root/radiance/ray/src/px/ran2tiff.csh
Revision: 2.2
Committed: Thu Jan 24 03:52:37 2008 UTC (17 years, 4 months ago) by greg
Content type: application/x-csh
Changes since 2.1: +7 -1 lines
Minor fixes
1 #!/bin/csh -fe
2 # Convert Radiance animation frames to TIFF output
3 #
4 set histosiz=200
5 set pfwt=0.9
6 set outdir=""
7 set pcopts=()
8 set tfopts=()
9 if (! $#argv) set argv=(DUMMY)
10 # Process options for pcond and ra_tiff
11 while ("$argv[1]" =~ -*)
12 switch ("$argv[1]")
13 case -W:
14 shift argv
15 set pfwt=$argv[1]
16 breaksw
17 case -H:
18 shift argv
19 set histof=$argv[1]:q
20 breaksw
21 case -D:
22 shift argv
23 if (! -d $argv[1]:q ) then
24 echo "Directory $argv[1] does not exist"
25 exit 1
26 endif
27 set outdir=$argv[1]:q/
28 breaksw
29 case -h*:
30 case -a*:
31 case -v*:
32 case -s*:
33 case -c*:
34 case -l*:
35 set pcopts=($pcopts $argv[1])
36 breaksw
37 case -u:
38 case -d:
39 case -f:
40 set pcopts=($pcopts $argv[1-2])
41 shift argv
42 breaksw
43 case -p:
44 shift argv
45 set pcopts=($pcopts -p $argv[1-6])
46 shift argv; shift argv; shift argv; shift argv; shift argv
47 breaksw
48 case -z:
49 case -b:
50 case -w:
51 set tfopts=($tfopts $argv[1])
52 breaksw
53 case -g:
54 shift argv
55 set tfopts=($tfopts -g $argv[1])
56 breaksw
57 default:
58 echo "$0: bad option: $argv[1]"
59 exit 1
60 endsw
61 shift argv
62 end
63 if ($#argv < 2) then
64 echo Usage: "$0 [-W prev_frame_wt][-H histo][-D dir][pcond opts][ra_tiff opts] frame1 frame2 .."
65 exit 1
66 endif
67 # Get shrunken image luminances
68 set vald=/tmp/val$$
69 mkdir $vald
70 foreach inp ($argv:q)
71 set datf="$inp:t"
72 set datf="$vald/$datf:r.dat"
73 pfilt -1 -x 128 -y 128 -p 1 $inp:q \
74 | pvalue -o -h -H -b -df \
75 | rcalc -if1 -e 'L=$1*179;cond=L-1e-7;$1=log10(L)' \
76 > $datf:q
77 end
78 # Get Min. and Max. log values
79 set Lmin=`cat $vald/*.dat | total -l | rcalc -e '$1=$1-.01'`
80 set Lmax=`cat $vald/*.dat | total -u | rcalc -e '$1=$1+.01'`
81 if ($?histof) then
82 if (-r $histof) then
83 # Fix min/max and translate histogram
84 set Lmin=`sed -n '1p' $histof | rcalc -e 'min(a,b):if(a-b,b,a);$1=min($1,'"$Lmin)"`
85 set Lmax=`sed -n '$p' $histof | rcalc -e 'max(a,b):if(a-b,a,b);$1=max($1,'"$Lmax)"`
86 tabfunc -i hfunc < $histof > $vald/oldhist.cal
87 cnt $histosiz \
88 | rcalc -e "L10=$Lmin+($Lmax-$Lmin)/$histosiz"'*($1+.5)' \
89 -f $vald/oldhist.cal -e '$1=L10;$2=hfunc(L10)' \
90 > $vald/oldhisto.dat
91 endif
92 endif
93 foreach inp ($argv:q)
94 set datf="$inp:t"
95 set datf="$vald/$datf:r.dat"
96 set outp="$inp:t"
97 set outp="$outdir$outp:r.tif"
98 endif
99 histo $Lmin $Lmax $histosiz < $datf > $vald/newhisto.dat
100 if (-f $vald/oldhisto.dat) then
101 rlam $vald/newhisto.dat $vald/oldhisto.dat \
102 | rcalc -e '$1=$1;$2=$2+$4*'$pfwt \
103 > $vald/histo.dat
104 else
105 mv $vald/{new,}histo.dat
106 endif
107 pcond $pcopts -I $inp:q < $vald/histo.dat \
108 | ra_tiff $tfopts - $outp:q
109 mv $vald/{,old}histo.dat
110 end
111 if ($?histof) then
112 cp -f $vald/oldhisto.dat $histof
113 endif
114 rm -rf $vald
