root/radiance/ray/src/px/ran2tiff.csh
Revision: 2.1
Committed: Sat Sep 17 05:14:14 2005 UTC (19 years, 10 months ago) by greg
Content type: application/x-csh
1 #!/bin/csh -fe
2 # Convert Radiance animation frames to TIFF output
3 #
4 set histosiz=200
5 set pfwt=0.9
6 set outdir=""
7 set pcopts=()
8 set tfopts=()
9 if (! $#argv) set argv=(DUMMY)
10 # Process options for pcond and ra_tiff
11 while ("$argv[1]" =~ -*)
12 switch ("$argv[1]")
13 case -W:
14 shift argv
15 set pfwt=$argv[1]
16 breaksw
17 case -H:
18 shift argv
19 set histof=$argv[1]:q
20 breaksw
21 case -D:
22 shift argv
23 set outdir=$argv[1]:q/
24 breaksw
25 case -h*:
26 case -a*:
27 case -v*:
28 case -s*:
29 case -c*:
30 case -l*:
31 set pcopts=($pcopts $argv[1])
32 breaksw
33 case -u:
34 case -d:
35 case -f:
36 set pcopts=($pcopts $argv[1-2])
37 shift argv
38 breaksw
39 case -p:
40 shift argv
41 set pcopts=($pcopts -p $argv[1-6])
42 shift argv; shift argv; shift argv; shift argv; shift argv
43 breaksw
44 case -z:
45 case -b:
46 case -w:
47 set tfopts=($tfopts $argv[1])
48 breaksw
49 case -g:
50 shift argv
51 set tfopts=($tfopts -g $argv[1])
52 breaksw
53 default:
54 echo "$0: bad option: $argv[1]"
55 exit 1
56 endsw
57 shift argv
58 end
59 if ($#argv < 2) then
60 echo Usage: "$0 [-W prev_frame_wt][-H histo][-D dir][pcond opts][ra_tiff opts] frame1 frame2 .."
61 exit 1
62 endif
63 # Get shrunken image luminances
64 set vald=/tmp/val$$
65 mkdir $vald
66 foreach inp ($argv:q)
67 set datf="$inp:t"
68 set datf="$vald/$datf:r.dat"
69 pfilt -1 -x 128 -y 128 -p 1 $inp:q \
70 | pvalue -o -h -H -b -df \
71 | rcalc -if1 -e 'L=$1*179;cond=L-1e-7;$1=log10(L)' \
72 > $datf:q
73 end
74 # Get Min. and Max. log values
75 set Lmin=`cat $vald/*.dat | total -l | rcalc -e '$1=$1-.01'`
76 set Lmax=`cat $vald/*.dat | total -u | rcalc -e '$1=$1+.01'`
77 if ($?histof) then
78 if (-r $histof) then
79 # Fix min/max and translate histogram
80 set Lmin=`sed -n '1p' $histof | rcalc -e 'min(a,b):if(a-b,b,a);$1=min($1,'"$Lmin)"`
81 set Lmax=`sed -n '$p' $histof | rcalc -e 'max(a,b):if(a-b,a,b);$1=max($1,'"$Lmax)"`
82 tabfunc -i hfunc < $histof > $vald/oldhist.cal
83 cnt $histosiz \
84 | rcalc -e "L10=$Lmin+($Lmax-$Lmin)/$histosiz"'*($1+.5)' \
85 -f $vald/oldhist.cal -e '$1=L10;$2=hfunc(L10)' \
86 > $vald/oldhisto.dat
87 endif
88 endif
89 foreach inp ($argv:q)
90 set datf="$inp:t"
91 set datf="$vald/$datf:r.dat"
92 set outp="$inp:t"
93 set outp="$outdir$outp:r.tif"
94 endif
95 histo $Lmin $Lmax $histosiz < $datf > $vald/newhisto.dat
96 if (-f $vald/oldhisto.dat) then
97 rlam $vald/newhisto.dat $vald/oldhisto.dat \
98 | rcalc -e '$1=$1;$2=$2+$4*'$pfwt \
99 > $vald/histo.dat
100 else
101 mv $vald/{new,}histo.dat
102 endif
103 pcond $pcopts -I $inp:q < $vald/histo.dat \
104 | ra_tiff $tfopts - $outp:q
105 mv $vald/{,old}histo.dat
106 end
107 if ($?histof) cp -f $vald/oldhisto.dat $histof
108 rm -rf $vald
