root/Development/ray/src/px/ran2tiff.csh
Revision: 2.4
Committed: Sat Aug 25 15:39:47 2012 UTC (13 years, 2 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.3: +0 -1 lines
Removed stray "endif"
# User Rev Content
1 greg 2.1 #!/bin/csh -fe
2     # Convert Radiance animation frames to TIFF output
3     #
4     set histosiz=200
5     set pfwt=0.9
6     set outdir=""
7     set pcopts=()
8     set tfopts=()
9     if (! $#argv) set argv=(DUMMY)
10     # Process options for pcond and ra_tiff
11     while ("$argv[1]" =~ -*)
12     switch ("$argv[1]")
13     case -W:
14     shift argv
15     set pfwt=$argv[1]
16     breaksw
17     case -H:
18     shift argv
19     set histof=$argv[1]:q
20     breaksw
21     case -D:
22     shift argv
23 greg 2.2 if (! -d $argv[1]:q ) then
24     echo "Directory $argv[1] does not exist"
25     exit 1
26     endif
27 greg 2.1 set outdir=$argv[1]:q/
28     breaksw
29     case -h*:
30     case -a*:
31     case -v*:
32     case -s*:
33     case -c*:
34     case -l*:
35     set pcopts=($pcopts $argv[1])
36     breaksw
37     case -u:
38     case -d:
39     case -f:
40     set pcopts=($pcopts $argv[1-2])
41     shift argv
42     breaksw
43     case -p:
44     shift argv
45     set pcopts=($pcopts -p $argv[1-6])
46     shift argv; shift argv; shift argv; shift argv; shift argv
47     breaksw
48     case -z:
49     case -b:
50     case -w:
51     set tfopts=($tfopts $argv[1])
52     breaksw
53     case -g:
54     shift argv
55     set tfopts=($tfopts -g $argv[1])
56     breaksw
57     default:
58     echo "$0: bad option: $argv[1]"
59     exit 1
60     endsw
61     shift argv
62     end
63     if ($#argv < 2) then
64     echo Usage: "$0 [-W prev_frame_wt][-H histo][-D dir][pcond opts][ra_tiff opts] frame1 frame2 .."
65     exit 1
66     endif
67     # Get shrunken image luminances
68 greg 2.3 set vald=`mktemp -d /tmp/val.XXXXXX`
69 greg 2.1 foreach inp ($argv:q)
70     set datf="$inp:t"
71     set datf="$vald/$datf:r.dat"
72     pfilt -1 -x 128 -y 128 -p 1 $inp:q \
73     | pvalue -o -h -H -b -df \
74     | rcalc -if1 -e 'L=$1*179;cond=L-1e-7;$1=log10(L)' \
75     > $datf:q
76     end
77     # Get Min. and Max. log values
78     set Lmin=`cat $vald/*.dat | total -l | rcalc -e '$1=$1-.01'`
79     set Lmax=`cat $vald/*.dat | total -u | rcalc -e '$1=$1+.01'`
80     if ($?histof) then
81     if (-r $histof) then
82     # Fix min/max and translate histogram
83     set Lmin=`sed -n '1p' $histof | rcalc -e 'min(a,b):if(a-b,b,a);$1=min($1,'"$Lmin)"`
84     set Lmax=`sed -n '$p' $histof | rcalc -e 'max(a,b):if(a-b,a,b);$1=max($1,'"$Lmax)"`
85     tabfunc -i hfunc < $histof > $vald/oldhist.cal
86     cnt $histosiz \
87     | rcalc -e "L10=$Lmin+($Lmax-$Lmin)/$histosiz"'*($1+.5)' \
88     -f $vald/oldhist.cal -e '$1=L10;$2=hfunc(L10)' \
89     > $vald/oldhisto.dat
90     endif
91     endif
92     foreach inp ($argv:q)
93     set datf="$inp:t"
94     set datf="$vald/$datf:r.dat"
95     set outp="$inp:t"
96     set outp="$outdir$outp:r.tif"
97     histo $Lmin $Lmax $histosiz < $datf > $vald/newhisto.dat
98     if (-f $vald/oldhisto.dat) then
99     rlam $vald/newhisto.dat $vald/oldhisto.dat \
100     | rcalc -e '$1=$1;$2=$2+$4*'$pfwt \
101     > $vald/histo.dat
102     else
103     mv $vald/{new,}histo.dat
104     endif
105     pcond $pcopts -I $inp:q < $vald/histo.dat \
106     | ra_tiff $tfopts - $outp:q
107     mv $vald/{,old}histo.dat
108     end
109 greg 2.2 if ($?histof) then
110     cp -f $vald/oldhisto.dat $histof
111     endif
112 greg 2.1 rm -rf $vald
