1 |
greg |
3.3 |
/* RCSid: $Id: rasterfile.h,v 3.2 2003/07/14 22:24:00 schorsch Exp $ */ |
2 |
greg |
3.1 |
/* @(#)rasterfile.h 1.11 89/08/21 SMI */ |
3 |
4 |
5 |
* Description of header for files containing raster images |
6 |
7 |
schorsch |
3.2 |
#ifndef _RAD_RASTERFILE_H_ |
8 |
#define _RAD_RASTERFILE_H_ |
9 |
greg |
3.1 |
10 |
schorsch |
3.2 |
#ifdef __cplusplus |
11 |
extern "C" { |
12 |
#endif |
13 |
greg |
3.1 |
14 |
struct rasterfile { |
15 |
int ras_magic; /* magic number */ |
16 |
int ras_width; /* width (pixels) of image */ |
17 |
int ras_height; /* height (pixels) of image */ |
18 |
int ras_depth; /* depth (1, 8, or 24 bits) of pixel */ |
19 |
int ras_length; /* length (bytes) of image */ |
20 |
int ras_type; /* type of file; see RT_* below */ |
21 |
int ras_maptype; /* type of colormap; see RMT_* below */ |
22 |
int ras_maplength; /* length (bytes) of following map */ |
23 |
/* color map follows for ras_maplength bytes, followed by image */ |
24 |
25 |
#define RAS_MAGIC 0x59a66a95 |
26 |
27 |
/* Sun supported ras_type's */ |
28 |
#define RT_OLD 0 /* Raw pixrect image in 68000 byte order */ |
29 |
#define RT_STANDARD 1 /* Raw pixrect image in 68000 byte order */ |
30 |
#define RT_BYTE_ENCODED 2 /* Run-length compression of bytes */ |
31 |
#define RT_FORMAT_RGB 3 /* XRGB or RGB instead of XBGR or BGR */ |
32 |
#define RT_FORMAT_TIFF 4 /* tiff <-> standard rasterfile */ |
33 |
#define RT_FORMAT_IFF 5 /* iff (TAAC format) <-> standard rasterfile */ |
34 |
#define RT_EXPERIMENTAL 0xffff /* Reserved for testing */ |
35 |
36 |
/* Sun registered ras_maptype's */ |
37 |
#define RMT_RAW 2 |
38 |
/* Sun supported ras_maptype's */ |
39 |
#define RMT_NONE 0 /* ras_maplength is expected to be 0 */ |
40 |
#define RMT_EQUAL_RGB 1 /* red[ras_maplength/3],green[],blue[] */ |
41 |
42 |
43 |
* NOTES: |
44 |
* Each line of the image is rounded out to a multiple of 16 bits. |
45 |
* This corresponds to the rounding convention used by the memory pixrect |
46 |
* package (/usr/include/pixrect/memvar.h) of the SunWindows system. |
47 |
* The ras_encoding field (always set to 0 by Sun's supported software) |
48 |
* was renamed to ras_length in release 2.0. As a result, rasterfiles |
49 |
* of type 0 generated by the old software claim to have 0 length; for |
50 |
* compatibility, code reading rasterfiles must be prepared to compute the |
51 |
* true length from the width, height, and depth fields. |
52 |
53 |
54 |
schorsch |
3.2 |
55 |
56 |
#endif |
57 |
#endif /* _RAD_RASTERFILE_H_ */ |
58 |
