1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Program to convert between RADIANCE RGBE and XYZE formats |
6 |
* Added white-balance adjustment 10/01 (GW). |
7 |
8 |
9 |
#include <stdio.h> |
10 |
#include <string.h> |
11 |
#include <math.h> |
12 |
#include <time.h> |
13 |
#include "color.h" |
14 |
#include "resolu.h" |
15 |
16 |
#ifdef MSDOS |
17 |
#include <fcntl.h> |
18 |
#endif |
19 |
20 |
int rgbinp = -1; /* input is RGBE? */ |
21 |
22 |
int rgbout = 0; /* output should be RGBE? */ |
23 |
24 |
RGBPRIMS inprims = STDPRIMS; /* input primaries */ |
25 |
26 |
RGBPRIMS outprims = STDPRIMS; /* output primaries */ |
27 |
28 |
double expcomp = 1.0; /* exposure compensation */ |
29 |
30 |
int doflat = -1; /* produce flat file? */ |
31 |
32 |
char *progname; |
33 |
34 |
35 |
int |
36 |
headline(s) /* process header line */ |
37 |
char *s; |
38 |
39 |
char fmt[32]; |
40 |
41 |
if (formatval(fmt, s)) { /* check if format string */ |
42 |
if (!strcmp(fmt,COLRFMT)) |
43 |
rgbinp = 1; |
44 |
else if (!strcmp(fmt,CIEFMT)) |
45 |
rgbinp = 0; |
46 |
else |
47 |
rgbinp = -2; |
48 |
return(0); /* don't echo */ |
49 |
50 |
if (isprims(s)) { /* get input primaries */ |
51 |
primsval(inprims, s); |
52 |
53 |
54 |
/* should I grok colcorr also? */ |
55 |
return(fputs(s, stdout)); |
56 |
57 |
58 |
59 |
main(argc, argv) |
60 |
int argc; |
61 |
char *argv[]; |
62 |
63 |
int i; |
64 |
#ifdef MSDOS |
65 |
extern int _fmode; |
66 |
_fmode = O_BINARY; |
67 |
setmode(fileno(stdin), O_BINARY); |
68 |
setmode(fileno(stdout), O_BINARY); |
69 |
#endif |
70 |
progname = argv[0]; |
71 |
72 |
for (i = 1; i < argc; i++) |
73 |
if (argv[i][0] == '-') |
74 |
switch (argv[i][1]) { |
75 |
case 'c': /* rle-compressed output */ |
76 |
doflat = 0; |
77 |
break; |
78 |
case 'u': /* flat output */ |
79 |
doflat = 1; |
80 |
break; |
81 |
case 'r': /* RGBE output */ |
82 |
rgbout = 1; |
83 |
break; |
84 |
case 'p': /* RGB primaries */ |
85 |
if (i+8 >= argc) |
86 |
goto userr; |
87 |
outprims[RED][CIEX] = atof(argv[++i]); |
88 |
outprims[RED][CIEY] = atof(argv[++i]); |
89 |
outprims[GRN][CIEX] = atof(argv[++i]); |
90 |
outprims[GRN][CIEY] = atof(argv[++i]); |
91 |
outprims[BLU][CIEX] = atof(argv[++i]); |
92 |
outprims[BLU][CIEY] = atof(argv[++i]); |
93 |
outprims[WHT][CIEX] = atof(argv[++i]); |
94 |
outprims[WHT][CIEY] = atof(argv[++i]); |
95 |
break; |
96 |
case 'e': /* exposure compensation */ |
97 |
expcomp = atof(argv[++i]); |
98 |
if (argv[i][0] == '+' || argv[i][0] == '-') |
99 |
expcomp = pow(2., expcomp); |
100 |
break; |
101 |
default: |
102 |
goto userr; |
103 |
104 |
else |
105 |
break; |
106 |
107 |
if (doflat < 0) |
108 |
doflat = !rgbout; |
109 |
if (i < argc-2) |
110 |
goto userr; |
111 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
112 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
113 |
progname, argv[i]); |
114 |
exit(1); |
115 |
116 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
117 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
118 |
progname, argv[i+1]); |
119 |
exit(1); |
120 |
121 |
getheader(stdin, headline, NULL); |
122 |
if (rgbinp == -2) |
123 |
quiterr("unrecognized input file format"); |
124 |
if (rgbinp == -1) |
125 |
rgbinp = !rgbout; |
126 |
printargs(argc, argv, stdout); /* add to header */ |
127 |
convert(); /* convert picture */ |
128 |
exit(0); |
129 |
userr: |
130 |
fprintf(stderr, "Usage: %s [-r][-e exp][-c|-u]", progname); |
131 |
fprintf(stderr, "[-p rx ry gx gy bx by wx wy] [input [output]]\n"); |
132 |
exit(1); |
133 |
134 |
135 |
136 |
quiterr(err) /* print message and exit */ |
137 |
char *err; |
138 |
139 |
if (err != NULL) { |
140 |
fprintf(stderr, "%s: %s\n", progname, err); |
141 |
exit(1); |
142 |
143 |
exit(0); |
144 |
145 |
146 |
147 |
convert() /* convert to XYZE or RGBE picture */ |
148 |
149 |
int order; |
150 |
int xmax, ymax; |
151 |
COLORMAT xfm; |
152 |
register COLOR *scanin; |
153 |
register COLR *scanout; |
154 |
double ourexp = expcomp; |
155 |
int y; |
156 |
register int x; |
157 |
/* compute transform */ |
158 |
if (rgbout) { |
159 |
if (rgbinp) { /* RGBE -> RGBE */ |
160 |
comprgb2rgbWBmat(xfm, inprims, outprims); |
161 |
} else { /* XYZE -> RGBE */ |
162 |
compxyz2rgbWBmat(xfm, outprims); |
163 |
ourexp *= WHTEFFICACY; |
164 |
165 |
} else { |
166 |
if (rgbinp) { /* RGBE -> XYZE */ |
167 |
comprgb2xyzWBmat(xfm, inprims); |
168 |
ourexp /= WHTEFFICACY; |
169 |
} else { /* XYZE -> XYZE */ |
170 |
for (y = 0; y < 3; y++) |
171 |
for (x = 0; x < 3; x++) |
172 |
xfm[y][x] = x==y ? 1. : 0.; |
173 |
174 |
175 |
176 |
177 |
xfm[y][x] *= expcomp; |
178 |
/* get input resolution */ |
179 |
if ((order = fgetresolu(&xmax, &ymax, stdin)) < 0) |
180 |
quiterr("bad picture format"); |
181 |
/* complete output header */ |
182 |
if (ourexp < 0.99 || ourexp > 1.01) |
183 |
fputexpos(ourexp, stdout); |
184 |
if (rgbout) { |
185 |
fputprims(outprims, stdout); |
186 |
fputformat(COLRFMT, stdout); |
187 |
} else |
188 |
fputformat(CIEFMT, stdout); |
189 |
putc('\n', stdout); |
190 |
fputresolu(order, xmax, ymax, stdout); |
191 |
/* allocate scanline */ |
192 |
scanin = (COLOR *)malloc(xmax*sizeof(COLOR)); |
193 |
if (scanin == NULL) |
194 |
quiterr("out of memory in convert"); |
195 |
scanout = doflat ? (COLR *)malloc(xmax*sizeof(COLR)) : NULL; |
196 |
/* convert image */ |
197 |
for (y = 0; y < ymax; y++) { |
198 |
if (freadscan(scanin, xmax, stdin) < 0) |
199 |
quiterr("error reading input picture"); |
200 |
for (x = 0; x < xmax; x++) { |
201 |
colortrans(scanin[x], xfm, scanin[x]); |
202 |
if (rgbout) |
203 |
clipgamut(scanin[x], bright(scanin[x]), |
204 |
CGAMUT_LOWER, cblack, cwhite); |
205 |
206 |
if (scanout != NULL) { |
207 |
for (x = 0; x < xmax; x++) |
208 |
setcolr(scanout[x], colval(scanin[x],RED), |
209 |
colval(scanin[x],GRN), |
210 |
colval(scanin[x],BLU)); |
211 |
fwrite((char *)scanout, sizeof(COLR), xmax, stdout); |
212 |
} else |
213 |
fwritescan(scanin, xmax, stdout); |
214 |
if (ferror(stdout)) |
215 |
quiterr("error writing output picture"); |
216 |
217 |
/* free scanline */ |
218 |
free((void *)scanin); |
219 |
if (scanout != NULL) |
220 |
free((void *)scanout); |
221 |
