1 |
#!/bin/csh -fe |
2 |
# Convert Radiance animation frames to TIFF output |
3 |
4 |
set histosiz=200 |
5 |
set pfwt=0.9 |
6 |
set outdir="" |
7 |
set pcopts=() |
8 |
set tfopts=() |
9 |
if (! $#argv) set argv=(DUMMY) |
10 |
# Process options for pcond and ra_tiff |
11 |
while ("$argv[1]" =~ -*) |
12 |
switch ("$argv[1]") |
13 |
case -W: |
14 |
shift argv |
15 |
set pfwt=$argv[1] |
16 |
breaksw |
17 |
case -H: |
18 |
shift argv |
19 |
set histof=$argv[1]:q |
20 |
breaksw |
21 |
case -D: |
22 |
shift argv |
23 |
if (! -d $argv[1]:q ) then |
24 |
echo "Directory $argv[1] does not exist" |
25 |
exit 1 |
26 |
endif |
27 |
set outdir=$argv[1]:q/ |
28 |
breaksw |
29 |
case -h*: |
30 |
case -a*: |
31 |
case -v*: |
32 |
case -s*: |
33 |
case -c*: |
34 |
case -l*: |
35 |
set pcopts=($pcopts $argv[1]) |
36 |
breaksw |
37 |
case -u: |
38 |
case -d: |
39 |
case -f: |
40 |
set pcopts=($pcopts $argv[1-2]) |
41 |
shift argv |
42 |
breaksw |
43 |
case -p: |
44 |
shift argv |
45 |
set pcopts=($pcopts -p $argv[1-6]) |
46 |
shift argv; shift argv; shift argv; shift argv; shift argv |
47 |
breaksw |
48 |
case -z: |
49 |
case -b: |
50 |
case -w: |
51 |
set tfopts=($tfopts $argv[1]) |
52 |
breaksw |
53 |
case -g: |
54 |
shift argv |
55 |
set tfopts=($tfopts -g $argv[1]) |
56 |
breaksw |
57 |
default: |
58 |
echo "$0: bad option: $argv[1]" |
59 |
exit 1 |
60 |
endsw |
61 |
shift argv |
62 |
end |
63 |
if ($#argv < 2) then |
64 |
echo Usage: "$0 [-W prev_frame_wt][-H histo][-D dir][pcond opts][ra_tiff opts] frame1 frame2 .." |
65 |
exit 1 |
66 |
endif |
67 |
# Get shrunken image luminances |
68 |
set vald=/tmp/val$$ |
69 |
mkdir $vald |
70 |
foreach inp ($argv:q) |
71 |
set datf="$inp:t" |
72 |
set datf="$vald/$datf:r.dat" |
73 |
pfilt -1 -x 128 -y 128 -p 1 $inp:q \ |
74 |
| pvalue -o -h -H -b -df \ |
75 |
| rcalc -if1 -e 'L=$1*179;cond=L-1e-7;$1=log10(L)' \ |
76 |
> $datf:q |
77 |
end |
78 |
# Get Min. and Max. log values |
79 |
set Lmin=`cat $vald/*.dat | total -l | rcalc -e '$1=$1-.01'` |
80 |
set Lmax=`cat $vald/*.dat | total -u | rcalc -e '$1=$1+.01'` |
81 |
if ($?histof) then |
82 |
if (-r $histof) then |
83 |
# Fix min/max and translate histogram |
84 |
set Lmin=`sed -n '1p' $histof | rcalc -e 'min(a,b):if(a-b,b,a);$1=min($1,'"$Lmin)"` |
85 |
set Lmax=`sed -n '$p' $histof | rcalc -e 'max(a,b):if(a-b,a,b);$1=max($1,'"$Lmax)"` |
86 |
tabfunc -i hfunc < $histof > $vald/oldhist.cal |
87 |
cnt $histosiz \ |
88 |
| rcalc -e "L10=$Lmin+($Lmax-$Lmin)/$histosiz"'*($1+.5)' \ |
89 |
-f $vald/oldhist.cal -e '$1=L10;$2=hfunc(L10)' \ |
90 |
> $vald/oldhisto.dat |
91 |
endif |
92 |
endif |
93 |
94 |
set datf="$inp:t" |
95 |
96 |
set outp="$inp:t" |
97 |
set outp="$outdir$outp:r.tif" |
98 |
endif |
99 |
histo $Lmin $Lmax $histosiz < $datf > $vald/newhisto.dat |
100 |
if (-f $vald/oldhisto.dat) then |
101 |
rlam $vald/newhisto.dat $vald/oldhisto.dat \ |
102 |
| rcalc -e '$1=$1;$2=$2+$4*'$pfwt \ |
103 |
> $vald/histo.dat |
104 |
else |
105 |
mv $vald/{new,}histo.dat |
106 |
endif |
107 |
pcond $pcopts -I $inp:q < $vald/histo.dat \ |
108 |
| ra_tiff $tfopts - $outp:q |
109 |
mv $vald/{,old}histo.dat |
110 |
end |
111 |
112 |
cp -f $vald/oldhisto.dat $histof |
113 |
endif |
114 |
rm -rf $vald |
