_STANDARD 1 /* Raw pixrect image in 68000 byte order */
| 30 |
#define RT_BYTE_ENCODED 2 /* Run-length compression of bytes */
| 31 |
#define RT_FORMAT_RGB 3 /* XRGB or RGB instead of XBGR or BGR */
| 32 |
#define RT_FORMAT_TIFF 4 /* tiff <-> standard rasterfile */
| 33 |
#define RT_FORMAT_IFF 5 /* iff (TAAC format) <-> standard rasterfile */
| 34 |
#define RT_EXPERIMENTAL 0xffff /* Reserved for testing */
| 35 |
| 36 |
/* Sun registered ras_maptype's */
| 37 |
#define RMT_RAW 2
| 38 |
/* Sun supported ras_maptype's */
| 39 |
#define RMT_NONE 0 /* ras_maplength is expected to be 0 */
| 40 |
#define RMT_EQUAL_RGB 1 /* red[ras_maplength/3],green[],blue[] */
| 41 |
| 42 |
| 43 |
* NOTES:
| 44 |
* Each line of the image is rounded out to a multiple of 16 bits.
| 45 |
* This corresponds to the rounding convention used by the memory pixrect
| 46 |
* package (/usr/include/pixrect/memvar.h) of the SunWindows system.
| 47 |
* The ras_encoding field (always set to 0 by Sun's supported software)
| 48 |
* was renamed to ras_length in release 2.0. As a result, rasterfiles
| 49 |
* of type 0 generated by the old software claim to have 0 length; for
| 50 |
* compatibility, code reading rasterfiles must be prepared to compute the
| 51 |
* true length from the width, height, and depth fields.
| 52 |
| 53 |
| 54 |
#ifdef __cplusplus
| 55 |
| 56 |
#endif
| 57 |
#endif /* _RAD_RASTERFILE_H_ */
| 58 |
