root/radiance/ray/src/px/rasterfile.h
Revision: 3.3
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 6 months ago) by greg
Changes since 3.2: +1 -1 lines
State: FILE REMOVED
# User Rev Content
1 greg 3.3 /* RCSid: $Id: rasterfile.h,v 3.2 2003/07/14 22:24:00 schorsch Exp $ */
2 greg 3.1 /* @(#)rasterfile.h 1.11 89/08/21 SMI */
3
4     /*
5     * Description of header for files containing raster images
6     */
7 schorsch 3.2 #ifndef _RAD_RASTERFILE_H_
8     #define _RAD_RASTERFILE_H_
9 greg 3.1
10 schorsch 3.2 #ifdef __cplusplus
11     extern "C" {
12     #endif
13 greg 3.1
14     struct rasterfile {
15     int ras_magic; /* magic number */
16     int ras_width; /* width (pixels) of image */
17     int ras_height; /* height (pixels) of image */
18     int ras_depth; /* depth (1, 8, or 24 bits) of pixel */
19     int ras_length; /* length (bytes) of image */
20     int ras_type; /* type of file; see RT_* below */
21     int ras_maptype; /* type of colormap; see RMT_* below */
22     int ras_maplength; /* length (bytes) of following map */
23     /* color map follows for ras_maplength bytes, followed by image */
24     };
25     #define RAS_MAGIC 0x59a66a95
26
27     /* Sun supported ras_type's */
28     #define RT_OLD 0 /* Raw pixrect image in 68000 byte order */
29     #define RT_STANDARD 1 /* Raw pixrect image in 68000 byte order */
30     #define RT_BYTE_ENCODED 2 /* Run-length compression of bytes */
31     #define RT_FORMAT_RGB 3 /* XRGB or RGB instead of XBGR or BGR */
32     #define RT_FORMAT_TIFF 4 /* tiff <-> standard rasterfile */
33     #define RT_FORMAT_IFF 5 /* iff (TAAC format) <-> standard rasterfile */
34     #define RT_EXPERIMENTAL 0xffff /* Reserved for testing */
35
36     /* Sun registered ras_maptype's */
37     #define RMT_RAW 2
38     /* Sun supported ras_maptype's */
39     #define RMT_NONE 0 /* ras_maplength is expected to be 0 */
40     #define RMT_EQUAL_RGB 1 /* red[ras_maplength/3],green[],blue[] */
41
42     /*
43     * NOTES:
44     * Each line of the image is rounded out to a multiple of 16 bits.
45     * This corresponds to the rounding convention used by the memory pixrect
46     * package (/usr/include/pixrect/memvar.h) of the SunWindows system.
47     * The ras_encoding field (always set to 0 by Sun's supported software)
48     * was renamed to ras_length in release 2.0. As a result, rasterfiles
49     * of type 0 generated by the old software claim to have 0 length; for
50     * compatibility, code reading rasterfiles must be prepared to compute the
51     * true length from the width, height, and depth fields.
52     */
53
54 schorsch 3.2 #ifdef __cplusplus
55     }
56     #endif
57     #endif /* _RAD_RASTERFILE_H_ */
58
