root/radiance/ray/src/px/ra_xyze.c
Revision: 2.14
Committed: Tue Oct 1 01:16:26 2024 UTC (10 months, 1 week ago) by greg
Changes since 2.13: +60 -26 lines
feat(ra_xyze): added accurate conversion of hyperspectral pictures on input
2 static const char RCSid[] = "$Id: ra_xyze.c,v 2.13 2019/12/28 18:05:14 greg Exp $";
5 * Program to convert between RADIANCE RGBE and XYZE formats
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include <math.h>
10
11 #include "platform.h"
12 #include "color.h"
13 #include "resolu.h"
14 #include "rtio.h"
15
16 enum {InpUNK, InpRGB, InpXYZ, InpSPEC}; /* input format */
17 int infmt = InpUNK;
18 int rgbout = 0; /* output should be RGBE? */
19 RGBPRIMS inprims = STDPRIMS; /* input primaries */
20 RGBPRIMS outprims = STDPRIMS; /* output primaries */
21 double expcomp = 1.0; /* exposure compensation */
22 int doflat = -1; /* produce flat file? */
23 double origexp = -1.0; /* original exposure */
24 char *progname;
25
26 static gethfunc headline;
27 static void quiterr(char *err);
28 static void myreadscan(COLOR *scn, int len);
29 static void convert(void);
30
31
32
33 static int
34 headline( /* process header line */
35 char *s,
36 void *p
37 )
38 {
39 char fmt[MAXFMTLEN];
40
41 if (formatval(fmt, s)) { /* check if format string */
42 if (!strcmp(fmt,COLRFMT))
43 infmt = InpRGB;
44 else if (!strcmp(fmt,CIEFMT))
45 infmt = InpXYZ;
46 else if (!strcmp(fmt,SPECFMT))
47 infmt = InpSPEC;
48 else
49 infmt = InpUNK;
50 return(0); /* don't echo */
51 }
52 if (origexp > 0.0 && isexpos(s)) {
53 origexp *= exposval(s);
54 return(0); /* don't echo */
55 }
56 if (isprims(s)) { /* get input primaries */
57 primsval(inprims, s);
58 return(0); /* don't echo */
59 }
60 if (iswlsplit(s)) { /* get wavelength limits */
61 wlsplitval(WLPART, s);
62 return(0); /* don't echo */
63 }
64 if (isncomp(s)) { /* number of color samples */
65 NCSAMP = ncompval(s);
66 return(0); /* don't echo */
67 }
68 /* should I grok colcorr also? */
69 return(fputs(s, stdout));
70 }
71
72
73 int
74 main(int argc, char *argv[])
75 {
76 int i;
77 SET_DEFAULT_BINARY();
78 SET_FILE_BINARY(stdin);
79 SET_FILE_BINARY(stdout);
80 progname = argv[0];
81
82 for (i = 1; i < argc; i++)
83 if (argv[i][0] == '-')
84 switch (argv[i][1]) {
85 case 'c': /* rle-compressed output */
86 doflat = 0;
87 break;
88 case 'u': /* flat output */
89 doflat = 1;
90 break;
91 case 'r': /* RGBE output */
92 rgbout = 1;
93 break;
94 case 'p': /* RGB primaries */
95 if (i+8 >= argc)
96 goto userr;
97 outprims[RED][CIEX] = atof(argv[++i]);
98 outprims[RED][CIEY] = atof(argv[++i]);
99 outprims[GRN][CIEX] = atof(argv[++i]);
100 outprims[GRN][CIEY] = atof(argv[++i]);
101 outprims[BLU][CIEX] = atof(argv[++i]);
102 outprims[BLU][CIEY] = atof(argv[++i]);
103 outprims[WHT][CIEX] = atof(argv[++i]);
104 outprims[WHT][CIEY] = atof(argv[++i]);
105 break;
106 case 'o': /* original exposure */
107 origexp = 1.0;
108 break;
109 case 'e': /* exposure compensation */
110 expcomp = atof(argv[++i]);
111 if (argv[i][0] == '+' || argv[i][0] == '-')
112 expcomp = pow(2., expcomp);
113 break;
114 default:
115 goto userr;
116 }
117 else
118 break;
119
120 if (doflat < 0)
121 doflat = !rgbout;
122 if (i < argc-2)
123 goto userr;
124 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
125 fprintf(stderr, "%s: can't open input \"%s\"\n",
126 progname, argv[i]);
127 exit(1);
128 }
129 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
130 fprintf(stderr, "%s: can't open output \"%s\"\n",
131 progname, argv[i+1]);
132 exit(1);
133 }
134 getheader(stdin, headline, NULL);
135 if (infmt == InpUNK)
136 quiterr("unrecognized/missing input file format");
137 printargs(argc, argv, stdout); /* add to header */
138 convert(); /* convert picture */
139 exit(0);
140 userr:
141 fprintf(stderr, "Usage: %s [-r][-o][-e exp][-c|-u]", progname);
142 fprintf(stderr, "[-p rx ry gx gy bx by wx wy] [input [output]]\n");
143 exit(1);
144 }
145
146
147 static void
148 quiterr( /* print message and exit */
149 char *err
150 )
151 {
152 if (err != NULL) {
153 fprintf(stderr, "%s: %s\n", progname, err);
154 exit(1);
155 }
156 exit(0);
157 }
158
159
160 static void
161 myreadscan(COLOR *scn, int len)
162 {
163 if (infmt == InpSPEC) { /* read & convert to XYZ */
164 SCOLR sclr;
165 SCOLOR scol;
166 while (len-- > 0) {
167 if (getbinary(sclr, LSCOLR, 1, stdin) != 1)
168 goto readerr;
169 scolr_scolor(scol, sclr);
170 scolor_cie(*scn++, scol);
171 }
172 return;
173 } /* else read as RGBE/XYZE */
174 if (freadscan(scn, len, stdin) >= 0)
175 return;
176 readerr:
177 quiterr("error reading input picture");
178 }
179
180
181 static void
182 convert(void) /* convert to XYZE or RGBE picture */
183 {
184 int order;
185 int xmax, ymax;
186 COLORMAT xfm;
187 COLOR *scanin;
188 COLR *scanout;
189 double exp2do = expcomp;
190 double exp2report = expcomp;
191 int y;
192 int x;
193 /* recover original? */
194 if (origexp > 0.0)
195 exp2do /= origexp;
196 /* compute transform */
197 if (rgbout) {
198 if (infmt == InpRGB) { /* RGBE -> RGBE */
199 comprgb2rgbWBmat(xfm, inprims, outprims);
200 } else { /* XYZE/Spectral -> RGBE */
201 compxyz2rgbWBmat(xfm, outprims);
202 }
203 if (infmt == InpXYZ) {
204 if (origexp > 0.0)
205 exp2do /= WHTEFFICACY;
206 else
207 exp2report *= WHTEFFICACY;
208 }
209 } else {
210 if (infmt == InpRGB) { /* RGBE -> XYZE */
211 comprgb2xyzWBmat(xfm, inprims);
212 } else { /* XYZE/Spectral -> XYZE */
213 memset(xfm, 0, sizeof(xfm));
214 for (x = 3; x--; )
215 xfm[x][x] = 1.;
216 }
217 if (infmt != InpXYZ) {
218 if (origexp > 0)
219 exp2do *= WHTEFFICACY;
220 else
221 exp2report /= WHTEFFICACY;
222 }
223 }
224 for (y = 0; y < 3; y++)
225 for (x = 0; x < 3; x++)
226 xfm[y][x] *= exp2do;
227 /* get input resolution */
228 if ((order = fgetresolu(&xmax, &ymax, stdin)) < 0)
229 quiterr("bad picture format");
230 /* complete output header */
231 if ((exp2report < 0.99) | (exp2report > 1.01))
232 fputexpos(exp2report, stdout);
233 if (rgbout) {
234 fputprims(outprims, stdout);
235 fputformat(COLRFMT, stdout);
236 } else
237 fputformat(CIEFMT, stdout);
238 putc('\n', stdout);
239 fputresolu(order, xmax, ymax, stdout);
240 /* allocate scanline */
241 scanin = (COLOR *)malloc(xmax*sizeof(COLOR));
242 if (scanin == NULL)
243 quiterr("out of memory in convert");
244 scanout = doflat ? (COLR *)malloc(xmax*sizeof(COLR)) : (COLR *)NULL;
245 /* convert image */
246 for (y = 0; y < ymax; y++) {
247 myreadscan(scanin, xmax);
248 for (x = 0; x < xmax; x++) {
249 colortrans(scanin[x], xfm, scanin[x]);
250 if (rgbout)
251 clipgamut(scanin[x], bright(scanin[x]),
252 CGAMUT_LOWER, cblack, cwhite);
253 }
254 if (scanout != NULL) {
255 for (x = 0; x < xmax; x++)
256 setcolr(scanout[x], colval(scanin[x],RED),
257 colval(scanin[x],GRN),
258 colval(scanin[x],BLU));
259 putbinary(scanout, sizeof(COLR), xmax, stdout);
260 } else
261 fwritescan(scanin, xmax, stdout);
262 if (ferror(stdout))
263 quiterr("error writing output picture");
264 }
265 /* free scanline */
266 free(scanin);
267 if (scanout != NULL)
268 free(scanout);
269 }
